Spra-Coupe Sprayer 4650 Parts Catalog WR128687
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 4650 Sprayer
Part Number: WR128687
Number of Pages: 1526 Pages
Publication Information
Engine Group
50 Hour Filter Kit
500 Hour Filter Kit
Engine-Perkins 123hp,1104 Elec
Cylinder Block And Liners
Assembly, Crankshaft
Pistons And Rings
Connecting Rods
Rear End Oil Seal
Cylinder Head Assembly
Rocker Shaft Assembly
Timing Gear And Camshaft
Pump, Fuel Injection
Pipe, Fuel Assembly
Atomiser
Solenoid, Mounting
Mount, Solenoid
Sensor, Pick-Up
Housing Flywheel
Fan Drive
Sump
Oil Strainer
Cylinder Head Cover
Breather
Filler
Oil Filter
Blanking Plates
Front End Drive Input
Pipes
Water Outlet Housing
Fan
Timing Case
Timing Cover
Plug,Blanking
Oil Pump And Delivery Housing
Turbocharger Install
Feed Pipes
Leak-Off Pipes
Pipework And Connections
Exhaust Manifold
Manifold,Injection
Pump Lift
Pipe, Fuel
Heater Plugs
Engine Lifting Eyes
Mount, Engine
Wiring, Loom
Wiring Looms
Pump, Lift Fuel
Assembly,Filter,Fuel
Miscellaneous And Auxiliaries
Kit, Gasket
Bottom Service Kit
Motor-Starter
Engine Support Install-At
Arm Assembly-Pulley
Exhaust Install-4450at And 4650at
Cooling Group
Air Cleaner Group
Filter-Air
Shift Group-Allison
Shifter Assembly-Allison
Driveline Group
Chaincase Group-4650
Case-Chain,Final Drive,Lh,Assembly
Hub Assembly-Wheel
Case-Chain,Final Drive,Rh,Assembly
Cylinder Assembly-Brake
Brake Install-4650
Pedal Assembly-Brake
Brake Assembly,Lh
Brake Assembly,Rh
Driveshaft Install-4000,80
Shaft-Drive 80-108 Hd
Driveshaft, Auto Allison
Driveshaft,Auto Allison R B 547155d1
Kit-Auto Trans,Allison,Sc4x50
Transmission-Auto,2100rds
Differential Assembly
Frame And Suspension Group
Frame Install-80 In At
Frame-Adjust Rear
Channel Assembly 80 Inch
Frame Assembly 80 Inch Wide Front
Footboard Install-4650 At
Footboard Group-W O Boomrest,4650at
Hitch-Install
F A-Front Extension,Sc
Axle And Steering Group
Extension Install-Front
Wide Front Group-Sc
Steering Group-Wf,80 In
Tie Rod Assembly-340-80
Steering Column
Steering Assembly-Arm
Fuel System Group
4000 At
Hydraulic Group
Tube Assembly
Drivetrain Install-4450 4650
Cooler Install-At
Cooler Assembly-At Oil
Hydraulic Install-Kit No H Frame
Valve Assembly-6 Spool
Valve-Check,Cv08200n25
H Frame
Cylinder-Hydraulic,2.00x4.00x1.00
Cylinder-Hydraulic,
Tank Assembly
Hydraulic Install-Chassis
Grip Assembly-Handle
Tank Assembly-Hydraulic
Valve-Float,2 Position
Pump Hydraulic R B 531603d1
Valve-Charge
Valve Assembly-Control
Elbow 90d 0.50mo-R X 0.50mjic
Hydraulic Install-Wf Steering
Cylinder-Hydraulic,1.75x6.19x1.00
Hydraulic Install-80 Axle Adj, 4000
Cylinder-Hydraulic,2.00x20.00x1.00
Hydraulic Install-H Frame
Valve-Relief;Assembly Boom
Hydraulic Install-Boom Fold
Cylinder-Hydraulic,1.50x8.38x1.00
Cylinder-Hydraulic,1.75x16.84x1.25
Cylinder-Hydraulic,1.50x8.38x0.88 R B 527610d1
Cylinder-Hydraulic,2.25 X 1.00 X 6.5
Cylinder Assembly- Boom Tip Fold
Cylinder-Hydraulic,2.00x16.00x1.25
Hose Install-Boom Tilt,Sc6080,7x50
Hose Install-Boom Tip,Sc6080,7x50
Hose Install-Boom Tip Sc6080,4xxx
Hydraulic Install-4x50at Chas,Sc6080
Cylinder Assembly-Hydraulic,Boom Swing, Sc6080
Cylinder-Hydraulic,2.75x11x1.38
Tube Install-Hydraulic,H Frame
Valve Assembly-Hydraulic,Boom,6 Bank,4x50
Valve-Hydraulic,Boom,6 Bank
Hose Install-Hydraulic,H Frame,4x50
Hose Install-Hydraulic,Boom Lift,4x50
Valve Install-Hydraulic,Boom,6 Bank,4x50
Pump-Gear,Hydraulic,16cc R B 531604d1
Kit-Field,Gear Pump,19cc,P5t
Pump-Gear,19cc,P5t
Adapter Assembly,-6mor X -6stor
Cab Group
Valve-Modulating
Cab Install-4000 At
Top Assembly-Cab
Kit-Radio,Sc
Seat Install
Seat-Suspension
Joystick Install
Joystick Assembly
Kit-Wiper Motor
Kit Hardware Wj3
Heater-Kit
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Electrical Group
Electrical Install-3 Valve
Electrical Install-5 Valve
Kit-Overspray
Battery Install
Electrical Install-Chassis,Auto
Light Assembly
Alternator,140 Amp-2 Groove
Electrical Install-Cab,Auto
Light-Flood,Med
F A-Floodlight Kit
Clutch Assembly
Appearance Group
Wf
Hood-Wf
Tire And Wheel Group
7.50 12.4
Tire Assembly-12.4x24 W 24x10
Tire Assembly-12.4-24 W 24x10
Tire Assembly-7.5x24 W 24xw7,
9.00 12.4
Tire Assembly-9x24 W 24xw8,
9.00 230
Tire Assembly-9.5x32 W 32xw8
F A-Tires, 320 95r32
Decal Group
Decal Install-4650,80,At,Wf
Tank And Saddle Group
Tank Assembly-Spray
Cover-Hinged
Insert Assembly-Sq End
Agitator-A And M
Tank Assembly,Spray
Pump-Spray
Option-Pp Plumbing,Sc6080x5x20,On
Pipe Assembly-90d W 1.00hb,6x20,Pp
Pipe Assembly-T W 2 1.00hb,5x20,Pp
Pipe Assembly-X W 3 1.00hb,5x20,Pp
Pipe Assembly-T W 2 1.00hb,2x20,Pp
Pipe Assembly-90d W 1.00hb,3x20,Pp
Bracket Assembly-Str,Lg,2ips,Rev P Clp
Bracket Assembly-Str,Lg,3ips Clp
Bracket Assembly-Str,Sh,Ips Clp,P Clp
Bracket Assembly-Str,Lg,Ips Clp,2p
Bracket Assembly-Str,Lg,2ips Clp
Bracket Assembly-L,Pp Stauff
Bracket Assembly-L,Pp Stauff,Rev P Clp
Bracket Assembly-L,Pp Stauff,Ctr P Clp
Bracket Assembly-Str,Lg,2ips Clp,1.00u
Bracket Assembly-L,Pp Stauff,1.00u
Bracket Assembly-Str,Sh,Ips Clp,1.00u
Bracket Assembly-Str,Lg,2ips,P Clp
Spray System Install-4000 Chassis
Valve Assembly-Inlet
Valve-Ball,2in Fp,W Cam
Filter-Inline
Valve 3-Way 2.00 Bottom Load
Strainer-Manifold
Valve Assembly R B 426406
Valve R B 056871
Strainer Assembly Less Screen 1.25
Spray Install-60 Ft Manifold
Nozzle Assembly-Single
Nozzle Assembly Double
Filter Assembly-Boom
Nozzle Assembly-Double
Spray System Instal-H Frame
3 Section Valve-Boom Shut Off
Valve Assembly-2.00sp Flg X Oring
Valve-Control,1.00npt 2.00sp Flg
Valve Assembly-Boom Shut Off,
Valve Assembly-Kz, 3 Section,
Valve W O Power Head
Insert-Seat,Qc3
Spray Install-Ctr Manifold
Spray Install-80 Ft Manifold
5 Section Valve-Boom Shut Off
Valve Assembly-Kz,5 Section,
Spray Install-Loose Parts Kit
Manifold Install-Ctr,Sc6080,4x50
Valve Assembly-Shutoff,Boom Section,5
Valve-Pressure,Control
Nozzle Assembly-Option,80x20 On,Tpl
Nozzle Holder-Triple 1.00 Ips
Valve Teejet
Gauge-Flow
Boom Group
Tilt Rack Assembly
Tube Assembly-Rack Tilt
Boom Lift Group
Rear H Frame Group
Spring, Assembly
Boom Group-Rh,60 Ft
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Group-Lh,60 Ft
Boom Group-Rh,80 Ft
Boom Group-Lh,80 Ft
Fresh Water Install
Option-Boom 60 80
Boom Assembly-60 80,Lh
Boom Assembly-60 80,Rh
Boom Assembly-60 80
Rack Install-Tilt,Boom,60 80
Rack Assembly-Tilt,Boom,60 80
Frame Install-H,Rear,Boom,60 80
Frame Assembly-H,Rear,Boom,60 80
Frame Assembly-H,Rear,B00m,60 80
Bar Install-Mtg,Plumbing,Ctr,Sc6080
Lift Install-Boom,Par Link,4x50
Boomrest Install-Sc6080,4x50
Bag-Parts
Kit-Loose Parts,Boom Hinge
Block Install-Boomrest,4x50
Controller Group
Kg-3600wf Raven Mount
Install-Control,Raven
Controller Raven Package
Foam Marker Group
F A-Marker,Rsc 2130
Deflector-Collector, 2 In
Rsc Foamhead Valve Assembly
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In
Filter Assembly, Incline
Compressor-Foam Marker
Filter Assembly-Carbon
Control Module Assembly
Options Group
Belly Pan Install-Wf
Shield-Center Assembly,Allison
Overspray Install
F A Crop Deflector,3600 4600
F A-Driveshaft Extension Kit
Recommended Dealer Stock
