Spra-Coupe Sprayer 3640-80 Parts Catalog WR128530
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 3640-80 Sprayer
Part Number: WR128530
Number of Pages: 1659 Pages
Publication Information
Engine Group
Fuel Group-Perkins,Sc
Cooling Group-Sc
Filter Air Group-Sc
Air Filter Assembly
Throttle Group-Sc
Pedal Assembly-Throttle
Engine-Perkins
Short Engine
Cylinder Block Kit
Rear Oil Seal Assembly
Cylinder Head Kit
Rocker Shaft Assembly
Timing Gear And Camshaft Assembly
Oil Pump And Housing Assembly
Crankshaft Rod And Piston Assembly
Conrod Kit
Fuel Injection Equipment
Flywheel Housing Assembly
Fan Drive Assembly
Oil Sump Assembly
Oil Filter Assembly
Oil Breather Assembly
Valve Cover Breather Hose Assembly
Oil Filter And Cooler Assembly
Front End Drive Input
Cooling Assembly
Thermostat Housing Assembly
Water Outlet And Inlet
Fan And Extension Assembly
Alternator And Generator Install
Auxillary Drive Option
Turbocharger Assembly
Turbo Manifold And Cooler Assembly
Turbo Actuator Assembly
Remote Air Charge Cooler
Lift Pump
Fuel Filter Install
Low Pressure Fuel System
Fuel Filter Assembly
Cold Start System
Engine Lifting Plate Install
Mountings Front And Rear
Heater Starter Switch
Oil Pressure Switch And Gauge
Temp Gauge And Sender
Radiator And Cooling Fitting Assembly
Fuel Re-Lift Pump Install
Filter
Miscellaneous And Auxillaries
Top Joint And Gasket Kit
Engine Support Group-Perkins
Arm Assembly-Pulley
Exhaust Group-Perkins,Sc
Engine Group-Perkins
Housing Assembly-Flywheel
Package-Parts,Ford
Flywheel Assembly
Motor-Starter
Driveline Group
Bellcrank Assembly
Cylinder-Master,Brake
Drive Train-Perkins,Sc
Shaft, Drive 80-108
Shaft-Drive,T-5
Transmission Assembly
Differential Assembly
Driveshaft-Telescoping
F A-Driveshaft Extension
Option-Belly Pan W F,Factory
Frame And Suspension Group
Frame Group-Sf And 3640
Footboard Group-Sc
Axle Group-Adjust
Frame Assembly
F A-Front Extension,Sc
F A-Crop Deflector,Wf,
Steering Assembly-Arm
Hitch-Install
Axle And Steering Group
Wide Front Group-Sc
Steering Group-Wf,80 In
Tie Rod Assembly-340-80
Steering Column
Chaincase Group-Sc3600
Hub Assembly-Wheel
Hydraulic Group
Hydraulic Group-Chassis,
Cylinder-Hydraulic,1.75x6.19x1.00
Cylinder-Hydraulic,1.75x16.84x1.00
Grip Assembly-Handle
Tank Assembly-Hydraulic
Valve-Float,2 Position
Valve-Steering
Pump-Hydraulic
Valve Assembly-Control
Valve-Check,Cv08200n25
Cylinder-Hydraulic,2.00x20.00x1.00
H Frame
Cylinder-Hydraulic,2.00x4.00x1.00
Valve Assembly-6 Spool
Hydraulic Install-Kit No H Frame
Cylinder-Hydraulic,1.50x8.38x0.88
Kit-Hydraulic Axle,Adjust,3430sf
Tank Assembly
Insert Assembly-Sq End
Hydraulic Group-60 Manual Fold
Cylinder-Hydraulic,R B 129450
Hydraulic Group-Hydraulic Fold
Valve-Relief,Assembly Boom
Cab Group
Brake Assembly-Pedal
Clutch Pedal Group-Sc
Pedal Assembly-Clutch
Control Group-Trans Shift
Linkage Assembly-Shift
Kit-Radio,Sc,Europe
Seat Group-Sc
Seat-Suspension
Cab Group-3000 Mt
Top Assembly-Cab
Cab Parts Group
Kit-Motor,Wiper
Ignition Switch Loader
Kit-Wiper Motor
Kit Hardware Wj3
Air Conditioner Group-Sc
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Heater-Kit
Electrical Group
Cab Electrical Group
Electrical Group-Sc
Light Assembly
Alternator-140 Amp
Gauge-Fuel,12v
Gauge-Oil Pressure
Gauge-Temperature,Water
Light-Flood,Med
Kit-Overspray
F A-Flood Light,Sc
Clutch Assembly
Appearance Group
Engine Cover Group-Wf Sc
Tire And Wheel Group
Tire Assembly-9x24 W 24 X W8,
Tire Assembly-12.4 24 W 24x10
Tire Assembly-12.4x24 W 24x10
Tire Assembly-7.5x24 W 24xw7,
Tire Assembly-9.5x32 W 32xw8,
Tire Assembly-9.5x32 W32xw8,
Decal Group
Final Assembly Group-Sc
Brake Group-Sc
Spray System-Group,Chassis
Strainer-Manifold
Valve Assembly R B 426406
Valve R B 056871
Strainer Assembly Less Screen 1.25
Manifold Assembly-Spray
Valve-Pressure,Control
Valve Assembly-Inlet
Filter-Strainer,Inline
Valve Ball, 1.50 Poly Ff
Pump-Spray
Valve Ball, 0.75 Poly Ff
Valve 3-Way, 1.50 Bottom Load
Valve Teejet
Spray System Group- H Frame
Valve Assembly-Kz, 5 Section,
Valve W O Power Head
Insert-Seat,Qc3
Nozzle Assembly-Single
Nozzle Assembly-Double
Filter Assembly-Boom
Valve Assembly-Boom Shut Off,
Valve Assembly-Kz, 3 Section,
Gauge-Flow
Spray System Assembly-3 Valve
Boom Group-60 In Man Fold
Boom Assembly-Rh,60 Ft Man Hydraulic
Boom Assembly-Lh,60 Ft Man Hydraulic
Spring, Assembly
Bag-Parts
Manifold Group-20 In ,Sc
Manifold Group-20, 80 Ft
Spray System Assembly-5 Valve
Spray Install-Ctr Manifold
Spray System Group
Spray Install-Loose Parts Kit
Valve-Control, 1.00npt 2.00sp Flg
Valve 5-Section, Boom Shut Off
Valve Assembly-2.00sp Flg X O-Ring
Valve Assembly-Kz,5 Section,
Nozzle Assembly-Drop
Boom Group
Boom Lift Group
Rear H Frame Group
Boom Group-60 Ft Hydraulic Fold
Boom Assembly-Rh,60 Ft Hydraulic
Boom Assembly-Rh
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Assembly-Lh,60 Ft Hydraulic
Boom Assembly-Lh
Tilt Rack Assembly
Tube Assembly-Rack Tilt
Boom Group-80 Ft Hydraulic Fold
Boom Assembly-Rh,80 Ft Hydraulic
Boom Assembly-Lh,80 Ft Hydraulic
Kit-Loose Parts,Boom Hinge
Controller Group
Controller Raven Package
Kg-3600wf Raven Mount
Option-Fieldstar,Wf,3 Valve
Option-Gps Receiver,5hz,Sc
Install-Fieldstar, Ctrlt, S C
Option-Fieldstar,Wf,5 Valve
Option-Fieldstar,Wf,3 Valve,W 0
Option-Fieldstar,Wf,5 Valve,W O
Option-Lightbar,Spra-Coupe
Kit-Gps Antenna Mount,Sc
Foam Marker Group
F A-Marker,Rsc 2130
Rsc Foamhead Valve Assembly
Deflector-Collector, 2 In
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In
Filter Assembly, Incline
Filter Assembly-Carbon
Compressor-Foam Marker
Module, Control
Options Group
Fresh Water Group-Sc
F A-Belly Pan,Wf
Recommended Dealer Stock
