702,019
Spra-Coupe Sprayer 4440-80 Parts Catalog WR128532
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 4440-80 Sprayer
Part Number: WR128532
Number of Pages: 1613 Pages
Publication Information
Engine Group
Engine-Perkins
Short Engine
Cylinder Block Kit
Rear Oil Seal Assembly
Cylinder Head Kit
Rocker Shaft Assembly
Timing Gear And Camshaft Assembly
Oil Pump And Housing Assembly
Crankshaft Rod And Piston Assembly
Conrod Kit
Fuel Injection Equipment
Flywheel Housing Assembly
Fan Drive Assembly
Oil Sump Assembly
Oil Filter Assembly
Oil Breather Assembly
Valve Cover Breather Hose Assembly
Oil Filter And Cooler Assembly
Front End Drive Input
Cooling Assembly
Thermostat Housing Assembly
Water Outlet And Inlet
Fan And Extension Assembly
Alternator And Generator Install
Auxillary Drive Option
Turbocharger Assembly
Turbo Manifold And Cooler Assembly
Turbo Actuator Assembly
Remote Air Charge Cooler
Lift Pump
Fuel Filter Install
Low Pressure Fuel System
Fuel Filter Assembly
Cold Start System
Engine Lifting Plate Install
Mountings Front And Rear
Heater Starter Switch
Oil Pressure Switch And Gauge
Temp Gauge And Sender
Radiator And Cooling Fitting Assembly
Fuel Re-Lift Pump Install
Filter
Miscellaneous And Auxillaries
Top Joint And Gasket Kit
Engine Support Group-Perkins
Arm Assembly-Pulley
Engine Group-Perkins
Motor-Starter
Throttle Group-4000,Sc
Throttle Assembly-Hand
Cooling Group-Sc
Filter Air Group-Sc
Air Filter Assembly
Exhaust Group-Perkins,Sc
Driveline Group
Chaincase Group-3400,Sc
Hub Assembly-Wheel
Brake Group-Power,4440
Valve-Modulating
Pedal Assembly-Brake
Brake Assembly,Lh
Brake Assembly,Rh
Cylinder Assembly-Brake
Option-Belly Pan W F,Factory
Option-Belly Pan S F,Factory
Drive Train Group
Transmission-A618 Reman
Shaft-Drive 80-108 Hd
Differential Assembly
Shaft-Drive,Auto
Shaft Drive 80-108 (Replaced By Wr55933)
Hub Assembly
F A-Driveshaft Extension
Frame And Suspension Group
Frame Group-4640,Sc
Frame Assembly 80 Inch Wide Front
Channel Assembly
Option-Single Front,Sc
Cylinder-Hydraulic,1.75x5.00x1.00
Engine Cover Group-Sf,Sc
Install-Control,Raven
Gauge-Flow
Axle Group-Adj,3430 Sf
Footboard Group-Sc
F A-Front Extension,Sc
Hitch-Install
Axle And Steering Group
Option-Wide Front,Sc
Steering Group-Sf
Steering Column
Tie Rod Assembly-3440-80
Fuel System Group
Fuel Group-Perkins,Sc
Tank Assembly
Hydraulic Group
Tube Assembly
Hydraulic Group-Hydraulic Fold
Valve Assembly-6 Spool
Valve-Check,Cv08200n25
Cylinder-Hydraulic,2.00x4.00x1.00
Valve-Relief;Assembly Boom
Hydraulic Group-Chassis,
Valve-Charge
Valve Assembly-Control
Grip Assembly-Handle
Cylinder-Hydraulic,2.00x20.00x1.00
Cylinder-Hydraulic,1.75x16.84x1.00
Valve-Float,2 Position
Pump-Hydraulic
Tank Assembly-Hydraulic
Valve-Steering
Cylinder-Hydraulic,1.50x8.38x0.88
H Frame
Hydraulic Install-Kit No H Frame
Cab Group
Shift Group-Auto,Sc
Control-Shift,A T
Kit-Radio,Sc,Europe
Seat Group-Sc
Seat-Suspension
Cab Group-4000 Mt
Top Assembly-Cab
Kit-Motor,Wiper
Ignition Switch Loader
Kit-Wiper Motor
Kit Hardware Wj3
Blower-Kit
Fan Assembly
Air Conditioner Group-Sc
Air Conditioner-Kit
Heater-Kit
Electrical Group
Kit-Overspray
F A-Flood Light,Sc
Light-Flood,Med
Electrical Group-Sc
Light,Head
Gauge-Fuel,12v
Light Assembly
Alternator-140 Amp
Gauge-Oil Pressure
Gauge-Temperature,Water
Cab Electrical Group
Clutch Assembly
Appearance Group
Engine Cover Group-Wf Sc
Install-Cover,Engine,W-F
Tire And Wheel Group
Tire Assembly-10.00-16sl W 18
Tire Assembly-12.4x24 W 24x10
Tire Assembly-9.5x32 W 32xw8,
Tire Assembly-9.5x32 W32xw8,
Tire Assembly-9x24 W 24 X W8,
Tire Assembly-7.5x24 W 24xw7,
Decal Group
Final Assembly Group-4440 Sf
Tank And Saddle Group
Tank Assembly-Spray
Cover-Hinged
Insert Assembly-Sq End
Filter Assembly-Boom
Valve Assembly-Boom Shut Off,
Valve Assembly-Kz, 3 Section,
Valve W O Power Head
Insert-Seat,Qc3
Valve Assembly-Kz,5 Section,
Valve Assembly-Kz, 5 Section,
Spray System-Group,Chassis
Strainer-Manifold
Valve Assembly R B 426406
Valve R B 056871
Strainer Assembly Less Screen 1.25
Manifold Assembly-Spray
Valve-Pressure,Control
Valve Assembly-Inlet
Valve-Ball,2 In Fp,W Cam
Filter-Inline
Pump-Spray
Valve Ball, 0.75 Poly Ff
Valve 3-Way, 2.00 Bottom Load
Valve Teejet
Spray System Group-H Frame
Nozzle Assembly-Single
Nozzle Assembly-Double
Spray System Assembly-3 Valve
Manifold Group-20 In ,Sc
Manifold Group-20, 80 Ft
Spray System Assembly-5 Valve
Spray Install-Ctr Manifold
Spray System Group
Nozzle Assembly-Drop
Boom Group
Boom Group-80 Ft Hydraulic Fold
Bag-Parts
Boom Assembly-Rh,80 Ft Hydraulic
Boom Assembly-Rh
Boom Assembly-Lh,80 Ft Hydraulic
Boom Assembly-Lh
Boom Lift Group
Boom Group-60 Ft Hydraulic Fold
Boom Assembly-Rh,60 Ft Hydraulic
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Assembly-Lh,60 Ft Hydraulic
Tilt Rack Assembly
Tube Assembly-Rack Tilt
Rear H Frame Group
Kit-Loose Parts,Boom Hinge
Boom Group-Rh,80 Ft
Boom Group-Lh,80 Ft
Controller Group
Controller Raven Package
Package-Raven Mnt,3400 Wf
Package-Mount,3400 Sf
Kg-3600wf Raven Mount
Install-Fieldstar, Ctrlt, S C
Option-Gps Receiver,5hz,Sc
Option-Fieldstar,Wf,3 Valve
Option-Fieldstar,Wf,5 Valve
Option-Fieldstar,Wf,3 Valve,W 0
Option-Fieldstar,Wf,5 Valve,W O
Option-Fieldstar,Sf,3 Valve
Option-Fieldstar,Sf,5 Valve
Option-Fieldstar,Sf3 Valve,W 0
Option-Fieldstar,Sf,5 Valve,W O
Option-Lightbar,Spra-Coupe
Kit-Gps Antenna Mount,Sc
Foam Marker Group
F A-Marker,Rsc 2130
Rsc Foamhead Valve Assembly
Deflector-Collector, 2 In
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In
Filter Assembly, Incline
Filter Assembly-Carbon
Module, Control
Options Group
Fresh Water Group-Sc
F A-Belly Pan,Wf
Recommended Dealer Stock
