118
6,911
Skyjack Vertical Mast Lifts SJ12 SJ16 Parts Manual 213557ADA 2023
Brand: Skyjack
Type of Machine: Vertical Mast Lifts
Model: Skyjack SJ12, SJ16 Vertical Mast Lifts
Serial Number: A600000001 - A600999999
Part Number: 213557ADA
Publication Date: 2023
Number of Pages: 146 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Recommended Service Parts
Section 1 – Platform
1.1 Upper Platform
1.2 Lower Platform
1.3 Railing
1.4 Gate
1.5 Saloon Gate
1.6 Limit Switches
1.7 Platform Control Console
1.8 Joystick
1.9 Platform Control Box Wiring
Section 2 – Mast - SJ12
2.1 Mast 1 - SJ12
2.2 Mast 2 - SJ12
2.3 Mast 3 - SJ12
2.4 Mast 4 - SJ12
2.5 Chain - SJ12
2.6 Lift Cylinder Hardware - SJ12
2.7 Lift Cylinder - SJ12
2.8 Mast Electrical - SJ12
2.9 Control Cable - SJ12
2.10 Power Outlet - CE
Section 3 – Mast - SJ16
3.1 Mast 1 - SJ16
3.2 Mast 2 - SJ16
3.3 Mast 3 - SJ16
3.4 Mast 4 - SJ16
3.5 Mast 5 - SJ16
3.6 Chain - SJ16
3.7 Lift Cylinder Hardware - SJ16
3.8 Lift Cylinder - SJ16
3.9 Mast Electrical - SJ16
3.10 Control Cable - SJ16
Section 4 – Base Parts
4.1 Base Cover
4.2 Base
4.3 Pothole Protection
4.4 Pothole Cylinder
4.5 Clevis
4.6 Drive and Steer
4.7 Steer Cylinder
4.8 Wheel Motor and Brake
4.9 Powerpack
4.10 Charger
4.11 Base Electrical Components
4.12 Lower Control Box
4.13 Terminal Strip
4.14 Circuit Breaker and Horn
4.15 Main and Brake Manifolds
4.16 Main Manifold
4.17 Main Harness
4.18 Battery
4.19 Wheel
Section 5 – Hose Connections
5.1 Standard Hose Numbering System
5.2 Hydraulic Hose Connections
Section 6 – Attachments and Options
6.1 Tube Caddy
6.2 Pipe Rack
6.3 Tool Tray
6.4 Flashing Light
6.5 Wind Rating Kit SJ16
6.6 Discover AGM Batteries
6.7 RCD Option - CE
6.8 Elevate Telematics
6.9 Telematics Keypad
6.10 Battery Management System
6.11 White Noise Alarm
Section 7 – Labels
7.1 Label Kits
7.2 Labels - Rear View
7.3 Labels - Left View
7.4 Labels - Front View
7.5 Labels - Right View
7.6 Labels - Control Box
7.7 Labels - Miscellaneous
7.8 Labels - Hydraulic Oil
