Spra-Coupe Sprayer 4450 Parts Catalog WR129578
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 4450 Sprayer
Part Number: WR129578
Number of Pages: 1721 Pages
Publication Information
Engine Group
50 Hour Filter Kit
500 Hour Filter Kit
Engine Group-4000 Mt
Engine-Perkins 122 Hp
Motor-Starter
Cylinder Block And Liners
Crank, Main And Big End Bearings
Pistons And Rings
Connecting Rods
Rear End Oil Seal
Cylinder Head Assembly
Rocker Shaft Assembly
Timing Gear And Camshaft
Fuel Injection Pump
High Pressure Fuel Pipes
Atomizers
Throttle And Stop Controls
Pick-Up Sensors
Core Plug
Fuel Leak-Off Pipe
Boost Control Pipe
Fan Drive
Sump
Dipstick And Filler Tube
Oil Strainer
Cylinder Head Cover
Breather
Filler
Oil Filter
Blanking Plates
Front End Drive Input
Pipes
Water Outlet Housing
Fan
Timing Case
Timing Cover
Blanking Plug
Oil Pump And Delivery Housing
Turbocharger Install
Feed Pipes
Leak-Off Pipes
Pipework And Connections
Exhaust Manifold
Induction Manifold
Pipework And Connecitons
Lift Pump
Filter To Injection Pump Pipe
Injection Pump To Filter Pipe
Heater Plugs
Engine Lifting Eyes
Engine Mounts
Lube Oil Pressure Switch-Gauge
Temperature Gauge And Sender
Fuel Pre-Lift Pump
Assembly, Filter, Fuel
Miscellaneous And Auxiliaries
Top Service Kit
Package-Parts,Ford
Engine Support Group
Arm Assembly-Pulley
Exhaust Group
Cooling Group
Air Cleaner Group
Filter-Air
4000 Series
Install Throttle
Throttle Assembly-Hand
Bottom Service Kit
Driveline Group
4000 Mt
Transmission Assembly
Shaft-Drive,T-5 Manual
Differential Assembly
Wf,80 In
Tie Rod Assembly-3440-80
Steering Column
Sf
Hub Assembly
Brake Install-4450
Pedal Assembly-Brake
Brake Assembly,Lh
Brake Assembly,Rh
Cylinder Assembly-Brake
Chaincase Group-4450
Case-Chain,Final Drive,Lh,Assembly
Hub Assembly-Wheel
Case-Chain,Final Drive,Rh,Assembly
Driveshaft Install-4000,80
Shaft-Drive 80-108 Hd
Option-72 In Driveshaft
Shaft-Drive,72 In
Shaft Drive T-S,Manual R B 523030d1
Frame And Suspension Group
72 In
80 In
Frame-Adjust Rear 72 Inch
Frame-Adjust Rear 44xx Series 80 Inch
Frame Assembly 72 Inch Wide Front
Channel Assembly 72 Inch
Frame Assembly 80 Inch Wide Front
Channel Assembly 80 Inch
F A-Front Extension,Sc
Footboard Group
Footboard Group-W O Boomrest,4450mt
Hitch-Install
Belly Pan Install-Wf
Belly Pan Install-Sf
Axle And Steering Group
Extension Install-Front
Wide Front Group-72 In ,Sc
Option-Wide Front,Sc
Tie Rod Assembly-3440-72
Steering Group-Wf,72 In
Steering Group-Sf
Steering Assembly-Arm
Hydraulic Group
Tube Assembly
Hydraulic Install-Kit No H Frame
Valve Assembly-6 Spool
Valve-Check,Cv08200n25
H Frame
Cylinder-Hydraulic,2.00x4.00x1.00
Cylinder-Hydraulic,
Hydraulic Install-4000 Chassis
Valve Assembly-Control
Tank Assembly-Hydraulic
Valve-Charge
Grip Assembly-Handle
Valve-Float,2 Position
Pump Hydraulic R B 531603d1
Elbow 90d 0.50mo-R X 0.50mjic
Hydraulic Install-Sf Steering
Cylinder-Hydraulic,1.75x5.00x1.00
Hydraulic Install-Wf Steering
Cylinder-Hydraulic,1.75x6.19x1.00
Hydraulic Install-80 Axle Adj, 4000
Cylinder-Hydraulic,2.00x20.00x1.00
Hydraulic Install-72 Axle Adj, 4000
Cylinder-Hydraulic,2.00x15.25x1.00
Cylinder-Hydraulic,2.00x14.25x1.00
Hydraulic Install-H Farme
Valve-Relief;Assembly Boom
Hydraulic Install-Boom Fold
Cylinder-Hydraulic,1.50x8.38x1.00
Cylinder-Hydraulic,1.75x16.84x1.25
Cylinder-Hydraulic,1.50x8.38x0.88 R B 527610d1
Cylinder-Hydraulic,2.25 X 1.00 X 6.5
Cylinder Assembly- Boom Tip Fold
Cylinder-Hydraulic,2.00x16.00x1.25
Hose Install-Boom Tilt,Sc6080,7x50
Hose Install-Boom Tip,Sc6080,7x50
Hose Install-Boom Tip Sc6080,4xxx
Hydraulic Install-4x50mt Chassis,Sc6080
Cylinder Assembly-Hydraulic,Boom Swing, Sc6080
Cylinder-Hydraulic,2.75x11x1.38
Tube Install-Hydraulic,H Frame
Valve Assembly-Hydraulic,Boom,6 Bank,4x50
Valve-Hydraulic,Boom,6 Bank
Hose Install-Hydraulic,H Frame,4x50
Hose Install-Hydraulic,Boom Lft,4x50
Valve Install-Hydraulic,Boom,6 Bank,4x50
Pump-Gear,Hydraulic,16cc R B 531604d1
Kit-Field,Gear Pump,19cc,P5t
Pump-Gear,19cc,P5t
Adapter Assembly,-6mor X -6stor
Tank Assembly
Cab Group
Valve-Modulating
Cab Install-4000 Mt
Top Assembly-Cab
Kit-Radio,Sc
Seat Install
Seat-Suspension
Clutch Pedal Install
Shift Install-Mt
Kit-Wiper Motor
Kit Hardware Wj3
Heater-Kit
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Electrical Group
Kit-Overspray
Electrical Install-3 Valve
Electrical Install-5 Valve
Battery Install
Electrical Install-Chassis
Electrical Install-Cab
Gauge-Fuel,12v
Gauge-Oil Pressure
Gauge-Temperature,Water
F A-Floodlight Kit
Light-Flood,Med
Clutch Assembly
Appearance Group
Wf
Hood-Wf
Hood Install-Sf
Hood-Sf
Tire And Wheel Group
10.00 12.4
Tire Assembly-10.00-16sl W 18
Tire Assembly-12.4x24 W 24x10
Tire Assembly-12.4-24 W 24x10
7.50 12.4
Tire Assembly-7.5x24 W 24xw7,
9.00 12.4
Tire Assembly-9x24 W 24xw8,
9.00 230
Tire Assembly-9.5x32 W 32xw8
F A-Tires, 320 95r32
Decal Group
Decal Install-4450mt,80,Wf
Decal Install-4450mt,72,Wf
Decal Install-4450mt,80,Sf
Tank And Saddle Group
Tank Assembly-Spray
Cover-Hinged
Insert Assembly-Sq End
Agitator-A And M
Tank Assembly,Spray
Spray Install-60 Ft Manifold
Filter Assembly-Boom
Nozzle Assembly-Single
Nozzle Assembly Double
Spray Install-4000 Chassis
Valve Ball 0.75 Poly Full Flow
Pump Assembly- Spray W Clutch
Pump-Spray
Valve 3-Way 2.00 Bottom Load
Valve Assembly-Inlet
Valve-Ball,2in Fp,W Cam
Filter-Inline
Strainer-Manifold
Valve Assembly R B 426406
Valve R B 056871
Strainer Assembly Less Screen 1.25
Spray System Instal-H Frame
3 Section Valve-Boom Shut Off
Valve Assembly-2.00sp Flg X Oring
Valve-Control,1.00npt 2.00sp Flg
Valve Assembly-Boom Shut Off,
Valve Assembly-Kz, 3 Section,
Valve W O Power Head
Insert-Seat,Qc3
Spray Install-Ctr Manifold
Spray Install-80 Ft Manifold
5 Section Valve-Boom Shut Off
Valve Assembly-Kz, 5 Section,
Spray Install-Loose Parts Kit
Nozzle Assembly-Double
Manifold Install-Ctr,Sc6080,4x50
Valve Assembly-Shutoff,Boom Sect,5
Valve-Pressure,Control
Option-Pp Plmb,Sc6080x5x20,On
Pipe Assembly-90d W 1.00hb,6x20,Pp
Pipe Assembly-T W 2 1.00hb,5x20,Pp
Pipe Assembly-X W 3 1.00hb,5x20,Pp
Pipe Assembly-T W 2 1.00hb,2x20,Pp
Pipe Assembly-90d W 1.00hb,3x20,Pp
Bracket Assembly-Str,Lg,2ips,Rev P Clp
Bracket Assembly-Str,Lg,3ips Clp
Bracket Assembly-Str,Sh,Ips Clp,P Clp
Bracket Assembly-Str,Lg,Ips Clp,2p
Bracket Assembly-Str,Lg,2ips Clp
Bracket Assembly-L,Pp Stauff
Bracket Assembly-L,Pp Stauff,Rev P Clp
Bracket Assembly-L,Pp Stauff,Ctr P Clp
Bracket Assembly-Str,Lg,2ips Clp,1.00u
Bracket Assembly-L,Pp Stauff,1.00u
Bracket Assembly-Str,Sh,Ips Clp,1.00u
Bracket Assembly-Str,Lg,2ips,P Clp
Nozzle Assembly-Option,80x20 On,Tpl
Nozzle Holder-Triple 1.00 Ips
Valve Teejet
Gauge-Flow
Boom Group
Tilt Rack Assembly
Tube Assembly-Rack Tilt
Boom Lift Group
Rear H Frame Group
Spring, Assembly
Boom Group-Rh,60 Ft
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Group-Lh,60 Ft
Boom Group-Rh,80 Ft
Boom Group-Lh,80 Ft
Kit-Loose Parts,Boom Hinge
Fresh Water Install
Option-Boom 60 80
Boom Assembly-60 80,Lh
Boom Assembly-60 80,Rh
Boom Assembly-60 80
Rack Install-Tilt,Boom,60 80
Rack Assembly-Tilt,Boom,60 80
Frame Install-H,Rear,Boom,60 80
Frame Assembly-H,Rear,Boom,60 80
Frame Assembly-H,Rear,B00m,60 80
Bar Install-Mounting,Plumbing,Ctr,Sc6080
Lift Install-Boom,Par Link,4x50
Boomrest Install-Sc6080,4x50
Bag-Parts
Block Install-Boom Rest,4x50
Controller Group
Controller Raven Package
Install-Control,Raven
Package-Raven Mount,3400 Wf
Package-Mount,3400 Sf
Foam Marker Group
F A-Marker,Rsc 2130
Deflector-Collector, 2 In
Rsc Foamhead Valve Assembly
Tank Assembly,13 Gallon Rsc2130
Cap-Assembly, 2 1 4 In
Filter Assembly, Incline
Compressor-Foam Marker
Filter Assembly-Carbon
Control Module Assembly
Options Group
Overspray Install
F A Crop Deflector,3400,4400
F A-Driveshaft Extension Kit
Recommended Dealer Stock
Brand: Spra-Coupe
Engine Group
50 Hour Filter Kit
500 Hour Filter Kit
Motor-Starter
Pistons And Rings
Connecting Rods
Rear End Oil Seal
Fuel Injection Pump
Atomizers
Pick-Up Sensors
Core Plug
Fuel Leak-Off Pipe
Boost Control Pipe
Fan Drive
Sump
Oil Strainer
Cylinder Head Cover
Breather
Filler
Oil Filter
Blanking Plates
Pipes
Fan
Timing Case
Timing Cover
Blanking Plug
Feed Pipes
Leak-Off Pipes
Exhaust Manifold
Induction Manifold
Lift Pump
Heater Plugs
Engine Lifting Eyes
Engine Mounts
Fuel Pre-Lift Pump
Top Service Kit
Package-Parts,Ford
Arm Assembly-Pulley
Exhaust Group
Cooling Group
Air Cleaner Group
Filter-Air
4000 Series
Install Throttle
Bottom Service Kit
Driveline Group
4000 Mt
Wf,80 In
Steering Column
Sf
Hub Assembly
Brake Install-4450
Brake Assembly,Lh
Brake Assembly,Rh
Hub Assembly-Wheel
Shaft-Drive,72 In
72 In
80 In
Footboard Group
Hitch-Install
Steering Group-Sf
Hydraulic Group
Tube Assembly
H Frame
Cylinder-Hydraulic,
Valve-Charge
Pump-Gear,19cc,P5t
Tank Assembly
Cab Group
Valve-Modulating
Cab Install-4000 Mt
Top Assembly-Cab
Kit-Radio,Sc
Seat Install
Seat-Suspension
Shift Install-Mt
Kit-Wiper Motor
Kit Hardware Wj3
Heater-Kit
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Electrical Group
Kit-Overspray
Battery Install
Gauge-Fuel,12v
Gauge-Oil Pressure
F A-Floodlight Kit
Light-Flood,Med
Clutch Assembly
Appearance Group
Wf
Hood-Wf
Hood Install-Sf
Hood-Sf
10.00 12.4
7.50 12.4
9.00 12.4
9.00 230
Decal Group
Tank Assembly-Spray
Cover-Hinged
Agitator-A And M
Tank Assembly,Spray
Pump-Spray
Filter-Inline
Strainer-Manifold
Valve R B 056871
Insert-Seat,Qc3
Valve Teejet
Gauge-Flow
Boom Group
Tilt Rack Assembly
Boom Lift Group
Rear H Frame Group
Spring, Assembly
Boom Group-Rh,60 Ft
Boom Group-Lh,60 Ft
Boom Group-Rh,80 Ft
Boom Group-Lh,80 Ft
Fresh Water Install
Option-Boom 60 80
Boom Assembly-60 80
Bag-Parts
Controller Group
Foam Marker Group
F A-Marker,Rsc 2130
Options Group
Overspray Install
- Spra Coupe EU 4460 4660 Sprayer Service Manual_79034247B
- Spra Coupe EU 4460 4660 Manual Transmission Operator Manual_519177D1D
- Spra Coupe SA 7000 Series SPRA-COUPE Service Manual_WR132165
- Spra Coupe EU 7460 7660 Sprayer System RTS_AG333725A
- Spra Coupe EU 7000 Series Sprayer Service Manual_79027326A
- Spra Coupe EU 7460 7660 Applicator Chassis Service Manual_79032953B
- Spra Coupe EU 4460 4660 Man Sprayer Repair Time Schedule_AG335277A
- Spra Coupe EU 4460 4660 Sprayer Automatic Transmission Operator Manual_519176D1D
- Spra Coupe EU 4455 4655 Sprayer Automatic Transmission Operator Manual_512150D1D
- Spra Coupe EU 4450 4650 4455 4655 Sprayer Service Manual_79027328B
- Spra Coupe SA 7000 Series Sprayer Service Manual_79027326
- Spra Coupe EU 7450 7650 Sprayer System Repair Time Schedule_AG331640A
- Spra Coupe EU 4460 4660 Auto Sprayer Repair Time Schedule_AG335025A
- Spra Coupe EU 7460 7660 Applicator Chassis RTS_AG333724A
- Spra Coupe SA 7450 7650 System Repair Time Schedule_AG331640A
