Spra-Coupe Sprayer 4650 Parts Catalog WR135265
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 4650 Sprayer
Part Number: WR135265
Number of Pages: 1679 Pages
Publication Information
Engine Group
50 Hour Filter Kit
500 Hour Filter Kit
Engine Group-4000 Mt
Engine-Perkins 122 Hp
Motor-Starter
Cylinder Block And Liners
Crank, Main And Big End Bearings
Pistons And Rings
Connecting Rods
Rear End Oil Seal
Cylinder Head Assembly
Rocker Shaft Assembly
Timing Gear And Camshaft
Fuel Injection Pump
High Pressure Fuel Pipes
Atomizers
Throttle And Stop Controls
Pick-Up Sensors
Core Plug
Fuel Leak-Off Pipe
Boost Control Pipe
Fan Drive
Sump
Dipstick And Filler Tube
Oil Strainer
Cylinder Head Cover
Breather
Filler
Oil Filter
Blanking Plates
Front End Drive Input
Pipes
Water Outlet Housing
Fan
Timing Case
Timing Cover
Blanking Plug
Oil Pump And Delivery Housing
Turbocharger Install
Feed Pipes
Leak-Off Pipes
Pipework And Connections
Exhaust Manifold
Induction Manifold
Lift Pump
Filter To Injection Pump Pipe
Injection Pump To Filter Pipe
Heater Plugs
Engine Lifting Eyes
Engine Mounts
Lube Oil Pressure Switch-Gauge
Temperature Gauge And Sender
Fuel Pre-Lift Pump
Assembly, Filter, Fuel
Miscellaneous And Auxiliaries
Top Service Kit
Package-Parts,Ford
Engine Support Group
Arm Assembly-Pulley
Exhaust Group
Cooling Install
Air Cleaner Group
Filter-Air
Install Throttle
Throttle Assembly-Hand
Bottom Service Kit
Driveline Group
4000 Mt
Transmission Assembly
Differential Assembly
Shaft-Drive,T-5 Manual
Chaincase Group-4650
Case-Chain,Final Drive,Lh,Assembly
Hub Assembly-Wheel
Case-Chain,Final Drive,Rh,Assembly
Cylinder Assembly-Brake
Brake Install-4650
Pedal Assembly-Brake
Brake Assembly,Lh
Brake Assembly,Rh
Driveshaft Install-4000,80
Shaft-Drive 80-108 Hd
Shaft Drive T-S,Manual R B 523030d1
Frame And Suspension Group
4000m8
Frame-Adjust Rear 46xx Series 80 Inch
Channel Assembly 80 Inch
Frame Assembly 80 Inch Wide Front
Footboard Group
Footboard Group-W O Boomrest,4650mt
Hitch-Install
F A-Front Extension,Sc
Belly Pan Install-Wf
Axle And Steering Group
Extension Install-Front
Wide Front Group-Sc
Steering Group-Wf,80 In
Tie Rod Assembly-340-80
Steering Column
Steering Assembly-Arm
Steer Install-No Tow,4650 80in
Hydraulic Group
Tube Assembly
Hydraulic Install-Kit No H Frame
Valve Assembly-6 Spool
Valve-Check,Cv08200n25
Assembly Valve-Hydraulic, H Frame
Valve-Hydraulic,Boom,6 Bank
H Frame
Cylinder-Hydraulic,2.00x4.00x1.00
Cylinder-Hydraulic, R B 129450
Hydraulic Install-4000 Chassis
Valve Assembly-Control
Tank Assembly-Hydraulic
Valve-Charge
Grip Assembly-Handle
Valve-Float,2 Position
Cylinder-Hydraulic,1.75x16.84x1.00
Pump Hydraulic R B 531603d1
Elbow 90d 0.50mo-R X 0.50mjic
Hydraulic Install-Wf Steering
Cylinder-Hydraulic,1.75x6.19x1.00
Hydraulic Install-80 Axle Adj, 4000
Cylinder-Hydraulic,2.00x20.00x1.00
Hydraulic Install-H Frame
Assembly-Valve,Relief,Boom Tip
Valve Relief-Boom Tip
Valve-Cartridge,Check-08 (4 Psi )
Hydraulic Install-Boom Fold
Cylinder-Hydraulic,1.50x8.38x1.00
Cylinder-Hydraulic,1.75x16.84x1.25
Cylinder-Hydraulic,1.50x8.38x0.88 R B 527610d1
Cylinder-Hydraulic,2.25 X 1.00 X 6.5
Cylinder Assembly- Boom Tip Fold
Cylinder-Hydraulic,2.00x16.00x1.25
Hose Install-Boom Tilt,Sc6080,7x50
Hose Install-Boom Tip,Sc6080,7x50
Hose Install-Boom Tip Sc6080,4xxx
Hydraulic Install-4x50mt Chassis,Sc6080
Cylinder Assembly-Hydraulic,Boom Swing, Sc6080
Cylinder-Hydraulic,2.75x11x1.38
Tube Install-Hydraulic,H Frame
Valve Assembly-Hydraulic,Boom,6 Bank,4x50
Hose Install-Hydraulic,H Frame,4x50
Hose Install-Hydraulic,Boom Lft,4x50
Valve Install-Hydraulic,Boom,6 Bank,4x50
Assembly Vlave-Hydraulic, H Frame
Chassis,4000m
Assembly Valve-2 Postion, Float
Assembly Pump-Hydraulic 4000,Chassis
Assembly-Valve Charge
Assembly Filter-Hydraulic,4000,Chassis
Assembly-Switch Pressure
Assembly Valve-Hydraulic,4000,Chassis
Valve-Hydraulic,Boom Lft Trk Adj,3bank
Pump-Gear,Hydraulic,16cc R B 531604d1
Kit-Field,Gear Pump,19cc,P5t
Pump-Gear,19cc,P5t
Adapter Assembly,-6mor X -6stor
Hydraulic Install-Chassis,4000m,Sc6080
Fuel System Group
Fuel Install- 4000
Tank Assembly
Cab Group
Valve-Modulating
Cab Install-4000 Mt
Top Assembly-Cab
Kit-Radio,Sc
Seat Install
Seat-Suspension
Shift Install-Mt
Clutch Pedal Install
Kit-Wiper Motor
Kit Hardware Wj3
Heater-Kit
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Electrical Group
Electrical Install-3 Valve
Electrical Install-5 Valve
Kit-Overspray
Battery Install
Electrical Install-Chassis,4000m
Light Assembly
Alternator,140 Amp-2 Groove
Electrical Install-Cab
Gauge-Fuel,12v
Gauge-Oil Pressure
Gauge-Temperature,Water
Light-Flood,Med
F A-Floodlight Kit
Electrical Install-Relief Valve
Clutch Assembly
Appearance Group
Wf
Tire And Wheel Group
9.00
Tire Assembly-320 85r24,Lh,White
Tire Assembly-320 85r24,Rh,White
Tire Assembly-9.00x23, White
Tire Install-320 9 White W Fluid
Tire Assembly-9.00x24 White W Fluid
Tire Assembly-320 85r24,Lh,Gray
Tire Assembly-320 85r24,Rh,Gray
Decal Group
Decal Install-4650mt,80,Wf
Tank And Saddle Group
Tank Assembly-Spray
Cover-Hinged
Insert Assembly-Sq End
Agitator-A And M
Tank Assembly,Spray
Spray Install-4000 Chassis
Valve Ball 0.75 Poly Full Flow
Pump Assembly- Spray W Clutch
Pump-Spray
Valve 3-Way 2.00 Bottom Load
Valve Assembly-Inlet
Valve-Ball,2 In Fp,W Cam
Strainer-Manifold
Valve Assembly R B 426406
Valve R B 056871
Strainer Assembly Less Screen 1.25
Flowmeter Kit-2.00sp Flg,Rfm60p
Flowmeter-2.00sp Flange,Rfm60p,Cnxl
Spray Install-60 Ft Manifold
Filter Assembly-Boom
Nozzle Assembly-Single
Nozzle Assembly-Double
Spray System Install-H Frame
3 Section Valve-Boom Shut Off
Valve Assembly-2.00sp Flg X O Ring
Valve-Control,1.00npt 2.00sp Flange
Valve Assembly-Boom Shut Off,
Valve Assembly-Kz, 3 Section,
Valve W O Power Head
Insert-Seat,Qc3
Spray Install-Center Manifold
Spray Install-80 Ft Manifold
5 Section Valve-Boom Shut Off
Valve Assembly-Kz, 5 Section,
Spray Install-Loose Parts Kit
Valve-Pressure,Control
Manifold Install-Center,Sc6080,4x50
Valve Assembly-Shutoff,Boom Section,5
Valve Teejet
Flowmeter-2.00sp Flange,Rfm60p,12v
Option-Pp Plumbing,Sc6080x5x20,Off
Pipe Assembly-90d W .75hb,6x20.Pp
Bracket Assembly-L,.75 Stauff,Std
Bracket Assembly-Z,Sh,.75ips,Std
Pipe Assembly-T W 2 1.00hb,5x20,Pp
Pipe Assembly-T W 2 1.00hb,3x20,Pp
Pipe Assembly-90d W 1.00hb,2x20,Pp
Pipe Assembly-90d W .75hb,6x20,Pp
Mender Assembly-Hose,.75x1.00,Pp
Bracket Assembly-L Lg Str,.75pp,2pclp
Bracket Assembly-L,.75 Stauff,Pclp,Std
Bracket Assembly-Z,Lg,.75 1.00ips,Pclp
Bracket Assembly-L,.75 Stauff,Rev Pclp
Bracket Assembly-Z,Lg,.75 1.00ips,1.0u
Bracket Assembly-Z,Sh,.75ips,1.00u
Bracket Assembly-L,.75 Stauff,1.00u
Option-Pp Plumbing,Sc6080x5x10,On
Pipe Assembly-90d W .75hb,11x10,Pp
Pipe Assembly-T W 2 1.00hb,10x10,Pp
Pipe Assembly-T W 2 1.00hb, 6x10,Pp
Pipe Assembly-90d W 1.00hb, 5x10,Pp
Option-Nozzle,3way,Rotary,80x10,0n
Body-Nozzle,3 Way,Rotary,.75
Option-Nozzle,3 Way,Rotary,80x20,Off
Boom Group
Tilt Rack Assembly
Tube Assembly-Rack Tilt
Boom Lift Group
Rear H Frame Group
Spring, Assembly
Boom Group-Rh,60 Ft
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Group-Lh,60 Ft
Boom Group-Rh,80 Ft
Boom Group-Lh,80 Ft
Option-Boom 60 80
Boom Assembly-60 80,Lh
Boom Assembly-60 80,Rh
Boom Assembly-60 80
Rack Install-Tilt,Boom,60 80
Rack Assembly-Tilt,Boom,60 80
Frame Install-H,Rear,Boom,60 80
Frame Assembly-H,Rear,Boom,60 80
Frame Assembly-H,Rear,B00m,60 80
Bar Install-Mounting,Plumbing,Ctr,Sc6080
Lift Install-Boom,Par Link,4x50
Boomrest Install-Sc6080,4x50
Bag-Parts
Kit-Loose Parts,Boom Hinge
Block Install-Boom Rest,4x50
Controller Group
Controller Install-Raven 460,Wf
Foam Marker Group
Rsc 2130
Deflector-Collector, 2 In
Rsc Foamhead Valve Assembly
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In
Filter Assembly, Incline
Compressor-Foam Marker
Filter Assembly-Carbon
Module, Control
Options Group
Fresh Water Install
Overspray Install
F A-Crop Deflector,3600 4600
Kit-Gps Antenna Mount,Sc
Gps Install-Raven Inv 115,Sc
Kit-Receiver Antenna,Gps,Inv 115
F A-Driveshaft Extension Kit
Recommended Dealer Stock
Brand: Spra-Coupe
Engine Group
50 Hour Filter Kit
500 Hour Filter Kit
Motor-Starter
Pistons And Rings
Connecting Rods
Rear End Oil Seal
Fuel Injection Pump
Atomizers
Pick-Up Sensors
Core Plug
Fuel Leak-Off Pipe
Boost Control Pipe
Fan Drive
Sump
Oil Strainer
Cylinder Head Cover
Breather
Filler
Oil Filter
Blanking Plates
Pipes
Fan
Timing Case
Timing Cover
Blanking Plug
Feed Pipes
Leak-Off Pipes
Exhaust Manifold
Induction Manifold
Lift Pump
Heater Plugs
Engine Lifting Eyes
Engine Mounts
Fuel Pre-Lift Pump
Top Service Kit
Package-Parts,Ford
Arm Assembly-Pulley
Exhaust Group
Cooling Install
Air Cleaner Group
Filter-Air
Install Throttle
Bottom Service Kit
Driveline Group
4000 Mt
Hub Assembly-Wheel
Brake Install-4650
Brake Assembly,Lh
Brake Assembly,Rh
4000m8
Footboard Group
Hitch-Install
Wide Front Group-Sc
Steering Column
Hydraulic Group
Tube Assembly
H Frame
Valve-Charge
Chassis,4000m
Pump-Gear,19cc,P5t
Fuel System Group
Fuel Install- 4000
Tank Assembly
Cab Group
Valve-Modulating
Cab Install-4000 Mt
Top Assembly-Cab
Kit-Radio,Sc
Seat Install
Seat-Suspension
Shift Install-Mt
Kit-Wiper Motor
Kit Hardware Wj3
Heater-Kit
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Electrical Group
Kit-Overspray
Battery Install
Light Assembly
Gauge-Fuel,12v
Gauge-Oil Pressure
Light-Flood,Med
F A-Floodlight Kit
Clutch Assembly
Appearance Group
Wf
9.00
Decal Group
Tank Assembly-Spray
Cover-Hinged
Agitator-A And M
Tank Assembly,Spray
Pump-Spray
Strainer-Manifold
Valve R B 056871
Insert-Seat,Qc3
Valve Teejet
Boom Group
Tilt Rack Assembly
Boom Lift Group
Rear H Frame Group
Spring, Assembly
Boom Group-Rh,60 Ft
Boom Group-Lh,60 Ft
Boom Group-Rh,80 Ft
Boom Group-Lh,80 Ft
Option-Boom 60 80
Boom Assembly-60 80
Bag-Parts
Controller Group
Foam Marker Group
Rsc 2130
Module, Control
Options Group
Fresh Water Install
Overspray Install
- Spra Coupe EU 4460 4660 Sprayer Service Manual_79034247B
- Spra Coupe EU 4460 4660 Manual Transmission Operator Manual_519177D1D
- Spra Coupe SA 7000 Series SPRA-COUPE Service Manual_WR132165
- Spra Coupe EU 7460 7660 Sprayer System RTS_AG333725A
- Spra Coupe EU 7000 Series Sprayer Service Manual_79027326A
- Spra Coupe EU 7460 7660 Applicator Chassis Service Manual_79032953B
- Spra Coupe EU 4460 4660 Man Sprayer Repair Time Schedule_AG335277A
- Spra Coupe EU 4460 4660 Sprayer Automatic Transmission Operator Manual_519176D1D
- Spra Coupe EU 4455 4655 Sprayer Automatic Transmission Operator Manual_512150D1D
- Spra Coupe EU 4450 4650 4455 4655 Sprayer Service Manual_79027328B
- Spra Coupe SA 7000 Series Sprayer Service Manual_79027326
- Spra Coupe EU 7450 7650 Sprayer System Repair Time Schedule_AG331640A
- Spra Coupe EU 4460 4660 Auto Sprayer Repair Time Schedule_AG335025A
- Spra Coupe EU 7460 7660 Applicator Chassis RTS_AG333724A
- Spra Coupe SA 7450 7650 System Repair Time Schedule_AG331640A
