Spra-Coupe Sprayer 4460 4660 Parts Catalog 518480D1
Brand: Spra-Coupe
Type of Machine: Sprayer
Model:
Spra-Coupe 4460 Sprayer
Spra-Coupe 4660 Sprayer
Part Number: 518480D1
Number of Pages: 3099 Pages
Publication Information
50 Hr Filter Kit
500 Hr Filter Kit
Engine Support Install-At
Arm Assembly-Pulley
Engine Install-4x60at Perkins
Motor-Starter
Engine-1104d Perkins Tier 3
Rear End Oil Seal Assembly
Dipstick And Filler Tube Assembly
Oil Strainer Assembly
Blanking Plate Assembly
Front End Drive Input Assembly
Fan Assembly
Timing Cover Assembly
Oil Pump And Delivery Housing Assembly
Leak-Off Pipe Assembly
Pipework And Connections Assembly
Temperature Gauge And Sender Assembly
Plug, Blanking Assembly
Engine Assembly-Short
Rods Connecting
Kit Crankshaft
Camshaft Timing Gear
Atomisers
Fuel Rail
Engine Control Module
Flywheel Housing
Rocker Shaft Assembly
Flywheel Starter Ring
Fan Drive
Blanking Plates
Sump
Cylinder Head Cover
Breather
Filler
Oil Filter
Pipes
Water Outlet Housing
Timing Case
Exhaust Manifold
Feed Pipes
Pipework Connections Assembly
Turbocharger Assembly
Pipework Assembly
Wastegate Sensor Assembly
Piston Rings Assembly
Fuel Pump-High Pressure Assembly
Fuel Filter Assembly
Fuel Leak-Off Pipe
Fuel Pipes-Low Pressure
Fuel Pipes-High Pressure
Sensors Assembly
Heater Plugs
Engine Lifting Eyes
Engine Mounts-Blanking Plugs
Lube Oil Pressure Switch Gauge
Wiring Looms
Wiring Looms Assembly
Pump, Fuel Pre-Lift Assembly
Filter Kit-Fuel,Perkins
Water Trap Assembly
Pre-Fuel Filter Assembly
Fuel Filter Bowl
Auxiliaries Miscellaneous
Cooling Install
Cooling Package Assembly
Tank-Dearation
Expansion Tank Install
Alternator,140 Amp-2 Groove
Shift Allison
Shifter Assembly-Allison
Air Cleaner Install
Filter-Air
Tank-Dearating
Exhaust Install-4450at And 4650at
Fuel Install
Air Filter Install
Hub Assembly-Wheel
Steering Wf,80in
Steering Column #9203218-C
Tie Rod Assembly-340-80
Steering Wf,72in
Tie Rod Assembly-3440-72
Steering Sf
Wide Front 80in 2010 And Before
Frame Assembly 80 Inch Wide Front
Wide Front 80in, 4660 2011 And After
Wide Front 2in 2010 And Before
Frame Assembly 72 Inch Wide Front
Wide Front 72in, 4460 2011 And After
Wide Front 2010 And Before
Wide Front 80in, 4460 2011 And After
Extension Install-Front
Steering Wide Front,80 In
Tie Rod Assembly-3440-80
Single Front
Hub Assembly
Differential Assembly
Frame And Suspension
Frame-Adjust Rear 72 Inch
Frame-Adjust Rear 44xx Series 80 Inch
Frame-Adjust Rear 46xx Series 80 Inch
Channel Assembly 80 Inch
Channel Assembly 72 Inch
Frame Install-Auto 72 Inch 4000a8
Frame Install-Aut O80 Inch 4000a8
Frame Install 4000a7
Frame Install 4000a8
Steering Assembly-Arm
Steer Install-No Tow,4650 80 In
Steer Install-No Tow,4450 72 In
Steer Install-No Tow,4450 80 In
Old
New
Drivetrain Install-At,Sc4x60
Driveshaft,Auto Allison
Cooler Assembly-At Oil
Oil Cooler Install
Driveshaft Install-4000,80 In
Shaft-Drive 80-108 Hd
Driveshaft Install-4000,80 In (New)
Shaft-Drive 80-108 In (New)
Driveshaft Install- 80-88 In
Driveshaft Assembly-80-88 In
Shaft-Male Drive, 80-88 In
Shaft-Female Drive, 80-88 In
Driveshaft Install-4000,80-88 In (New)
Driveshaft Assembly 80-88 New (New)
Driveshaft, 80-88 In
72 In Driveshaft
Shaft-Drive,72 In
Driveshaft Install-4000,72 In (New)
Shaft-Drive,72 In (New)
Driveshaft, Auto Allison
Driveshaft Extension Kit
Coupler, 6in Quick Disconnect (Old)
Drivetrain Install-At, 4450 4650
5c X 1310 Driveshaft
4460
Case-Chain,Final Drive,Left Hand,Assembly 4460
Case-Chain, Final Drive, Right Hand Assembly 4460
4660
Case-Chain,Final Drive,Left Hand,Assembly 4660
Case-Chain,Final Drive,Right Hand,Assembly 4660
Coupler,6in Quick Disconnect (New)
Brake Assembly- 6 Disc Left Hand
Brake Assembly- 6 Disc Right Hand
Cylinder Assembly-Brake
Pedal Assembly-4x60 Brake
Valve-Brake Modulating
Brake Install-4660
Brake Install-4460
H Frame,Sc6080,4x50
Valve Install-Hydraulic,Boom,6 Bank,4x50
Valve Assembly-Hydraulic,Boom,6 Bank,4x50
Valve-Hydraulic,Boom,6 Bank
Valve-Check,Cv08200n25
Tube Install-Hydraulic,H Frame
Hose Install-Hydraulic,H Frame,4x50
H Frame, Sc4060, Sc4080
Cylinder-Hydraulic,2.00x8.44x1.00, Boom Fold
Cylinder-Hydraulic,2.00x4.00x1.00, Boom Tilt
Assembly-Valve,Relief,Boom Tip
Valve Relief-Boom Tip
Valve-Cartridge,Check-08
Assembly Valve-Hydraulic, H Frame
H Frame Only
Cylinder Assembly-Hydraulic,Boom Swing, Sc6080
Cylinder-Hydraulic,2.75x11x1.38, Boom Swing
Cylinder Assembly- Boom Tip Fold
Cylinder-Hydraulic,2.00x16.00x1.25, Boom Tip Fold
Cylinder-Hydraulic,2.25 X 1.00 X 6.5, Boom Tilt
Cylinder,1.75x16.84x1.25,Boom Lift R B522456d1
Cylinder-Hydraulic 1.75x16.84x1.25, Boom Lift
Hydraulic Install-Chassis,4000at
Assembly Valve-2 Postion, Float
Grip Assembly-Handle
Valve-Float,2 Position
Assembly-Valve Charge
Valve-Charge
Assembly-Switch Pressure
Hydraulic Tank Assembly
Pump Assembly-Hydraulic
Pump-Gear,19cc,P5t
Adapter Assembly,-6mor X -6stor
Elbow 90d 0.50mo-R X 0.50mjic
Filter Assembly-Hydraulic
Cylinder-Hydraulic,1.75x16.84x1.00 Boom Lift
Assembly Valve-Hydraulic,4000,Chassis
Valve-Hydraulic,Boom Left Track Adjust,3 Bank
Kit-Field,Gear Pump,19cc,P5t
Hydraulic Install-Chassis,4000at 60 80
Hydraulic Install-Wf Steering
Cylinder-Hydraulic,1.75x6.19x1.00, Steering
Hydraulic Install-80 Axle Adjust, 4000
Cylinder-Hyd,2.00x20.00x1.00, 80 Track Adjust
Hydraulic Install-72 Axle Adjust, 4000
Cylinder-Hyd,2.00x15.25x1.00, 72 Track Adjust
Cylinder-Hyd,2.00x14.25x1.00, 72 Track Adjust
Hose Install-Boom Tilt,Sc6080,7x50
Hose Install-Boom Tip,Sc6080,7x50
Hose Install-Boom Tip Sc6080,4xxx
Hose Install-Hydraulic,Boom Lift,4x50
No H Frame
Hydraulic Install-Single Front Steering
Cylinder-Hydraulic,1.75x5.00x1.00, Steering
Hydraulic Install-Boom Fold
Cylinder-Hydraulic,1.50x8.38x1.00 Boom Fold
Cylinder,1.50x8.38x0.88 Boom Tip R B 527610d1
Chassis Hydraulic Install
Radio,Xm
Install-Antenna,Sat
Radio,Sirius
Radio Am Fm Stereo W Cd
Radio,Deluxe
Electrical Install-Cab, 4000at
Ignition Switch Loader
Windshield Washer
Gauge-Fuel,12v
Gauge-Oil Pressure
Gauge-Temperature,Water
Light Assembly-Dome
Pedal-Throttle
Wiper Motor
Kit Hardware Wj3
Electrical Install-Chassis, 4000at, Domestic
Headlight-Halogen,Wrapolying,Left Hand
Headlight-Halogen,Wrapolying,Right Hand
Light Assembly
Lamp Cluster Rear Right Hand
Lamp Cluster Rear Left Hand
Electrical Install-Chassis,4000at, Europe
Headlight Assembly-Wiring,Left Hand
Headlight Assembly-Wiring, Right Hand
Battery Install
Electrical Install-Relief Valve
Electrical Install-5 Valve
Throttle Handle Assembly
Floodlight Kit
Work Light
Floodlight Kit,Hid
Light-Work,Hid
4455 4655 At
Cab Install-4460 4660 At 2008-2009
Cab Install-4460 4660 At Challenger 2008-2009
Cab Install-4460 4660,Sc,At 2010
Cab Door Assembly-Painted
Seat Basic
Seat Install
Seat Mech Suspension
Recliner Assembly
Cushion,Back
Service,Slides
Seat Top Sst
Pan Back W Lumbar
Lumbar,Sst
Seat Cushion
Arm Rest Right Hand
Arm Rest Left Hand
Mechanical Suspension
Seat Deluxe
Seat Install-Deluxe, Auto Transmission
Seat Air Suspension
Suspension Boot-Air
Air Suspension
Service,Boot,Lp Air
Joystick Install
Radio Accessories
A C Kit-Cab
A C Kit-Front
Blower Kit
Heater Kit
White
Challenger Yellow
Hood Install-Challenger
Crop Deflector,3400 4400
Crop Deflector,3600 4600
Belly Pan Install-Sf
Shield-Center Assembly,Allison
Belly Pan Install-Sf,At
Belly Pan Install-Wf,At
Install-Front,Fender,Sc4
Install-Rear,Fender.Sc4460
Install-Rear,Small,Fender,Sc4660
Footboard Install-4450 At
Footboard Install-4650 At
Footboard W O Boomrest,4450at
Footboard W O Boomrest,4650at
44xx At
46xx At
Footboard W O Boomrest,44xx At
Footboard W O Boomrest,46xx At
Shield Install-Belt
Install-Toolbox
Box-Accessory,Molded
Product Containment
Tank Assembly,Spray
Insert Assembly
Agitator-A And M
Cover-Hinged
Primary Product Distribution
Strainer Assembly Less Screen 1.25
Valve 2 Inch Mnpt X 2 Inch Madap
Pump Assembly- Spray W Clutch
Pump-Spray
Secondary Product Distribution
Spray System Install-4000at Chassis
Valve Assembly Inlet
Filter-Inline
Valve 3-Way 2.00 Bottom Load
Valve Ball 0.75 Poly Full Flow
Strainer-Manifold
Flowmeter Kit-2.00sp Flange, Rfm60p
Flowmeter-2.00sp Flange,Rfm60p,Cnxl
Spray Install-Sc4000,At,With Rinse
Tank Assembly-Spray
Strap Assembly-Fresh Water
Tank Assembly-Fresh Water
Tee Assembly-Check Valve
Valve Assembly-Sump, With Fresh Water
Valve Teejet
Ball Valve Assembly 1 Inch 3-Wire
H Frame
5 Section Valve-Boom Shut Off
Valve Assembly-2.00sp Flg X O-Ring
Valve-Control,1.00npt 2.00 Sp Flange
Spray System Install-H Frame
3 Section Valve-Boom Shut Off
Spray Install-Loose Parts Kit
Manifold Install-Control,Sc6080,4xxx
Valve Assembly-5 Section,Boom Shut Off
Valve Assembly-Inlet
Valve-Ball,2 In Fp,W Cam
Spray Install-60 Ft Manifold
Nozzle Assembly-Single
Nozzle Assembly-Double
Filter Assembly-Boom
Spray Install-80 Ft Manifold
Option-Poly Plumbing,Sc6080x5x20,Off
Pipe Assembly-90d W .75hb,6x20.Poly
Bracket Assembly-L,.75 Stauff,Std
Bracket Assembly-Z,Sh,.75ips,Std
Pipe Assembly-T W 2 1.00hb,5x20,Poly
Pipe Assembly-T W 2 1.00hb,3x20,Poly
Pipe Assembly-90d W 1.00hb,2x20,Poly
Pipe Assembly-90d W .75hb,6x20,Poly
Bracket Assembly-L Lg Str,.75poly,2pclp
Bracket Assembly-L,.75 Stauff,Pclp,Std
Bracket Assembly-Z,Lg,.75 1.00ips,Pclp
Bracket Assembly-L,.75 Stauff,Rev Pclp
Bracket Assembly-Z,Lg,.75 1.00ips,1.0u
Bracket Assembly-Z,Sh,.75ips,1.00u
Bracket Assembly-L,.75 Stauff,1.00u
Mender Assembly-Hose,.75x1.00,Poly
Spray Install-Ctr Manifold
Poly Plumbing,Sc6080x5x10,On
Pipe Assembly-90d W .75hb,11x10,Poly
Pipe Assembly-T W 2 1.00hb,10x10,Poly
Pipe Assembly-T W 2 1.00hb, 6x10,Poly
Pipe Assembly-90d W 1.00hb, 5x10,Poly
Nozzle,3way,Rotary,80x10,0n
Body-Nozzle,3 Way,Rotary,.75
Nozzle,3 Way,Rotary,80x20,Off
Non Domestic Shipping
Booms
Boom 60 80
Boom Assembly-60 80,Left Hand
Boom Assembly-60 80,Right Hand
Boom Assembly-60 80
Cam Assembly-Breakaway,60 80
Cam Assembly-Boom Breakaway
Boom Install-Lift Rack,H Frame,4x50
Hydraulic Install-Cap,Plug
Rack Install-Tilt,Boom,60 80
Rack Assembly-Tilt,Boom,60 90
Frame Install-H,Rear,Boom,60 80
Frame Assembly-H,Rear,B00m,60 80
Lift Install-Boom,Par Link,4x50
Bar Install-Mounting,Plumbing,Ctr,Sc6080
Bag-Loose Parts,60 80
Block Install-Boomrest,4x50
Tube Assembly-Rack Tilt
Frame Assembly-H,Rear,Boom,60 80
Boom Right Hand,60 Ft
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Left Hand,60 Ft
Boom Right Hand,80 Ft
Boom Left Hand,80 Ft
Boomrest Install-Sc6080,4x50
Kit-Loose Parts,Boom Hinge4
Bag-Parts
Tilt Rack Assembly
Boom Lift
Rear H Frame Group Sc4060, Sc4080
Boom,Sc4060
Boom,Sc4080
Boom Install-Center,H Frame Tilt
Install Hydraulic-H Frame 40 80
Foam Marker
Rsc 2130
Rsc Foamhead Valve Assembly
Deflector-Collector, 2 In
Filter Assembly, Incline
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In
Compressor-Foam Marker
Filter Assembly-Carbon
Decal Install-Hood
Decal Install-Spray
Decal Install-Cab, Inside Na
Decal Install-Chassis
Decal Install-Suspension
Decal Install-Cab, Outside
Decal 4460, At
Decal Install (International)
Decal (International) 2010
Decal Install (North American)
Decal (North American) 2010
Decal 4660, At
Decal 4460,At 2010
Decal Install-Sc4460,At 2010
Decal 4660,At 2010
Decal Install-Sc4660,At 2010
Decal 4460,Mt 2010
Decal Install-Sc4460,Mt 2010
Decal 4660,Mt 2010
Decal Install-Sc4660,Mt 2010
Decal Install-Sc4460,At 2012
Decal Install-Sc4660,At 2012
Decal Install-Chemical Eductor,Na
Decal Install-Chemical Eductor,Int
Tire Install-10.00x16,Gray
Tire Assembly-10.00-16,Gray
Tire Install-320 85r24,Gray,Rear
Tire Assembly-320 85r24,Left Hand,Gray
Tire Assembly-320 85r24,Right Hand,Gray
Tire Install-380 85r24,Gray
Tire Assembly-380 85r24,Left Hand,Gray
Tire Assembly-380 85r24,Right Hand,Gray
Tire Install-230 95r32, Gray
Tire Assembly-230 95r32, Left Hand Gray
Tire Assembly-230 95r32, Right Hand Gray
9.00x24,Gray
Tire Assembly-9.00x24,Gry
320 85r24,Gray
9.00x24,Gray,Fld
Tire Assembly-9.00x24,Gry,Fld
320 85r24,Gray,Fld
Tire Assembly-320 85r24,Left Hand,Gray,Fld
Tire Assembly-320 85r24,Right Hand,Gray,Fld
Controller System
Controller Install-Raven 460,Sf
Tag Assembly, Calibration
Controller Install-Raven 460,Wf
Guidance System
Phoenix 200,Sc 4000
Antenna Mounting
Rpr 100s, Sc 4000
Install-Rgl600t,3 4x50
Lightbar, Rgl600t
Receiver Phoenix 300,Sc4xx
Receiver Install-Phoenix 300,Rav
Gps,Phoenix 300
Electric Install-Receiver,Sc4xxx
Lightbar, Rgl600
Lightbar Install-Rgl600
Lightbar,Rgl600
Fresh Water Install
Overspray Install
Hitch-Install
F I-Chemical Eductor,Poly,Sc4xxx
Chem Eductor-Instl,Pe,Sc4xxx
Eductor Asm-Chemical,Pe
Agitator-Instl,Sc4xxx
Fitting-Tank,2.00flg X 2.00 Inch Full Port
Vlv Poly 1.25
Eductor-Chem,Cleanload Ii,Pe
Triple Nozzle Bodies, 80ft
Nozzle Kit Xrc11003vp, 50
Nozzle Kit Xrc11003vp, 60
Nozzle Kit Xrc11003vp, 75
F I-Filling Pump,Sc4xxx
Pump-Install,Filling,Sc4xxx
Pump Unit, Engine Driven,5hp
