Spra-Coupe Sprayer Chassis 7460 7660 Parts Catalog 531461D1
Brand: Spra-Coupe
Type of Machine: Sprayer Chassis
Model:
Spra-Coupe 7460 Sprayer Chassis
Spra-Coupe 7660 Sprayer Chassis
Part Number: 531461D1
Number of Pages: 4776 Pages
Publication Information
Engine, Fuel, And Exhaust System
Engine Install
Engine-Perkins 1106d,174hp
Alternator Mounting Assembly
Timing Cover Assembly
Timing Case
Auxiliaries Miscellaneous
Engine Control Module Assembly
Sensors Assembly
Cylinder Block And Liners Assembly
Rear Oil Seal Assembly
Crankshaft Main And Big Bearing
Pistons And Rings Assembly
Connecting Rods Assembly
Cylinder Head Assembly
Rocker Shaft Assembly
Timing Gear Chamshaft Assembly
High Pressure Fuel Pump Assembly
Fuel Rail Assembly
High Pressure Fuel Pipes Assembly
Pipework Assembly
Fan Drive Assembly
Cylinder Head Cover Base Assembly
Breather Assembly
Blanking Plates Assembly
Oil Cooler Assembly
Oil Filter
Front Drive Output
Water Pump Assembly
Pipes Assembly
Water Outlet Housing Assembly
Timing Case Assembly
Oil Pump Delivery Housing Assembly
Turbocharger Assembly
Pipework Connections Assembly
Induction Manifold Assembly
Pipework Connection Assembly
Heater Plugs Assembly
Engine Lifting Eyes Assembly
Oil Sump Drain Pump Assembly
Oil Pressure Switch Gauge Assembly
Wiring Looms Assembly
Water Trap Assembly
Atomisers
Flywheel Housing
Ring Flywheel And Starter
Sump
Tube Dipstick And Filler
Oil Strainer
Cover Cylinder Head
Blanking Plates
Drive Input Front End
Feed Pipes
Pipes Leak-Off
Exhaust Manifold
Wastegate Sensor
Pipes Low Pressure Fuel
Pipe Fuel Leak-Off
Filter Fuel
Compressor-A C,R134a,2 Groove
Pump-Assembly,Hydraulic,Chassis
Pump-Hydraulic,Gear,2.75 Cid
Adapter Straight 0.75mo-R X 1.00mjic
Adapter Straight .50mo-R X 0.50 Mjic
Cooling Package
Cooling Package,Tier 3
Elbow 90d -12mjic X -12mstor
Switch Assembly-A C,High Pressure
Tank-Dearation
Fan Guard Install
Air Intake
Air Filter Assembly,12.00in
Exhaust System
Line Lubrication Oil Assembly
M16 Mstor X 08hb
M12 Mstor X 08hb
Fuel Tank, Lock
Cap Install-Fuel.Lockable
Shaft, Output Planet
Shaft, Output Assembly
Axle-Front,88in-120in
Hub Spindle-10 Stud,11.25 B.C.
Axle-Front,120in
Axle-Front, Narrow Track
Axle-Assembly.Low Speed,17.8 1
Carrier-Assembly,2.92 1
Assembly Center Axle
Carrier Assembly
Chaincase-Assembly,Rh,1.18 1
Brake Group
Assembly, Service Brake Disc
Parking Brake, Assembly Left Hand
Kit, Lining
Kit, Seal
Kit, Hydraulic
Kit, Hardware
Kit, Repair
Brake, Assembly Right Hand
Chaincase-Assembly,Lh,1.18 1
Axle,Rear,Spring,71in
Axle-Rear,Spring,71in
Hydraulic-Install,Rear Axle,71 Spring
Cylinder-Install,Rear Axle,71
Adapter Straight 0.37mo-R X 0.37mjic
Cylinder-Hydraulic,725 Rear Trk Nrw
Hose-Install,Rear Axle,71
Hose-Kit,Rear Axle,71
Bolt Assembly-Eye
Drive Shaft W U Joint Caps,Narrow
Axle,Rear,Hydraulic,71in
Axle-Rear,Hydraulic,71in
Hydraulic-Install,Rear Axle,71 Hydraulic
Hydraulic-Install, Hydraulic Suspension
Hydraulic Suspension Assembly
Cylinder-Single Acting,3x12.00in
Xle,Rear,Spring,88in
Rear,Spring,88in
Hydraulic-Install,Rear Axle,88 Spring
Hose-Kit,Rear Axle,88
Cylinder-Install,Rear Axle,88
Cylinder-Hydraulic,Track Adjust
Hose-Install,Rear Axle,88
Driveshaft-W Caps,88in-128in
Option-Axle,Rear,Hydraulic,88in
Rear,Hydraulic,88in
Hydraulic-Install,Rear Axle,88 Hydraulic
Axle,Rear,Spring,120in
Axle-Install,Rear,120
Hydraulic-Install,Rear Axle,120 Spring
Cylinder-Install,Rear Axle,120
Hose-Install,Rear Axle,120
Hose-Kit,Rear Axle,120
Driveshaft-W Caps,120in
Axle,Rear,Hydraulic,120in
Axle-Rear,120in,Hydraulic
Hydraulic-Install,Rear Axle,120 Hydraulic
Frame And Suspension
Assembly-Frame
Standard Steering Orbitrol
Steering Unit Install
Steering Unit Assembly
Steer Unit-Ospq,125 250
Hose-Install,Non Autoguide
Install,Assist-Steer Components
Assembly,Steering-Unit,Assist
Assisted Steer Ready
Hose-Install,Autoguide
Kit-Hose,Autoguide
Steering Column Cover Assembly
Steering Column And Covers
Steering Column
Tcu-Install, 6 Speed
Tcu-Install,4 Speed
Transmission-Install
Transmission-Powershift,6 Speed 1.94tc
Input Shaft Assembly
Valve-Clutch 1
Valve, Forward Hi-Lo
Valve-Clutch
Cartridge, Relief
Driveshaft-6c Telescoping
Adapter Straight 1.00mo-R X 0.75mjic
Counter Shaft Assembly
Main Shaft Assembly
Reverse Idler Shaft Assembly
Valve Install-Park Brake
Valve Assembly-Park Brake
Valve-Park Brake
Pedal Assembly-Park Brake
Valve Assembly,Park Brake
Valve Assembly-Solenoid,3-Way
Valve-Solenoid, 3-Way
Cylinder-Hydraulic,6.50in Stroke
2 Wheel Drive-Hydraulic Tank Install
2 Wheel Drive-Hydraulic Tank Assembly
Tee-Run,Steerthd -6
Plug 0.75mo-R Hex
Tank-Hydraulic
2-Wheel Drive Cover Install
Piston Assembly Bbc02
Distributor Assembly Bbc02
Housing Assembly Rear Bbc02
Cylinder Block Assembly Bbc02
Wheel Motor Group
Wheel Motor-Hydraulic,940 470cc
Plug 0.37mo-R Hex
Cylinder-Install,Front Axle,120
Cylinder-Assembly,Steering,7000
Cylinder-Steering,7000,9.59 Stroke
Cylinder-Install,Front Axle,88
Install-2 Wheel Drive
Fwa,Hose Install,120
Flange Split Kit Code 61-32
Hose Support Install,120
Fwa,Hose Install,88
Wheel Motor,Hose Install,120
Adapter-12orfs X -12mor 90deg
Wheel Motor,Hose Install,88
Fwa Hydraulic Group,Narrow
Fwa,Hydraulic Tank Install
Fwa-Hydraulic Tank Assembly
Fwa,Component Install
Filter Assembly-Fwa,R3
Hose Support Install,71
Wheel Motor,Hose Install,71
Fwa,Hose Install,71
Fwa-Pump Assembly
Pump-Hydraulic,51cc,Load Sense
Control Kit, Load Sensing
Fwa-2 Speed Case Bypass Assembly
Filter Assembly-Fwa,R2
Filter-Hydraulic,W 25psi By-Pass
Valve Assembly-Fwa,Main
Valve-Control,F.W.A. S D
Hose-Install,Front Axle,88
Hose-Install,Front Axle,120
Hose-Install,Front Axle,71
Cylinder-Install,Front Axle,71
Cylinder-Hydraulic,Track Adjust,Narrow
Hose-Support,Steering
Hydraulic Chassis Group,Domestic
Component Install-Chassis
Fitting Install-Product Boom Valve
Valve-Product Boom Priority
Valve, Compensator
Poppet
Valve, Relief
Valve, Priority
Fitting Install-Brake Charge Valve
Valve-Brake Charge
Retainer, Filter
Unloader, Pilot
Valve-Cartridge,Check-08
Filter-Assembly,Chassis
Chassis-Hose Assembly Install
Kit-Hose,Chassis
Valve Install-Hydraulic,Boom Lift Track Adjust
Valve Assembly-Hydraulic,Boom Lift Track Adjust
Valve-Hydraulic,Boom Lft Trk Adjust,3 Bank
Adapter Straight .37morx.37mjic Long
Valve Install-Smartrax,7x60
Kit-Chassis,Smartrax,7x60
Valve Assembly-Hydraulic,Smartrax
Hydraulic Chassis Non Domestic
Adapter-Straight,.50mo-R X .50mo-R
Cylinder Assembly-Hydraulic,Boom Rack
Cylinder-Hydraulic,1 X 3 X .50
Hose Support Install,88
Actuator-000-60-M-9
Harness-Install,Fwa
Control Panel Hvac Non Atc
Electric Install,2wd
Key,Cam Assembly
Lamp-Warning,Amber
Electric Install-Beacon,Amber,7x50
Kit-Radio,Xm
Kit-Radio,Sirius
Kit-Radio,Am Fm Stereo W Cd
Radio,Deluxe
Switch-Install,Autoguide
Panel Assembly-Fnr,Console
Control Assembly-Fnr
Kit-Spring
Face Plate Assembly
Lever And Control Head W O Face Panel
Handle And Joint
Handle-Multifuntion
Module-Handle
Harness Install-Right Hand Console
Panel Assembly-Switch,Console
Harness Install-Center Console
Panel Install-Instrument Cluster
Panel Assembly-Instrument Cluster
Cab Electrical
Lighter
Electric Inner Roof Standard Hvac
Electric Inner Roof W Atc
Electric Install-Cab,7x50
Electric Install-Jumper,Standard Hvac
Electric Install-Cab,Atc,7x60
Electric Install-Jumper,Atc Hvac
Electric Install-Cab,7x60,Euro
Electric Install-Cab,Atc,7x60,Euro
Electric Autoguide
Electric Install,7x60,Domestic
Electric Install-Radar Product Control
Assembly-I O,High Current,Rear
Battery-Install,7x60
Assembly-Magnetic Switch Breaker,80 Amp
Battery Cable-Install,7x60
Install-Master Module,Sc7x60,Domestic
Harness-Install,Chassis,7x60
Valve-Ball,1.00fp Flangexnpt,Electric
Module Assembly-I O,Can
Headlight-Halogen,Wrapping,Left Hand
Headlight-Halogen,Wrapping,Right Hand
Electric Group-Install,7x60,Euro
Install-Electric,Backup Alarm,7x50
Harness-Backup,7x50
Install-Master Module,7x60,Euro
Harness-Install,Chassis,7x60,Euro
Kit-Field,No Power Down
Light Install-Work,Boom Rest
Light-Work,Hid,Pendent Mount
Boom Rest Install-Domestic
Light-Work,Dual Beam,Pendent Mount
Harness Install-No Worklight
F A Light Install-Work,Cab,Mini
Work Light
Light,Work,Cab,Mini
Light-Work,Hid
Light Install-Hid, Boom Rest
Lightbar Install
Kit-Lightbar,Rgl600
Light Install-Hid,Cab,Mini
Tuv Lighting
Headlight Assembly-Wiring,Left Hand
Headlight-Left,Hella
Headlight Assembly-Wiring, Right Hand
Headlight-Right,Hella
Lamp-Rotating,Amber
Seat Install-Deluxe
Seat Deluxe
Kit-Suspension Semi Active
Kit-Suspension
Kit-Air Spring
Kit-Seat Top, Sst
Kit-Recliner Assembly
Kit-Pan Back W Lumbar
Kit-Lumbar,Sst
Kit-Cushion,Seat,Sst
Kit-Back,Upper
Assembly Spring Isolater
New
Seat Install-Basic
Seat Assembly-Basic, Air
Kit-Suspension,Air,Low Profile
Kit-Service,Slides
Install-Bracket,Roof,Ag2 Topdock
Cab 7x60,Standard Hvac,Ch
Cab Assembly-Challenger,Standard Hvac
Insulation Install
Floormat Install-Cab
Firewall Install
Support Assembly-Hood,Rear
Storage Install
Cab-Midsize,Challenger,Standard Hvac
Door Installation
Wiper Assembly 2011
Bottle
Wiper Motor,1 Inch Shaft,Left Hand,85
Kit-Wiper Motor
Kit Hardware Wj3
Wiper Blade Assembly
Floormats Covers
Controls
Inner Roof
Interior Trim
Cab Glass
Roof Assembly-Outer
Audio Standard Hvac
Antenna
Radio Accessory Kit
Standard Hvac Group
Hvac Unit W O Atc
Gaskets Kit
Pedal Install-Brake Throttle
Pedal-Throttle
Pedal Assembly,Service Brake
Console Install-Seat,Right Hand,Na
Console Assembly-Seat,Right Hand,Na
Panel Assembly-Fnr,Console,Na
Console-Armrest,Right Hand
Cab 7x60,Atc,Ch
Cab Assembly-Challenger,Atc
Cab-Midsize,Challenger,With Atc
Audio W Atc Hvac
Hvac Group With Atc
2011
Cover-Assembly
Cab 7x60,Euro,Standard Hvac,Ch
Cab Assembly-Challenger,Euro,Standard Hvac
Roof Electric Assembly
Controls Front Assembly
Antenna Radio
Cab 7x60,Euro,Atc,Ch
Cab Assembly-Challenger,Euro,Atc
Wiper Assembly 2010 And Before
Motor-Wiper,1in
Group Part-718455
Floormats Covers Assembly
Interior Trim Ssembly
Cab Electric Assembly
Telemetry Ready Assembly
Hvac Assembly
Used Before 2011
Motor Blower Assembly
Motor Blower Assembly Pressure
A C Group
Receiver Dehydrator
Deflector Install-Crop
Deflector Assembly-Crop
Ladder Install-Sc7000
Platform Install-Sc7000
Boomrest Install-Europe
Handrail Install,7650,Ss
Handrail Install,7650,Poly
Install-Front,Fender
F A-Front,Fender
Install-Rear,Fender,Spring
F A-Rear,Fender,Spring
Install-Rear,Fender,Hydraulic
F A-Rear,Fender,,Hydraulic
Install-Front,Fender,76xx
F A-Front,Fender,76xx
Install-Rear,Fender,76xx
F A-Rear,Fender,76xx
Hood Install-Challenger
Bellypan-Install,Front,7000
Seal-Brush And Holder,10.0 X 19.5
Bellypan-Install,Middle,7000
Bellypan-Instal,Rear,7000
Bellypan-Install,Tank Shields
Belting Instal-Bellypan
Decal Install-Sc7xxx,Na,Standard Hvac
Decal Install-Sc7xxx,Int,Standard Hvac
Decal Install-Sc7xxx,Na,Atc Hvac
Decal Install-Sc7xxx,Int,Atc Hvac
Decal Install-7460 2010-2011
Decal Install-Sc7460 2010-2011
Decal Install-7660 2010-2011
Decal Install-Sc7660 2010-2011
Decal Install-Sc7460 2012
Decal Install-Sc7660 2012
Mounting Hardware
Hardware-Front,Wheel,28in
Hardware-Front,Wheel,38in
Option-Tire,Gy,320 90r46,Challenger
Wheel Tire-320 90r46,Left Hand,Challenger
Wheel Tire-320 90r46,Right Hand,Challenger
Option-Tire,Gy,380 90r46,Challenger
Wheel Tire-380 90r46,Left Hand,Challenger
Wheel Tire-380 90r46,Right Hand,Challenger
Option-Tire,Gy,480 80r46,Challenger
Wheel Tire-480 80r46,Left Hand,Challenger
Wheel Tire-480 80r46,Right Hand,Challenger
Option-Tire,380 80r38,Gy,Challenger
Wheel Tire-380 80r38,Right Hand,Challenger
Wheel Tire-380 80r38,Left Hand,Challenger
Option-Tire,620 70r42,Challenger
Wheel Tire-620 70r42,Right Hand,Challenger
Wheel Tire-620 70r42,Left Hand,Challenger
Option-Tire,380 80r38,Challenger
Fa-Tire,Gy 620 70r42,Challenger
F A-Tire,Gy 380 80r38 2wd,Challenger
F A-Tire,Gy 320 90r46,Challenger
F A-Tire,Gy 380 90r46,Challenger
F A-Tire,Gy 480 80r46,Challenger
F A-Tire,Fwa,Gy,380 80r38,Challenger
Option-Tire,12.4x28-8,5ofs,8 Hole
Wheel Tire-12.4x28.8,Left Hand,8 Hole
Wheel Tire-12.4x28.8,Right Hand,8 Hole
Option-Tire,12.4x28-8,5ofs,10hole
Wheel Tire-12.4x28-8,Left Hand,10hole
Wheel Tire-12.4x28-8,Right Hand,10hole
Kit-Steering Knuckle Spacer
Option-Tire,540 65r34,Gy,Challenger
Tire Rim Assembly-540 65r34 R1w,Left Hand
Tire Rim Assembly-540 65r34 R1w,Right Hand
F A-Tire,Fwa,Gy,540 65r34,Challenger
Option-Tire,540 65r34,Gy,10 Hole
F A-Tire,540 65r34,Gy,10 Hole
Option-Tire,320 85r38,Gy,Challenger
Wheel Tire-320 85r38,Right Hand,Challenger
Wheel Tire-320 85r38,Left Hand,Challenger
F A-Tire,Gy 320 85r38 2wd,Challenger
F A-Tire,Fwa,Gy 320 85r38,Challenger
Controller System
Console Install-Raven 5000
Controller Install-Viper Pro
Kit-Console,Viper Pro
Clamp Assembly-Mounting,Ball,7.50
Clamp Assembly-Mounting,Ball,4.00
Guidance System
Gps,Phoenix 300,Sc7000
Kit-Gps,Phoenix 300
Gps,Phoenix 200,Sc7000
Kit-Gps,Phoenix 200
Gps,Rpr 100s,Sc7000
Kit-Gps,Rpr 100s,Sc7000
Kit-Sensor,Tilt
Smartrax,Sc 7x60
Control Install-Smartrax,7x60 Cab
Kit-Cab,Smartrax
Install-Was,Autoguide,7660
Install-Was,Autoguide,7460
Bracket Install-Smartrax,Phx 200
Autoguide Mounting Kit-Sc7000
Terminal Kit-Autoguide
Install-Bracket,Roof,B4 Topdock
Telemetry Hardware
Assembly,Atutoguide-Ready,Sc7460
Assembly,Autoguide-Ready,Sc7660
Install-Bracket,Terminal,Autoguide
Terminal-Install,A5,Autoguide
Telemetry Assembly-Sc7000
Sensor Install-Tilt
Console Install-Gta,Sc7000
Install-Antenna,Satellite
F A-Crop Shields
Key,Overseas
50hr Filter Kit
500hr Filter Kit
500hr Fwa Filter Kit
