Spra-Coupe Sprayer 3440-72 Parts Catalog WR128528
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 3440-72 Sprayer
Part Number: WR128528
Number of Pages: 1509 Pages
Publication Information
Engine Group
Fuel Group-Perkins,Sc
Cooling Group-Sc
Filter Air Group-Sc
Air Filter Assembly
Throttle Group-Sc
Pedal Assembly-Throttle
Engine-Perkins
Short Engine
Cylinder Block Kit
Rear Oil Seal Assembly
Cylinder Head Kit
Rocker Shaft Assembly
Timing Gear And Camshaft Assembly
Oil Pump And Housing Assembly
Crankshaft Rod And Piston Assembly
Conrod Kit
Fuel Injection Equipment
Flywheel Housing Assembly
Fan Drive Assembly
Oil Sump Assembly
Oil Filter Assembly
Oil Breather Assembly
Valve Cover Breather Hose Assembly
Oil Filter And Cooler Assembly
Front End Drive Input
Cooling Assembly
Thermostat Housing Assembly
Water Outlet And Inlet
Fan And Extension Assembly
Alternator And Generator Install
Auxillary Drive Option
Turbocharger Assembly
Turbo Manifold And Cooler Assembly
Turbo Actuator Assembly
Remote Air Charge Cooler
Lift Pump
Fuel Filter Install
Low Pressure Fuel System
Fuel Filter Assembly
Cold Start System
Engine Lifting Plate Install
Mountings Front And Rear
Heater Starter Switch
Oil Pressure Switch And Gauge
Temp Gauge And Sender
Radiator And Cooling Fitting Assembly
Fuel Re-Lift Pump Install
Filter
Miscellaneous And Auxillaries
Top Joint And Gasket Kit
Arm Assembly-Pulley
Engine Group-Perkins
Housing Assembly-Flywheel
Flywheel Assembly
Motor-Starter
Driveline Group
Drive Train Group Perkins
Shaft-Drive,T-5
Transmission Assembly
Differential Assembly
Shaft-Drive 72 In
Shaft-Drive,72 In
Bellcrank Assembly
Cylinder-Master,Brake
Chaincase Group-Sc
Hub Assembly-Wheel
Driveshaft Install-3000, 72
Driveshaft Install-3000,80 In
Shaft Drive 80-101
Driveshaft-Telescoping
F A-Driveshaft Extension
Option-Belly Pan W F,Factory
Frame And Suspension Group
Frame Group-3440 Wf,Sc
Footboard Group-3640 Esp
Axle Group-Adjust
Frame Assembly 72 Inch Wide Front
Option-Single Front,Sc
F A-Front Extension,Sc
Hitch-Install
F A-Crop Deflector,Sc
Axle And Steering Group
Steering Group-Wf,72 In
Tie Rod Assembly-3440-72
Steering Column
Wide Front Group-72 In ,Sc
Steering Assembly-Arm
Hydraulic Group
Kit-Hydraulic Axle Adjust,70 In
Cylinder-Hydraulic,2.00x15.25x1.00
Cylinder-Hydraulic,2.00x14.25x1.00
Valve Assembly-Control
Valve-Check,Cv08200n25
Hydraulic Group-Hydraulic Fold
Cylinder-Hydraulic,2.00x4.00x1.00
Valve Assembly-6 Spool
Valve-Relief;Assembly Boom
Hydraulic Group-Chassis,
Grip Assembly-Handle
Tank Assembly-Hydraulic
Valve-Float,2 Position
Valve-Steering
Pump-Hydraulic
Cylinder-Hydraulic,1.75x6.19x1.00
Cylinder-Hydraulic,1.75x16.84x1.00
Hydraulic Install-Kit No H Frm
Cylinder-Hydraulic,1.50x8.38x0.88
Hydraulic Group-60 Manual Fold
Tank Assembly
Insert Assembly-Sq End
H Frame
Cab Group
Brake Assembly-Pedal
Clutch Pedal Group-Sc
Control Group-Trans Shift
Linkage Assembly-Shift
Kit-Radio,Sc,Europe
Seat Group-Sc
Install-Seat
Seat-Suspension
Cab Group-3000 Mt
Top Assembly-Cab
Kit-Motor,Wiper
Cab Parts Group
Ignition Switch Loader
Kit-Wiper Motor
Kit Hardware Wj3
Air Conditioning Group-Sc
Air Conditioner-Kit
Blower-Kit
Fan Assembly
Heater-Kit
Electrical Group
Cab Electrical Group
Electrical Group-Sc
Light Assembly
Alternator-140 Amp
Gauge-Fuel,12v
Gauge-Oil Pressure
Gauge-Temperature,Water
Light-Flood,Med
F A-Flood Light,Sc
Kit-Overspray
Clutch Assembly
Appearance Group
Engine Cover Group-Wf Sc
Tire And Wheel Group
Tire Assembly-9x24 W 24 X W8,
Tire Assembly-12.4 24 W 24x10
Tire Assembly-12.4x24 W 24x10
Tire Assembly-7.5x24 W 24xw7,
Tire Assembly-9.5x32 W 32xw8,
Tire Assembly-9.5x32 W32xw8,
Decal Group
Final Assembly Group-Sc
Brake Group-Sc
Spray System-Group,Chassis
Strainer-Manifold
Valve Assembly R B 426406
Valve R B 056871
Strainer Assembly, Less Screen, 1.25
Manifold Assembly-Spray
Valve-Pressure,Control
Valve Assembly-Inlet
Filter-Strainer,Inline
Valve Ball, 1.50 Poly Ff
Pump-Spray
Valve Ball, 0.75 Poly Ff
Valve Assembly-Boom Shut Off,
Valve Assembly-Kz, 5 Section,
Valve W O Power Head
Insert-Seat,Qc3
Spray System Assembly-3 Valve
Boom Group-60 In Manifold
Boom Assembly-Rh,60 Ft Man Hydraulic
Boom Assembly-Lh,60 Ft Man Hydraulic
Bag-Parts
Spring, Assembly
Manifold Group-20 In ,Sc
Nozzle Assembly-Single
Nozzle Assembly-Double
Filter Assembly-Boom
Manifold Group-20, 80 Ft
Spray System Assembly-5 Valve
Spray Install-Ctr Manifold
Spray System Group
Spray Install-Loose Parts Kit
Valve-Control, 1.00npt 2.00sp Flg
Valve 5-Section-Boom Shut Off
Valve Assembly, 2.00sp Flg X O-Ring
Valve Assembly-Kz,5 Section,
Nozzle Assembly-Drop
Valve Teejet
Spray System Group-H Frame
Valve Assembly-Kz, 3 Section,
Gauge-Flow
Boom Group
Boom Lift Group
Boom Group-60 Ft Hydraulic Fold
Boom Assembly-Rh,60 Ft Hydraulic
Boom Assembly-Rh
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Assembly-Lh,60 Ft Hydraulic
Boom Assembly-Lh
Tilt Rack Assembly
Tube Assembly-Rack Tilt
Boom Group-80 Ft Hydraulic Fold
Boom Assembly-Rh,80 Ft Hydraulic
Boom Assembly-Lh,80 Ft Hydraulic
Rear H Frame Group
Kit-Loose Parts,Boom Hinge
Controller Group
Option-Gps Receiver,5hz,Sc
Option-Lightbar,Spra-Coupe
Install-Fieldstar, Ctrlt, S C
Controller Raven Package
Package-Raven Mount,3400 Wf
Kit-Gps Antenna Mount,Sc
Option-Fieldstar,Wf,3 Valve
Option-Fieldstar,Wf,5 Valve
Option-Fieldstar,Wf,3 Valve,W 0
Option-Fieldstar,Wf,5 Valve,W O
Foam Marker Group
Filter Assembly, Incline
F A-Marker,Rsc 2130
Rsc Foamhead Valve Assembly
Deflector-Collector, 2 In
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In
Filter Assembly-Carbon
Compressor-Foam Marker
Module, Control
Options Group
Fresh Water Group-Sc
F A-Belly Pan,Wf
Recommended Dealer Stock
