Spra-Coupe Sprayer 3640 ESP Parts Catalog WR128518
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 3640 ESP Sprayer
Part Number: WR128518
Number of Pages: 1297 Pages
Publication Information
Engine Group
Engine-Perkins
Short Engine
Cylinder Block Kit
Rear Oil Seal Assembly
Cylinder Head Kit
Rocker Shaft Assembly
Timing Gear And Camshaft Assembly
Oil Pump And Housing Assembly
Crankshaft Rod And Piston Assembly
Conrod Kit
Fuel Injection Equipment
Flywheel Housing Assembly
Fan Drive Assembly
Oil Sump Assembly
Oil Filter Assembly
Oil Breather Assembly
Valve Cover Breather Hose Assembly
Oil Filter And Cooler Assembly
Front End Drive Input
Cooling Assembly
Thermostat Housing Assembly
Water Outlet And Inlet
Fan And Extension Assembly
Alternator And Generator Install
Auxillary Drive Option
Turbocharger Assembly
Turbo Manifold And Cooler Assembly
Turbo Actuator Assembly
Remote Air Charge Cooler
Lift Pump
Fuel Filter Install
Low Pressure Fuel System
Fuel Filter Assembly
Cold Start System
Engine Lifting Plate Install
Mountings Front And Rear
Heater Starter Switch
Oil Pressure Switch And Gauge
Temperature Gauge And Sender
Radiator And Cooling Fitting Assembly
Fuel Re-Lift Pump Install
Filter
Miscellaneous And Auxillaries
Top Joint And Gasket Kit
Engine-Perkins,Tpem
Kit,Engine Overhaul
Kit, Thrust Washer
Kit,Thrust Washer
Kit, Valve Train
Piston,Conn Rod
Turbocharger, Assembly
Gasket Kit
Engine Support Group-Perkins
Arm Assembly-Pulley
Engine Group-Perkins
Housing Assembly-Flywheel
Package-Parts,Ford
Flywheel Assembly
Motor-Starter
Cooling Group-Sc
Filter Air Group-Sc
Air Filter Assembly
Exhaust Group-Perkins,Sc
Fuel Group-Perkins,Sc
Kit-Engine,Esp Ii,Sc
Driveline Group
Bellcrank Assembly
Drive Train-Perkins,Sc
Shaft, Drive 80-108
Shaft-Drive,T-5
Transmission Assembly
Differential Assembly
Driveshaft-Telescoping
Cylinder-Master,Brake
F A-Driveshaft Extension
Frame And Suspension Group
Channel Assembly 80 Inch
Frame Group-Sf And 3640
Wide Front Group-Sc 46 Series 80 Inch Frame
Frame Assembly 80 Inch Wide Front
Axle Group-Adjust
Footboard Group-3640 Esp
Frame Group-Boom Center,
Spring, Assembly
Hitch-Install
F A-Crop Deflector,Wf,
Steering Assembly-Arm
F A-Front Extension,Sc
F A-Wheel Shield,32 In
Axle And Steering Group
Chaincase Group-Sc3600
Hub Assembly-Wheel
Steering Group-Wf,80 In
Tie Rod Assembly-340-80
Steering Column
Hydraulic Group
Tube Assembly
Hydraulic Group-3640 Esp,
Install-Hydraulic
Tank Assembly-Hydraulic
Grip Assembly-Handle
Cylinder-Hydraulic,2.00x4.00x1.00
Cylinder-Hydraulic,1.75x6.19x1.00
Cylinder-Hydraulic,1.75x16.84x1.00
Valve-Float,2 Position
Valve Steering
Kit-Hydraulic Axle,Adjust,3640 Esp
Valve Assembly-Control
Valve-Check,Cv08200n25
Cylinder-Hydraulic,2.00x20.00x1.00
Hydraulic Group-Esp Ii,Sc
Valve-Hydraulic
Valve
Plug
Pump-Centrifugal
Tank Assembly
Insert Assembly-Sq End
Valve Assembly-6 Spool
Float Assembly-South
Stem Assembly-Float
Float Assembly-North
Hydraulic Group-Boom,Comp
Cylinder-Hydraulic, R B 129450
Cylinder-Hydraulic,2.5x15.64x1.00rd
Drive Shaft Install-3000,80
Cab Group
Brake Assembly-Pedal
Control Group-Trans Shift
Linkage Assembly-Shift
Pedal Assembly-Clutch
Clutch Pedal Group-Sc
Radio Group-Europe,Sc
Kit-Radio,Sc,Europe
Seat Group-Sc
Install-Seat
Seat-Suspension
Install-Cab
Top Assembly-Cab
Cab Group-3640 Esp
Kit-Motor,Wiper
Pedal Assembly-Throttle
Control Group-Joystick
Install-Throttle
Ignition Switch Loader
Kit-Wiper Motor
Kit Hardware Wj3
Blower-Kit
Fan Assembly
Air Conditioner Group-Sc
Air Conditioner-Kit
Heater-Kit
Electrical Group
Electrical Group-3640 Esp
Gauge-Fuel,12v
Alternator-140 Amp
Gauge-Oil Pressure
Gauge-Temperature,Water
Electrical Group-Esp Ii
Install-Electrical,Esp Ii
Float Assembly-Complete
Flasher Assembly
Switch Assembly-Plate
Light-Flood,Med
F A-Flood Light,Sc
Clutch Assembly
Appearance Group
Cover Group-Esp Ii,Sc
Shield Assembly-Cc
Engine Cover Group-Wf Sc
Install-Cover,Engine,W-F
Tire And Wheel Group
Tire Assembly-9x24 W 24 X W8,
Tire Assembly-12.4x24 W 24x10
Tire Assembly-7.5x24 W 24xw7,
Tire Assembly-9.5x32 W 32xw8,
Tire Assembly-9.5x32 W32xw8,
Decal Group
Final Assembly Group-3640 Esp
Install-Final
Tank And Saddle Group
Tank Group-Esp Ii,Sc
Container Assembly
Brake Group-Sc
Pump-Spray
Inlet Group-Esp Ii,Sc
Valve Assembly-Inlet
Filter-Strainer,Inline
Valve Ball, 1.50 Poly Ff
Manifold, Inlet
Valve Assembly
Valve Assembly Ball, 1in 3-Wire13-12
Strainer Assembly Less Screen 1.25
Valve Ball, 0.75 Poly Ff
Outlet Group-Esp Ii,Sc
Manifold, Outlet
Final Group-Esp 60,Comp
Manifold Group-Esp 60,
Nozzle Assembly
Filter Assembly-Boom
Nozzle Assembly-Single
Nozzle Assembly-Double
Coupler Assembly
Dual Manifold Install-Esp
Boom Group
Hinge,Tip Fold Assembly,Lh
Insulator Group-Esp Ii,Sc
Install-Insulator,Esp Ii
Hinge Group-60 Comp,Sc
Boom Support Group-Esp 60
Esp,Lh
Boom,60 Ft Comp Assembly,Lh
Controller Group
Control-Rate,Package
Package Rate Control-Spanish
Kit-Ground Speed,Magnetic
Sensor-Ground Speed,Radar
Control Group-Esp Ii,Sc
Kit-Gps Antenna Mount,Sc
Foam Marker Group
Compressor-Foam Marker
Filter Assembly, Inline
Marker Install-Esp
Package-Marker Hose,Esp
Filter-Carbon,Inline
Assembly-Head,Foam
Options Group
Fresh Water Group-Sc
F A-Belly Pan,Wf
Recommended Dealer Stock
