Spra-Coupe Sprayer 4440-72 Parts Catalog WR128531
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 4440-72 Sprayer
Part Number: WR128531
Number of Pages: 1352 Pages
Publication Information
Engine Group
Exhaust Group-Perkins,Sc
Cooling Group-Sc
Filter Air Group-Sc
Air Filter Assembly
Throttle Group-4000,Sc
Throttle Assembly-Hand
Engine-Perkins
Short Engine
Cylinder Block Kit
Rear Oil Seal Assembly
Cylinder Head Kit
Rocker Shaft Assembly
Timing Gear And Camshaft Assembly
Oil Pump And Housing Assembly
Crankshaft Rod And Piston Assembly
Conrod Kit
Fuel Injection Equipment
Flywheel Housing Assembly
Fan Drive Assembly
Oil Sump Assembly
Oil Filter Assembly
Oil Breather Assembly
Valve Cover Breather Hose Assembly
Oil Filter And Cooler Assembly
Front End Drive Input
Cooling Assembly
Thermostat Housing Assembly
Water Outlet And Inlet
Fan And Extension Assembly
Alternator And Generator Install
Auxillary Drive Option
Turbocharger Assembly
Turbo Manifold And Cooler Assembly
Turbo Actuator Assembly
Remote Air Charge Cooler
Lift Pump
Fuel Filter Install
Low Pressure Fuel System
Fuel Filter Assembly
Cold Start System
Engine Lifting Plate Install
Mountings Front And Rear
Heater Starter Switch
Oil Pressure Switch And Gauge
Temp Gauge And Sender
Radiator And Cooling Fitting Assembly
Fuel Re-Lift Pump Install
Filter
Miscellaneous And Auxillaries
Top Joint And Gasket Kit
Engine Support Group-Perkins
Arm Assembly-Pulley
Engine Group-Perkins
Motor-Starter
Driveline Group
Option-72 In Driveshaft
Shaft-Drive,72 In
Driveshaft Install-4000,80
Shaft-Drive 80-108 Hd
Drive Train Group-Sc
Transmission-A618 Reman
Differential Assembly
Shaft-Drive,Auto
Chaincase Group-3400,Sc
Hub Assembly-Wheel
Brake Group-Power,4440
Pedal Assembly-Brake
Valve-Modulating
Brake Assembly,Lh
Brake Assembly,Rh
Cylinder Assembly-Brake
Shaft Drive 80-108 (Replaced By Wr55933)
F A-Driveshaft Extension
Option-Belly Pan W F,Factory
Frame And Suspension Group
Frame Group-4440 Wf,Sc
Footboard Group-Sc
Frame Assembly 72 Inch Wide Front
Axle Group-Adjust
F A-Front Extension,Sc
Hitch-Install
F A-Crop Deflector,Sc
Axle And Steering Group
Wide Front Group-72 In ,Sc
Steering Group-Wf,72 In
Tie Rod Assembly-3440-72
Steering Column
Steering Assembly-Arm
Fuel System Group
Fuel Group-Perkins,Sc
Tank Assembly
Hydraulic Group
Hydraulic Group-Chassis
Valve Assembly-Control
Valve-Check,Cv08200n25
Cylinder-Hydraulic,2.00x15.25x1.00
Cylinder-Hydraulic,2.00x14.25x1.00
Cylinder-Hydraulic,1.75x6.19x1.00
Valve-Steering
Tank Assembly-Hydraulic
Valve-Charge
Cylinder-Hydraulic,1.75x16.84x1.00
Valve-Float,2 Position
Pump-Hydraulic
Grip Assembly-Handle
H Frame
Valve Assembly-6 Spool
Cylinder-Hydraulic,2.00x4.00x1.00
Hydraulic Install-Kit No H Frame
Valve-Relief;Assembly Boom
Cylinder-Hydraulic,1.50x8.38x0.88
Hydraulic Group-Hydraulic Fold
Cab Group
Kit-Radio,Sc,Europe
Seat Group-Sc
Seat-Suspension
Cab Group-4000 Mt
Top Assembly-Cab
Shift Group-Auto,Sc
Control-Shift,A T
Kit-Motor,Wiper
Ignition Switch Loader
Kit-Wiper Motor
Kit Hardware Wj3
Air Conditioner Group-Sc
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Heater-Kit
Electrical Group
Electrical Group-Sc
Gauge-Fuel,12v
Light Assembly
Alternator-140 Amp
Gauge-Oil Pressure
Gauge-Temperature,Water
Cab Electrical Group
Light-Flood,Med
Kit-Overspray
F A-Flood Light,Sc
Clutch Assembly
Appearance Group
Engine Cover Group-Wf Sc
Tire And Wheel Group
Tire Assembly-9x24 W 24 X W8,
Tire Assembly-12.4x24 W 24x10
Tire Assembly-7.5x24 W 24xw7,
Tire Assembly-9.5x32 W 32xw8,
Tire Assembly-9.5x32 W32xw8,
Decal Group
Final Assembly Group-4440 Wf
Tank And Saddle Group
Tank Assembly-Spray
Cover-Hinged
Spray System-Group,Chassis
Strainer-Manifold
Valve Assembly R B 426406
Valve R B 056871
Strainer Assembly Less Screen 1.25
Manifold Assembly-Spray
Valve-Pressure,Control
Pump-Spray
Valve Assembly-Inlet
Filter-Inline
Valve-Ball,2in Fp,W Cam
Valve Ball, 0.75 Poly Ff
Valve Teejet
Spray Sys Group-H Frame
Valve Assembly-Kz, 5 Section,
Valve W O Power Head
Insert-Seat,Qc3
Filter Assembly-Boom
Nozzle Assembly-Single
Nozzle Assembly-Double
Valve Assembly-Boom Shut Off,
Valve Assembly-Kz, 3 Section,
Gauge-Flow
Spray System Assembly-3 Valve
Manifold Group-20 In ,Sc
Manifold Group-20, 80 Ft
Spray System Assembly-5 Valve
Spray Install-Ctr Manifold
Spray System Group
Spray Install-Loose Parts Kit
Valve-Control, 1.00npt 2.00sp Flg
Valve 5-Section, Boom Shut Off
Valve Assembly-2.00sp Flg X O-Ring
Valve Assembly-Kz,5 Section,
Nozzle Assembly-Drop
Boom Group
Boom Lift Group
Rear H Frame Group
Spring, Assembly
Bag-Parts
Boom Group-60 Ft Hydraulic Fold
Boom Assembly-Rh,60 Ft Hydraulic
Boom Assembly-Rh
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Assembly-Lh,60 Ft Hydraulic
Boom Assembly-Lh
Tilt Rack Assembly
Tube Assembly-Rack Tilt
Boom Group-80 Ft Hydraulic Fold
Boom Assembly-Rh,80 Ft Hydraulic
Boom Assembly-Lh,80 Ft Hydraulic
Kit-Loose Parts,Boom Hinge
Controller Group
Controller Raven Package
Package-Raven Mnt,3400 Wf
Option-Fieldstar,Wf,3valve
Option-Gps Receiver,5hz,Sc
Install-Fieldstar, Ctrlt, S C
Option-Fieldstar,Wf,5valve
Option-Fieldstar,Wf,3valve,W 0
Option-Fieldstar,Wf,5valve,W O
Option-Lightbar,Spra-Coupe
Kit-Gps Antenna Mount,Sc
Foam Marker Group
F A-Marker,Rsc 2130
Rsc Foamhead Valve Assembly
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In
Filter Assembly, Incline
Filter Assembly-Carbon
Compressor-Foam Marker
Module, Control
Options Group
Fresh Water Group-Sc
F A-Belly Pan,Wf
Recommended Dealer Stock
