Spra-Coupe Sprayer 3650 Parts Catalog WR129575
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 3650 Sprayer
Part Number: WR129575
Number of Pages: 1124 Pages
Publication Information
Engine Group
F A-50hr Filter Kit
F A-500hr Filter Kit
Engine Group-3000 Mt
Engine-Perkins 108 Hp
Motor-Starter
Cylinder Block And Liners
Crank, Main And Big End Bearings
Pistons And Rings
Connecting Rods
Rear End Oil Seal
Cylinder Head Assembly
Rocker Shaft Assembly
Fuel Injection Pump
High Pressure Fuel Pipes
Atomizers
Throttle And Stop Controls
Pick-Up Sensors
Fuel Leak-Off Pipe
Boost Control Pipe
Fan Drive
Sump
Dipstick And Filler Tube
Oil Strainer
Cylinder Head Cover
Breather
Filler
Oil Filter
Blanking Plates
Front End Drive Input
Pipes
Water Outlet Housing
Fan
Timing Case
Timing Cover
Blanking Plug
Oil Pump And Delivery Housing
Turbocharger
Feed Pipes
Leak-Off Pipes
Pipework And Connections
Exhaust Manifold
Induction Manifold
Pipework And Connecitons
Lift Pump
Filter To Injection Pump Pipe
Injection Pump To Filter Pipe
Heater Plugs
Engine Lifting Eyes
Engine Mounts
Lube Oil Pressure Switch-Gauge
Temperature Gauge And Sender
Miscellaneous And Auxiliaries
Top Service Kit
Bottom Service Kit
Package-Parts,Ford
Cooling Group
Engine Support Group
Arm Assembly-Pulley
Exhaust Group
Air Cleaner Group
Filter-Air
Install Throttle
Throttle Assembly-Hand
Driveline Group
3000 Mt
Transmission Assembly
Shaft-Drive,T-5
Differential Assembly
Chaincase Install-3600
Chaincase Assembly-3600,Lh
Hub Assembly-Wheel
Chaincase Assembly-3600,Rh
Install, Brake
Brake Tolomatic
Cylinder-Master,Brake
Brake Assembly-Pedal
Bellcrank Assembly
Shaft, Drive 80-108
F A-Driveshaft Extension
Frame And Suspension Group
Frame-Adjust Rear 46xx Series 80 Inch
3xxx Series 80 Inch
Channel Assembly 80 Inch
Frame Assembly 80 Inch Wide Front
Footboard Install-3650
F A-Front Extension,Sc
Belly Pan Install-Wf
Hitch-Install
Axle And Steering Group
Extension Install-Front
Tie Rod Assembly-340-80
Wide Front Group-Sc
Steering Group-Wf,80 In
Steering Column
Steering Assembly-Arm
Fuel System Group
Fuel Group
Hydraulic Group
Tube Assembly
Drive Shaft Install-3000,80
Grip Assembly-Handle
Hydraulic Install-Kit No H Frame
Valve Assembly-6 Spool
Valve-Check,Cv08200n25
H Frame
Cylinder-Hydraulic,2.00x4.00x1.00
Cylinder-Hydraulic,
Hydraulic Install-80 Axle Adj, 3000
Cylinder-Hydraulic,2.00x20.00x1.00
Valve Assembly-Control
Hydraulic Install-Wf Steering
Cylinder-Hydraulic,1.75x6.19x1.00
Hydraulic Install-H Frame
Valve-Relief;Assembly Boom
Hydraulic Install-Boom Fold
Cylinder-Hydraulic,1.50x8.38x1.00
Tank Assembly-Hydraulic
Hydraulic Install-3000 Chassis
Cylinder-Hydraulic,1.75x16.84x1.00
Valve-Float,2 Position
Pump Hydraulic R B 531603d1
Elbow 90d 0.50mo-R X 0.50mjic
Cylinder-Hydraulic,1.50x8.38x0.88 R B 527610d1
Pump-Gear,Hydraulic,16cc R B 531604d1
Kit-Field,Gear Pump,19cc,P5t
Pump-Gear,19cc,P5t
Adapter Assembly,-6mor X -6stor
Tank Assembly
Insert Assembly-Sq End
Cab Group
Clutch Pedal Install
Shift Install-Mt
Cab Install-3000 Mt
Top Assembly-Cab
Kit-Radio,Sc
Seat Install
Seat-Suspension
Kit-Wiper Motor
Kit Hardware Wj3
Air Conditioner-Kit
Heater-Kit
Blower-Kit
Fan Assembly
Electrical Group
Electrical Install-3 Valve
Electrical Install-5 Valve
Battery Install
Electrical Install-Cab
Gauge-Fuel,12v
Gauge-Oil Pressure
Gauge-Temperature,Water
Electrical Install-Chassis
Light Assembly
Alternator,140 Amp-2 Groove
F A-Floodlight Kit
Light-Flood,Med
Kit-Overspray
Clutch Assembly
Appearance Group
Wf
Hood-Wf
Tire And Wheel Group
7.50 12.4
Tire Assembly-12.4x24 W 24x10
Tire Assembly-12.4-24 W 24x10
Tire Assembly-7.5x24 W 24xw7,
9.00 12.4
Tire Assembly-9x24 W 24xw8,
9.00 230
Tire Assembly-9.5x32 W 32xw8
Decal Group
Decal Install-3650mt,80,Wf
Valve-Pressure,Control
Valve Assembly R B 426406
Valve R B 056871
Valve Teejet
Valve Assembly-Inlet
Filter-Strainer,Inline
Spray System-3000 Chassis
Strainer-Manifold
Strainer Assembly Less Screen 1.25
Valve 3-Way 1.50 Bottom Load
Pump-Spray
Spray Install-60 Ft Manifold
Filter Assembly-Boom
Nozzle Assembly-Single
Nozzle Assembly Double
Spray System Instal-H Frame
3 Section Valve-Boom Shut Off
Valve Assembly-2.00sp Flange X O Ring
Valve-Control,1.00npt 2.00sp Flg
Valve Assembly-Boom Shut Off,
Valve Assembly-Kz, 3 Section,
Valve W O Power Head
Insert-Seat,Qc3
Spray Install-Ctr Manifold
Spray Install-80 Ft Manifold
5 Section Valve-Boom Shut Off
Valve Assembly-Kz,5 Section
Spray Install-Loose Parts Kit
Nozzle Assembly-Double
Gauge-Flow
Boom Group
Tilt Rack Assembly
Tube Assembly-Rack Tilt
Boom Lift Group
Rear H Frame Group
Spring, Assembly
Boom Group-Rh,60 Ft
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Group-Lh,60 Ft
Boom Group-Lh,80 Ft
Boom Group-Rh,80 Ft
Fresh Water Install
Bag-Parts
Kit-Loose Parts,Boom Hinge
Controller Group
Controller Raven Package
Install-Control,Raven
Kg-3600wf Raven Mount
Foam Marker Group
F A-Marker,Rsc 2130
Deflector-Collector, 2 In
Rsc Foamhead Valve Assembly
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In
Filter Assembly, Incline
Compressor-Foam Marker
Filter Assembly-Carbon
Control Module Assembly
Options Group
Overspray Install
F A Crop Deflector,3600 4600
F A-Driveshaft Extension Kit
Recommended Dealer Stock
