Spra-Coupe Sprayer 3450 Parts Catalog WR128712
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 3450 Sprayer
Part Number: WR128712
Number of Pages: 1347 Pages
Publication Information
Engine Group
Arm Assembly-Pulley
Install Throttle
Throttle Assembly-Hand
Engine Support Group
Exhaust Group
Cooling Group
Air Cleaner Group
Filter-Air
Engine Group-3000 Mt
Motor-Starter
Engine-Perkins 108 Hp
Cylinder Block And Liners
Crank, Main And Big End Bearings
Pistons And Rings
Connecting Rods
Rear End Oil Seal
Cylinder Head Assembly
Rocker Shaft Assembly
Fuel Injection Pump
High Pressure Fuel Pipes
Atomizers
Throttle And Stop Controls
Pick-Up Sensors
Fuel Leak-Off Pipe
Boost Control Pipe
Fan Drive
Sump
Dipstick And Filler Tube
Oil Strainer
Cylinder Head Cover
Breather
Filler
Oil Filter
Blanking Plates
Front End Drive Input
Pipes
Water Outlet Housing
Fan
Timing Case
Timing Cover
Blanking Plug
Oil Pump And Delivery Housing
Turbocharger
Feed Pipes
Leak-Off Pipes
Pipework And Connections
Exhaust Manifold
Induction Manifold
Pipework And Connecitons
Lift Pump
Filter To Injection Pump Pipe
Injection Pump To Filter Pipe
Heater Plugs
Engine Mounts
Lube Oil Pressure Switch-Gauge
Temperature Gauge And Sender
Miscellaneous And Auxiliaries
Top Service Kit
Bottom Service Kit
Package-Parts,Ford
Engine Lifting Eyes
Driveline Group
Front Suspension Install-Sf
Hub Assembly
Chaincase Install-3400
Chaincase Assembly-3400,Lh
Hub Assembly-Wheel
Chaincase Assembly-3400,Rh
Wf,80 In
Tie Rod Assembly-3440-80
Steering Column
Install, Brake
Brake Tolomatic
Cylinder-Master,Brake
Brake Assembly-Pedal
Bellcrank Assembly
3000 Mt
Transmission Assembly
Shaft-Drive,T-5
Differential Assembly
Driveshaft Install-3000,80 In
Shaft Drive 80-101
Shaft-Drive,72 In
Shaft, Drive 80-108
Shaft-Drive 72in
Frame And Suspension Group
Frame-Adjust Rear 72 Inch
Frame-Adjust Rear 44xx Series 80 Inch
3xxx Series 72 Inch
3xxx Series 80 Inch
Channel Assembly 80 Inch
Frame Assembly
Channel Assembly 72 Inch
Frame Assembly 80 Inch Wide Front
Footboard Install-3450
Belly Pan Install-Wf
Belly Pan Install-Sf
F A-Front Extension,Sc
Hitch-Install
Axle And Steering Group
Extension Install-Front
Option-Wide Front,Sc
Wide Front Group-72 In ,Sc
Steering Group-Sf
Steering Group-Wf,72 In
Tie Rod Assembly-3440-72
Steering Assembly-Arm
Fuel System Group
Fuel Group
Hydraulic Group
Tube Assembly
Drive Shaft Install-3000,80
Hydraulic Install-Kit No H Frame
Valve Assembly-6 Spool
Valve-Check,Cv08200n25
H Frame
Cylinder-Hydraulic,2.00x4.00
Cylinder-Hydraulic,
Hydraulic Install-72 Axle Adjust,3000
Cylinder-Hydraulic,2.00x15.25x1.00
Cylinder-Hydraulic,2.00x14.25x1.00
Hydraulic Install-80 Axle Adjust, 3000
Cylinder-Hydraulic,2.00x20.00x1.00
Hydraulic Install-3000 Chassis
Valve Assembly-Control
Tank Assembly-Hydraulic
Cylinder-Hydraulic 1.75x16.84x1.00
Pump Hydraulic R B 531603d1
Elbow 90d 0.50mo-R X 0.50mjic
Valve-Float,2 Position
Grip Assembly-Handle
Hydraulic Install-Sf Steering
Cylinder-Hydraulic,1.75x5.00x1.00
Hydraulic Install-Wf Steering
Cylinder-Hydraulic,1.75x6.19x1.00
Hydraulic Install-H Frame
Valve-Relief Assembly Boom
Hydraulic Install-Boom Fold
Cylinder-Hydraulic,1.50x8.38x1.00
Cylinder-Hydraulic,1.50x8.38x0.88 R B 527610d1
Pump-Gear,Hydraulic,16cc R B 531604d1
Pump-Gear,19cc,P5t
Adapter Assembly,-6mor X -6stor
Kit-Field,Gear Pump,19cc,P5t
Tank Assembly
Insert Assembly-Sq End
Cab Group
Shift Install-Mt
Cab Install-3000 Mt
Top Assembly-Cab
Kit-Radio,Sc,Europe
Seat Install
Seat-Suspension
Kit-Radio,Sc
Ignition Switch Loader
Kit-Motor,Wiper
Clutch Pedal Install
Heater-Kit
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Electrical Group
Electrical Install-3 Valve
Electrical Install-5 Valve
Battery Install
Electrical Install-Chassis
Light Assembly
Alternator,140 Amp-2 Groove
Electrical Install-Cab
Lamp-Warning,Amber
Light Assembly-Dome,W Sw
Gauge-Fuel,12v
Gauge-Oil Pressure
Gauge-Temperature,Water
Light-Flood,Med
Kit-Overspray
F A-Floodlight Kit
Clutch Assembly
Appearance Group
Hood Install-Sf
Hood-Sf
Wf
Hood-Wf
Tire And Wheel Group
10.00 12.4
Tire Assembly-10.00-16sl W 18
Tire Assembly-12.4x24 W 24x10
Tire Assembly-12.4-24 W 24x10
7.50 12.4
Tire Assembly-7.5x24 W 24xw7,
9.00 12.4
Tire Assembly-9x24 W 24xw8,
9.00 230
Tire Assembly-9.5x32 W 32xw8
Tire Assembly-9.5x32 W32xw8
Decal Group
Decal Install-3450,80,Mt
Decal Install-3450,72,Mt
Decal Install-3450,80,Sf
Valve Assembly R B 426406
Valve R B 056871
Valve Teejet
Valve Assembly-Inlet
Filter-Strainer,Inline
Spray System-3000 Chassis
Strainer-Manifold
Strainer Assembly Less Screen 1.25
Valve 3-Way 1.50 Bottom Load
Pump-Spray
Spray Install-60 Ft Manifold
Filter Assembly-Boom
Nozzle Assembly-Single
Nozzle Assembly Double
Spray System Install-H Frame
3 Section Valve-Boom Shut Off
Valve Assembly-2.00sp Flg X O Ring
Valve-Control,1.00npt 2.00sp Flg
Valve Assembly-Boom Shut Off,
Valve Assembly-Kz, 3 Section,
Valve W O Power Head
Insert-Seat,Qc3
Spray Install-Ctr Manifold
Spray Install-80 Ft Manifold
5 Section Valve-Boom Shut Off
Valve Assembly-Kz, 5 Section
Spray Install-Loose Parts Kit
Nozzle Assembly-Double
Valve-Pressure,Control
Gauge-Flow
Boom Group
Tilt Rack Assembly
Tube Assembly-Rack Tilt
Boom Group-Lh,80 Ft
Link Assembly-Wing Fold,Outer
Link Assembly-Wing Fold,Inner
Boom Group-Rh,80 Ft
Boom Group-Lh,60 Ft
Boom Lift Group
Rear H Frame Group
Spring, Assembly
Boom Group-Rh,60 Ft
Bag-Parts
Kit-Loose Parts,Boom Hinge
Controller Group
Controller Raven Package
Install-Control,Raven
Package-Raven Mount,3400 Wf
Package-Mount,3400 Sf
Foam Marker Group
F A-Marker,Rsc 2130
Deflector-Collector, 2 In
Rsc Foamhead Valve Assembly
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In
Filter Assembly, Incline
Compressor-Foam Marker
Filter Assembly-Carbon
Control Module Assembly
Options Group
Fresh Water Install
Overspray Install
F A Crop Deflector,3400 4400
F A-Driveshaft Extension Kit
Recommended Dealer Stock
Brand: Spra-Coupe
Engine Group
Arm Assembly-Pulley
Install Throttle
Exhaust Group
Cooling Group
Air Cleaner Group
Filter-Air
Motor-Starter
Pistons And Rings
Connecting Rods
Rear End Oil Seal
Fuel Injection Pump
Atomizers
Pick-Up Sensors
Fuel Leak-Off Pipe
Boost Control Pipe
Fan Drive
Sump
Oil Strainer
Cylinder Head Cover
Breather
Filler
Oil Filter
Blanking Plates
Pipes
Fan
Timing Case
Timing Cover
Blanking Plug
Turbocharger
Feed Pipes
Leak-Off Pipes
Exhaust Manifold
Induction Manifold
Lift Pump
Heater Plugs
Engine Mounts
Top Service Kit
Bottom Service Kit
Package-Parts,Ford
Engine Lifting Eyes
Driveline Group
Hub Assembly
Hub Assembly-Wheel
Wf,80 In
Steering Column
Install, Brake
Brake Tolomatic
Bellcrank Assembly
3000 Mt
Shaft-Drive,T-5
Shaft Drive 80-101
Shaft-Drive,72 In
Shaft, Drive 80-108
Shaft-Drive 72in
3xxx Series 72 Inch
3xxx Series 80 Inch
Frame Assembly
Hitch-Install
Steering Group-Sf
Fuel System Group
Fuel Group
Hydraulic Group
Tube Assembly
H Frame
Cylinder-Hydraulic,
Pump-Gear,19cc,P5t
Tank Assembly
Cab Group
Shift Install-Mt
Cab Install-3000 Mt
Top Assembly-Cab
Kit-Radio,Sc,Europe
Seat Install
Seat-Suspension
Kit-Radio,Sc
Kit-Motor,Wiper
Heater-Kit
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Electrical Group
Battery Install
Light Assembly
Lamp-Warning,Amber
Gauge-Fuel,12v
Gauge-Oil Pressure
Light-Flood,Med
Kit-Overspray
F A-Floodlight Kit
Clutch Assembly
Appearance Group
Hood Install-Sf
Hood-Sf
Wf
Hood-Wf
10.00 12.4
7.50 12.4
9.00 12.4
9.00 230
Decal Group
Valve R B 056871
Valve Teejet
Strainer-Manifold
Pump-Spray
Insert-Seat,Qc3
Gauge-Flow
Boom Group
Tilt Rack Assembly
Boom Group-Lh,80 Ft
Boom Group-Rh,80 Ft
Boom Group-Lh,60 Ft
Boom Lift Group
Rear H Frame Group
Spring, Assembly
Boom Group-Rh,60 Ft
Bag-Parts
Controller Group
Foam Marker Group
F A-Marker,Rsc 2130
Options Group
Fresh Water Install
Overspray Install
- Spra Coupe EU 4460 4660 Sprayer Service Manual_79034247B
- Spra Coupe EU 4460 4660 Manual Transmission Operator Manual_519177D1D
- Spra Coupe SA 7000 Series SPRA-COUPE Service Manual_WR132165
- Spra Coupe EU 7460 7660 Sprayer System RTS_AG333725A
- Spra Coupe EU 7000 Series Sprayer Service Manual_79027326A
- Spra Coupe EU 7460 7660 Applicator Chassis Service Manual_79032953B
- Spra Coupe EU 4460 4660 Man Sprayer Repair Time Schedule_AG335277A
- Spra Coupe EU 4460 4660 Sprayer Automatic Transmission Operator Manual_519176D1D
- Spra Coupe EU 4455 4655 Sprayer Automatic Transmission Operator Manual_512150D1D
- Spra Coupe EU 4450 4650 4455 4655 Sprayer Service Manual_79027328B
- Spra Coupe SA 7000 Series Sprayer Service Manual_79027326
- Spra Coupe EU 7450 7650 Sprayer System Repair Time Schedule_AG331640A
- Spra Coupe EU 4460 4660 Auto Sprayer Repair Time Schedule_AG335025A
- Spra Coupe EU 7460 7660 Applicator Chassis RTS_AG333724A
- Spra Coupe SA 7450 7650 System Repair Time Schedule_AG331640A
