118
6,911
Skyjack Vertical Mast Lifts SJ12 Parts Manual 155184AF 2023
Brand: Skyjack
Type of Machine: Vertical Mast Lifts
Model: Skyjack SJ12 Vertical Mast Lifts
Serial Number: 14000001 - 14001105
Part Number: 155184AF
Publication Date: 2023
Number of Pages: 92 Pages
Section 1 – PLATFORM RELATED PARTS
1.1 Chain Entrance Assembly
1.2 Lower Platform Assembly
1.3 Upper Platform Assembly
1.4 Railing Assembly
1.5 Gate Assembly
1.6 Platform Control Console Assembly
1.7 Controller Assembly
1.8 Platform Control Cable Assembly
1.9 Platform Limit Switch Assembly
Section 2 – MAST RELATED PARTS
2.1 Mast 1 Assembly
2.2 Mast 2 Assembly
2.3 Mast 3 Assembly
2.4 Mast 4 Assembly
2.5 Mast 4 Assembly
2.6 Chain Assembly
2.7 Mast Lift Cylinder Assembly
2.8 Lift Cylinder
2.9 Mast Electrical Assembly
Section 3 – BASE RELATED PARTS
3.1 Base Cover Assembly
3.2 Base Assembly
3.3 Base Assembly
3.4 Pothole Protection Assembly
3.5 Brake Manifold Assembly
3.6 Brake Manifold Assembly
3.7 Main Manifold Assembly
3.8 Main Manifold Assembly
3.9 Drive and Steer Assembly
3.10 Steer Speed Valve Assembly
3.11 Steer Cylinder Assembly
3.12 Steer Cylinder Assembly
3.13 Wheel Motor and Brake Assembly
3.14 Powerpack Assembly
3.15 Battery Charger Assembly
3.16 Base Electrical Components
3.17 Hydraulic Hose Connections
3.18 Hydraulic Hose Connections
3.19 Base Control Centre Assembly
3.20 Terminal Strip Assembly
3.21 Horn and Hour Meter Assembl
3.22 Main Harness Assembly
3.23 Main Harness Assembly
3.24 Steer Speed Harness
3.25 Battery Assembly
3.26 Wheel Assembly
Section 4 – OPTIONAL EQUIPMENT
4.1 Tool Tray Assembly
4.2 Biodegradeable Hydraulic Oil Option
Section 5 – LABELS
5.1 Label Kits
5.2 Left Side
5.3 Right Side
5.4 Rear
5.5 Front
5.6 Base
5.7 Platform Control Console
5.8 Miscellaneous
Section 6 – TABLES
6.1 Standard Hose Numbering System
6.2 Vertical Mast Fluids Table
