Spra-Coupe Sprayer 4455 Parts Catalog 506993D1
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 4455 Sprayer
Part Number: 506993D1
Number of Pages: 2445 Pages
Publication Information
Engine Group
50 Hr Filter Kit
500 Hr Filter Kit
Engine-Perkins 123hp,1104 Elec
Solenoid Mounting Assembly
Connecting Rod Assembly
Cylinder Block And Liners Assembly
Pistons And Rings
Rear End Oil Seal Assembly
Rocker Shaft Assembly
Timing Gear And Camshaft Assembly
Fan Drive Assembly
Sump Assembly
Dipstick And Filler Tube Assembly
Oil Strainer Assembly
Cylinder Head Cover
Cylinder Head Cover Assembly
Breather Assembly
Filler
Oil Filter Assembly
Blanking Plate Assembly
Front End Drive Input Assembly
Water Pump Assembly
Pipe Assembly
Water Outlet Housing Assembly
Fan Assembly
Timing Case Assembly
Timing Cover Assembly
Oil Pumpanddelivery Housing Assembly
Feed Pipe Assembly
Leak-Off Pipe Assembly
Pipework And Connections Assembly
Exhaust Manifold Assembly
Heater Plugs Assembly
Engine Lifting Eye Assembly
Miscellaneous And Auxiliary Assembly
Bottom Service Kit Assembly
Turbocharger Install
Assembly, Crankshaft
Cylinder Head Assembly
Pump Fuel Injection Assembly
Pipe Fuel Assembly
Atomizer Assembly
Mount Solenoid Assembly
Sensor Pickup Assembly
Housing Flywheel Assembly
Plug, Blanking Assembly
Manifold Induction Assembly
Pump Lift Assembly
Pipe, Fuel Assembly
Mount, Engine Assembly
Wiring, Loom Assembly
Pump, Lift Fuel Assembly
Kit, Gasket
Assembly, Filter, Fuel
Motor-Starter
Thermostat Housing
Thermostat Housing Assembly
Starter Install
Top Service Kit Assembly
Engine Support Install-At
Arm Assembly-Pulley
Air Cleaner Group
Filter-Air
Shift Group-Allison
Shifter Assembly-Allison
Cooling Install
Tank-Dearating
Exhaust Install-4450at And 4650at
Transmission Group
Kit-Auto Transmission,Allison,Sc4x50
Transmission-Auto, 2100rds
Kit-Bolt,Flexplate Adapter
Kit-Auto Trans,Allison,Sc4x60
Driveline Group
Drivetrain Install-At, 4450 4650
Differential Assembly
Driveshaft,Auto Allison
5c X 1310 Driveshaft
Cylinder Assembly-Brake
4455
Case-Chain, Final Drive, Lh Assembly
Hub Assembly-Wheel
Case-Chain, Final Drive, Rh Assembly
4460
Case-Chain,Final Drive,Lh,Assembly
Wf,80in
Tie Rod Assembly-3440-80
Steering Column
Sf
Hub Assembly
Driveshaft, Auto Allison
Driveshaft,Auto Allison R B 547155d1
Option-72in Driveshaft
Shaft-Drive,72in
Driveshaft Install-4000,80
Shaft-Drive 80-108 Hd
Shaft-Male Drive, 80-88 In
Shaft-Female Drive, 80-88in
Driveshaft Assembly-80-88in
Driveshaft Install- 80-88in
Fa-Driveshaft, 80-88in
Frame And Suspension Group
Frame Assembly 80 Inch Wide Front
Frame Assembly 72 Inch Wide Front
Frame-Adjust Rear 72 Inch
Frame-Adjust Rear 44xx Series 80 Inch
Channel Assembly 80 Inch
Channel Assembly 72 Inch
Footboard Install-4450 At
Footboard Group-W O Boomrest,4450at
Frame Install-4000a7
Frame Install-4000a8
Hitch-Install
Shield Install-Belt
4450 At
Axle And Steering Group
Pedal Assembly-4x55 Brake
Brake Assembly- 6 Disc Lh
Brake Assembly- 6 Disc Rh
Valve-Brake Modulating,
Steering Assembly-Arm
Steer Install-No Tow,4450 72in
Tie Rod Assembly-3440-72
Steer Install-No Tow,4450 80in
Steering Group-Wf,72in
Wide Front Group
Extension Install-Front
Steering Group-Sf
Fuel System Group
4000at
Hydraulic Group
Hydraulic Install-H Frame,Sc6080,4x50
Valve Install-Hydraulic,Boom,6 Bank,4x50
Valve Assembly-Hydraulic,Boom,6 Bank,4x50
Valve-Hydraulic,Boom,6 Bank
Valve-Check,Cv08200n25
Hose Install-Hydraulic,H Frame,4x50
Tube Install-Hydraulic,H Frame
Cylinder Assembly-Hydraulic,Boom Swing, Sc6080
Cylinder-Hydraulic,2.75x11x1.38
Cylinder Assembly- Boom Tip Fold
Cylinder-Hydraulic,2.00x16.00x1.25
H Frame
Cylinder-Hydraulic,2.00x4.00x1.00
Assembly Valve-Hydraulic, H Frame
Assembly-Valve,Relief,Boom Tip
Valve Relief-Boom Tip
Valve-Cartridge,Check-08 (4 Psi )
No H Frame
Hydraulic Install-Chassis,4000 At
Assembly Valve-2 Postion, Float
Grip Assembly-Handle
Valve-Float,2 Position
Assembly Pump-Hydraulic 4000,Chassis
Pump Hydraulic R B 531603d1
Adapter Straight .37morx.37mjic Long
Assembly-Valve Charge
Valve-Charge
Assembly Filter-Hydraulic,4000,Chassis
Elbow 90d 0.50mo-R X 0.50mjic
Assembly-Switch Pressure
Hydraulic Tank Assembly
Assembly Valve-Hydraulic,4000,Chassis
Valve-Hydraulic,Boom Lift Track Adj,3bank
Cylinder-Hydraulic,1.75x16.84x1.00
Cylinder-Hydraulic,2.25 X 1.00 X 6.5
Hose Install-Boom Tilt,Sc6080,7x50
Cylinder-Hydraulic,1.75x16.84x1.25
Pump-Gear,Hydraulic,16cc R B 531604d1
Kit-Field,Gear Pump,19cc,P5t
Pump-Gear,19cc,P5t
Adapter Assembly,-6mor X -6stor
Hydraulic Install-Sf Steering
Cylinder-Hydraulic,1.75x5.00x1.00
Hydraulic Install-Wf Steering
Cylinder-Hydraulic,1.75x6.19x1.00
Hydraulic Install-80 Axle Adj, 4000
Cylinder-Hydraulic,2.00x20.00x1.00
Hydraulic Install-72 Axle Adj, 4000
Cylinder-Hydraulic,2.00x15.25x1.00
Cylinder-Hydraulic,2.00x14.25x1.00
Hydraulic Install-Boom Fold
Cylinder-Hydraulic,1.50x8.38x1.00
Cylinder-Hydraulic,1.50x8.38x0.88 R B 527610d1
Hose Install-Boom Tip,Sc6080,7x50
Hose Install-Boom Tip Sc6080,4xxx
Cooler Install-At
Cooler Assembly-At Oil
Hose Install-Hydraulic,Boom Lift,4x50
Cab Group
Ignition Switch Loader
Pedal-Throttle
Kit-Wiper Motor
Kit Hardware Wj3
Joystick Install
Throttle Handle Assembly
Joystick Assembly
4000a
Seat Group-Basic
Seat Install
Seat Group-Mechanical Suspension
Kit-Recliner Assembly
Kit-Cushion,Back
Kit-Service,Slides (200mm Bf Single Locking )
Kit-Seat Top Sst
Kit-Pan Back W Lumbar
Kit-Lumbar,Sst
Kit-Seat Cushion
Kit-Arm Rest Rh
Kit-Arm Rest Lh
Kit-Mechanical Suspension
Seat Group-Deluxe
Seat Group-Air Suspension
Suspension Boot-Air
Kit-Air Suspension
Kit-Service,Boot,Lp Air
Kit-Radio, Sc
Kit-Radio,Xm
Radio-Cd (Xm)
Install-Antenna,Sat
Group-Radio Accessory
Air Conditioner-Kit
Heater-Kit
A C Kit-Front
A C Kit-Cab
Core Assembly-Evaporator
Blower Kit
Blower Assembly
Heater Kit
Electrical Group
Assembly-I O,High Current
Assembly-I O,High Current,Rear
Electrical Install-Chassis,4000a,Euro
Light Assembly
Headlight-Halogen,Wrapping,Lh
Headlight-Halogen,Wrapping,Rh
Headlight Assembly-Wiring,Lh
Headlight-Left,Hella
Headlight Assembly-Wiring, Rh
Headlight-Right,Hella
Lamp Cluster Rear Rh
Lamp Cluster Rear Lh
Alternator,140 Amp-2 Groove
Electrical Install-Cab
Light Assembly-Dome,W Sw
Gauge-Fuel,12v
Electrical Install-Chassis,3000m
Lamp-Warning,Amber
Electrical Install-3 Valve
Battery Install
Electrical Install-Relief Valve
Electrical Install-5 Valve
Clutch Assembly
Gauge-Oil Pressure
Gauge-Temperature,Water
Lighting Group
Appearance Group
Hood Installation
Tire And Wheel Group
Tire Assembly-320 85r24,Lh,White
Tire Assembly-320 85r24,Rh,White
Tire Assembly-9.00x24, White
Tire Assembly-11.00x16
Tire Assembly-9.00x24 White W Fluid
10.00 -16
Tire Install-9.00x24,Wht
Tire Install-9.00x24,Wht,Fld
Tire Install-10.00x16,Wht
Tire Install-320 85r24,Wht
Tire Install-320 85r24,Wht,Fld
Tire Assembly-320 85r24,Lh,Wht,Fld
Tire Assembly-320 85r24,Rh,Wht,Fld
Tire Install-380 85r24,Wht
Tire Assembly-380 85r24,Lh,Wht
Tire Assembly-380 85r24,Rh,Wht
9.00x24,Wht
Tire Assembly-10.00x16,Wht
320 85r24,Wht
9.00x24,Wht,Fld
Tire Assembly-9.00x24,Wht,Fld
320 85r24,Wht,Fld
10.00 X 16,Wht
Tire Install-230 95r32, Wht
Tire Assembly-230 95r32, Lh Wht
Tire Assembly-230 95r32, Rh Wht
Tire Install-320 85r24,Wht,Rear
Decal Group
Hood
Spray
Cab, Inside
Cab, Outside
Suspension
Guidance Group
Kit-Lightbar,Rgl600t
Tank And Saddle Group
Tank Assembly-Spray
Cover-Hinged
Insert Assembly-Sq End
Agitator-Aandm
Strap Assembly-Tank
Product Pump And Pressure Plumbing Group
Spray System Install-4000 Chassis
Pump Assembly- Spray W Clutch
Pump-Spray
Valve Assembly Inlet
Valve 2 Inch Mnpt X 2 In. Madap
Filter-Inline
Valve 3-Way 2.00 Bottom Load
Flowmeter Kit-2.00sp Flange, Rfm60p
Flowmeter-2.00sp Flange,Rfm60p,Cnxl
Valve Ball 0.75 Poly Ff
Strainer-Manifold
Strainer Assembly Less Screen 1.25
Valve Assembly R B 426406
Valve R B 056871
Kit-Pulley Clutch Assembly
Boom Group
Boom Install-Lft Rack,H Frm,4x50
Hydraulic Install-Cap,Plug
Frame Install-H,Rear,Boom,60 80
Frame Assembly-H,Rear,B00m,60 80
Rack Install-Tilt,Boom,60 80
Rack Assembly-Tilt,Boom,60 80
Lift Install-Boom,Par Link,4x50
Bar Install-Mounting,Plmbing,Center,Sc6080
Bag-Loose Parts,60 80
Block Install-Boomrest,4x50
Option-Boom 60 80
Boom Assembly-60 80,Lh
Boom Assembly-60 80,Rh
Boom Assembly-60 80
Cam Assembly-Breakaway,60 80
Cam Assembly-Boom Breakaway
Frame Assembly-H,Rear,Boom,60 80
Boom Group-Rh,60ft
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Group-Lh,60ft
Boom Group-Rh,80ft
Boom Group-Lh,80ft
Pivot-Mach
Rear H Frame Group
Spring, Assembly
Tube Assembly-Rack Tilt
Boomrest Install-Sc6080,4x50
Kit-Loose Parts,Boom Hinge
Bag-Parts
Tilt Rack Assembly
Boom Lift Group
Boom Plumbing Group
Valve Teejet
Spray System Install-H Frame
3 Section Valve-Boom Shut Off
Valve Assembly-2.00sp Flange X O-Ring
Valve-Control,1.00npt 2.00sp Flange
5 Section Valve-Boom Shut Off
Manifold Install-Center,Sc6080,4x50
Valve Assembly-Shutoff,Boom Section,5
Valve Assembly-Kz, 5 Section,
Valve W O Power Head
Insert-Seat,Qc3
Manifold Install-Center,Sc6080,4xxx
Valve Assembly-5 Section,Boom Shut Off
Valve Assembly-Inlet
Valve-Ball,2in Fp,W Cam
Spray Install-60ft Manifold
Nozzle Assembly-Single
Nozzle Assembly-Double
Filter Assembly-Boom
Spray Install-Center Manifold
Spray Install-80ft Manifold
Spray Install-Loose Parts Kit
Option-Pp Plumbing,Sc6080x5x20,Off
Pipe Assembly-90d W .75hb,6x20.Pp
Bracket Assembly-L,.75 Stauff,Std
Bracket Assembly-Z,Sh,.75ips,Std
Pipe Assembly-T W 2 1.00hb,5x20,Pp
Pipe Assembly-T W 2 1.00hb,3x20,Pp
Pipe Assembly-90d W 1.00hb,2x20,Pp
Pipe Assembly-90d W .75hb,6x20,Pp
Mender Assembly-Hose,.75x1.00,Pp
Bracket Assembly-L Lg Str,.75pp,2pclp
Bracket Assembly-L,.75 Stauff,Pclp,Std
Bracket Assembly-Z,Lg,.75 1.00ips,Pclp
Bracket Assembly-L,.75 Stauff,Rev Pclp
Bracket Assembly-Z,Lg,.75 1.00ips,1.0u
Bracket Assembly-Z,Sh,.75ips,1.00u
Bracket Assembly-L,.75 Stauff,1.00u
Option-Pp Plmb,Sc6080x5x10,On
Pipe Assembly-90d W .75hb,11x10,Pp
Pipe Assembly-T W 2 1.00hb,10x10,Pp
Pipe Assembly-T W 2 1.00hb, 6x10,Pp
Pipe Assembly-90d W 1.00hb, 5x10,Pp
Option-Nozzle,3way,Rotary,80x10,0n
Body-Nozzle,3 Way,Rotary,.75
Option-Nozzle,3way,Rotary,80x20,Off
1130 Controller Group
Groups Install-Raven Inv 115,Sc
Kit-Groups Antenna Mount,Sc
Picture-Groups Antenna Mounting
Kit-Receiver Antenna,Groups,Inv 115
Install-Rgl600t,3 4x50 Sc
Controller Install-Raven 460,Single Front
Tag Assembly, Calibration
Controller Install-Raven 460,Wide Front
Option-Groups,Phoenix 200,Sc 4000
Kit-Groups,Phoenix 200
Option-Groups,Rpr 100s, Sc 4000
Kit-Groups,Rpr 100s
1166 Foam Marker Group
Rsc 2130
Rsc Foamhead Valve Assembly
Deflector-Collector, 2in
Filter Assembly, Incline
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4in
Control Module-Power Unit
Compressor-Foam Marker
Filter Assembly-Carbon
1186 Options Group
F A-Crop Deflector,3400 4400
Belly Pan Install-Single Front
Shield-Center Assembly,Allison
Belly Pan Install-Single Front,At
Fresh Water Install
Overspray Install
Belly Pan
Belly Pan Install-Wide Front,At
F A Floodlight Kit
Work Light
F A Floodlight Kit,Hid
Light-Work,Hid
Floodlight Kit
Light-Flood,Med
F A-Driveshaft Extension Kit
1226 Recommended Dealer Stock
Brand: Spra-Coupe
Engine Group
50 Hr Filter Kit
500 Hr Filter Kit
Pistons And Rings
Fan Drive Assembly
Sump Assembly
Cylinder Head Cover
Breather Assembly
Filler
Oil Filter Assembly
Water Pump Assembly
Pipe Assembly
Fan Assembly
Feed Pipe Assembly
Pipe Fuel Assembly
Atomizer Assembly
Pump Lift Assembly
Pipe, Fuel Assembly
Kit, Gasket
Motor-Starter
Thermostat Housing
Starter Install
Arm Assembly-Pulley
Air Cleaner Group
Filter-Air
Shift Group-Allison
Cooling Install
Tank-Dearating
Transmission Group
Driveline Group
4455
Hub Assembly-Wheel
4460
Wf,80in
Steering Column
Sf
Hub Assembly
Shaft-Drive,72in
Hitch-Install
Shield Install-Belt
4450 At
Wide Front Group
Steering Group-Sf
Fuel System Group
4000at
Hydraulic Group
H Frame
No H Frame
Valve-Charge
Pump-Gear,19cc,P5t
Cooler Install-At
Cab Group
Pedal-Throttle
Kit-Wiper Motor
Kit Hardware Wj3
Joystick Install
Joystick Assembly
4000a
Seat Group-Basic
Seat Install
Kit-Cushion,Back
Kit-Seat Top Sst
Kit-Lumbar,Sst
Kit-Seat Cushion
Kit-Arm Rest Rh
Kit-Arm Rest Lh
Seat Group-Deluxe
Suspension Boot-Air
Kit-Air Suspension
Kit-Radio, Sc
Kit-Radio,Xm
Radio-Cd (Xm)
Install-Antenna,Sat
Air Conditioner-Kit
Heater-Kit
A C Kit-Front
A C Kit-Cab
Blower Kit
Blower Assembly
Heater Kit
Electrical Group
Light Assembly
Gauge-Fuel,12v
Lamp-Warning,Amber
Battery Install
Clutch Assembly
Gauge-Oil Pressure
Lighting Group
Appearance Group
Hood Installation
10.00 -16
9.00x24,Wht
320 85r24,Wht
9.00x24,Wht,Fld
320 85r24,Wht,Fld
10.00 X 16,Wht
Decal Group
Hood
Spray
Cab, Inside
Cab, Outside
Suspension
Guidance Group
Tank Assembly-Spray
Cover-Hinged
Agitator-Aandm
Strap Assembly-Tank
Pump-Spray
Filter-Inline
Strainer-Manifold
Valve R B 056871
Boom Group
Option-Boom 60 80
Boom Assembly-60 80
Boom Group-Rh,60ft
Boom Group-Lh,60ft
Boom Group-Rh,80ft
Boom Group-Lh,80ft
Pivot-Mach
Rear H Frame Group
Spring, Assembly
Bag-Parts
Tilt Rack Assembly
Boom Lift Group
Boom Plumbing Group
Valve Teejet
Insert-Seat,Qc3
Kit-Groups,Rpr 100s
Rsc 2130
1186 Options Group
Fresh Water Install
Overspray Install
Belly Pan
F A Floodlight Kit
Work Light
Light-Work,Hid
Floodlight Kit
Light-Flood,Med
- Spra Coupe EU 4460 4660 Sprayer Service Manual_79034247B
- Spra Coupe EU 4460 4660 Manual Transmission Operator Manual_519177D1D
- Spra Coupe SA 7000 Series SPRA-COUPE Service Manual_WR132165
- Spra Coupe EU 7460 7660 Sprayer System RTS_AG333725A
- Spra Coupe EU 7000 Series Sprayer Service Manual_79027326A
- Spra Coupe EU 7460 7660 Applicator Chassis Service Manual_79032953B
- Spra Coupe EU 4460 4660 Man Sprayer Repair Time Schedule_AG335277A
- Spra Coupe EU 4460 4660 Sprayer Automatic Transmission Operator Manual_519176D1D
- Spra Coupe EU 4455 4655 Sprayer Automatic Transmission Operator Manual_512150D1D
- Spra Coupe EU 4450 4650 4455 4655 Sprayer Service Manual_79027328B
- Spra Coupe SA 7000 Series Sprayer Service Manual_79027326
- Spra Coupe EU 7450 7650 Sprayer System Repair Time Schedule_AG331640A
- Spra Coupe EU 4460 4660 Auto Sprayer Repair Time Schedule_AG335025A
- Spra Coupe EU 7460 7660 Applicator Chassis RTS_AG333724A
- Spra Coupe SA 7450 7650 System Repair Time Schedule_AG331640A
