Momed80
151
35,046
Snorkel Scissor Lift 90.23 MB PDF Parts Service Manual
Brand: Snorkel
Type of Machine: Scissor Lift
Type of Manual: Parts Manual, Service Manual
List of Files:
Snorkel Articulated Boom Lift A38E Parts Service Manual.pdf (132 Pages)
Snorkel Scissor Lift M1230E Parts Service Manual.pdf (96 Pages)
Snorkel Scissor Lift S1930E S1932E S2632E Operators Manual.pdf (26 Pages)
Snorkel Scissor Lift S3370BE S2770BE S3370RT S2770RT Parts Service Manual.pdf (134 Pages)
Table of Contents
General Specifications
General Specifications SR3370 3
General Specifications SR2770 4
Engine Data 5
Engine Oil Charts 5
Maintenance Information
About this Manual: 7
Manual Organization 7
Maintenance and Schematics 7
Maintenance schedules 8
Daily Maintenance 9
90 Day or 150 Hour Maintenance(Trained Service Technician) 10
Yearly or 500 Hour Maintenance(Trained Service Technician) 10
Lubricants 11
Batteries (Item 11) 12
Preventive inspection maintenance90 day or 150 hour checklist 14
Torque chart 16
Servicing STC Fittings 17
Auto Level System Troubleshooting 19
To order service or repair parts 22
Section 1. - Repair Parts
Chassis assembly 1-2
Chassis assembly drawing 1-3
Chassis assembly drawing, no stabilisers 1-4
Chassis assembly no stabilisers 1-5
Steer axle assembly 1-6
Steer axle assembly drawing 1-7
Articulating axle assembly drawing 1-8
Articulating axle assembly 1-9
Control & hydraulic cabinet assembly 1-10
Control & hydraulic cabinet assemblydrawing 1-11
Engine cabinet assembly drawing 1-12
Engine cabinet assembly 1-13
Cable operated emergency bleed down SR3370 1-14
Cable operated bleed down drawing, SR3370 1-15
Cable operated emergency bleed down SR2770 1-16
Cable operated bleed down drawing, SR2770 1-17
Scissor stack tees SR3370 1-19
Scissor stack assembly SR3370 1-20
Scissor stack assembly drawing SR3370 1-21
Scissor stack assembly drawing SR2770 1-22
Scissor stack assembly SR2770 1-23
Stabiliser assembly 1-24
Stabiliser assembly drawing 1-25
Platform assembly drawing 1-26
Platform assembly 1-27
Fuel tank assembly, diesel fuel 1-28
Upper control box mounting assembly 1-29
Placards and decals installation 1-30
Placards and decals drawing 1-31
Cabinet assembly 1-32
Cabinet assembly drawing 1-33
Engine assembly drawing 1-34
Engine assembly, Kubota D902 1-35
Section 2. - Hydraulics
Hydraulic assembly 2-2
4 wheel drive hydraulic schematic drawing 2-3
Hose Part Numbers and Colour Codes 2-5
Hose part numbers and colour codes 2-5
Manifold assembly, main 2-6
Manifold assembly, main drawing 2-7
Manifold assembly, 4 wheel drive 2-8
Manifold assembly, stabilisers 2-9
Hydraulic oil tank assembly 2-10
Hydraulic oil tank assembly drawing 2-11
Steer axle cylinder 2-12
Axle cylinder 2-13
Main lift cylinder assembly 2-14
Section 3. - Electrical
Looms 3-2
Electrical schematic drawing, auto level 3-3
Colour coded wiring circuit auto level 3-4
Electrical schematic drawing, no stabilisers 3-5
Colour coded wiring circuit, no stabilisers 3-6
Ground control box assembly drawing 3-8
Ground control box assembly 3-9
Ground box 3-10
Ground box drawing - sheet 1 3-11
Ground box drawing - sheet 2 3-12
Platform control box assembly 3-14
Platform Control Box Assembly drawingSheet 1 3-15
Platform Control Box Assembly drawingSheet 2 3-16
Section 4. - General Options
AC outlet at platform, 230 volt 4-2
AC outlet at platform 230V drawing 4-3
Flashing light installation 4-4
Fuel gauge option 4-5
4-6
Section 4. - 24Volt DC Option
24Volt DC Option 4-7
Colour coded wiring schematic,24VDC option 4-9
Control & hydraulic cabinet assembly - 24VDC 4-10
Control & hydraulic cabinet assemblydrawing, 24VDC option 4-11
Battery box assembly drawing, 24VDC option 4-12
Battery box assembly - 24VDC option 4-13
Battery box mounting - 24VDC option 4-14
Emergency bleed down mounting, 24VDC 4-15
Relay box assembly, 24VDC option 4-16
Relay box assembly drawing, 24VDC option 4-17
Unloader valve 24VDC option 4-18
Section 1
Section 2
Axle cylinder 2-13
Section 3
Looms 3-2
Ground box 3-10
Section 4
4-6
Parts index - Page locator
230 Volt AC outlet at platform, 4-2
A
AC outlet at platform, 230 volt AC, 4-2
D
Decal and placards installation, 1-30
G
Gradeability, 2-3, 2-4
Ground clearance, 2-3, 2-4
Ground control box assembly, 3-9
I
Insulation rating, 2-3, 2-4
J
Joystick controller, 3-14
K
Key switch, 3-10
L
Lift time, 2-3, 2-4
M
Maintenance, 0-7
Maintenance schedules, 0-8
Manual organisation
Manual Organization, 0-7
Maximum rated axle capacity, 2-3, 2-4
N
Nominal working height, 2-3, 2-4
O
Overall height, 2-3, 2-4
Overall length (with stabilizers), 2-3, 2-4
Overall weight, 2-3, 2-4
P
Placards and decals installation, 1-30
Platform control box assembly, 3-14
Platform size, 2-3, 2-4
S
Safe working load (main deck), 2-3, 2-4
Safe working load (roll out deck), 2-3, 2-4
Speed (maximum drive), 2-3, 2-4
T
Temperature sensor, 3-10
Travelling height, 2-3, 2-4
Turning radius (inner), 2-3, 2-4
Turning radius (outer), 2-3, 2-4
W
Warranty - Limited
Weight, 2-3, 2-4
Working height, 2-3, 2-4
Snorkel Scissor Lift TL49J Service Parts Manual.pdf (128 Pages)
Snorkel Scissor Lift X-26 Parts Service Manual.pdf (100 Pages)
Snorkel Scissor Lift X-27-33-RT Service Parts Manual.pdf (134 Pages)
Table of Contents
Engine Data 5
Engine Oil Charts 5
Daily Maintenance 9
Lubricants 11
Torque chart 16
Axle cylinder 2-13
Looms 3-2
Ground box 3-10
4-6
Section 1
Section 2
Axle cylinder 2-13
Section 3
Looms 3-2
Ground box 3-10
Section 4
4-6
A
D
G
I
J
K
Key switch, 3-10
L
Lift time, 2-3, 2-4
M
Maintenance, 0-7
Manual organisation
N
O
P
S
T
W
Warranty - Limited
Weight, 2-3, 2-4
