Spra-Coupe Sprayer 4450 Parts Catalog WR135264
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 4450 Sprayer
Part Number: WR135264
Number of Pages: 1781 Pages
Publication Information
Engine Group
50 Hour Filter Kit
500 Hour Filter Kit
Engine Group-4000 Mt
Engine-Perkins 122 Hp
Motor-Starter
Cylinder Block And Liners
Crank, Main And Big End Bearings
Pistons And Rings
Connecting Rods
Rear End Oil Seal
Cylinder Head Assembly
Rocker Shaft Assembly
Timing Gear And Camshaft
Fuel Injection Pump
High Pressure Fuel Pipes
Atomizers
Throttle And Stop Controls
Pick-Up Sensors
Core Plug
Fuel Leak-Off Pipe
Boost Control Pipe
Fan Drive
Sump
Dipstick And Filler Tube
Oil Strainer
Cylinder Head Cover
Breather
Filler
Oil Filter
Blanking Plates
Front End Drive Input
Pipes
Water Outlet Housing
Fan
Timing Case
Timing Cover
Blanking Plug
Oil Pump And Delivery Housing
Turbocharger Install
Feed Pipes
Leak-Off Pipes
Pipework And Connections
Exhaust Manifold
Induction Manifold
Lift Pump
Filter To Injection Pump Pipe
Injection Pump To Filter Pipe
Heater Plugs
Engine Lifting Eyes
Engine Mounts
Lube Oil Pressure Switch-Gauge
Temperature Gauge And Sender
Fuel Pre-Lift Pump
Assembly, Filter, Fuel
Miscellaneous And Auxiliaries
Top Service Kit
Package-Parts,Ford
Engine Support Group
Arm Assembly-Pulley
Exhaust Group
Cooling Install
Air Cleaner Group
Filter-Air
Install Throttle
Throttle Assembly-Hand
Bottom Service Kit
Driveline Group
4000 Mt
Transmission Assembly
Shaft-Drive,T-5 Manual
Differential Assembly
Wide Front,80in
Tie Rod Assembly-3440-80
Steering Column
Single Front
Hub Assembly
Brake Install-4450
Pedal Assembly-Brake
Brake Assembly,Lh
Brake Assembly,Rh
Cylinder Assembly-Brake
Chaincase Group-4450
Case-Chain,Final Drive,Lh,Assembly
Hub Assembly-Wheel
Case-Chain,Final Drive,Rh,Assembly
Driveshaft Install-4000,80
Shaft-Drive 80-108 Hd
Option-72 In Driveshaft
Shaft-Drive,72 In
Shaft Drive T-S,Manual R B 523030d1
Frame And Suspension Group
4000m7
4000m8
Frame-Adjust Rear 72 Inch
Frame-Adjust Rear 44xx Series 80 Inch
Frame Assembly 72 Inch Wide Front
Channel Assembly 72 Inch
Frame Assembly 80 Inch Wide Front
Channel Assembly 80 Inch
F A-Front Extension,Sc
Footboard Group
Footboard Group-W O Boomrest,4450mt
Hitch-Install
Belly Pan Install-Wide Front
Belly Pan Install-Single Front
Axle And Steering Group
Extension Install-Front
Wide Front Group-72 In ,Sc
Option-Wide Front,Sc
Tie Rod Assembly-3440-72
Steering Group-Wide Front,72 In
Steering Group-Single Front
Steering Assembly-Arm
Steer Install-No Tow,4450 72in
Steer Install-No Tow,4450 80in
Fuel System Group
Fuel Install- 4000
Tank Assembly
Hydraulic Group
Tube Assembly
Valve-Check,Cv08200n25
Cylinder-Hydraulic,R B 129450
Valve-Hydraulic,Boom Lift Track Adjust,3 Bank
Grip Assembly-Handle
Tank Assembly-Hydraulic
Hydraulic Install-Single Front Steering
Cylinder-Hydraulic,1.75x5.00x1.00
Hydraulic Install-Wide Front Steering
Cylinder-Hydraulic,1.75x6.19x1.00
Hydraulic Install-80 Axle Adj, 4000
Cylinder-Hydraulic,2.00x20.00x1.00
Hydraulic Install-72 Axle Adj, 4000
Cylinder-Hydraulic,2.00x15.25x1.00
Cylinder-Hydraulic,2.00x14.25x1.00
H Frame
Cylinder-Hydraulic,2.00x4.00x1.00
Assembly-Valve,Relief,Boom Tip
Valve Relief-Boom Tip
Valve-Cartridge,Check-08 (4 Psi )
Assembly Valve-Hydraulic, H Frame
Valve-Hydraulic,Boom,6 Bank
Hydraulic Install-Boom Fold
Cylinder-Hydraulic,1.50x8.38x1.00
Cylinder-Hydraulic,1.75x16.84x1.25
Cylinder-Hydraulic,1.50x8.38x0.88 R B 527610d1
Cylinder-Hydraulic,2.25 X 1.00 X 6.5
Cylinder-Hydraulic,2.00x16.00x1.25
Cylinder Assembly- Boom Tip Fold
Hose Install-Boom Tilt,Sc6080,7x50
Hose Install-Boom Tip,Sc6080,7x50
Hose Install-Boom Tip Sc6080,4xxx
Hydraulic Install-4x50mt Chassis,Sc6080
Valve Assembly-Control
Valve-Charge
Valve-Float,2 Position
Pump Hydraulic R B 531603d1
Elbow 90d 0.50mo-R X 0.50mjic
Cylinder Assembly-Hydraulic,Boom Swing, Sc6080
Cylinder-Hydraulic,2.75x11x1.38
Tube Install-Hydraulic,H Frame
Valve Assembly-Hydraulic,Boom,6 Bank,4x50
Hose Install-Hydraulic,H Frame,4x50
Hose Install-Hydraulic,Boom Lft,4x50
Valve Install-Hydraulic,Boom,6 Bank,4x50
Chassis,4000m
Assembly Valve-2 Postion, Float
Assembly Pump-Hydraulic 4000,Chassis
Assembly-Valve Charge
Assembly Filter-Hydraulic,4000,Chassis
Assembly-Switch Pressure
Cylinder-Hydraulic,1.75x16.84x1.00
Assembly Valve-Hydraulic,4000,Chassis
No H Frame
Pump-Gear,Hydraulic,16cc R B 531604d1
Kit-Field,Gear Pump,19cc,P5t
Pump-Gear,19cc,P5t
Adapter Assembly,-6mor X -6stor
Hydraulic Install-Chassis,4000m,Sc6080
Cab Group
Valve-Modulating
Cab Install-4000 Mt
Top Assembly-Cab
Kit-Radio,Sc
Seat Install
Seat-Suspension
Clutch Pedal Install
Shift Install-Mt
Kit-Wiper Motor
Kit Hardware Wj3
Heater-Kit
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Electrical Group
Electrical Install-3 Valve
Electrical Install-5 Valve
Battery Install
Electrical Install-Chassis,4000m
Light Assembly
Alternator,140 Amp-2 Groove
Electrical Install-Cab
Gauge-Fuel,12v
Gauge-Oil Pressure
Gauge-Temperature,Water
F A-Floodlight Kit
Light-Flood,Med
Electrical Install-Relief Valve
Clutch Assembly
Appearance Group
Wide Front
Hood Install-Single Front
Tire And Wheel Group
9.00
Tire Assembly-320 85r24,Lh,White
Tire Assembly-320 85r24,Rh,White
Tire Assembly-9.00x23, White
Tire Install-320 10,White
Tire Assembly-10.00-16
Tire Install-320 9 White W Fluid
Tire Assembly-9.00x24 White W Fluid
Tire Assembly-320 85r24,Lh,Gray
Tire Assembly-320 85r24,Rh,Gray
Decal Group
Decal Install-4450mt,72,Wide Front
Decal Install-4450mt,80,Single Front
Decal Install-4450mt,80,Wide Front
Tank And Saddle Group
Tank Assembly-Spray
Cover-Hinged
Insert Assembly-Sq End
Agitator-Aandm
Tank Assembly,Spray
Spray Install-60 Ft Manifold
Filter Assembly-Boom
Nozzle Assembly-Single
Nozzle Assembly-Double
Spray Install-4000 Chassis
Valve Ball 0.75 Poly Full Flow
Pump Assembly- Spray W Clutch
Pump-Spray
Valve 3-Way 2.00 Bottom Load
Valve Assembly-Inlet
Valve-Ball,2 In Fp,W Cam
Filter-Inline
Strainer-Manifold
Valve Assembly R B 426406
Valve R B 056871
Strainer Assembly Less Screen 1.25
Flowmeter Kit-2.00sp Flange,Rfm60p
Flowmeter-2.00sp Flg,Rfm60p,Cnxl
Spray System Install-H Frame
Valve-Control,1.00npt 2.00sp Flg
3-Section Valve-Boom Shut Off
Valve Assembly-2.00sp Flg X O-Ring
Valve Assembly-Boom Shut Off,
Valve Assembly-Kz, 3 Section,
Valve W O Power Head
Insert-Seat,Qc3
Spray Install-Center Manifold
Spray Install-80 Ft Manifold
5-Section Valve-Boom Shut Off
Valve Assembly-Kz, 5 Section,
Spray Install-Loose Parts Kit
Manifold Install-Ctr,Sc6080,4x50
Valve Assembly-Shutoff,Boom Sect,5
Valve-Pressure,Control
Valve Teejet
Flowmeter-2.00sp Flange,Rfm60p,12v
Option-Pp Plmb,Sc6080x5x20,Off
Pipe Assembly-90d W .75hb,6x20.Pp
Bracket Assembly-L,.75 Stauff,Std
Bracket Assembly-Z,Sh,.75ips,Std
Pipe Assembly-T W 2 1.00hb,5x20,Pp
Pipe Assembly-T W 2 1.00hb,3x20,Pp
Pipe Assembly-90d W 1.00hb,2x20,Pp
Pipe Assembly-90d W .75hb,6x20,Pp
Mender Assembly-Hose,.75x1.00,Pp
Bracket Assembly-L Lg Str,.75pp,2pclp
Bracket Assembly-L,.75 Stauff,Pclp,Std
Bracket Assembly-Z,Lg,.75 1.00ips,Pclp
Bracket Assembly-L,.75 Stauff,Rev Pclp
Bracket Assembly-Z,Lg,.75 1.00ips,1.0u
Bracket Assembly-Z,Sh,.75ips,1.00u
Bracket Assembly-L,.75 Stauff,1.00u
Option-Pp Plumbing,Sc6080x5x10,On
Pipe Assembly-90d W .75hb,11x10,Pp
Pipe Assembly-T W 2 1.00hb,10x10,Pp
Pipe Assembly-T W 2 1.00hb, 6x10,Pp
Pipe Assembly-90d W 1.00hb, 5x10,Pp
Option-Nozzle,3way,Rotary,80x10,0n
Body-Nozzle,3 Way,Rotary,.75
Option-Nozzle,3way,Rotary,80x20,Off
Boom Group
Tilt Rack Assembly
Tube Assembly-Rack Tilt
Boom Lift Group
Rear H Frame Group
Spring, Assembly
Boom Group-Rh,60 Ft
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Group-Lh,60 Ft
Boom Group-Rh,80 Ft
Boom Group-Lh,80 Ft
Kit-Loose Parts,Boom Hinge
Option-Boom 60 80
Boom Assembly-60 80,Lh
Boom Assembly-60 80,Rh
Boom Assembly-60 80
Rack Install-Tilt,Boom,60 80
Rack Assembly-Tilt,Boom,60 80
Frame Install-H,Rear,Boom,60 80
Frame Assembly-H,Rear,Boom,60 80
Frame Assembly-H,Rear,B00m,60 80
Bar Install-Mounting,Plumbing,Ctr,Sc6080
Lift Install-Boom,Par Link,4x50
Boomrest Install-Sc6080,4x50
Bag-Parts
Block Install-Boom Rest,4x50
Controller Group
Controller Install-Raven 460,Single Front
Controller Install-Raven 460,Wide Front
Foam Marker Group
Rsc 2130
Deflector-Collector, 2 In
Rsc Foamhead Valve Assembly
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In
Filter Assembly, Incline
Compressor-Foam Marker
Filter Assembly-Carbon
Module, Control
Options Group
Fresh Water Install
Overspray Install
F A-Crop Deflector,3400 4400
Kit-Gps Antenna Mount,Sc
Gps Install-Raven Inv 115,Sc
Kit-Receiver Antenna,Gps,Inv 115
Kit-Overspray
F A-Driveshaft Extension Kit
Recommended Dealer Stock
