118
7,392
Skyjack Vertical Mast Lifts SJ12 SJ16 Service Manual 213558AFA 2023
Brand: Skyjack
Type of Machine: Vertical Mast Lifts
Type of Manual: Service Manual, Electrical Schematic, Hydraulic Schematic
Model: Skyjack SJ12, SJ16 Vertical Mast Lifts
Serial Number: A600000001 - A600999999
Part Number: 213558AFA
Publication Date: 2023
Number of Pages: 142 Pages
Section 1 – Scheduled Maintenance
1.1 Read and heed
1.2 Maintenance and Inspection Schedule
1.3 Owner’s Annual Inspection Record
1.4 Frequent/Periodic/Annual/Pre-Delivery Inspection Checklist
1.5 General inspections
1.6 Base inspections
1.7 Mast inspections
1.8 Platform inspections
1.9 Function Tests
Section 2 – Maintenance Tables and Diagrams
2.1 Standard Hose Numbering System
2.2 Specifications and Features - ANSI/CSA
2.3 Specifications and Features - CE, AS
2.4 Maximum Platform Capacities (Evenly Distributed) ANSI/CSA
2.5 Maximum Platform Capacities (Evenly Distributed) CE,AS
2.6 Floor Loading Pressure ANSI/CSA
2.7 Floor Loading Pressure - CE, AS
2.8 Torque Specifications
2.9 Torque Specifications for Fasteners (Imperial)
2.10 Torque Specifications for Fasteners (Metric)
2.11 Torque Specifications for Hydraulic Couplings & Hoses
Section 3 – System Component Identification and Schematics
3.1 Electrical Symbol Chart
3.2 Hydraulic Symbol Chart
3.3 Wire Number and Color Code
3.4 Hydraulic Component Parts List
3.5 Electrical Component Parts LIst
3.6 Cylinders and Port Identifications
3.7 Wheel Brake and Port Identifications
3.8 Powerpack and Port Identifications
3.9 Platform Control Box Wiring
3.10 Platform Control Box Wiring - SGLE
3.11 Platform Control Box Cable
3.12 Platform Control Box Cable - SGLE
3.13 Terminal Strip
3.14 Major Components
3.15 Brake and Main Manifold and Hydraulic Identifications
3.16 Disc Brake Kits and Torque Specifications
3.17 Hydraulic Schematic
3.18 Base Control Wiring Diagram (Page 1 of 2)
3.19 Base Control Wiring Diagram (Page 2 of 2)
3.20 Main Electrical Harness (Page 1 of 2)
3.21 Main Electrical Harness (Page 2 of 2)
3.22 Mast Control Cable
3.23 Limit Switches
3.24 Electrical Schematic (ANSI/CSA)
3.25 Electrical Schematic (CE)
3.26 Electrical Schematic (AS)
3.27 Elevate Telematics Harness
Section 4 – Troubleshooting Information
4.1 Introduction
4.2 Electrical System Troubleshooting
4.3 Hydraulic System Troubleshooting
Section 5 – Procedures
5.1 General
5.2 Electrical System Adjustments
5.3 Hydraulic System Adjustments
5.4 Electronic Tilt Switch Setup Procedure
5.5 Wheel Reinstallation and Torquing Procedure
5.6 Battery Maintenance
5.7 Pothole Limit Switch(LS2) Replacement and Adjustment
5.8 Mast Lubrication Procedure
5.9 Mast Roller Inspection/Maintenance
5.10 Mast Chain Visual Inspection
5.11 Mast Disassembly Procedure
5.12 Mast Roller Replacement
5.13 Mast Assembly Procedure
5.14 Lift Cylinder Replacement
5.15 Railing Maintenance and Repair
