118
6,911
Skyjack Vertical Mast Lifts SJ12 SJ16 Service Manual 161917AH 2023
Brand: Skyjack
Type of Machine: Vertical Mast Lifts
Type of Manual: Service Manual, Electrical Schematic, Hydraulic Schematic
Model: Skyjack SJ12, SJ16 Vertical Mast Lifts
Serial Number: 14002154 - 14999999
Part Number: 161917AH
Publication Date: 2023
Number of Pages: 135 Pages
Section 1 – Scheduled Maintenance
1.1 Read and Heed
1.2 Maintenance and Inspection Schedule
1.3 Hydraulic System & Component Maintenance and Repair
1.4 Railing Maintenance and Repair
1.5 About this Section
1.6 Owner’s Annual Inspection Record
1.7 Pre-Delivery/Maintenance Inspection
1.8 Scheduled Maintenance Inspections
1.9 Function Tests
Section 2 – Maintenance Tables and Diagrams
2.1 Standard Hose Numbering System
2.2 Specifications and Features - ANSI/CSA
2.3 Specifications and Features - KC
2.4 Specifications and Features - CE
2.5 Maximum Platform Capacities (Evenly Distributed) - ANSI/CSA
2.6 Maximum Platform Capacities (Evenly Distributed) - KC
2.7 Maximum Platform Capacities (Evenly Distributed) - CE
2.8 Floor Loading Pressure ANSI/CSA & KC
2.9 Floor Loading Pressure - KC
2.10 Floor Loading Pressure - CE
2.11 Torque Specifications
2.12 Torque Specifications for Fasteners (Imperial)
2.13 Torque Specifications for Fasteners (Metric)
2.14 Torque Specifications for Hydraulic Couplings & Hoses
Section 3 – System Component Identification and Schematics
3.1 Electrical Symbol Chart
3.2 Hydraulic Symbol Chart
3.3 Wire Number and Color Code
3.4 Hydraulic Component Parts List
3.5 Electrical Component Parts List
3.6 Cylinders and Port Identifications
3.7 Wheel Brake and Port Identifications
3.8 Powerpack and Port Identifications
3.9 Platform Control Console Wire Diagram
3.10 Brake and Main Manifold and Hydraulic Identifications
3.11 Disc Brake Kits and Torque Specifications
3.12 Hydraulic Schematic - SJ12/SJ16
3.13 Main Electrical Harness - SJ12/SJ16
3.14 Mast Control Cable
3.15 Limit Switches
3.16 Base Control Wiring Diagram (SJ12/SJ16 - ANSI)
3.17 Base Control Wiring Diagram (SJ12/SJ16 - CE/KC)
3.18 Electrical Schematic (SJ12/SJ16 - ANSI/CSA)
3.19 Electrical Schematic (SJ12/SJ16 - CE/KC)
3.20 Harness Assembly Trackunit
3.21 Harness Assembly Elevate
Section 4 – Troubleshooting Information
4.1 Introduction
4.2 Electrical System Troubleshooting
4.3 Hydraulic System Troubleshooting
Section 5 – Procedures
5.1 General
5.2 Electrical System Adjustments
5.3 Hydraulic System Adjustments
5.4 Electronic Tilt Switch Setup Procedure
5.5 Wheel Reinstallation and Torquing Procedure
5.6 Wheel Reinstallation and Torquing Procedure
5.7 Battery Maintenance
5.8 Charger Maintenance - Delta-Q
5.9 Pothole Limit Switch(LS2) Replacement and Adjustment
5.10 Mast Lubrication Procedure
5.11 Mast Roller Inspection/Maintenance
5.12 Mast Chain Visual Inspection
5.13 Mast Disassembly Procedure
5.14 Mast Roller Replacement
5.15 Mast Assembly Procedure
5.16 Lift Cylinder Replacement
