Spra-Coupe Sprayer 4640-80 Parts Catalog WR128536
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 4640-80 Sprayer
Part Number: WR128536
Number of Pages: 1458 Pages
Publication Information
Engine Group
Exhaust Group-Perkins,Sc
Cooling Group-Sc
Filter Air Group-Sc
Air Filter Assembly
Engine-Perkins
Short Engine
Cylinder Block Kit
Rear Oil Seal Assembly
Cylinder Head Kit
Rocker Shaft Assembly
Timing Gear And Camshaft Assembly
Oil Pump And Housing Assembly
Crankshaft Rod And Piston Assembly
Conrod Kit
Fuel Injection Equipment
Flywheel Housing Assembly
Fan Drive Assembly
Oil Sump Assembly
Oil Filter Assembly
Oil Breather Assembly
Valve Cover Breather Hose Assembly
Oil Filter And Cooler Assembly
Front End Drive Input
Cooling Assembly
Thermostat Housing Assembly
Water Outlet And Inlet
Fan And Extension Assembly
Alternator And Generator Install
Auxillary Drive Option
Turbocharger Assembly
Turbo Manifold And Cooler Assembly
Turbo Actuator Assembly
Remote Air Charge Cooler
Lift Pump
Fuel Filter Install
Low Pressure Fuel System
Fuel Filter Assembly
Cold Start System
Engine Lifting Plate Install
Mountings Front And Rear
Heater Starter Switch
Oil Pressure Switch And Gauge
Temp Gauge And Sender
Radiator And Cooling Fitting Assembly
Fuel Re-Lift Pump Install
Filter
Miscellaneous And Auxillaries
Top Joint And Gasket Kit
Eng Support Group-Perkins
Arm Assembly-Pulley
Engine Group-Perkins
Housing Assembly-Flywheel
Package-Parts,Ford
Flywheel Assembly
Motor-Starter
Driveline Group
Drive Train Group-Manual
Shaft Drive T-S,Manual R B 523030d1
Shaft-Drive 80-108 Hd
Transmission Assembly
Differential Assembly
Shaft-Drive,T-5 Manual
Shaft Drive 80-108 (Replaced By Wr55933)
Chaincase Group-Sc
Hub Assembly-Wheel
Brake Group-Power,4640
Cylinder Assembly-Brake
Valve-Modulating
Pedal Assembly-Brake
Brake Assembly,Lh
Brake Assembly,Rh
F A-Driveshaft Extension
Option-Belly Pan W F,Factory
Frame And Suspension Group
Axle Group-Adjust
Footboard Group-Sc
Frame Assembly 80 Inch Wide Front
F A-Front Extension,Sc
F A-Crop Deflector,Wf,
Steering Assembly-Arm
Hitch-Install
Axle And Steering Group
Steering Group-Wf,80 In
Tie Rod Assembly-340-80
Steering Column
Wide Front Group-Sc
Fuel System Group
Fuel Group-Perkins,Sc
Tank Assembly
Hydraulic Group
Hydraulic Group-Chassis,
Valve-Charge
Valve Assembly-Control
Valve-Check,Cv08200n25
Cylinder-Hydraulic,2.00x20.00x1.00
Cylinder-Hydraulic,1.75x6.19x1.00
Grip Assembly-Handle
Valve-Float,2 Position
Pump-Hydraulic
Tank Assembly-Hydraulic
Valve-Steering
Cylinder-Hydraulic,1.75x16.84x1.00
H Frame
Valve Assembly-6 Spool
Cylinder-Hydraulic,2.00x4.00x1.00
Hydraulic Install-Kit No H Frame
Valve-Relief Assembly Boom
Cylinder-Hydraulic,1.50x8.38x0.88
Hydraulic Group-Hydraulic Fold
Cab Group
Clutch Pedal Group-Sc
Pedal Assembly-Clutch
Control Group-Trans Shift
Linkage Assembly-Shift
Cab Group-4000 Mt
Top Assembly-Cab
Control Group-Joystick
Install-Throttle
Pedal Assembly-Throttle
Kit-Radio,Sc,Europe
Seat Group-Sc
Seat-Suspension
Kit-Motor,Wiper
Ignition Switch Loader
Kit-Wiper Motor
Kit Hardware Wj3
Heater-Kit
Air Conditioner Group-Sc
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Electrical Group
Cab Electrical Group
Electrical Group-4000 W
Light-Head
Gauge-Fuel,12v
Gauge-Oil Pressure
Gauge-Temperature,Water
Light Assembly
Alternator-140 Amp
Light-Flood,Med
Kit-Overspray
F A-Flood Light,Sc
Clutch Assembly
Appearance Group
Engine Cover Group-Wf Sc
Tire And Wheel Group
Tire Assembly-9x24 W 24 X W8,
Tire Assembly-12.4x24 W 24x10
Tire Assembly-7.5x24 W 24xw7,
Tire Assembly-9.5x32 W 32xw8,
Tire Assembly-9.5x32 W32xw8,
Decal Group
Final Assembly Group Manual
Tank And Saddle Group
Tank Assembly-Spray
Cover-Hinged
Insert Assembly-Sq End
Valve Assembly-Boom Shut Off,
Valve Assembly-Kz, 5 Section,
Valve W O Power Head
Insert-Seat,Qc3
Spray System Assembly-3 Valve
Valve-Pressure,Control
Manifold Group-20 In ,Sc
Nozzle Assembly-Single
Nozzle Assembly-Double
Filter Assembly-Boom
Manifold Group-20, 80 Ft
Spray System Assembly-5 Valve
Spray Install-Ctr Manifold
Spray System Group
Spray Install-Loose Parts Kit
Valve-Control, 1.00npt 2.00sp Flg
Valve 5-Section-Boom Shut Off
Valve Assembly, 2.00sp Flg X O-Ring
Valve Assembly-Kz,5 Section,
Spray Sys-Group,Chassis
Strainer-Manifold
Valve Assembly R B 426406
Valve R B 056871
Strainer Assembly Less Screen 1.25
Manifold Assembly-Spray
Pump-Spray
Valve Assembly-Inlet
Valve-Ball,2 In Fp,W Cam
Filter-Inline
Valve Ball, 0.75 Poly Ff
Valve 3-Way, 2.00 Bottom Load
Valve Teejet
Spray System Group-H Frame
Valve Assembly-Kz, 3 Section,
Gauge-Flow
Nozzle Assembly-Drop
Boom Group
Boom Lift Group
Rear H Frame Group
Boom Group-60 Ft Hydraulic Fold
Boom Assembly-Rh,60 Ft Hydraulic
Boom Assembly-Rh
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Assembly-Lh,60 Ft Hydraulic
Boom Assembly-Lh
Tilt Rack Assembly
Tube Assembly-Rack Tilt
Boom Group-80 Ft Hydraulic Fold
Boom Assembly-Rh,80 Ft Hydraulic
Boom Assembly-Lh,80 Ft Hydraulic
Kit-Loose Parts,Boom Hinge
Controller Group
Kg-3600wf Raven Mount
Option-Fieldstar,Wf,3 Valve
Option-Gps Receiver,5hz,Sc
Install-Fieldstar, Ctrlt, S C
Option-Fieldstar,Wf,5 Valve
Option-Fieldstar,Wf,3 Valve,W 0
Option-Fieldstar,Wf,5 Valve,W O
Option-Lightbar,Spra-Coupe
Kit-Gps Antenna Mount,Sc
Controller Raven Package
Foam Marker Group
F A-Marker,Rsc 2130
Rsc Foamhead Valve Assembly
Deflector-Collector, 2 In
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In
Filter Assembly, Incline
Filter Assembly-Carbon
Compressor-Foam Marker
Module, Control
Options Group
Fresh Water Group-Sc
F A-Belly Pan,Wf
Recommended Dealer Stock
Brand: Spra-Coupe
Engine Group
Cooling Group-Sc
Filter Air Group-Sc
Air Filter Assembly
Engine-Perkins
Short Engine
Cylinder Block Kit
Cylinder Head Kit
Conrod Kit
Fan Drive Assembly
Oil Sump Assembly
Oil Filter Assembly
Cooling Assembly
Lift Pump
Fuel Filter Install
Cold Start System
Filter
Arm Assembly-Pulley
Package-Parts,Ford
Flywheel Assembly
Motor-Starter
Driveline Group
Chaincase Group-Sc
Hub Assembly-Wheel
Valve-Modulating
Brake Assembly,Lh
Brake Assembly,Rh
Axle Group-Adjust
Footboard Group-Sc
Hitch-Install
Steering Column
Wide Front Group-Sc
Fuel System Group
Tank Assembly
Hydraulic Group
Valve-Charge
Pump-Hydraulic
Valve-Steering
H Frame
Cab Group
Cab Group-4000 Mt
Top Assembly-Cab
Install-Throttle
Kit-Radio,Sc,Europe
Seat Group-Sc
Seat-Suspension
Kit-Motor,Wiper
Kit-Wiper Motor
Kit Hardware Wj3
Heater-Kit
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Electrical Group
Light-Head
Gauge-Fuel,12v
Gauge-Oil Pressure
Light Assembly
Alternator-140 Amp
Light-Flood,Med
Kit-Overspray
F A-Flood Light,Sc
Clutch Assembly
Appearance Group
Decal Group
Tank Assembly-Spray
Cover-Hinged
Insert-Seat,Qc3
Spray System Group
Strainer-Manifold
Valve R B 056871
Pump-Spray
Filter-Inline
Valve Teejet
Gauge-Flow
Boom Group
Boom Lift Group
Rear H Frame Group
Boom Assembly-Rh
Boom Assembly-Lh
Tilt Rack Assembly
Controller Group
Foam Marker Group
F A-Marker,Rsc 2130
Module, Control
Options Group
F A-Belly Pan,Wf
- Spra Coupe EU 4460 4660 Sprayer Service Manual_79034247B
- Spra Coupe EU 4460 4660 Manual Transmission Operator Manual_519177D1D
- Spra Coupe SA 7000 Series SPRA-COUPE Service Manual_WR132165
- Spra Coupe EU 7460 7660 Sprayer System RTS_AG333725A
- Spra Coupe EU 7000 Series Sprayer Service Manual_79027326A
- Spra Coupe EU 7460 7660 Applicator Chassis Service Manual_79032953B
- Spra Coupe EU 4460 4660 Man Sprayer Repair Time Schedule_AG335277A
- Spra Coupe EU 4460 4660 Sprayer Automatic Transmission Operator Manual_519176D1D
- Spra Coupe EU 4455 4655 Sprayer Automatic Transmission Operator Manual_512150D1D
- Spra Coupe EU 4450 4650 4455 4655 Sprayer Service Manual_79027328B
- Spra Coupe SA 7000 Series Sprayer Service Manual_79027326
- Spra Coupe EU 7450 7650 Sprayer System Repair Time Schedule_AG331640A
- Spra Coupe EU 4460 4660 Auto Sprayer Repair Time Schedule_AG335025A
- Spra Coupe EU 7460 7660 Applicator Chassis RTS_AG333724A
- Spra Coupe SA 7450 7650 System Repair Time Schedule_AG331640A
