Spra-Coupe Sprayer System 7450 7650 Parts Catalog WR136107
Brand: Spra-Coupe
Type of Machine: Sprayer System
Model:
Spra-Coupe 7450 Sprayer System
Spra-Coupe 7650 Sprayer System
Part Number: WR136107
Number of Pages: 901 Pages
Publication Information
Product Containment
Tank And Saddle Assembly-660 Gallon Ss
Tank Assembly-660 Gallon,Ss
Tank-660 Gallon,Ss
Assembly 10in Lid
Kit Gasket 10in
Valve-Stubby, 2.00 Npt Port, Malexfemale
Assembly Strap 360 Gallon 38inx75in Rnd
Tank Strap W Strap Bolts
Tiedown Install
Tank Install-Rinse,65 Gallon
Tank Assembly-Rinse,65 Gallon
Tank-Poly,65 Gallon,Right Hand
Valve-Ball, 0.50 Npt Union, Poly
Tiedown Install-725 Gallon Poly
Tank Assembly-Poly,725 Gallon
Flange-Tank,Bottom Drain,2.00
Cover-Hinged
Primary Product Distribution
Plumbing Install-System,Liquid,660 Gal Ss Tank
Plumbing Assembly-Pump And Reload,1.50x1.25
Pump-Centrifugal,1.50x1.25,9303chm1
Valve-Ball, 1.00 Npt Union, Poly
Valve-Stubby, 2.00fp,Mnptxfnpt
Plumbing Assembly-Pressure Manifold,660 Gal Ss
Valve-Ball,1.00fp Flgxnpt,Electric
Actuator-000-60-M-9
Manifold Assembly-Str Rinse Valve,1.50
Plumbing Install-Press,660 Gallon Ss
Valve Assembly-Low Rate Kit
Valve Assembly-Regulating,Pressure
Valve-Ball, 1.50, Poly, Ff
Flowmeter-2.00sp Flange,Rfm60,12v
Tube Install-Hydraulic,Prod Pump
Strainer-Y,2.0sp,Flg,W 30 Mesh
Reload Install-2.00
Valve 2 In Mnpt X 2 In Madap
Reload Install-3.00
Valve-3.00fnptx3.00m Adapter
Flowmeter-2.00sp Flange,Rfm60p,12v
Valve-2.0flgx1.50npt,T Handle
Valve-2.0flgx1.25npt,T Handle
Bracket Assembly-Drop Hose,Foam Marker,Rh
Bracket Assembly-Drop Hose,Foam Marker,Lh
Strainer-Line,1.50fnpt,32 Mesh
Strainer Body Assembly 1.00
Option-Chemical Eductor,Ss,660 Gallon
Plumbing Assembly-Eductor,Ss
Eductor Assembly-Chemical,Cleanload,Pe
Eductor-Chemical,Cleanload,Pe
Plumbing Assembly-Return,Eductor
Option-Chemical Eductor,W O
Option-Chemical Eductor,Ss,725 Gal Poly
Plumbing Install-System,Liquid,725 Gal Poly
Plumbing Assembly-Pressure Manifold,725 Gal Poly
Plumbing Install-Pressure,725 Gallon
Valve Assembly-Low Rate,Poly
Secondary Product Distribution
Option-Poly Plumbing,Sc6080x80x5x20,Off
Bracket Assembly-L,Poly Stauff
Bracket Assembly-Str,Sh,Ips
Pipe Assembly-X W 3 1.00hb,6x20,Poly
System Install-Plumbing,Sc60180x5,Electric
Manifold Assembly-Y,1.00fp Flange,Electric
Bracket Assembly-Str,Sh,So,Ips
Bracket Assembly-L,So,Stauff,Rev
Bracket Assembly-Str,Lg,3ips
Bracket Assembly-L,Poly Stauff,Rev
Pipe Assembly-90d W 1.00hb,5x20,Poly
Pipe Assembly-T W 2 1.00hb,5x20,Poly
Pipe Assembly-T W 2 1.00hb,3x20,Poly
Bracket Assembly-L Lg Str,Pp Pipe Clp
Bracket Assembly-Str,Lg,2ips
Bracket Assembly-Str,Lg,So,2ips
Bracket Assembly-L,Poly Stauff,Ctr
Pipe Assembly-90d W 1.00hb,6x20,Poly
Pipe Assembly-90d W 1.00hb,3x20,Poly
Bracket Assembly-Str,Lg,2ips Clp,1.00u
Bracket Assembly-L,Poly Stauff,1.00u
Bracket Assembly-Str,Sh,Ips Clp,1.00u
Option-Nozzle,Varitaret,Clr,80x20
Kit-Nozzle,Varitarget,Clr,25
Nozzle-Spray,Varitarget,1.2gpm
Option-Nozzle,Varitarget,Clr,90x20
Kit-Nozzle,Spray,Varitarget,Clr,5
Nozzle Assembly-Option 20x90 Triple
Nozzle Holder-Triple 1.00 Ips
Option-Nozzle,Varitarget,90x20
Kit-Nozzle,Spray,Varitarget,5
Nozzle-Spray,Varitarget,1.5gpm
Option-Nozzle,Varitarget,80x20
Harness Install-Electrical Boom Section Valve
Manifold Assembly-Boom,W Ball Valve,Std
Cap Install-W O H Frame
Cap Install-H Frame W O Boom
Nozzle Assembly-Fence Row 60 80 Boom
Valve-Solenoid,Nozzle Body,Arag,150psi
Parts-Service,Nozzle Valve
Nozzle Assembly-Option,20x80,Triple
Booms
Option-Hinge,Boom,60 80ft
Hinge Assembly-60 80,Right Hand
Cylinder-Hydraulic,2.25x1.00x6.5
Hinge Assembly-60 80,Left Hand
Hose Install-Boom Tilt, 60 80
Option-Boom,90ft
Boom Assembly-60 90, Left Hand
Boom Assembly-60 90,Left Hand Right Hand
Cam Assembly-Breakaway,60 80
Cam Assembly-Boom Breakaway
Boom Assembly-60 90, Right Hand
Hose Install-Boom Tip, 60 80
Cylinder Assembly- Boom Tip Fold
Cylinder-Hydraulic,2.00x16.00x1.25
Block Install-Boomrest
Block Assembly-Boom Rest, 7xxx
Manifold Install-Ball Valve,Std
Lift Install-Boom,Par Link
Cylinder-Hydraulic,1.75x16.84x1.25
Rack Install-Tilt,Boom,60 80
Rack Assembly-Tilt,Boom,60 80
Tube Assembly-Rack Tilt
Frame Install-H,Rear,Boom,60 80
Frame Assembly-H,Rear,Boom,60 80
Cylinder Assembly-Hydraulic,Boom Swing, 60 80
Cylinder-Hydraulic,2.75x11x1.38
Frame Install-H,W O Tilt Rack
Frame Assembly-H,Rear,B00m,60 80
Option-Boom 60 80
Boom Assembly-60 80,Left Hand
Boom Assembly-60 80,Right Hand
Boom Assembly-60 80
Hose Install-Boom Tip 60 80
Foam Marker
Foam Marker Install-Tank Pump,25gl
Tank Pump Assembly-Fm,25gl,Richway
Parts-Service,Foam Marker
Manifold Assembly W Actuators
Airline Install-Foam Marker
Foam Marker Install-Boom Parts
Bracket Assembly-Mounting,Fm Mixing Chamber
Chamber-Mixing,Foam Marker,Richway
Hose Install-Hydraulic,Boom Lift,Par Link
Accumulator Install-Par Links
Valve Install-Hydraulic,Boom,6 Bank
Valve-Hydraulic,Boom,6 Bank
Valve-Check,Cv08200n25
Tube Install-Hydraulic, H Frame
Hose Install-Hydraulic, H Frame
Electrical Install-System,Raven 4000
Electrical Install-Boom
Module Assembly-I O,Can
Lamp Cluster Rear Right Hand
Lamp Cluster Rear Left Hand
Lamp-Work,Oval,Trap Lens
Light Install-Tail
Harness Install-Taillight
Light Install-Tail,W O Tilt Rack
End Row Switch Install
Panel Assembly-Switch,Console
Option-Work Lights Boom
Light Install-Work,Cab,Mini
Harness Install-Tllt,Nowl
Decal Install-660 Gallon Ss
Decal-Install 725 Gallon Poly
Decal Install-2498 Liter Ss
