Spra-Coupe Sprayer 4655 Parts Catalog 506996D1
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 4655 Sprayer
Part Number: 506996D1
Number of Pages: 2416 Pages
Publication Information
Engine Group
50 Hour Filter Kit
500 Hour Filter Kit
Engine Group-4000 Mt
Engine-Perkins 122 Hp
Cylinder Block And Liners Assembly
Crank, Main And Big End Bearings Assembly
Pistons And Rings
Connecting Rod Assembly
Rear End Oil Seal Assembly
Cylinder Head Assembly
Rocker Shaft Assembly
Timing Gear And Camshaft Assembly
Fuel Injection Pump
High Press. Fuel Pipe Assembly
Atomizer Assembly
Throttle And Stop Controls Assembly
Pick-Up Sensors Assembly
Boost Control Pipe Assembly
Core Plug
Fuel Leak-Off Pipe Assembly
Fan Drive Assembly
Sump Assembly
Dipstick And Filler Tube Assembly
Oil Strainer Assembly
Cylinder Head Cover
Cylinder Head Cover Assembly
Breather Assembly
Filler
Oil Filter Assembly
Blanking Plate Assembly
Front End Drive Input
Front End Drive Input Assembly
Water Pump Assembly
Pipe Assembly
Water Outlet Housing Assembly
Fan Assembly
Timing Case Assembly
Timing Cover Assembly
Blanking Plug Assembly
Oil Pump And Delivery Housing Assembly
Feed Pipe Assembly
Pipework And Connections Assembly
Exhaust Manifold Assembly
Induction Manifold Assembly
Lift Pump Assembly
Injection Pump To Filter Pipe Assembly
Heater Plugs Assembly
Engine Lifting Eye Assembly
Filter To Injection Pump Pipe Assembly
Engine Mounts Assembly
Lube Oil Pressure Switch-Gauge Assembly
Temperature Gauge And Sender Assembly
Miscellaneous And Auxiliary Assembly
Fuel Pre-Lift Pump Assembly
Top Service Kit Assembly
Turbocharger Install
Assembly, Filter, Fuel
Motor-Starter
Package-Parts,Ford
Engine Support Group
Arm Assembly-Pulley
Bottom Service Kit Assembly
Air Cleaner Group
Filter-Air
Install Throttle
Throttle Assembly-Hand
Cooling Install
Tank-Dearating
Exhaust Group
Driveline Group
Cylinder Assembly-Brake
Adapter Str 0.37mo-R X 0.37mjic
4655
Case-Chain, Final Drive, Lh Assembly
Hub Assembly-Wheel
Case-Chain, Final Drive, Rh Assembly
4460
Case-Chain,Final Drive,Lh,Assembly
4000 Mt
Transmission Assembly
Differential Assembly
Shaft-Drive,T-5 Manual
Shaft Drive T-S,Manual R B 523030d1
Driveshaft Install-4000,80
Shaft-Drive 80-108 Hd
Frame And Suspension Group
Frame Install-Manual Trans 80 Inch 4000m8
Frame Assembly 80 Inch Wide Front
Frame-Adjust Rear 46xx Series 80 Inch
Footboard Group
Channel Assembly 80 Inch
Footboard Group-W O Boomrest,4650mt
Hitch-Install
Shield Install-Belt
Axle And Steering Group
Pedal Assembly-4x55 Brake
Brake Assembly- 6 Disc Lh
Brake Assembly- 6 Disc Rh
Valve-Brake Modulating,
Steering Assembly-Arm
Steer Install-No Tow,4650 80 In.
Tie Rod Assembly-340-80
Steering Column
Steering Group-Wf,80 In.
Wide Front Group-Sc
Extension Install-Front
Fuel System Group
Fuel Install- 4000
Hydraulic Group
Hydraulic Install-H Frame,Sc6080,4x50
Valve Install-Hydraulic,Boom,6 Bank,4x50
Valve Assembly-Hydraulic,Boom,6 Bank,4x50
Valve-Hydraulic,Boom,6 Bank
Valve-Check,Cv08200n25
Hose Install-Hydraulic,H Frame,4x50
Tube Install-Hydraulic,H Frame
Cylinder Assembly-Hydraulic,Boom Swing, Sc6080
Cylinder-Hydraulic,2.75x11x1.38
Cylinder Assembly- Boom Tip Fold
Cylinder-Hydraulic,2.00x16.00x1.25
H Frame
Cylinder-Hydraulic,2.00x4.00x1.00
Assembly Vlave-Hydraulic, H Frame
Assembly-Valve,Relief,Boom Tip
Valve Relief-Boom Tip
Valve-Cartridge,Check-08 (4 Psi )
Assembly Valve-Hydraulic, H Frame
No H Frame
Hydraulic Install-Chassis,4000 Mt
Assembly Valve-2 Position, Float
Grip Assembly-Handle
Valve-Float,2 Position
Assembly Pump-Hydraulic 4000,Chassis
Pump Hydraulic R B 531603d1
Adapter Straight .37morx.37mjic Long
Assembly-Valve Charge
Valve-Charge
Assembly Filter-Hydraulic,4000,Chassis
Elbow 90d 0.50mo-R X 0.50mjic
Assembly-Switch Pressure
Hydraulic Tank Assembly
Assembly Valve-Hydraulic,4000,Chassis
Valve-Hydraulic,Boom Lift Track Adjust,3 Bank
Cylinder-Hydraulic,1.75x16.84x1.00
Cylinder-Hydraulic,2.25 X 1.00 X 6.5
Hose Install-Boom Tilt,Sc6080,7x50
Cylinder-Hydraulic,1.75x16.84x1.25
Pump-Gear,Hydraulic,16cc R B 531604d1
Kit-Field,Gear Pump,19cc,P5t
Pump-Gear,19cc,P5t
Adapter Assembly,-6mor X -6stor
Hydraulic Install-Wf Steering
Cylinder-Hydraulic,1.75x6.19x1.00
Hydraulic Install-80 Axle Adj, 4000
Cylinder-Hydraulic,2.00x20.00x1.00
Hydraulic Install-Boom Fold
Cylinder-Hydraulic,1.50x8.38x1.00
Cylinder-Hydraulic,1.50x8.38x0.88 R B 527610d1
Hose Install-Boom Tip,Sc6080,7x50
Hose Install-Boom Tip Sc6080,4xxx
Hose Install-Hydraulic,Boom Lft,4x50
Cab Group
Ignition Switch Loader
Kit-Wiper Motor
Kit Hardware Wj3
Throttle Install
Throttle Handle Assembly
4000m
Seat Group-Basic
Seat Install
Seat Group-Mechanical Suspension
Kit-Recliner Assembly
Kit-Cushion,Back
Kit-Service,Slides (200mm Bf Single Locking )
Kit-Seat Top Sst
Kit-Pan Back W Lumbar
Kit-Lumbar,Sst
Kit-Seat Cushion
Kit-Arm Rest Rh
Kit-Arm Rest Lh
Kit-Mechanical Suspension
Seat Group-Deluxe
Seat Group-Air Suspension
Suspension Boot-Air
Kit-Air Suspension
Kit-Service,Boot,Lp Air
Clutch Pedal Install
Shift Install-Mt
Kit-Radio, Sc
Kit-Radio,Xm
Radio-Cd (Xm)
Install-Antenna,Sat
Group-Radio Accessory
Air Conditioner-Kit
Heater-Kit
A C Kit-Front
A C Kit-Cab
Core Assembly-Evaporator
Blower Kit
Blower Assembly
Heater Kit
Electrical Group
Electrical Install-Chassis,4000m,Euro
Light Assembly
Headlight Assembly-Wiring,Lh
Headlight-Left,Hella
Headlight Assembly-Wiring, Rh
Headlight-Right,Hella
Headlight-Halogen,Wrapping,Lh
Headlight-Halogen,Wrapping,Rh
Lamp Cluster Rear Rh
Lamp Cluster Rear Lh
Alternator,140 Amp-2 Groove
Electrical Install-Cab
Light Assembly-Dome,With Switch
Gauge-Fuel,12v
Gauge-Oil Pressure
Gauge-Temperature,Water
Electrical Install-Chassis,3000m
Lamp-Warning,Amber
Electrical Install-3 Valve
Battery Install
Electrical Install-Relief Valve
Electrical Install-5 Valve
Clutch Assembly
Lighting Group
Appearance Group
Hood Installation
Hood Assembly
Tire And Wheel Group
Tire Assembly-320 85r24,Lh,White
Tire Assembly-320 85r24,Rh,White
Tire Assembly-9.00x24, White
Tire Assembly-9.00x24 White W Fluid
Tire Install-9.00x24,Wht
Tire Install-9.00x24,Wht,Fld
Tire Install-320 85r24,Wht
Tire Install-320 85r24,Wht,Fld
Tire Assembly-320 85r24,Lh,Wht,Fld
Tire Assembly-320 85r24,Rh,Wht,Fld
Tire Install-380 85r24,Wht
Tire Assembly-380 85r24,Lh,Wht
Tire Assembly-380 85r24,Rh,Wht
9.00x24,Wht
Tire Assembly-10.00x16,Wht
320 85r24,Wht
9.00x24,Wht,Fld
Tire Assembly-9.00x24,Wht,Fld
320 85r24,Wht,Fld
Tire Install-230 95r32, Wht
Tire Assembly-230 95r32, Lh Wht
Tire Assembly-230 95r32, Rh Wht
Tire Install-320 85r24,Wht,Rear
Decal Group
Hood
Spray
Cab, Outside
Cab, Inside
Suspension
Cab, Inside,
Guidance Group
Kit-Lightbar,Rgl600t
Tank And Saddle Group
Spray Install-4000 Chassis 2007
Tank Assembly,Spray
Cover-Hinged
Insert Assembly-Sq End
Agitator-Aandm
Strap Assembly-Tank
Pump Assembly- Spray W Clutch
Pump-Spray
Valve Ball 0.75 Poly Ff
Flowmeter Kit-2.00sp Flange, Rfm60p
Flowmeter-2.00sp Flange,Rfm60p,Cnxl
Strainer-Manifold
Strainer Assembly Less Screen 1.25
Valve Assembly R B 426406
Valve R B 056871
Ball Valve Assembly 1 Inch 3-Wire
Valve Assembly-Inlet
Valve-Ball,2 In. Fp,W Cam
Filter-Inline
Valve 3-Way 2.00 Bottom Load
Spray Install-4000 Chassis 2008
Valve Assembly Inlet
Valve 2 Inch Mnpt X 2 In. Madap
Tank Assembly-Spray
Product Pump And Pressure Plumbing Group
Kit-Pulley Clutch Assembly
Boom Group
Boom Install-Lift Rack,H Frame,4x50
Hydraulic Install-Cap,Plug
Frame Install-H,Rear,Boom,60 80
Frame Assembly-H,Rear,B00m,60 80
Rack Install-Tilt,Boom,60 80
Rack Assembly-Tilt,Boom,60 80
Lift Install-Boom,Par Link,4x50
Bar Install-Mounting,Plumbing,Ctr,Sc6080
Bag-Loose Parts,60 80
Block Install-Boomrest,4x50
Option-Boom 60 80
Boom Assembly-60 80,Lh
Boom Assembly-60 80,Rh
Boom Assembly-60 80
Cam Assembly-Breakaway,60 80
Cam Assembly-Boom Breakaway
Frame Assembly-H,Rear,Boom,60 80
Boom Group-Rh,60 Ft. Ft.
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Group-Lh,60 Ft. Ft.
Boom Group-Rh,80 Ft. Ft.
Boom Group-Lh,80 Ft. Ft.
Pivot-Mach
Rear H Frame Group
Spring, Assembly
Tube Assembly-Rack Tilt
Boomrest Install-Sc6080,4x50
Kit-Loose Parts,Boom Hinge
Bag-Parts
Tilt Rack Assembly
Boom Lift Group
Boom Plumbing Group
Valve Teejet
Spray System Install-H Frame
3 Section Valve-Boom Shut Off
Valve Assembly-2.00sp Flange X O-Ring
Valve-Control,1.00npt 2.00sp Flange
5 Section Valve-Boom Shut Off
Manifold Install-Ctr,Sc6080,4x50
Valve Assembly-Shutoff,Boom Sect,5
Valve Assembly-Kz, 5 Section,
Valve W O Power Head
Insert-Seat,Qc3
Manifold Install-Center,Sc6080,4xxx
Valve Assembly-5 Sect,Boom Shut Off
Spray Install-60 Ft. Ft. Manifold
Nozzle Assembly-Single
Nozzle Assembly-Double
Filter Assembly-Boom
Spray Install-Center Manifold
Spray Install-80 Ft. Ft. Manifold
Spray Install-Loose Parts Kit
Option-Poly Plumbing,Sc6080x5x20,Off
Pipe Assembly-90d W .75hb,6x20.Pp
Bracket Assembly-L,.75 Stauff,Std
Bracket Assembly-Z,Sh,.75ips,Std
Pipe Assembly-T W 2 1.00hb,5x20,Pp
Pipe Assembly-T W 2 1.00hb,3x20,Pp
Pipe Assembly-90d W 1.00hb,2x20,Pp
Pipe Assembly-90d W .75hb,6x20,Pp
Mender Assembly-Hose,.75x1.00,Pp
Bracket Assembly-L Lg Str,.75pp,2pclp
Bracket Assembly-L,.75 Stauff,Pclp,Std
Bracket Assembly-Z,Lg,.75 1.00ips,Pclp
Bracket Assembly-L,.75 Stauff,Rev Pclp
Bracket Assembly-Z,Lg,.75 1.00ips,1.0u
Bracket Assembly-Z,Sh,.75ips,1.00u
Bracket Assembly-L,.75 Stauff,1.00u
Option-Pp Plmb,Sc6080x5x10,On
Pipe Assembly-90d W .75hb,11x10,Pp
Pipe Assembly-T W 2 1.00hb,10x10,Pp
Pipe Assembly-T W 2 1.00hb, 6x10,Pp
Pipe Assembly-90d W 1.00hb, 5x10,Pp
Option-Nozzle,3 Way,Rotary,80x10,0n
Body-Nozzle,3 Way,Rotary,.75
Option-Nozzle,3 Way,Rotary,80x20,Off
Controller Group
Gps Install-Raven Inv 115,Sc
Kit-Gps Antenna Mount,Sc
Picture-Gps Antenna Mounting
Kit-Receiver Antenna,Gps,Inv 115
Install-Rgl600t,3 4x50 Sc
Controller Install-Raven 460,Wf
Tag Assembly, Calibration
Option-Gps,Phoenix 200,Sc 4000
Kit-Gps,Phoenix 200
Option-Gps,Rpr 100s, Sc 4000
Kit-Gps,Rpr 100s
Foam Marker Group
Rsc 2130
Rsc Foamhead Valve Assembly
Deflector-Collector, 2 In.
Filter Assembly, Incline
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In.
Control Module-Power Unit
Compressor-Foam Marker
Filter Assembly-Carbon
Options Group
F A-Crop Deflector,3600 4600
Fresh Water Install
Overspray Install
Belly Pan
F A Floodlight Kit
Work Light
F A Floodlight Kit,Hid
Light-Work,Hid
Floodlight Kit
Light-Flood,Med
F A-Driveshaft Extension Kit
Recommended Dealer Stock
Brand: Spra-Coupe
Engine Group
50 Hour Filter Kit
500 Hour Filter Kit
Pistons And Rings
Fuel Injection Pump
Atomizer Assembly
Core Plug
Fan Drive Assembly
Sump Assembly
Cylinder Head Cover
Breather Assembly
Filler
Oil Filter Assembly
Water Pump Assembly
Pipe Assembly
Fan Assembly
Feed Pipe Assembly
Lift Pump Assembly
Motor-Starter
Package-Parts,Ford
Arm Assembly-Pulley
Air Cleaner Group
Filter-Air
Install Throttle
Cooling Install
Tank-Dearating
Exhaust Group
Driveline Group
4655
Hub Assembly-Wheel
4460
4000 Mt
Footboard Group
Hitch-Install
Shield Install-Belt
Steering Column
Wide Front Group-Sc
Fuel System Group
Fuel Install- 4000
Hydraulic Group
H Frame
No H Frame
Valve-Charge
Pump-Gear,19cc,P5t
Cab Group
Kit-Wiper Motor
Kit Hardware Wj3
Throttle Install
4000m
Seat Group-Basic
Seat Install
Kit-Cushion,Back
Kit-Seat Top Sst
Kit-Lumbar,Sst
Kit-Seat Cushion
Kit-Arm Rest Rh
Kit-Arm Rest Lh
Seat Group-Deluxe
Suspension Boot-Air
Kit-Air Suspension
Shift Install-Mt
Kit-Radio, Sc
Kit-Radio,Xm
Radio-Cd (Xm)
Install-Antenna,Sat
Air Conditioner-Kit
Heater-Kit
A C Kit-Front
A C Kit-Cab
Blower Kit
Blower Assembly
Heater Kit
Electrical Group
Light Assembly
Gauge-Fuel,12v
Gauge-Oil Pressure
Lamp-Warning,Amber
Battery Install
Clutch Assembly
Lighting Group
Appearance Group
Hood Installation
Hood Assembly
9.00x24,Wht
320 85r24,Wht
9.00x24,Wht,Fld
320 85r24,Wht,Fld
Decal Group
Hood
Spray
Cab, Outside
Cab, Inside
Suspension
Cab, Inside,
Guidance Group
Tank Assembly,Spray
Cover-Hinged
Agitator-Aandm
Strap Assembly-Tank
Pump-Spray
Strainer-Manifold
Valve R B 056871
Filter-Inline
Tank Assembly-Spray
Boom Group
Option-Boom 60 80
Boom Assembly-60 80
Pivot-Mach
Rear H Frame Group
Spring, Assembly
Bag-Parts
Tilt Rack Assembly
Boom Lift Group
Boom Plumbing Group
Valve Teejet
Insert-Seat,Qc3
Controller Group
Kit-Gps,Phoenix 200
Kit-Gps,Rpr 100s
Foam Marker Group
Rsc 2130
Options Group
Fresh Water Install
Overspray Install
Belly Pan
F A Floodlight Kit
Work Light
Light-Work,Hid
Floodlight Kit
Light-Flood,Med
- Spra Coupe EU 4460 4660 Sprayer Service Manual_79034247B
- Spra Coupe EU 4460 4660 Manual Transmission Operator Manual_519177D1D
- Spra Coupe SA 7000 Series SPRA-COUPE Service Manual_WR132165
- Spra Coupe EU 7460 7660 Sprayer System RTS_AG333725A
- Spra Coupe EU 7000 Series Sprayer Service Manual_79027326A
- Spra Coupe EU 7460 7660 Applicator Chassis Service Manual_79032953B
- Spra Coupe EU 4460 4660 Man Sprayer Repair Time Schedule_AG335277A
- Spra Coupe EU 4460 4660 Sprayer Automatic Transmission Operator Manual_519176D1D
- Spra Coupe EU 4455 4655 Sprayer Automatic Transmission Operator Manual_512150D1D
- Spra Coupe EU 4450 4650 4455 4655 Sprayer Service Manual_79027328B
- Spra Coupe SA 7000 Series Sprayer Service Manual_79027326
- Spra Coupe EU 7450 7650 Sprayer System Repair Time Schedule_AG331640A
- Spra Coupe EU 4460 4660 Auto Sprayer Repair Time Schedule_AG335025A
- Spra Coupe EU 7460 7660 Applicator Chassis RTS_AG333724A
- Spra Coupe SA 7450 7650 System Repair Time Schedule_AG331640A
