Spra-Coupe Sprayer 215 216 Parts Catalog 6720586
Brand: Spra-Coupe
Type of Machine: Sprayer
Model:
Spra-Coupe 215 Sprayer
Spra-Coupe 216 Sprayer
Part Number: 6720586
Number of Pages: 275 Pages
Publication Information
Chassis & Boom - Main Frame
Chassis & Boom - Panel - Nosecone
Chassis & Boom - Cab
Chassis & Boom - Engine Covers
Chassis & Boom - Windows - Cab
Chassis & Boom - Step And Footboard
Chassis & Boom - Blower
Chassis & Boom - Seat - Suspension
Chassis & Boom - Seat Suspension - Lower
Chassis & Boom - Seat Assembly, Standard And Optional
Chassis & Boom - Boom - 50 Foot - Model 215
Chassis & Boom - Boom - 50 Foot - Model 216
Chassis & Boom - Boom Support - Electric Boom - Model 216
Chassis & Boom - Main Frame - Electric Boom - Model 216
Chassis & Boom - Actuators - Boom - Saginaw 8 & 12 -216,
Chassis & Boom - Actuator - 8 - Boom Fold - Model Burr
Chassis & Boom - Decals Location - Model 215
Chassis & Boom - Decals - Model 215
Chassis & Boom - Decals Location - Model 216
Chassis & Boom - Decals - Model 216
Drive Train - Tires And Rims
Drive Train - Steering Manual
Drive Train - Power Steering - Model 216
Drive Train - Pump - Power Steering - Model 216
Drive Train - Cylinder - Power Steering - Model 216
Drive Train - Control Unit - Steering - Model 216
Drive Train - Tow Valve - Model 216
Drive Train - Front Suspension - Single Wheel
Drive Train - Axle Front - Single Wheel
Drive Train - Wide Front Wheels
Drive Train - Final Drive
Drive Train - Axle Adjustable
Drive Train - Brake Assembly - S N & Down
Drive Train - Brake Assembly - S N & Up
Drive Train - Brake - Emergency
Drive Train - Pedal - Brake, Clutch Cable
Drive Train - Gear Shift - 4 Speed
Drive Train - Hand Throttle
Spray System - Tank - 215, 216, 215, 216, S N 6537 & Down,
Spray System - Tank - Model 216, S N 298811048 And Up
Spray System - Filter, Fittings & Pump, 215, 216 S N 6537 And
Spray System - Filter, Fittings & Pump - Model 216, S N
Spray System - Gauge, Valve & Fittings - 215 & 216, Model 215
Spray System - Gauge, Control Valve & Fittings - 216
Spray System - Manifold - 20 Spacing - 50 Foot Boom, Melroe
Spray System - Manifold-20 & 30 Spacing-50 Foot Boom, 216,
Spray System - Manifold - 20 Spacing - 50 Foot Boom, S N
Spray System - Pump - Hypro
Spray System - Clutch - Electric
Spray System - Clutch - Electric Heavy Duty, S N 208811048 &
Spray System - Selector - Spray
Spray System - Valve Ball - Boom Selector
Spray System - Valves - Selector Ball - Boom
Spray System - Valve - Pressure Control
Spray System - Nozzle - Melroe - With 73 Deg. Tip
Spray System - Nozzle - Quick Jet - With 73 Deg. Tip
Spray System - Nozzle - Quickjet - With 80 Deg. Tip
Power Unit - Engine - Motor Mounts
Power Unit - Clutch, Pressure Plate & Transmission
Power Unit - Belts, Pulleys
Power Unit - Radiator, Battery & Engine Harness
Power Unit - Carburetor, Manifold Intake, Exhaust & Starter
Power Unit - Water Outlet, Switches & Filter, Oil
Power Unit - Engine - Timing Belt
Power Unit - Cylinder Head - Oil Pan - Engine
Power Unit - Hydraulic Lifters - Camshaft & Valves
Power Unit - Solid Lifters - Camshaft & Valves
Power Unit - Piston, Rings & Crankshaft
Power Unit - Oil Pump
Power Unit - Gasket Sets - Engine
Power Unit - Distributor
Power Unit - Alternator - Delco - 215 & 216, 5956 & Down
Power Unit - Alternator - Motorola, S N 5957 Thru 6537, 216
Power Unit - Alternator - Prestolite
Power Unit - Governor
Power Unit - Air Cleaner Assembly
Power Unit - Muffler, Pipe Exhaust
Power Unit - Transmission Case
Power Unit - Gears, Bearings & Shafts
Power Unit - Pinion Gearset
Power Unit - Tank - Fuel
Electrical - Gauges, Switches & Harness
Electrical - Electrical Diagram - Model 215, (Model 215
Electrical - Electrical Diagram - Model 215, (Model 215 Continued)
Electrical - Electrical Diagram - Model 216, S N 5556 Thru 6537, (Model 216 Continued)
Electrical - Electrical Diagram - Model 216, With, Electric Booms (S N 208811001 & Up), (Model 216, W Electric Booms Continued)
Accessories - Air Conditioner - R12, Refrigerant
Accessories - Boom Fold - Electric - Model 216
Accessories - Boom Tip Lift - Electric
Accessories - Drop Nozzle - Boom
Accessories - Filler Hose Attachment - 215 & 216, Model 215, 216 S N 6535 And Down, Model 216, S N 20881101 Thru 208811047
Accessories - Floodlight
Accessories - Foam Marker - Model Sc515
Accessories - Compressor - Model Sc515, Sc520 & Sc525
Accessories - Valve - Type 144, Model Sc515, Sc520 & Sc525
Accessories - Valve - Type 144f - Model Sc525
Accessories - Foam Marker Cables - Model Sc520
Accessories - Foam Marker Tank - Model Sc520
Accessories - Foam Marker Box - Model Sc525
Accessories - Foam Marker Controls - Model Sc525
Accessories - Foam Marker Tank - Model Sc525
Accessories - Handsprayer Attachment
Accessories - Heater Kit
Accessories - Hitch Tow - Single Front
Accessories - Hitch - Tow - Wide Front - S N Down
Accessories - Insulated Panels - Cab
Accessories - Overspray Nozzle
Accessories - Shift Cable Kit - Model 216
Accessories - Spra - Controller - Melroe
Accessories - Speed Sensor Adapter - Melroe
Accessories - Spray Monitor - Field Technologies
Accessories - Speed Sensor - Wide Front, Field Technologies
Accessories - Test Simulator - Field Technologies
Accessories - Rate Controller - Automatic - Field, Technologies
Miscellaneous - Bulk Items
