Spra-Coupe Sprayer 220 230 Parts Catalog 6720588
Brand: Spra-Coupe
Type of Machine: Sprayer
Model:
Spra-Coupe 220 Sprayer
Spra-Coupe 230 Sprayer
Part Number: 6720588
Number of Pages: 413 Pages
Publication Information
Chassis & Boom - Main Frame
Chassis & Boom - Panel, Nosecone
Chassis & Boom - Cab
Chassis & Boom - Engine Covers
Chassis & Boom - Windows, Cab
Chassis & Boom - Step And Footboard - Model 220
Chassis & Boom - Step And Footboard - Model 230
Chassis & Boom - Blower
Chassis & Boom - Seat Suspension
Chassis & Boom - Seat Suspension - Lower
Chassis & Boom - Seat Assembly (Standard), Suspension Seat
Chassis & Boom - Boom-50 Foot - 1 1 2 Tube, (S N 209211156 &
Chassis & Boom - Boom - 60 Foot- 1-3 4 Tube, (S N 209211157
Chassis & Boom - Catch - Boom Outer - 60 Foot Boom, 1-3 4
Chassis & Boom - Boom Support - With Electric Booms
Chassis & Boom - Main Frame Boom - With Electric Booms
Chassis & Boom - Boom Support - With Hydraulic Booms
Chassis & Boom - Main Frame Boom - With Hydraulic Booms
Chassis & Boom - Actuators - Boom Control - Saginaw 8 ,
Chassis & Boom - Actuators - Boom Fold - Burr 8 Stroke,
Chassis & Boom - Decals - Model 220 - Location
Chassis & Boom - Decals - Model 230 - Location
Drive Train - Tires And Rims
Drive Train - Steering Manual
Drive Train - Front Suspension - Single Wheel
Drive Train - Axle Front - Single Wheel
Drive Train - Wide Front Wheels, Model 220, 220-72 & 220-78
Drive Train - Wide Front Wheels - Model 230
Drive Train - Final Drive - Model 220
Drive Train - Final Drive - Model 230
Drive Train - Axle - Adjustable
Drive Train - Brake Assembly - Model 220
Drive Train - Model 220 - Brake Assembly
Drive Train - Brake Assembly - Ausco - Model 220
Drive Train - Brake Assembly - Model 230
Drive Train - Pedal - Brake, Clutch Assembly-Model 220
Drive Train - Pedal-Brake, Clutch Assembly-Model 230
Drive Train - Emergency Brake
Drive Train - Gear Shift 4 Speed
Drive Train - Shift Cable Assembly
Drive Train - Shift Cable Assembly (Cont'd)
Drive Train - Hand Throttle
Hydraulic System - Power Steering System - Model 220, S N
Hydraulic System - Power Steering System - Model 230, S N
Hydraulic System - Valve, Fittings, Tubelines - Model 230,
Hydraulic System - Cylinders, Tubes, Hoses & Tubelines, Model
Hydraulic System - Cylinders, Tubes, Hoses & Tubelines, Model 230 S N 209011101 & Above
Hydraulic System - Tank, Valve, Tubes & Hoses - Model 220, S N 208912515 & Abv. - 209211061 & Abv.
Hydraulic System - Cylinders, Tubes, Hoses & Tubelines, Model 220 S N 208912515 & Abv. 209211061
Hydraulic System - Pump - Power Steering
Hydraulic System - Cylinder - Boom Lift
Hydraulic System - Cylinder - Power Steering
Hydraulic System - Cylinder - Boom Fold, S N 209211195 & Bel.
Hydraulic System - Cylinder - Boom Cushion Fold, S N
Hydraulic System - Cylinder - Boom Tip Lift
Hydraulic System - Pump - Hydraulic
Hydraulic System - Valve Control Hydraulic - S N Below, S N
Hydraulic System - Port Section - Valve - S N Below, S N 208913335 & Bel. - S N 209211201 &, Bel. - S N 209011865 & Bel.
Hydraulic System - Section - Valve, S N 208913335 & Bel., S N
Hydraulic System - Valve - Control - S N Above, S N 208913336
Hydraulic System - Port Section - Valve - S N Above, S N 208913336 & Abv.- S N 209211202 &, Abv. - S N 209011866 & Abv.
Hydraulic System - Section - Valve - S N Above, S N 208913336
Hydraulic System - Control Unit Steering - S N Below
Hydraulic System - Control Unit Steering - S N Above
Hydraulic System - Valve - Tow, (Model 220 - All, Model 230 -
Hydraulic System - Valve 2 Position Float, Model 230 - S N
Hydraulic System - Valve 2 Position Float - Model 230, S N
Spray System - Tank (Model 220 S N 6537 & Below)
Spray System - Tank - Model 220 & 230, Model 220 S N
Spray System - Filter, Fittings & Pump - Model 220, Model 220
Spray System - Filter, Fittings & Pump- Model 220 & 230,
Spray System - Gauges, Valves & Fittings - Model 220, (S N &
Spray System - Gauges, Valves & Fittings - Model 230
Spray System - Manifold - 20 Spacing - 50 Foot Boom, Melroe
Spray System - Manifold-20 & 30 Spacing-50 Foot Boom, Model
Spray System - Manifold - 20 Spacing - 50 Foot Boom, Model
Spray System - Manifold - 20 Spacing - 50 F00t Boom, Model
Spray System - Manifold - 20 Spacing - 60 Foot Boom -, Model
Spray System - Manifold-20 Spacing-60 Foot Boom, Model 220,
Spray System - Filter - Manifold Boom - Model 220, Model 220
Spray System - Manifold - 20 Spacing - 60 Foot Boom, Model 230, S N 209011661 & Above
Spray System - Valve - Solenoid - Model 220, Model 220 S N
Spray System - Pump - Hypro
Spray System - Clutch - Electric - Model 220, Model 220 S N
Spray System - Clutch - Electric Heavy Duty - Model 220, Model 220 & 230 Model 220 S N 208911001, & Above & 230
Spray System - Ball Valves - Boom Selector
Spray System - Valves - Selector Ball - Boom
Spray System - Valve - Pressure Control
Spray System - Nozzle - Quick Jet - W 80 Deg. Tip, Model 220
Spray System - Nozzle - Quick Jet - W 80 Deg. Tip, Model 230 (S N & Below) Model 230 - S N, 209011660 & Below
Spray System - Nozzle - Melroe - With 73 Deg. Tip
Spray System - Nozzle - Quick Jet - With 73 Deg. Tip
Power Unit - Engine - Motor Mounts
Power Unit - Clutch, Pressure Plate & Transmission
Power Unit - Belts, Pulleys
Power Unit - Tank - Fuel
Power Unit - Radiator, Battery & Engine Harness
Power Unit - Carburetor, Manifold Intake - Exhaust &, Starter
Power Unit - Water Outlet, Switches & Filter Oil
Power Unit - Engine, Timing Belt
Power Unit - Cylinder Head - Oil Pan - Engine
Power Unit - Distributor - Engine
Power Unit - Solid Lifters, Camshaft & Valves
Power Unit - Hydraulic Lifters, Camshaft & Valves
Power Unit - Pistons, Rings & Crankshaft
Power Unit - Oil Pump
Power Unit - Gasket Sets, Engine
Power Unit - Alternator - Delco, Models 220 & 230, S N 5956
Power Unit - Alternator - Motorola, 220 - S N 5957-6537 & S N
Power Unit - Alternator - Prestolite
Power Unit - Alternator Denso 140 Amp Kit
Power Unit - Governor
Power Unit - Air Cleaner Assembly
Power Unit - Muffler, Pipe Exhaust
Power Unit - Transmission Case
Power Unit - Gears, Bearings & Shafts
Power Unit - Pinion, Gearset
Electrical - Gauges, Switches & Harness
Electrical - Electrical Diagram-Model 220 Spra-Coupes, S N
Electrical - Electrical Diagram-Model 220 Spra-Coupes, S N 5555 & Below (Cont'd)
Electrical - Electrical Diagram-Model 220 Spra-Coupes, S N 5556-6537
Electrical - Electrical Diagram-Model 220 Spra-Coupes, S N 5556-6537 (Cont'd)
Electrical - Electrical Diagram-Model 220 Spra-Coupes, S N 5556-6357 (Cont'd)
Electrical - Electrical Diagram, Model 220 Spra-Coupes W Electric Booms, S N 208911001 & Above
Electrical - Electrical Diagram-Model 230 Spra-Coupes, With Electric Booms
Electrical - Electrical Diagram (Cont'd) Model 230, Spra-Coupes With Hydraulic Booms
Electrical - Electrical Diagram (Cont'd) Model 230, Spra-Coupes With Electric Booms
Electrical - Electrical Diagram - Model 220, 230, Spra-Coupes With Hydraulic Booms
Electrical - Electrical Diagram (Cont'd), Model 220, 230 Spra-Coupes W Hydraulic, Booms
Accessories - Air Conditioner-R12 Refrigerant, S N 209211274,208913811 & 209012021 &, Below
Accessories - Air Conditioner - R134a Refrigerant, S N
Accessories - Auxiliary Boom
Accessories - Belly Pan - Front - Model 230
Accessories - Belly Pan - Rear - Model 230
Accessories - Boom Raising
Accessories - Boom Support Cable
Accessories - Boom Tip Lift - Electric
Accessories - Crop Deflectors, 220 With Single Front Wheel -
Accessories - Crop Deflectors-Front, Rear - Model 230
Accessories - Drop Nozzle - Boom
Accessories - Filler Hose Attachment, Model 220 S N 6537 & Below
Accessories - Flood Light
Accessories - Handsprayer Attachment
Accessories - Heater Kit
Accessories - Hitch Tow - Single Front - 220
Accessories - Hitch - Tow - 220, Wide Front Wheels, Model 220
Accessories - Hitch - Tow - Wide Front - 220, 230, Model S N
Accessories - Insulated Panels - Cab
Accessories - Overspray Nozzle
Accessories - Foam Marker - Model Sc515
Accessories - Compressor - Model Sc515, Sc520 & Sc525
Accessories - Valve - Type 144 - Model Sc515, Sc520 &, Sc525
Accessories - Valve - Type 144f - Model Sc525
Accessories - Foam Marker - Model Sc520
Accessories - Foam Marker - Model Sc525
Accessories - Shift Cable Kit - Model 220, 230
Accessories - Shift Cable Kit - Model 220 & 230
Accessories - Spra-Controller - Melroe
Accessories - Speed Sensor - Melroe
Accessories - Spray Monitor - Field Technologies
Accessories - Automatic Rate Controller - Automatic, Field
Accessories - Speed Sensor - Wide Front, Field Technologies
Accessories - Test Simulator - Field Technologies
Bulk Items
