Spra-Coupe Sprayer 4450 Parts Catalog WR135262
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 4450 Sprayer
Part Number: WR135262
Number of Pages: 1974 Pages
Publication Information
Engine Group
50 Hour Filter Kit
500 Hour Filter Kit
Engine-Perkins 123hp,1104 Electric
Cylinder Block And Liners Assembly
Pistons And Rings
Connecting Rod Assembly
Rear End Oil Seal Assembly
Rocker Shaft Assembly
Timing Gear And Camshaft Assembly
Fan Drive Assembly
Sump Assembly
Dipstick And Filler Tube Assembly
Oil Strainer Assembly
Cylinder Head Cover
Cylinder Head Cover Assembly
Breather Assembly
Filler
Oil Filter Assembly
Blanking Plate Assembly
Front End Drive Input Assembly
Water Pump Assembly
Pipe Assembly
Water Outlet Housing Assembly
Fan Assembly
Timing Case Assembly
Timing Cover Assembly
Oil Pump And Delivery Housing Assembly
Feed Pipe Assembly
Leak-Off Pipe Assembly
Pipework And Connections Assembly
Exhaust Manifold Assembly
Heater Plugs Assembly
Engine Lifting Eye Assembly
Miscellaneous And Auxiliary Assembly
Bottom Service Kit Assembly
Turbocharger Install
Assembly, Crankshaft
Cylinder Head Assembly
Pump Fuel Inj Assembly
Pipe Fuel Assembly
Atomizer Assembly
Solenoid Mounting Assembly
Mount Solenoid Assembly
Sensor Pickup Assembly
Housing Flywheel Assembly
Plug, Blanking Assembly
Manifold Induction Assembly
Pump Lift Assembly
Pipe, Fuel Assembly
Mount, Engine Assembly
Wiring, Loom Assembly
Pump, Lift Fuel Assembly
Kit, Gasket
Assembly, Filter, Fuel
Motor-Starter
Air Cleaner Group
Filter-Air
Shift Group-Allison
Shifter Assembly-Allison
Engine Support Install-At
Arm Assembly-Pulley
Fan-Assembly
Cooling Install
Exhaust Install-4450at And 4650at
Driveline Group
Chaincase Group-4450
Case-Chain,Final Drive,Lh,Assembly
Hub Assembly-Wheel
Case-Chain,Final Drive,Rh,Assembly
Brake Install-4450
Pedal Assembly-Brake
Cylinder Assembly-Brake
Brake Assembly,Lh
Brake Assembly,Rh
Kit-Auto Transmission,Allison,Sc4x50
Transmission-Auto,2100rds
Wf,80in
Tie Rod Assembly-3440-80
Steering Column
Sf
Hub Assembly
Driveshaft, Auto Allison
Driveshaft,Auto Allison R B 547155d1
Differential Assembly
Option-72in Driveshaft
Shaft-Drive,72in
Driveshaft Install-4000,80
Shaft-Drive 80-108 Hd
Frame And Suspension Group
Frame Assembly 80 Inch Wide Front
Frame Assembly 72 Inch Wide Front
Frame-Adjust Rear 72 Inch
Frame-Adjust Rear 44xx Series 80 Inch
Channel Assembly 80 Inch
Channel Assembly 72 Inch
Footboard Install-4450 At
Footboard Group-W O Boomrest,4450at
4000a7
4000a8
F A-Front Extension,Sc
Hitch-Install
Axle And Steering Group
Steering Assembly-Arm
Steering Group-Wf,72in
Tie Rod Assembly-3440-72
Wide Front Group
Extension Install-Front
Steering Group-Sf
Steer Install-No Tow,4450 72in
Steer Install-No Tow,4450 80in
Fuel System Group
4000at
Tank Assembly
Hydraulic Group
Hydraulic Install-H Frame,Sc6080,4x50
Valve Install-Hydraulic,Boom,6 Bank,4x50
Valve Assembly-Hydraulic,Boom,6 Bank,4x50
Valve-Hydraulic,Boom,6 Bank
Valve-Check,Cv08200n25
Tube Install-Hydraulic,H Frame
Hose Install-Hydraulic,H Frame,4x50
Cylinder Assembly-Hydraulic,Boom Swing, Sc6080
Cylinder-Hydraulic,2.75x11x1.38
H Frame
Cylinder-Hydraulic,2.00x4.00x1.00
Assembly Valve-Hydraulic, H Frame
Assembly-Valve,Relief,Boom Tip
Valve Relief-Boom Tip
Valve-Cartridge,Check-08 (4 Psi )
No H Frame
Chassis,4000a
Assembly Filter-Hydraulic,4000,Chassis
Elbow 90d 0.50mo-R X 0.50mjic
Assembly Valve-2 Postion, Float
Grip Assembly-Handle
Valve-Float,2 Position
Assembly Pump-Hydraulic 4000,Chassis
Pump Hydraulic R B 531603d1
Adapter Straight .37morx.37mjic Long
Tank Assembly-Hydraulic
Assembly-Valve Charge
Valve-Charge
Assembly-Switch Pressure
Assembly Valve-Hydraulic,4000,Chassis
Valve-Hydraulic,Boom Lift Track Adjust,3bank
Hydraulic Install-Chas, 40001,Sc6080
Cylinder-Hydraulic,2.25 X 1.00 X 6.5
Cylinder Assembly- Boom Tip Fold
Cylinder-Hydraulic,2.00x16.00x1.25
Drivetrain Install-At,4450 4650
Hydraulic Install-4x50at Chas,Sc6080
Valve Assembly-Control
Cylinder-Hydraulic,1.75x16.84x1.25
Pump-Gear,Hydraulic,16cc R B 531604d1
Kit-Field,Gear Pump,19cc,P5t
Pump-Gear,19cc,P5t
Adapter Assembly,-6mor X -6stor
Hydraulic Install-Sf Steering
Cylinder-Hydraulic,1.75x5.00x1.00
Hydraulic Install-Wf Steering
Cylinder-Hydraulic,1.75x6.19x1.00
Hydraulic Install-80 Axle Adj, 4000
Cylinder-Hydraulic,2.00x20.00x1.00
Hydraulic Install-72 Axle Adj, 4000
Cylinder-Hydraulic,2.00x15.25x1.00
Cylinder-Hydraulic,2.00x14.25x1.00
Hydraulic Install-Boom Fold
Cylinder-Hydraulic,1.50x8.38x1.00
Cylinder-Hydraulic,1.50x8.38x0.88 R B 527610d1
Hose Install-Boom Tilt,Sc6080,7x50
Hose Install-Boom Tip,Sc6080,7x50
Hose Install-Boom Tip Sc6080,4xxx
Cooler Install-At
Cooler Assembly-At Oil
Hose Install-Hydraulic,Boom Lift,4x50
Cylinder-Hydraulic, R B 129450
Valve Assembly-6 Spool
Tube Assembly
Valve-Relief;Assembly Boom
Cab Group
Valve-Modulating
Cab Install-4000 At
Top Assembly-Cab
Seat Install
Seat-Suspension
Joystick Install
Joystick Assembly
Kit-Radio,Sc
Kit-Radio, Sc
Kit-Wiper Motor
Kit Hardware Wj3
Blower-Kit
Air Conditioner-Kit
Heater-Kit
Electrical Group
F A-Floodlight Kit
Light-Flood,Med
Electrical Install-Chassis,4000a
Alternator,140 Amp-2 Groove
Electrical Install-3 Valve
Electrical Install-5 Valve
Battery Install
Electrical Install-Cab,Auto
Gauge-Fuel,12v
Electrical Install-Relief Valve
Kit-Overspray
Clutch Assembly
Gauge-Oil Pressure
Gauge-Temperature,Water
Appearance Group
Wide Front
Hood Install-Single Front
Single Front
Tire And Wheel Group
9.00
Tire Assembly-320 85r24,Lh,White
Tire Assembly-320 85r24,Rh,White
Tire Assembly-9.00x24, White
320 10, White
Tire Install-320 9 White W Fluid
Tire Assembly-9.00x24 White W Fluid
Tire Assembly-320 85r24,Lh,Gray
Tire Assembly-320 85r24,Rh,Gray
10.00 -16
Decal Group
Decal Install-4450,72,At,Wf
Decal Install-4450,80,At,Sf
Decal Install-4450,80,At,Wf
Tank And Saddle Group
Tank Assembly-Spray
Cover-Hinged
Insert Assembly-Sq End
Agitator-A And M
Tank Assembly,Spray
Valve-Control,1.00npt 2.00sp Flange
5-Section Valve-Boom Shut Off
Valve Assembly-2.00sp Flange X O-Ring
Valve Assembly-Boom Shut Off,
Valve Assembly-Kz, 5 Section,
Valve W O Power Head
Insert-Seat,Qc3
Spray System Instal-H Frm
3-Section Valve-Boom Shut Off
Valve Assembly-Kz, 3 Section,
Spray System Install-4000 Chassis
Valve Assembly-Inlet
Filter-Inline
Valve 3-Way 2.00 Bottom Load
Strainer-Manifold
Valve Assembly R B 426406
Valve R B 056871
Strainer Assembly Less Screen 1.25
Flowmeter Kit-2.00sp Flg, Rfm60p
Flowmeter-2.00sp Flange,Rfm60p,Cnxl
Valve Teejet
Manifold Install-Ctr,Sc6080,4x50
Valve Assembly-Shutoff,Boom Section,5
Valve-Pressure,Control
Spray Install-Loose Parts Kit
Spray Install-60ft Manifold
Nozzle Assembly-Single
Nozzle Assembly-Double
Filter Assembly-Boom
Spray Install-80ftmanifold
Pump-Spray
Option-Pp Plumbing,Sc6080x5x20,Off
Pipe Assembly-90d W .75hb,6x20.Pp
Bracket Assembly-L,.75 Stauff,Std
Bracket Assembly-Z,Sh,.75ips,Std
Pipe Assembly-T W 2 1.00hb,5x20,Pp
Pipe Assembly-T W 2 1.00hb,3x20,Pp
Pipe Assembly-90d W 1.00hb,2x20,Pp
Pipe Assembly-90d W .75hb,6x20,Pp
Mender Assembly-Hose,.75x1.00,Pp
Bracket Assembly-L Lg Str,.75pp,2pclp
Bracket Assembly-L,.75 Stauff,Pclp,Std
Bracket Assembly-Z,Lg,.75 1.00ips,Pclp
Bracket Assembly-L,.75 Stauff,Rev Pclp
Bracket Assembly-Z,Lg,.75 1.00ips,1.0u
Bracket Assembly-Z,Sh,.75ips,1.00u
Bracket Assembly-L,.75 Stauff,1.00u
Spray Install-Ctr Manifold
Option-Pp Plumbing,Sc6080x5x10,On
Pipe Assembly-90d W .75hb,11x10,Pp
Pipe Assembly-T W 2 1.00hb,10x10,Pp
Pipe Assembly-T W 2 1.00hb, 6x10,Pp
Pipe Assembly-90d W 1.00hb, 5x10,Pp
Option-Nozzle,3 Way,Rotary,80x10,0n
Body-Nozzle,3 Way,Rotary,.75
Option-Nozzle,3 Way,Rotary,80x20,Off
Pipe Assembly-90d W 1.00hb,6x20,Pp
Flowmeter-2.00sp Flange,Rfm60p,12v
Boom Group
Option-Boom 60 80
Boom Assembly-60 80,Lh
Boom Assembly-60 80,Rh
Boom Assembly-60 80
Cam Assembly-Breakaway,60 80
Cam Assembly-Boom Breakaway
Boom Install-Lift Rack,H Frame,4x50
Hydraulic Install-Cap,Plug
Frame Install-H,Rear,Boom,60 80
Frame Assembly-H,Rear,B00m,60 80
Rack Install-Tilt,Boom,60 80
Rack Assembly-Tilt,Boom,60 80
Lift Install-Boom,Par Link,4x50
Bar Install-Mounting,Plumbing,Ctr,Sc6080
Block Install-Boom Rest,4x50
Frame Assembly-H,Rear,Boom,60 80
Boom Group-Rh,60ft
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Group-Lh,60ft
Boom Group-Rh,80ft
Boom Group-Lh,80ft
Rear Inhin Frame Group
Spring, Assembly
Boomrest Install-Sc6080,4x50
Kit-Loose Parts,Boom Hinge
Bag-Parts
Tilt Rack Assembly
Boom Lift Group
Tube Assembly-Rack Tilt
Controller Group
Gps Install-Raven Inv 115,Sc
Kit-Receiver Antenna,Gps,Inv 115
Kit-Gps Antenna Mount,Sc
Controller Install-Raven 460,Sf
Controller Install-Raven 460,Wf
Foam Marker Group
Rsc 2130
Rsc Foamhead Valve Assembly
Deflector-Collector, 2in
Filter Assembly, Incline
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4in
Compressor-Foam Marker
Filter Assembly-Carbon
Module, Control
Options Group
F A-Crop Deflector,3400 4400
Belly Pan Install-Wf
Shield-Center Assembly,Allison
Belly Pan Install-Sf
Fresh Water Install
Overspray Install
F A-Driveshaft Extension Kit
Recommended Dealer Stock
Brand: Spra-Coupe
Engine Group
50 Hour Filter Kit
500 Hour Filter Kit
Pistons And Rings
Fan Drive Assembly
Sump Assembly
Cylinder Head Cover
Breather Assembly
Filler
Oil Filter Assembly
Water Pump Assembly
Pipe Assembly
Fan Assembly
Feed Pipe Assembly
Pipe Fuel Assembly
Atomizer Assembly
Pump Lift Assembly
Pipe, Fuel Assembly
Kit, Gasket
Motor-Starter
Air Cleaner Group
Filter-Air
Shift Group-Allison
Arm Assembly-Pulley
Fan-Assembly
Cooling Install
Driveline Group
Hub Assembly-Wheel
Brake Install-4450
Brake Assembly,Lh
Brake Assembly,Rh
Wf,80in
Steering Column
Sf
Hub Assembly
Shaft-Drive,72in
4000a7
4000a8
Hitch-Install
Wide Front Group
Steering Group-Sf
Fuel System Group
4000at
Tank Assembly
Hydraulic Group
H Frame
No H Frame
Chassis,4000a
Valve-Charge
Pump-Gear,19cc,P5t
Cooler Install-At
Tube Assembly
Cab Group
Valve-Modulating
Cab Install-4000 At
Top Assembly-Cab
Seat Install
Seat-Suspension
Joystick Install
Joystick Assembly
Kit-Radio,Sc
Kit-Radio, Sc
Kit-Wiper Motor
Kit Hardware Wj3
Blower-Kit
Air Conditioner-Kit
Heater-Kit
Electrical Group
F A-Floodlight Kit
Light-Flood,Med
Battery Install
Gauge-Fuel,12v
Kit-Overspray
Clutch Assembly
Gauge-Oil Pressure
Appearance Group
Wide Front
Single Front
9.00
320 10, White
10.00 -16
Decal Group
Tank Assembly-Spray
Cover-Hinged
Agitator-A And M
Tank Assembly,Spray
Insert-Seat,Qc3
Filter-Inline
Strainer-Manifold
Valve R B 056871
Valve Teejet
Pump-Spray
Boom Group
Option-Boom 60 80
Boom Assembly-60 80
Boom Group-Rh,60ft
Boom Group-Lh,60ft
Boom Group-Rh,80ft
Boom Group-Lh,80ft
Spring, Assembly
Bag-Parts
Tilt Rack Assembly
Boom Lift Group
Controller Group
Foam Marker Group
Rsc 2130
Module, Control
Options Group
Fresh Water Install
Overspray Install
- Spra Coupe EU 4460 4660 Sprayer Service Manual_79034247B
- Spra Coupe EU 4460 4660 Manual Transmission Operator Manual_519177D1D
- Spra Coupe SA 7000 Series SPRA-COUPE Service Manual_WR132165
- Spra Coupe EU 7460 7660 Sprayer System RTS_AG333725A
- Spra Coupe EU 7000 Series Sprayer Service Manual_79027326A
- Spra Coupe EU 7460 7660 Applicator Chassis Service Manual_79032953B
- Spra Coupe EU 4460 4660 Man Sprayer Repair Time Schedule_AG335277A
- Spra Coupe EU 4460 4660 Sprayer Automatic Transmission Operator Manual_519176D1D
- Spra Coupe EU 4455 4655 Sprayer Automatic Transmission Operator Manual_512150D1D
- Spra Coupe EU 4450 4650 4455 4655 Sprayer Service Manual_79027328B
- Spra Coupe SA 7000 Series Sprayer Service Manual_79027326
- Spra Coupe EU 7450 7650 Sprayer System Repair Time Schedule_AG331640A
- Spra Coupe EU 4460 4660 Auto Sprayer Repair Time Schedule_AG335025A
- Spra Coupe EU 7460 7660 Applicator Chassis RTS_AG333724A
- Spra Coupe SA 7450 7650 System Repair Time Schedule_AG331640A
