Spra-Coupe Sprayer 4460 4660 Parts Catalog 518481D1
Brand: Spra-Coupe
Type of Machine: Sprayer
Model:
Spra-Coupe 4460 Sprayer
Spra-Coupe 4660 Sprayer
Part Number: 518481D1
Number of Pages: 2977 Pages
Publication Information
50 Hr Filter Kit
500 Hr Filter Kit
Engine Support Install-Mt
Arm Assembly-Pulley
Engine Install-40x6mt Perkins
Engine-1104d Perkins Tier 3 Mt
Rear End Oil Seal Assembly
Dipstick And Filler Tube Assembly
Oil Strainer Assembly
Blanking Plate Assembly
Front End Drive Input Assembly
Fan Assembly
Timing Cover Assembly
Oil Pump And Delivery Housing Assembly
Leak-Off Pipe Assembly
Engine Mounts Assembly
Temperature Gauge And Sender Assembly
Plug, Blanking Assembly
Engine Assembly-Short
Rods Connecting
Kit Crankshaft
Crankshaft-Main And Big Bearing
Camshaft Timing Gear
Atomisers
Engine Control Module
Rocker Shaft Assembly
Fan Drive
Sump
Cylinder Head Cover
Breather
Oil Filter
Pipes
Water Outlet Housing
Timing Case
Exhaust Manifold
Feed Pipes
Turbocharger Assembly
Wastegate Sensor Assembly
Pipework Connections Assembly
Piston Rings Assembly
Fuel Leak-Off Pipe
Fuel Pipes-Low Pressure
Heater Plugs
Engine Lifting Eyes
Lube Oil Pressure Switch Gauge
Wiring Looms
Wiring Looms Assembly
Pump, Fuel Pre-Lift Assembly
Filter Kit-Fuel,Perkins
Water Trap Assembly
Auxiliaries Miscellaneous
Cylinder Block Assembly
Cylinder Block Liners Assembly
Cylinder Head Assembly
Blanking Plates Assembly
Filler Assembly
Pipework
Induction Manifold Assembly
Engine Control Module Assembly
Fuel Rail Assembly
Fuel Pipes-High Pressure
Fuel Pump-High Pressure Assembly
Pipework Assembly
Sensors Assembly
Motor-Starter
Package-Parts,Ford
Cooling Install
Cooling Package Assembly
Tank-Dearation
Expansion Tank Install
Alternator,140 Amp-2 Groove
Air Cleaner Install
Filter-Air
Tank-Dearating
Exhaust
Fuel Install
Differential Assembly
Steering Wide Front,80 In
Steering Column #9203218-C
Hub Assembly
Hub Assembly-Wheel
Steering Wf,80in
Tie Rod Assembly-340-80
Steering Wf,72in
Tie Rod Assembly-3440-72
Steering Sf
Wide Front 80in 2010 And Before
Frame Assembly 80 Inch Wide Front
Wide Front 80in, 4660 2011 And Up
Wide Front 72in 2010 And Before
Frame Assembly 72 Inch Wide Front
Wide Front 72in, 4460 2011 And Up
Wide Front Group 2010 And Before
Wide Front 80in, 4460 2011 And Up
Frame And Suspension
Frame Install-Manual 72 Inch 4000m7
Frame Install-Manual 80 Inch 4000m8
Frame-Adjust Rear 72 Inch
Frame-Adjust Rear 44xx Series 80 Inch
Frame-Adjust Rear 46xx Series 80 Inch
Front Suspension Install
Frame Install 4000m7
Frame Install 4000m8
Steering Assembly-Arm
Steer Install-No Tow,4650 80in
Steer Install-No Tow,4450 72in
Steer Install-No Tow,4450 80in
4460
Case-Chain,Drive,Lh,Assembly 4460
Case-Chain,Drive, Rh Assembly 4460
Chaincase Install 4660
Case-Chain,Drive,Lh,Assembly 4660
Case-Chain,Drive,Rh,Assembly 4660
4000 Mt
Transmission Assembly
Driveshaft Install-4000,80 In
Shaft-Drive 80-108 Hd
Driveshaft Install-4000,80 In (New)
Shaft-Drive 80-108 In (New)
Driveshaft Install- 80-88 In
Driveshaft Assembly-80-88 In
Shaft-Male Drive, 80-88 In
Shaft-Female Drive, 80-88 In
Driveshaft Install-4000,80-88 In
Driveshaft Assembly 80-88 New
Driveshaft, 80-88 In
72 In Driveshaft
Shaft-Drive,72 In
Driveshaft Install-4000,72 In
Driveshaft Extension Kit
Coupler, 6in Quick Disconnect (Old)
Oil Cooler Install
Brake Assembly- 6 Disc Left Hand
Brake Assembly- 6 Disc Right Hand
Cylinder Assembly-Brake
Pedal Assembly-4x60 Brake
Valve-Brake Modulating
Brake Install
Hydraulic Install-H Frame,Sc6080,4x50
Valve Install-Hydraulic,Boom,6 Bank,4x50
Valve Assembly-Hydraulic,Boom,6 Bank,4x50
Valve-Hydraulic,Boom,6 Bank
Valve-Check,Cv08200n25
Tube Install-Hydraulic,H Frame
Hose Install-Hydraulic,H Frame,4x50
Cylinder Assembly-Hydraulic,Boom Swing
Cylinder-Hydraulic,2.75x11x1.38, Boom Swing
Cylinder Assembly- Boom Tip Fold
Cylinder-2.00x16.00x1.25, Boom Tip Fold
Cylinder-2.25 X 1.00 X 6.5, Boom Tip Fold
Cylinder-1.75x16.84x1.25, Boom Lift
H Frame
Cylinder-Hydraulic,2.00x8.44x1.00, Boom Fold
Cylinder-Hydraulic,2.00x4.00x1.00, Boom Tilt
Assembly-Valve,Relief,Boom Tip
Valve Relief-Boom Tip
Valve-Cartridge,Check-08
Assembly Valve-Hydraulic, H Frame
Hydraulic Install-Chassis,4000at
Assembly Valve-2 Postion, Float
Grip Assembly-Handle
Valve-Float,2 Position
Assembly-Valve Charge
Valve-Charge
Assembly-Switch Pressure
Hydraulic Tank Assembly
Pump Assembly-Hydraulic
Elbow 90d 0.50mo-R X 0.50mjic
Pump-Gear,19cc,P5t
Adapter Assembly,-6mor X -6stor
Filter Assembly-Hydraulic
Assembly Valve-Hydraulic,4000,Chassis
Valve-Hydraulic,Boom Lift Track Adjust,3 Bank
Cylinder-Hydraulic,1.75x16.84x1.00, Boom Lift
Hydraulic Install-Chassis,4000at 60 80
Field,Gear Pump,19cc,P5t
Hydraulic Install-Chassis,4000mt
Hydraulic Install-Chassis,4000mt 60 80
Hydraulic Install-Wide Front Steering
Cylinder-Hydraulic,1.75x6.19x1.00, Steering
Hydraulic Install-80 Axle Adjust, 4000
Cylinder-Hyd,2.00x20.00x1.00, 80 Track Adjust
Hydraulic Install-72 Axle Adjust, 4000
Cylinder-Hyd,2.00x15.25x1.00, 72 Track Adjust
Cylinder-Hyd,2.00x14.25x1.00, 72 Track Adjust
Hose Install-Boom Tilt,Sc6080,7x50
Hose Install-Boom Tip,Sc6080,7x50
Hose Install-Boom Tip 6080
Hose Install-Hydraulic,Boom Lift,4x50
No H Frame
Hydraulic Install-Single Front Steering
Cylinder-Hydraulic,1.75x5.00x1.00, Steering
Hydraulic Install-Boom Fold
Cylinder-Hydraulic,1.50x8.38x1.00
Radio,Xm
Install-Antenna,Sat
Radio,Sirius
Radio Am Fm Stereo W Cd
Radio,Deluxe
Electrical Install-Cab, 4000mt
Windshield Washer
Light Assembly-Dome
Wiper Motor
Kit Hardware Wj3
Ignition Switch Loader
Gauge-Fuel,12v
Gauge-Oil Pressure
Gauge-Temperature,Water
Pedal-Throttle
Electrical Install-Chassis, 4000mt, Dom
Headlight-Halogen,Wrapping,Left Hand
Headlight-Halogen,Wrapping,Right Hand
Light Assembly
Lamp Cluster Rear Right Hand
Lamp Cluster Rear Left Hand
Cruise Control Module Assembly
Electrical Install-Chassis, 4000mt, Europe
Headlight Assembly-Wiring,Left Hand
Headlight Assembly-Wiring, Right Hand
Electrical Install-3 Valve
Battery Install
Electrical Install-Relief Valve
Electrical Install-5 Valve
Throttle Handle Assembly
Floodlight Kit
Work Light
Floodlight Kit,Hid
Light-Work,Hid
Seat Group-Basic
Seat Install
Seat Mechanical Suspension
Kit-Recliner Assembly
Cushion,Back
Service,Slides
Seat Top Sst
Kit-Pan Back W Lumbar
Kit-Lumbar,Sst
Seat Cushion
Arm Rest Right Hand
Arm Rest Left Hand
Seat Air Suspension
Suspension Boot-Air
Air Suspension
Service,Boot,Lp Air
Seat Deluxe
Seat Install-Deluxe,Manual Transmission
Cab Install-Mt 2008-2009
Cab Install-Mt,Challenger 2008-2009
Cab Install- Mt 2010
Cab Door Assembly-Painted
Clutch Pedal Install
Shift Install-Mt
Joystick Install
Radio Accessory
A C Kit-Cab
A C Kit-Front
Blower Kit
Heater Kit
White
Challenger Yellow
Hood Install-Challenger
Belly Pan Install-Single Front
Footboard 44xx Series Manual
Footboard
Channel Assembly 80 Inch
Channel Assembly 72 Inch
Footboard Group-W O Boomrest,4450mt
Footboard Group-W O Boomrest,4650mt
Footboard 44xx Mt
Footboard 46xx Mt
Footboard W O Boomrest,44xx Mt
Footboard W O Boomrest,46xx Mt
Shield Install-Belt
Crop Deflector,3400 4400
Crop Deflector,3600 4600
Belly Pan Install-Wf,At
Belly Pan Install-Sf,Mt
Install-Front,Fender,Sc4
Install-Rear,Fender.Sc4460
Install-Rear,Small,Fender,Sc4660
Install-Toolbox
Box-Accessory,Molded
Product Containment
Tank Assembly,Spray
Insert Assembly-Sq End
Agitator-Aandm
Cover-Hinged
Primary Product Distribution
Spray Install-4000 Chassis
Valve Ball, 0.75 Poly Ff
Valve 3-Way, 2.00 Bottom Load
Pump Assembly- Spray W Clutch
Pump-Spray
Strainer-Manifold
Strainer Assembly Less Screen 1.25
Valve Assembly Inlet
Valve 2 Inch Mnpt X 2 In. Madap
Filter-Inline
Flowmeter Kit-2.00sp Flange, Rfm60p
Flowmeter-2.00sp Flg,Rfm60p,Cnxl
Secondary Product Distribution
Spray Install 4000mt, No Rinse
Spray Install-Sc4000,Mt,With Rinse
Tank Assembly-Spray
Strap Assembly-Fresh Water
Tank Assembly-Fresh Water
Tee Assembly-Check Valve
Valve Assembly-Sump, With Fresh Water
Valve Teejet
Ball Valve Assembly 1 Inch 3-Wire
5 Section Valve-Boom Shut Off
Valve Assembly-2.00sp Flange X O-Ring
Valve-Control,1.00npt 2.00sp Flange
Spray System Install-H Frame
3 Section Valve-Boom Shut Off
Spray Install-Loose Parts Kit
Manifold Install-Ctr,Sc6080,4xxx
Valve Assembly-5 Sect,Boom Shut Off
Valve Assembly-Inlet
Valve-Ball,2 In Fp,W Cam
Spray Install-60 Ft Manifold
Nozzle Assembly-Single
Nozzle Assembly-Double
Filter Assembly-Boom
Spray Install-80 Ft Manifold
Poly Plumbing,Sc6080x5x20,Off
Pipe Assembly-90d W .75hb,6x20.Poly
Bracket Assembly-L,.75 Stauff
Bracket Assembly-Z,Sh,.75ips
Pipe Assembly-T W 2 1.00hb,5x20,Poly
Pipe Assembly-T W 2 1.00hb,3x20,Poly
Pipe Assembly-90d W 1.00hb,2x20,Poly
Pipe Assembly-90d W .75hb,6x20,Poly
Bracket Assembly-L Lg Str,.75poly,2pclp
Bracket Assembly-L,.75 Stauff,Pclp,Std
Bracket Assembly-Z,Lg,.75 1.00ips,Pclp
Bracket Assembly-L,.75 Stauff,Rev Pclp
Bracket Assembly-Z,Lg,.75 1.00ips,1.0u
Bracket Assembly-Z,Sh,.75ips,1.00u
Bracket Assembly-L,.75 Stauff,1.00u
Mender Assembly-Hose,.75x1.00,Poly
Spray Install-Center Manifold
Option-Poly Plumbing,Sc6080x5x10,On
Pipe Assembly-90d W .75hb,11x10,Poly
Pipe Assembly-T W 2 1.00hb,10x10,Poly
Pipe Assembly-T W 2 1.00hb, 6x10,Poly
Pipe Assembly-90d W 1.00hb, 5x10,Poly
Nozzle,3 Way,Rotary,80x10,0n
Body-Nozzle,3 Way,Rotary,.75
Nozzle,3-Way,Rotary,80x20,Off
Coupler,6in Quick Disconnect (New)
Booms
Boom 60 80
Boom Assembly-60 80,Left Hand
Boom Assembly-60 80,Right Hand
Boom Assembly-60 80
Cam Assembly-Breakaway,60 80
Cam Assembly-Boom Breakaway
Boom Install-Lift Rack,H Frame,4x50
Hydraulic Install-Cap,Plug
Rack Install-Tilt,Boom,60 80
Rack Assembly-Tilt,Boom,60 90
Frame Install-H,Rear,Boom,60 80
Frame Assembly-H,Rear,B00m,60 80
Lift Install-Boom,Par Link,4x50
Bar Install-Mounting,Plumbin,Ctr,Sc6080
Bag-Loose Parts,60 80
Block Install-Boom Rest,4x50
Tube Assembly-Rack Tilt
Frame Assembly-H,Rear,Boom,60 80
Boom Right Hand,60 Ft
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Left Hand,60 Ft
Boom Right Hand,80 Ft
Boom Left Hand,80 Ft
Boomrest Install-Sc6080,4x50
Kit-Loose Parts,Boom Hinge
Bag-Parts
Tilt Rack Assembly
Boom Lift
Rear H Frame Sc4060, Sc4080
Boom,Sc4060
Boom,Sc4080
Boom Install-Center,H Frame Tilt
Install Hydraulic-H Frame 40 80
Foam Marker
Rsc 2130
Rsc Foamhead Valve Assembly
Deflector-Collector, 2 In
Filter Assembly, Incline
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In
Compressor-Foam Marker
Filter Assembly-Carbon
Hood
Spray
Decal Install -Cab, Inside Na
Decal Install -Chassis
Suspension
Decal Install-Cab, Outside
Decal Install-Cab, Inside
Decal Install-Chassis
Decal 4460, Mt
Decal Install 4xxx, (International)
Decal 4xxx (International) 2010
Decal Install 4xxx, (North American)
Decal 4xxx (North American) 2010
Decal 4660, Mt
Decal 4460,At 2010
Decal Install-Sc4460,At 2010
Decal 4660,At 2010
Decal Install-Sc4660,At 2010
Decal 4460,Mt 2010
Decal Install-Sc4460,Mt 2010
Decal 4660,Mt 2010
Decal Install-Sc4660,Mt 2010
Decal Install-Sc4460,Mt 2012
Decal Install-Sc4660,Mt 2012
Decal Install-Chemical Eductor,Na
Decal Install-Chemical Eductor,Int
Tire Install-10.00x16,Gray
Tire Assembly-10.00-16,Gray
Tire Install-320 85r24,Gray,Rear
Tire Assembly-320 85r24,Left Hand,Gray
Tire Assembly-320 85r24,Right Hand,Gray
Tire Install-380 85r24,Gray
Tire Assembly-380 85r24,Left Hand,Gray
Tire Assembly-380 85r24,Right Hand,Gray
Tire Install-230 95r32, Gray
Tire Assembly-230 95r32, Left Hand Gray
Tire Assembly-230 95r32, Right Hand Gray
9.00x24,Gray
Tire Assembly-9.00x24,Gray
320 85r24,Gray
9.00x24,Gray,Fld
Tire Assembly-9.00x24,Gray,Fld
320 85r24,Gray,Fld
Controller System
Ogps,Rpr 100s, Sc 4000
Gps Antenna Mount
Gps Antenna Mounting
Install-Rgl600t,3 4x50
Kit-Lightbar,Rgl600t
Controller Install-Raven 460,Single
Tag Assembly, Calibration
Controller Install-Raven 460,Wide Front
Receiver Phoenix 300,Sc4xx
Receiver Install-Phoenix 300,Raven
Gps,Phoenix 300
Electric Install-Receiver
Guidance System
Gps,Phoenix 200
Lightbar Group-Sc4x60,Rgl600
Lightbar Install-Rgl600
Kit-Lightbar,Rgl600
Hitch-Install
Fresh Water Install
Overspray Install
F I-Chemical Eductor,Poly,Sc4xxx
Chem Eductor-Instl,Pe,Sc4xxx
Eductor Asm-Chemical,Pe
Agitator-Instl,Sc4xxx
Fitting-Tank,2.00flg X 2.00 Inch Full Port
Vlv Poly 1.25
Eductor-Chem,Cleanload Ii,Pe
Triple Nozzle Bodies, 80ft
Nozzle Kit Xrc11003vp, 50
Nozzle Kit Xrc11003vp, 60
Nozzle Kit Xrc11003vp, 75
F I-Filling Pump
Pump-Install,Filling
Pump Unit, Engine Driven,5hp
F A-Filling Pump
