Spra-Coupe Sprayer 3440-72 Parts Catalog WR128520
Brand: Spra-Coupe
Type of Machine: Sprayer
Model: Spra-Coupe 3440-72 Sprayer
Part Number: WR128520
Number of Pages: 1453 Pages
Publication Information
Engine Group
Engine-Perkins
Short Engine
Cylinder Block Kit
Rear Oil Seal Assembly
Cylinder Head Kit
Rocker Shaft Assembly
Timing Gear And Camshaft Assembly
Oil Pump And Housing Assembly
Crankshaft Rod And Piston Assembly
Conrod Kit
Fuel Injection Equipment
Flywheel Housing Assembly
Fan Drive Assembly
Oil Sump Assembly
Oil Filter Assembly
Oil Breather Assembly
Valve Cover Breather Hose Assembly
Oil Filter And Cooler Assembly
Front End Drive Input
Cooling Assembly
Thermostat Housing Assembly
Water Outlet And Inlet
Fan And Extension Assembly
Alternator And Generator Install
Auxillary Drive Option
Turbocharger Assembly
Turbo Manifold And Cooler Assembly
Turbo Actuator Assembly
Remote Air Charge Cooler
Lift Pump
Fuel Filter Install
Low Pressure Fuel System
Fuel Filter Assembly
Cold Start System
Engine Lifting Plate Install
Mountings Front And Rear
Heater Starter Switch
Oil Pressure Switch And Gauge
Temp Gauge And Sender
Radiator And Cooling Fitting Assembly
Fuel Re-Lift Pump Install
Filter
Miscellaneous And Auxillaries
Top Joint And Gasket Kit
Eng Support Group-Perkins
Arm Assembly-Pulley
Engine Group-Perkins
Housing Assembly-Flywheel
Package-Parts,Ford
Flywheel Assembly
Motor-Starter
Throttle Group-Sc
Pedal Assembly-Throttle
Cooling Group-Sc
Filter Air Group-Sc
Air Filter Assembly
Exhaust Group-Perkins,Sc
Fuel Group-Perkins,Sc
Driveline Group
Cylinder-Master,Brake
Bellcrank Assembly
Drive Train Group-Perkins
Shaft-Drive 72 In
Shaft-Drive,T-5
Transmission Assembly
Differential Assembly
Shaft-Drive,72 In
Chaincase Group-Sc
Hub Assembly-Wheel
Shaft Drive 80-101
Driveshaft-Telescoping
Frame And Suspension Group
Frame Group-3440 Wf,Sc
Frame Assembly 72 Inch Wide Front
Channel Assembly 72 Inch
Axle Group-Adjust
Footboard Group-3640 Esp
F A-Front Extension,Sc
Hitch-Install
F A-Crop Deflector,Sc
Axle And Steering Group
Wide Front Group-72 In ,Sc
Steering Group-Wf,72 In
Tie Rod Assembly-3440-72
Steering Column
Steering Assembly-Arm
Hydraulic Group
Hydraulic Group-Hydraulic Fold
Cylinder-Hydraulic,2.00x4.00x1.00
Valve Assembly-6 Spool
Valve-Check,Cv08200n25
Valve-Relief;Assembly Boom
Hydraulic Group-Chassis,
Grip Assembly-Handle
Tank Assembly-Hydraulic
Cylinder-Hydraulic,1.75x6.19x1.00
Cylinder-Hydraulic,1.75x16.84x1.00
Valve-Float,2 Position
Valve-Steering
Pump-Hydraulic
Kit-Hydraulic Axle Adjust,70 In
Valve Assembly-Control
Cylinder-Hydraulic,2.00x15.25x1.00
Cylinder-Hydraulic,2.00x14.25x1.00
Hydraulic Group-60 Manual Fold
Cylinder-Hydraulic,1.50x8.38x0.88
Tank Assembly
Cab Group
Brake Assembly-Pedal
Control Group-Trans Shift
Linkage Assembly-Shift
Clutch Pedal Group-Sc
Pedal Assembly-Clutch
Kit-Radio,Sc,Europe
Seat Group-Sc
Seat-Suspension
Install-Seat
Cab Group-3000 Mt
Install-Cab
Top Assembly-Cab
Kit-Motor,Wiper
Cab Parts Group
Ignition Switch Loader
Kit-Wiper Motor
Kit Hardware Wj3
Blower-Kit
Fan Assembly
Air Conditioner-Kit
Heater-Kit
Air Conditioner Group
Electrical Group
Electrical Group-Sc
Alternator-140 Amp
Gauge-Fuel,12v
Gauge-Oil Pressure
Gauge-Temperature,Water
Cab Electrical Group
Light-Flood,Med
Kit-Overspray
F A-Flood Light,Sc
Clutch Assembly
Appearance Group
Engine Cover Group-Wf Sc
Install-Cover,Engine,W-F
Tire And Wheel Group
Tire Assembly-12.4x24 W 24x10
Tire Assembly-7.5x24 W 24xw7,
Tire Assembly-9.5x32 W 32xw8,
Tire Assembly-9.5x32 W32xw8,
Tire Assembly-9x24 W 24 X W8,
Tire Assembly-12.4 24 W 24x10
Decal Group
Final Assembly Group-Sc
Brake Group-Sc
Manifold Group-20, 80 Ft
Filter Assembly-Boom
Nozzle Assembly-Single
Nozzle Assembly-Double
Spray System Assembly-5 Valve
Valve-Pressure,Control
Spray System Assembly-3 Valve
Boom Assembly-Rh,60 Ft Man
Boom Assembly-Rh,60ft Man Hydraulic
Boom Assembly-Lh,60ft Man Hydraulic
Boom Assembly-Lh,60 Ft Man
Valve Assembly-Boom Shut Off,
Valve Assembly-Kz, 5 Section,
Valve W O Power Head
Insert-Seat,Qc3
Valve Assembly-Kz, 3 Section
Spray System-Group,Chassis
Strainer-Manifold
Valve Assembly R B 426406
Valve R B 056871
Strainer Assembly Less Screen 1.25
Valve Assembly-Inlet
Valve Ball, 1.50 Poly Ff
Filter-Strainer, Inline
Pump-Spray
Manifold Assembly-Spray
Valve Ball, 0.75 Poly Ff
Valve 3-Way, 1.50 Bottom Load
Valve Teejet
Manifold Group-20 In ,Sc
Spray Install-Ctr Manifold
Spray System Group
Spray Install-Loose Parts Kit
Valve-Control, 1.00npt 2.00sp Flg
Valve 5-Section, Boom Shut Off
Valve Assembly-2.00sp Flg X O-Ring
Gauge-Flow
Valve Assembly-Kz,5 Section,
Nozzle Assembly-Drop
Boom Group
Boom Group-60 Ft Hydraulic Fold
Boom Assembly-Rh,60 Ft Hydraulic
Boom Assembly-Rh
Link Assembly-Wing Fold,Inner
Link Assembly-Wing Fold,Outer
Boom Assembly-Lh,60 Ft Hydraulic
Boom Assembly-Lh
Bag-Parts
Rear H Frame Group
Boom Assembly-Rh,80 Ft Hydraulic
Boom Assembly-Lh,80 Ft Hydraulic
Boom Lift Group
Tilt Rack Assembly
Tube Assembly-Rack Tilt
Kit-Loose Parts,Boom Hinge
Controller Group
Option-Fieldstar,Wf,3 Valve
Option-Gps Receiver,5hz,Sc
Install-Fieldstar, Ctrlt, S C
Option-Fieldstar,Wf,5 Valve
Option-Fieldstar,Wf,3 Valve,W 0
Option-Fieldstar,Wf,5 Valve,W O
Controller Raven Package
Package-Raven Mount,3400 Wf
Option-Lightbar,Spra-Coupe
Kit-Gps Antenna Mount,Sc
Foam Marker Group
F A-Marker,Rsc 2130
Rsc Foamhead Valve Assembly
Deflector-Collector, 2 In
Tank Assembly,13 Gal Rsc2130
Cap-Assembly, 2 1 4 In
Filter Assembly, Incline
Filter Assembly-Carbon
Compressor-Foam Marker
Module, Control
Options Group
Fresh Water Group-Sc
F A-Belly Pan,Wf
Recommended Dealer Stock
