Spra-Coupe Sprayer 4450 Parts Catalog WR128718
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 4450 Sprayer
Part Number: WR128718
Number of Pages: 1615 Pages
Publication Information
Engine Group
Engine Support Group
Arm Assembly-Pulley
Exhaust Group
Cooling Group
Air Cleaner Group
Filter-Air
4000 Series
Install Throttle
Throttle Assembly-Hand
Package-Parts,Ford
Engine Group-4000 Mt
Engine-Perkins 122 Hp
Motor-Starter
Cylinder Block And Liners
Crank, Main And Big End Bearings
Pistons And Rings
Connecting Rods
Rear End Oil Seal
Cylinder Head Assembly
Rocker Shaft Assembly
Timing Gear And Camshaft
Fuel Injection Pump
High Pressure Fuel Pipes
Atomizers
Throttle And Stop Controls
Pick-Up Sensors
Core Plug
Fuel Leak-Off Pipe
Boost Control Pipe
Fan Drive
Sump
Dipstick And Filler Tube
Oil Strainer
Cylinder Head Cover
Breather
Filler
Oil Filter
Blanking Plates
Front End Drive Input
Pipes
Water Outlet Housing
Fan
Timing Case
Timing Cover
Blanking Plug
Oil Pump And Delivery Housing
Turbocharger Install
Feed Pipes
Leak-Off Pipes
Pipework And Connections
Exhaust Manifold
Induction Manifold
Pipework And Connecitons
Lift Pump
Filter To Injection Pump Pipe
Injection Pump To Filter Pipe
Heater Plugs
Engine Lifting Eyes
Engine Mounts
Lube Oil Pressure Switch-Gauge
Temperature Gauge And Sender
Fuel Pre-Lift Pump
Assembly, Filter, Fuel
Miscellaneous And Auxiliaries
Top Service Kit
Bottom Service Kit
Driveline Group
4000 Mt
Transmission Assembly
Shaft-Drive,T-5 Manual
Differential Assembly
Wf,80 In
Tie Rod Assembly-3440-80
Steering Column
Sf
Hub Assembly
Brake Install-4450
Pedal Assembly-Brake
Brake Assembly,Lh
Brake Assembly,Rh
Cylinder Assembly-Brake
Chaincase Group-4450
Case-Chain,Final Drive,Lh,Assembly
Hub Assembly-Wheel
Case-Chain,Final Drive,Rh,Assembly
Driveshaft Install-4000,80
Shaft-Drive 80-108 Hd
Option-72in Driveshaft
Shaft-Drive,72 In
Shaft Drive T-S,Manual R B 523030d1
Frame And Suspension Group
72 In
80 In
Frame-Adjust Rear 72 Inch
Frame-Adjust Rear 44xx Series 80 Inch
Frame Assembly 72 Inch Wide Front
Channel Assembly 72 Inch
Frame Assembly 80 Inch Wide Front
Channel Assembly 80 Inch
F A-Front Extension,Sc
Footboard Group
Footboard Group-W O Boom Rest,4450mt
Hitch-Install
Belly Pan Install-Wf
Belly Pan Install-Sf
Axle And Steering Group
Extension Install-Front
Wide Front Group-72 In ,Sc
Option-Wide Front,Sc
Tie Rod Assembly-3440-72
Steering Assembly-Arm
Steering Group-Wf,72 In
Steering Group-Sf
Hydraulic Group
Tube Assembly
Cylinder-Hydraulic,2.00x20.00x1.00
Hydraulic Install-Kit No H Frame
Valve Assembly-6 Spool
Valve-Check,Cv08200n25
H Frame
Cylinder-Hydraulic,2.00x4.00x1.00
Cylinder-Hydraulic,
Hydraulic Install-4000 Chassis
Valve Assembly-Control
Tank Assembly-Hydraulic
Valve-Charge
Grip Assembly-Handle
Valve-Float,2 Position
Pump Hydraulic R B 531603d1
Elbow 90d 0.50mo-R X 0.50mjic
Hydraulic Install-Sf Steering
Cylinder-Hydraulic,1.75x5.00x1.00
Hydraulic Install-Wf Steering
Cylinder-Hydraulic,1.75x6.19x1.00
Hydraulic Install-80 Axle Adjust, 4000
Hydraulic Install-72 Axle Adjust, 4000
Cylinder-Hydraulic,2.00x15.25x1.00
Cylinder-Hydraulic,2.00x14.25x1.00
Hydraulic Install-H Frame
Valve-Relief Assembly Boom
Hydraulic Install-Boom Fold
Cylinder-Hydraulic,1.50x8.38x1.00
Cylinder-Hydraulic,1.75x16.84x1.25
Cylinder-Hydraulic,1.50x8.38x0.88 R B 527610d1
Cylinder-Hydraulic,2.25 X 1.00 X 6.5
Cylinder Assembly- Boom Tip Fold
Cylinder-Hydraulic,2.00x16.00x1.25
Hose Install-Boom Tilt,Sc6080,7x50
Hose Install-Boom Tip,Sc6080,7x50
Hose Install-Boom Tip Sc6080,4xxx
Hydraulic Install-4x50mt Chassis,Sc6080
Cylinder Assembly-Hydraulic,Boom Swing, Sc6080
Cylinder-Hydraulic,2.75x11x1.38
Tube Install-Hydraulic,H Frame
Valve Assembly-Hydraulic,Boom,6 Bank,4x50
Valve-Hydraulic,Boom,6 Bank
Hose Install-Hydraulic,H Frame,4x50
Hose Install-Hydraulic,Boom Lft,4x50
Valve Install-Hydraulic,Boom,6 Bank,4x50
Pump-Gear,Hydraulic,16cc R B 531604d1
Kit-Field,Gear Pump,19cc,P5t
Pump-Gear,19cc,P5t
Adapter Assembly,-6mor X -6stor
Tank Assembly
Cab Group
Valve-Modulating
Cab Install-4000 Mt
Top Assembly-Cab
Kit-Radio,Sc,Europe
Seat Install
Seat-Suspension
Kit-Radio,Sc
Kit-Motor,Wiper
Clutch Pedal Install
Shift Install-Mt
Ignition Switch Loader
Heater-Kit
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Electrical Group
Kit-Overspray
Electrical Install-3 Valve
Electrical Install-5 Valve
Battery Install
Electrical Install-Chassis
Alternator,140 Amp-2 Groove
Electrical Install-Cab
Lamp-Warning,Amber
Gauge-Fuel,12v
Gauge-Oil Pressure
Gauge-Temperature,Water
F A-Floodlight Kit
Light-Flood,Med
Clutch Assembly
Appearance Group
Wf
Hood-Wf
Hood Install-Sf
Hood-Sf
Tire And Wheel Group
10.00 12.4
Tire Assembly-10.00-16sl W 18
Tire Assembly-12.4x24 W 24x10
Tire Assembly-12.4-24 W 24x10
7.50 12.4
Tire Assembly-7.5x24 W 24xw7,
9.00 12.4
Tire Assembly-9x24 W 24xw8,
9.00 230
Tire Assembly-9.5x32 W 32xw8
Decal Group
Decal Install-4450,80,Mt
4450,72,Mt
Decal Install-4450,80,Mt,Sf
Tank And Saddle Group
Tank Assembly-Spray
Cover-Hinged
Insert Assembly-Sq End
Agitator-A And M
Tank Assembly,Spray
Option-Pp Plumbing,Sc6080x5x20,On
Pipe Assembly-90d W 1.00hb,6x20,Pp
Pipe Assembly-T W 2 1.00hb,5x20,Pp
Pipe Assembly-X W 3 1.00hb,5x20,Pp
Pipe Assembly-T W 2 1.00hb,2x20,Pp
Pipe Assembly-90d W 1.00hb,3x20,Pp
Bracket Assembly-Str,Lg,2ips,Rev P Clp
Bracket Assembly-Str,Lg,3ips Clp
Bracket Assembly-Str,Sh,Ips Clp,P Clp
Bracket Assembly-Str,Lg,Ips Clp,2p
Bracket Assembly-Str,Lg,2ips Clp
Bracket Assembly-L,Pp Stauff
Bracket Assembly-L,Pp Stauff,Rev P Clp
Bracket Assembly-L,Pp Stauff,Ctr P Clp
Bracket Assembly-Str,Lg,2ips Clp,1.00u
Bracket Assembly-L,Pp Stauff,1.00u
Bracket Assembly-Str,Sh,Ips Clp,1.00u
Bracket Assembly-Str,Lg,2ips,P Clp
Spray Install-60 Ft Manifold
Filter Assembly-Boom
Nozzle Assembly-Single
Nozzle Assembly Double
Spray Install-4000 Chassis
Valve Ball 0.75 Poly Full Flow
Pump Assembly- Spray W Clutch
Pump-Spray
Valve 3-Way 2.00 Bottom Load
Valve Assembly-Inlet
Valve-Ball,2in Fp,W Cam
Filter-Inline
Strainer-Manifold
Valve Assembly R B 426406
Valve R B 056871
Strainer Assembly Less Screen 1.25
Spray System Install-H Frame
3 Section Valve-Boom Shut Off
Valve Assembly-2.00sp Flange X O Ring
Valve-Control,1.00npt 2.00sp Flg
Valve Assembly-Boom Shut Off,
Valve Assembly-Kz, 3 Section,
Valve W O Power Head
Insert-Seat,Qc3
Spray Install-Ctr Manifold
Spray Install-80 Ft Manifold
5 Section Valve-Boom Shut Off
Valve Assembly-Kz, 5 Section,
Spray Install-Loose Parts Kit
Nozzle Assembly-Double
Manifold Install-Ctr,Sc6080,4x50
Valve Assembly-Shutoff,Boom Section,5
Valve-Pressure,Control
Nozzle Assembly-Opt,80x20 On,Tpl
Nozzle Holder-Tpl 1.00 Ips
Valve Teejet
Gauge-Flow
Boom Group
Tilt Rack Assembly
Tube Assembly-Rack Tilt
Boom Lift Group
Rear H Frame Group
Spring, Assembly
Boom Group-Rh,60 Ft
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Group-Lh,60 Ft
Boom Group-Rh,80 Ft
Boom Group-Lh,80 Ft
Kit-Loose Parts,Boom Hinge
Option-Boom 60 80
Boom Assembly-60 80,Lh
Boom Assembly-60 80,Rh
Boom Assembly-60 80
Cam Assembly-Breakaway,60 80
Cam Assembly-Boom Breakaway
Rack Install-Tilt,Boom,60 80
Rack Assembly-Tilt,Boom,60 80
Frame Install-H,Rear,Boom,60 80
Frame Assembly-H,Rear,Boom,60 80
Frame Assembly-H,Rear,B00m,60 80
Bar Install-Mounting,Plumbing,Ctr,Sc6080
Lift Install-Boom,Par Link,4x50
Boomrest Install-Sc6080,4x50
Bag-Parts
Block Install-Boomrest,4x50
Controller Group
Controller Raven Package
Install-Control,Raven
Package-Raven Mount,3400 Wf
Foam Marker Group
F A-Marker,Rsc 2130
Deflector-Collector, 2 In
Rsc Foamhead Valve Assembly
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In
Filter Assembly, Incline
Compressor-Foam Marker
Filter Assembly-Carbon
Control Module Assembly
Options Group
Fresh Water Install
Overspray Install
F A-Crop Deflector,3400 4400
F A-Driveshaft Extension Kit
Recommended Dealer Stock
