Spra-Coupe Sprayer 4640-80 Parts Catalog WR128522
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 4640-80 Sprayer
Part Number: WR128522
Number of Pages: 1560 Pages
Publication Information
Engine Group
Engine-Perkins
Short Engine
Cylinder Block Kit
Rear Oil Seal Assembly
Cylinder Head Kit
Rocker Shaft Assembly
Timing Gear And Camshaft Assembly
Oil Pump And Housing Assembly
Crankshaft Rod And Piston Assembly
Conrod Kit
Fuel Injection Equipment
Flywheel Housing Assembly
Fan Drive Assembly
Oil Sump Assembly
Oil Filter Assembly
Oil Breather Assembly
Valve Cover Breather Hose Assembly
Oil Filter And Cooler Assembly
Front End Drive Input
Cooling Assembly
Thermostat Housing Assembly
Water Outlet And Inlet
Fan And Extension Assembly
Alternator And Generator Install
Auxillary Drive Option
Turbocharger Assembly
Turbo Manifold And Cooler Assembly
Turbo Actuator Assembly
Remote Air Charge Cooler
Lift Pump
Fuel Filter Install
Low Pressure Fuel System
Fuel Filter Assembly
Cold Start System
Engine Lifting Plate Install
Mountings Front And Rear
Heater Starter Switch
Oil Pressure Switch And Gauge
Temp Gauge And Sender
Radiator And Cooling Fitting Assembly
Fuel Re-Lift Pump Install
Filter
Miscellaneous And Auxillaries
Top Joint And Gasket Kit
Engine-Perkins,Tpem
Kit,Engine Overhaul
Kit, Thrust Washer
Kit,Thrust Washer
Kit, Valve Train
Piston,Conn Rod
Turbocharger, Assembly
Gasket Kit
Engine Support Group-Perkins
Arm Assembly-Pulley
Engine Group-Perkins
Motor-Starter
Throttle Group-4000,Sc
Throttle Assembly-Hand
Cooling Group-Sc
Filter Air Group-Sc
Air Filter Assembly
Exhaust Group-Perkins,Sc
Driveline Group
Chaincase Group-Sc
Hub Assembly-Wheel
Brake Group-Power,4640
Cylinder Assembly-Brake
Pedal Assembly-Brake
Valve-Modulating
Brake Assembly,Lh
Brake Assembly,Rh
Drive Train Group
Transmission-A618 Reman
Shaft-Drive 80-108 Hd
Differential Assembly
Shaft-Drive,Auto
Shaft Drive 80-108 (Replaced By Wr55933)
F A-Driveshaft Extension
Frame And Suspension Group
Axle Group-Adj
Frame Group-4640,Sc
Channel Assembly 80 Inch
Frame Assembly 80 Inch Wide Front
Footboard Group-Sc
F A-Front Extension,Sc
F A-Crop Deflector,Wf,
Steering Assembly-Arm
Hitch-Install
Axle And Steering Group
Wide Front Group-Sc 46 Series 80 Inch Frame
Steering Group-Wide Front,80 Inch
Tie Rod Assembly-340-80
Steering Column
Fuel System Group
Fuel Group-Perkins,Sc
Tank Assembly
Hydraulic Group
Tube Assembly
Hydraulic Group-Hydraulic Fold
Valve Assembly-6 Spool
Valve-Check,Cv08200n25
Cylinder-Hydraulic,2.00x4.00x1.00
Valve-Relief Assembly Boom
Cylinder-Hydraulic,R B 129450
Hydraulic Group-Chassis,
Valve-Charge
Valve Assembly-Control
Grip Assembly-Handle
Pump-Hydraulic
Tank Assembly-Hydraulic
Cylinder-Hydraulic,2.00x20.00x1.00
Cylinder-Hydraulic,1.75x6.19x1.00
Valve-Float,2 Position
Valve-Steering
Cylinder-Hydraulic,1.75x16.84x1.00
Cylinder-Hydraulic,1.50x8.38x0.88
Cab Group
Shift Group-Auto,Sc
Control-Shift,A T
Kit-Radio,Sc,Europe
Install-Seat
Seat-Suspension
Cab Group-4000 Mt
Top Assembly-Cab
Kit-Motor,Wiper
Seat Group-Sc
Ignition Switch Loader
Kit-Wiper Motor
Kit Hardware Wj3
Blower-Kit
Fan Assembly
Heater-Kit
Air Conditioner Group-Sc
Air Conditioner-Kit
Electrical Group
Cab Electrical Group
Electrical Group-Sc
Gauge-Fuel,12v
Light Assembly
Alternator-140 Amp
Gauge-Oil Pressure
Gauge-Temperature,Water
Light-Flood,Med
Kit-Overspray
F A-Flood Light,Sc
Clutch Assembly
Appearance Group
Engine Cover Group-Wf Sc
Install-Cover,Engine,W-F
Tire And Wheel Group
Tire Assembly-9x24 W 24 X W8,
Tire Assembly-12.4x24 W 24x10
Tire Assembly-7.5x24 W 24xw7,
Tire Assembly-9.5x32 W 32xw8,
Tire Assembly-9.5x32 W32xw8,
Decal Group
Final Assembly Group-4640wf
Tank And Saddle Group
Tank Assembly-Spray
Cover-Hinged
Insert Assembly-Sq End
Spray System Assembly-3 Valve
Valve-Pressure,Control
Manifold Group-20 In ,Sc
Nozzle Assembly-Single
Nozzle Assembly-Double
Filter Assembly-Boom
Manifold Group-20, 80 Ft
Spray System Assembly-5 Valve
Spray Install-Ctr Manifold
Spray System Group
Spray Install-Loose Parts Kit
Valve 5-Section-Boom Shut Off
Valve Assembly-2.00sp Flg X O-Ring
Valve-Control, 1.00npt 2.00sp Flg
Valve Assembly-Boom Shut Off,
Valve Assembly-Kz, 3 Section,
Valve W O Power Head
Insert-Seat,Qc3
Valve Assembly-Kz, 5 Section,
Gauge-Flow
Valve Assembly-Kz,5 Section,
Spray Sys-Group,Chassis
Manifold Assembly-Spray
Valve Assembly R B 426406
Valve R B 056871
Valve Assembly-Inlet
Valve-Ball,2 In Fp,W Cam
Strainer-Manifold
Strainer Assembly Less Screen 1.25
Pump-Spray
Valve Ball, 0.75 Poly Ff
Valve Teejet
Nozzle Assembly-Drop
Boom Group
Boom Group-60 Ft Hydraulic Fold
Boom Assembly-Rh,60 Ft Hydraulic
Boom Assembly-Rh
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Assembly-Lh,60 Ft Hydraulic
Boom Assembly-Lh
Spring, Assembly
Bag-Parts
Tilt Rack Assembly
Tube Assembly-Rack Tilt
Boom Group-80 Ft Hydraulic Fold
Boom Assembly-Rh,80 Ft Hydraulic
Boom Assembly-Lh,80 Ft Hydraulic
Rear H Frame Group
Kit-Loose Parts,Boom Hinge
Boom Lift Group
Controller Group
Controller Raven Package
Kg-3600wf Raven Mount
Option-Fieldstar,Wf,3 Valve
Option-Gps Receiver,5hz,Sc
Install-Fieldstar, Ctrlt, S C
Option-Fieldstar,Wf,5 Valve
Option-Fieldstar,Wf,3 Valve,W 0
Option-Fieldstar,Wf,5 Valve,W O
Option-Lightbar,Spra-Coupe
Kit-Gps Antenna Mount,Sc
Foam Marker Group
F A-Marker,Rsc 2130
Deflector-Collector, 2 In
Rsc Foamhead Valve Assembly
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In
Filter Assembly, Incline
Compressor-Foam Marker
Filter Assembly-Carbon
Module, Control
Options Group
Fresh Water Group-Sc
F A-Belly Pan,Wf
Recommended Dealer Stock
