Spra-Coupe Sprayer 4440-80 Parts Catalog WR128526
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 4440-80 Sprayer
Part Number: WR128526
Number of Pages: 1639 Pages
Publication Information
Engine Group
Engine-Perkins
Short Engine
Cylinder Block Kit
Rear Oil Seal Assembly
Cylinder Head Kit
Rocker Shaft Assembly
Timing Gear And Camshaft Assembly
Oil Pump And Housing Assembly
Crankshaft Rod And Piston Assembly
Conrod Kit
Fuel Injection Equipment
Flywheel Housing Assembly
Fan Drive Assembly
Oil Sump Assembly
Oil Filter Assembly
Oil Breather Assembly
Valve Cover Breather Hose Assembly
Oil Filter And Cooler Assembly
Front End Drive Input
Cooling Assembly
Thermostat Housing Assembly
Water Outlet And Inlet
Fan And Extension Assembly
Alternator And Generator Install
Auxillary Drive Option
Turbocharger Assembly
Turbo Manifold And Cooler Assembly
Turbo Actuator Assembly
Remote Air Charge Cooler
Lift Pump
Fuel Filter Install
Low Pressure Fuel System
Fuel Filter Assembly
Cold Start System
Engine Lifting Plate Install
Mountings Front And Rear
Heater Starter Switch
Oil Pressure Switch And Gauge
Temp Gauge And Sender
Radiator And Cooling Fitting Assembly
Fuel Re-Lift Pump Install
Filter
Miscellaneous And Auxillaries
Top Joint And Gasket Kit
Engine-Perkins,Tpem
Kit,Engine Overhaul
Kit, Thrust Washer
Kit,Thrust Washer
Kit, Valve Train
Piston,Conn Rod
Turbocharger, Assembly
Gasket Kit
Engine Support Group-Perkins
Arm Assembly-Pulley
Engine Group-Perkins
Housing Assembly-Flywheel
Package-Parts,Ford
Flywheel Assembly
Motor-Starter
Driveline Group
Chaincase Group-Sc
Hub Assembly-Wheel
Brake Group-Power,4640
Cylinder Assembly-Brake
Pedal Assembly-Brake
Valve-Modulating
Brake Assembly,Lh
Brake Assembly,Rh
Drive Train Group-Manual
Shaft Drive T-S,Manual R B 523030d1
Transmission Assembly
Differential Assembly
Shaft-Drive 80-108 Hd
Shaft-Drive,T-5 Manual
F A-Driveshaft Extension
Frame And Suspension Group
Frame Group-4640,Sc 80 Inch
Frame Assembly 80 Inch Wide Front
Channel Assembly 80 Inch
Axle Group-Adjust
Footboard Group-Sc
F A-Front Extension,Sc
F A-Crop Deflector,Wf,
Steering Assembly-Arm
Hitch-Install
Axle And Steering Group
Wide Front Group-Sc 46 Series 80 Inch Frame
Steering Group-Wf,80 Inch
Tie Rod Assembly-340-80
Steering Column
Fuel System Group
Fuel Group-Perkins,Sc
Tank Assembly
Hydraulic Group
Tube Assembly
Hydraulic Group-Hydraulic Fold
Valve Assembly-6 Spool
Valve-Check,Cv08200n25
Cylinder-Hydraulic,2.00x4.00x1.00
Valve-Relief;Assembly Boom
Valve Assembly-Control
Grip Assembly-Handle
Pump-Hydraulic
Tank Assembly-Hydraulic
Hydraulic Group-Chassis,
Valve-Charge
Cylinder-Hydraulic,2.00x20.00x1.00
Cylinder-Hydraulic,1.75x6.19x1.00
Valve-Float,2 Position
Valve-Steering
Cylinder-Hydraulic,1.75x16.84x1.00
Cylinder-Hydraulic,1.50x8.38x0.88
Cylinder-Hydraulic,R B 129450
Cab Group
Clutch Pedal Group-Sc
Pedal Assembly-Clutch
Control Group-Trans Shift
Linkage Assembly-Shift
Cab Group-4000 Mt
Top Assembly-Cab
Install-Cab
Pedal Assembly-Throttle
Kit-Radio,Sc,Europe
Seat Group-Sc
Install-Seat
Seat-Suspension
Kit-Motor,Wiper
Control Group-Joystick
Install-Throttle
Ignition Switch Loader
Kit-Wiper Motor
Kit Hardware Wj3
Air Conditioner Group-Sc
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Heater-Kit
Electrical Group
Electrical Group-4000 W
Gauge-Fuel,12v
Gauge-Oil Pressure
Gauge-Temperature,Water
Light Assembly
Alternator-140 Amp
Cab Electrical Group
Light-Flood,Med
F A-Flood Light,Sc
Kit-Overspray
Clutch Assembly
Appearance Group
Engine Cover Group-Wf Sc
Install-Cover,Engine,W-F
Tire And Wheel Group
Tire Assembly-9x24 W 24 X W8,
Tire Assembly-12.4x24 W 24x10
Tire Assembly-7.5x24 W 24xw7,
Tire Assembly-9.5x32 W 32xw8,
Tire Assembly-9.5x32 W32xw8,
Decal Group
Final Assembly Group Manual
Tank And Saddle Group
Tank Assembly-Spray
Cover-Hinged
Insert Assembly-Sq End
Spray System-Group,Chassis
Strainer-Manifold
Valve Assembly R B 426406
Valve R B 056871
Strainer Assembly Less Screen 1.25
Manifold Assembly-Spray
Valve-Pressure,Control
Valve Assembly-Inlet
Valve-Ball,2 In Fp,W Cam
Pump-Spray
Valve Ball, 0.75 Poly Ff
Valve 3-Way, 2.00 Bottom Load
Valve Assembly-Boom Shut Off,
Valve Assembly-Kz, 5 Section,
Valve W O Power Head
Insert-Seat,Qc3
Spray System Assembly-3 Valve
Manifold Group-20 In ,Sc
Nozzle Assembly-Single
Nozzle Assembly-Double
Filter Assembly-Boom
Manifold Group-20, 80 Ft
Spray System Assembly-5 Valve
Valve Assembly-Kz,5 Section,
Valve Teejet
Gauge-Flow
Nozzle Assembly-Drop
Boom Group
Boom Group-60 Ft Hydraulic Fold
Boom Assembly-Rh,60 Ft Hydraulic
Boom Assembly-Rh
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Assembly-Lh,60 Ft Hydraulic
Boom Assembly-Lh
Spring, Assembly
Bag-Parts
Tilt Rack Assembly
Tube Assembly-Rack Tilt
Boom Group-80 Ft Hydraulic Fold
Boom Assembly-Lh,80 Ft Hydraulic
Boom Assembly-Rh,80 Ft Hydraulic
Rear H Frame Group
Boom Lift Group
Controller Group
Kg-3600wf Raven Mount
Option-Fieldstar,Wf,3 Valve
Install-Fieldstar, Ctrlt, S C
Option-Gps Receiver,5hz,Sc
Option-Fieldstar,Wf,5 Valve
Option-Fieldstar,Wf,3 Valve,W 0
Option-Fieldstar,Wf,5 Valve,W O
Option-Lightbar,Spra-Coupe
Controller Raven Package
Kit-Gps Antenna Mount,Sc
Foam Marker Group
Module, Control
F A-Marker,Rsc 2130
Rsc Foamhead Valve Assembly
Deflector-Collector, 2 In
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In
Filter Assembly, Incline
Filter Assembly-Carbon
Compressor-Foam Marker
Options Group
Fresh Water Group-Sc
F A-Belly Pan,Wf
Recommended Dealer Stock
Brand: Spra-Coupe
Engine Group
Engine-Perkins
Short Engine
Cylinder Block Kit
Cylinder Head Kit
Conrod Kit
Fan Drive Assembly
Oil Sump Assembly
Oil Filter Assembly
Cooling Assembly
Lift Pump
Fuel Filter Install
Cold Start System
Filter
Engine-Perkins,Tpem
Kit,Engine Overhaul
Kit, Thrust Washer
Kit,Thrust Washer
Kit, Valve Train
Piston,Conn Rod
Gasket Kit
Arm Assembly-Pulley
Package-Parts,Ford
Flywheel Assembly
Motor-Starter
Driveline Group
Chaincase Group-Sc
Hub Assembly-Wheel
Valve-Modulating
Brake Assembly,Lh
Brake Assembly,Rh
Axle Group-Adjust
Footboard Group-Sc
Hitch-Install
Steering Column
Fuel System Group
Tank Assembly
Hydraulic Group
Tube Assembly
Pump-Hydraulic
Valve-Charge
Valve-Steering
Cab Group
Cab Group-4000 Mt
Top Assembly-Cab
Install-Cab
Kit-Radio,Sc,Europe
Seat Group-Sc
Install-Seat
Seat-Suspension
Kit-Motor,Wiper
Install-Throttle
Kit-Wiper Motor
Kit Hardware Wj3
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Heater-Kit
Electrical Group
Gauge-Fuel,12v
Gauge-Oil Pressure
Light Assembly
Alternator-140 Amp
Light-Flood,Med
F A-Flood Light,Sc
Kit-Overspray
Clutch Assembly
Appearance Group
Decal Group
Tank Assembly-Spray
Cover-Hinged
Strainer-Manifold
Valve R B 056871
Pump-Spray
Insert-Seat,Qc3
Valve Teejet
Gauge-Flow
Boom Group
Boom Assembly-Rh
Boom Assembly-Lh
Spring, Assembly
Bag-Parts
Tilt Rack Assembly
Rear H Frame Group
Boom Lift Group
Controller Group
Foam Marker Group
Module, Control
F A-Marker,Rsc 2130
Options Group
F A-Belly Pan,Wf
- Spra Coupe EU 4460 4660 Sprayer Service Manual_79034247B
- Spra Coupe EU 4460 4660 Manual Transmission Operator Manual_519177D1D
- Spra Coupe SA 7000 Series SPRA-COUPE Service Manual_WR132165
- Spra Coupe EU 7460 7660 Sprayer System RTS_AG333725A
- Spra Coupe EU 7000 Series Sprayer Service Manual_79027326A
- Spra Coupe EU 7460 7660 Applicator Chassis Service Manual_79032953B
- Spra Coupe EU 4460 4660 Man Sprayer Repair Time Schedule_AG335277A
- Spra Coupe EU 4460 4660 Sprayer Automatic Transmission Operator Manual_519176D1D
- Spra Coupe EU 4455 4655 Sprayer Automatic Transmission Operator Manual_512150D1D
- Spra Coupe EU 4450 4650 4455 4655 Sprayer Service Manual_79027328B
- Spra Coupe SA 7000 Series Sprayer Service Manual_79027326
- Spra Coupe EU 7450 7650 Sprayer System Repair Time Schedule_AG331640A
- Spra Coupe EU 4460 4660 Auto Sprayer Repair Time Schedule_AG335025A
- Spra Coupe EU 7460 7660 Applicator Chassis RTS_AG333724A
- Spra Coupe SA 7450 7650 System Repair Time Schedule_AG331640A
