Skyjack Telescopic Booms SJ82T SJ86T Service Manual 170454AN 2023
Brand: Skyjack
Type of Machine: Telescopic Booms
Type of Manual: Service Manual, Electrical Schematic, Hydraulic Schematic
Model: Skyjack SJ82T, SJ86T Telescopic Booms
Serial Number: 97100001 to 97199999
Part Number: 170454AN
Publication Date: 2023
Number of Pages: 280 Pages
Section 1 – Scheduled Maintenance
1.1 Read and Heed
1.2 Maintenance and Service
1.3 Scheduled Maintenance
1.4 Owner’s Annual Inspection Record
1.5 Pre-Delivery/Maintenance Inspection Checklist
1.6 Scheduled Maintenance Inspections
1.7 Function Tests
Section 2 – Maintenance Tables and Diagrams
2.1 Standard Hose Numbering System
2.2 MEWP Torque Specifications
2.3 Axle Torque Specifications
2.4 Torque Specifications for Fasteners (US)
2.5 Torque Specifications for Fasteners (Metric)
2.6 Torque Specifications for Hydraulic Couplings & Hoses
2.7 Axles Maintenance Intervals
2.8 Tire Specifications
2.9 Floor Loading Pressure
2.10 Hydraulic Specifications & Gear Oil
2.11 Specifications & Features - Dimensional Data
2.12 Specifications & Features - Performance and Speeds
2.13 Engine Specifications
2.14 Axle Oscillation Diagrams
2.15 Dimension and Reach Diagram - SJ82T
2.16 Dimension and Reach Diagram - SJ86T
Section 3 – System Component Identification and Schematics
3.1 Electrical Symbol Chart
3.2 Hydraulic Symbol Chart
3.3 Wire Number and Color Code
3.4 Wire Numbers and Color Codes - Additional
3.5 Hydraulic Parts List
3.6 Electrical Parts List
3.7 Hourmeter/Counter Harness - CE
3.8 Rotary Manifold Port Identification
3.9 System and Drive Pump Port Identification
3.10 Drive Motors Port Identification
3.11 Jib Valve Port Identification
3.12 No Jib Valve Port Identification
3.13 Brake Manifold Port Identification
3.14 Pressure Reducing Valve Port Identification
3.15 Main Manifold Port Identification
3.16 Main Manifold Electrical Component Identification
3.17 Main Manifold Hydraulic Component Identification
3.18 Main Harness Wiring Diagram
3.19 Boom Lift Valve Harness
3.20 Differential Lock Harness
3.21 Platform Rotate & Jib Harnesses
3.22 Platform to Base Control Cable Harnesses
3.23 Power Control Cable Connections
3.24 Limit Switch Connections
3.25 Load Sensing Cable Connection - CE & AS
3.26 ECU Engine Wiring Diagram - Deutz Diesel Engine
3.27 Glow Plug and EGR Harnesses - Deutz Diesel Engine
3.28 Generator and Oil Cooler Harness Connections
3.29 Generator Wiring
3.30 SGE Wiring Diagrams
3.31 Platform Work Light
3.32 Positive Air Shut-Off Option Harness
3.33 Dual Capacity Sensing Module
3.34 Load Circuit - ANSI/CSA with Deutz TD2.9L
3.35 Hydraulic Schematic
3.36 Platform Controls Wiring - SJ82T ANSI/CSA
3.37 Platform Controls Wiring - SJ86T ANSI/CSA
3.38 Platform Controls Wiring - SJ86T CE - Deutz TCD2.2
3.39 Platform Controls Wiring - SJ86T CE - Deutz TD2.9L
3.40 Platform Controls Wiring - SJ86T AS
3.41 Base Controls Wiring - SJ82T ANSI/CSA - Deutz D2011
3.42 Base Controls Wiring - SJ82T ANSI/CSA - Deutz TD2.9L
3.43 Base Controls Wiring - SJ82T ANSI/CSA - Deutz TD2.9L with Positive Air Shut-Off
3.44 Base Controls Wiring - SJ82T ANSI/CSA - Perkins 2.2TA
3.45 Base Controls Wiring - SJ86T ANSI/CSA - Deutz D2011
3.46 Base Controls Wiring - SJ86T ANSI/CSA - Deutz TD2.9L
3.47 Base Controls Wiring - SJ86T ANSI/CSA - Deutz TD2.9L with Positive Air Shut-Off
3.48 Base Controls Wiring - SJ86T ANSI/CSA - Perkins 2.2TA
3.49 Base Controls Wiring - SJ86T CE - Deutz TCD2.2
3.50 Base Controls Wiring - SJ86T CE - Deutz D2011
3.51 Base Controls Wiring - SJ86T CE - Deutz TD2.9L
3.52 Base Controls Wiring - SJ86T AS - Deutz D2011
3.53 Electrical Schematic - SJ82T & SJ86T ANSI/CSA Deutz D2011(S/N 97101144 & below)
3.54 Electrical Schematic - SJ82T & SJ86T ANSI/CSA Deutz D2011(S/N 97101145 & above)
3.55 Electrical Schematic - SJ82T & SJ86T ANSI/CSA Deutz TD2.9L (S/N 97101144 & below)
3.56 Electrical Schematic - SJ82T & SJ86T ANSI/CSA Deutz TD2.9L (S/N 97101145 & above)
3.57 Electrical Schematic - SJ82T & SJ86T ANSI/CSA Perkins 2.2TA (S/N 97101144 & below)
3.58 Electrical Schematic - SJ82T & SJ86T ANSI/CSA Perkins 2.2TA (S/N 97101145 & above)
3.59 Electrical Schematic - SJ86T CE Deutz TCD2.2
3.60 Electrical Schematic - SJ86T CE Deutz D2011 (S/N 97101144 & below)
3.61 Electrical Schematic - SJ86T CE Deutz D2011 (S/N 97101145 & above)
3.62 Electrical Schematic - SJ86T CE Deutz TD2.9L (S/N 97101144 & below)
3.63 Electrical Schematic - SJ86T CE Deutz TD2.9L (S/N 97101145 & above)
3.64 Electrical Schematic - SJ86T AS Deutz D2011 (S/N 97101144 & below)
3.65 Electrical Schematic - SJ86T AS Deutz D2011 (S/N: 97101145& above)
3.66 Engine Electrical Schematic - Deutz TCD2.2
3.67 Engine Interface Harness Schematic - Deutz TCD2.2
3.68 Engine Electrical Schematic - Deutz TD2.9L (S/N 97101144 & below)
3.69 Engine Electrical Schematic - Deutz TD2.9L (S/N 97101145 & above)
3.70 Engine Electrical Schematic CE - Deutz TD2.9L (S/N 97101144 & below)
3.71 Engine Electrical Schematic CE - Deutz TD2.9L (S/N 97101145 & above)
3.72 Engine Interface Harness Schematic - Deutz TD2.9L
3.73 Engine Interface Harness - Perkins 2.2TA (S/N 97101144 & below)
3.74 Engine Interface Harness - Perkins 2.2TA (S/N 97101145 & above)
3.75 Engine OEM Harness - Perkins 2.2TA (S/N 97101144 & below)
3.76 Engine OEM Harness - Perkins 2.2TA (S/N 97101145 & above)
3.77 Engine Component Harness - Perkins 2.2TA (S/N 97101144 & below)
3.78 Engine Component Harness - Perkins 2.2TA (S/N 97101145 & above)
Section 4 – Troubleshooting Information
4.1 Introduction
4.2 Electrical System
4.3 Hydraulic System
4.4 Load Sensing System - CE
Section 5 – Procedures
5.1 General
5.2 Platform
5.3 Boom
5.4 Turret
5.5 Deutz Diesel Engines
5.6 Hydraulic Tank
5.7 Manifolds and Hydraulic Pumps
5.8 Axles
5.9 Grease Points
5.10 Load Sensing System
Brand: Skyjack
1.1 Read and Heed
1.7 Function Tests
4.1 Introduction
5.1 General
5.2 Platform
5.3 Boom
5.4 Turret
5.6 Hydraulic Tank
5.8 Axles
5.9 Grease Points
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
