Skyjack Telescopic Booms SJ61T+ SJ66T+ Service Manual 229039AFA 2023
Brand: Skyjack
Type of Machine: Telescopic Booms
Type of Manual: Service Manual, Electrical Schematic, Hydraulic Schematic
Model: Skyjack SJ61T+, SJ66T+ Telescopic Booms
Serial Number: A401000001 - A401999999
Part Number: 229039AFA
Publication Date: 2023
Number of Pages: 254 Pages
Section 1 – Maintenance
1.1 Read And Heed
1.2 General Information
1.3 Scheduled Maintenance And Inspections
Section 2 – Maintenance Tables And Diagrams
2.1 Standard Hose Numbering System
2.2 Torque Specifications for Fasteners (Metric)
2.3 Torque Specifications for Fasteners (US)
2.4 Axle Torque Specifications
2.5 Torque Specifications for Hydraulic Couplings & Hoses
2.6 MEWP Torque Specifications
2.7 Axle Maintenance Intervals
2.8 Hydraulic Specifications
2.9 Hydraulic & Gear Oils
2.10 Platform Capacities
2.11 Specifications and Features - Dimensional Data
2.12 Specifications and Features - Performance & Speeds
2.13 Engine Specifications
2.14 Reach Diagram - SJ61 T+
2.15 Reach Diagram - SJ66 T+
Section 3 – System Component Identification and Schematics
3.1 Electrical Symbol Chart
3.2 Hydraulic Symbol Chart
3.3 Wire Number and Colour Chart
3.4 Wire Numbers and Colour Codes - Additional
3.5 Hydraulic Parts List
3.6 Electrical Parts List
3.7 Rotary Manifold Port Identification
3.8 Brake Manifold Port Identification
3.9 System and Drive Pumps and Port Identifications
3.10 System Pump and Port Identifications
3.11 Drive Pump and Port Identifications
3.12 Drive Motors and Port Identifications
3.13 Platform Rotate Valve and Port Identification - SJ61 T+
3.14 Jib & Platform Rotate Valve and Port Identification - SJ66 T+
3.15 Main Manifold Port Identification
3.16 Main Manifold Electrical Component Identification
3.17 Main Manifold Hydraulic Component Identification
3.18 Generator Control Valves and Port Indentifcations
3.19 Major Components
3.20 Main Harness Wiring Diagram
3.21 ECU Engine Wiring Diagram - Deutz
3.22 Glow Plug and EGR Harnesses - Deutz
3.23 Engine Interface Harness - Deutz TD2.9L
3.24 Engine Interface Harness - Deutz TCD2.2
3.25 Engine Interface Harness - Deutz D2011
3.26 Jib and Platfor Rotate Harnesses
3.27 Limit Switch Connections
3.28 Generator and Oil Cooler Harness Connections
3.29 Generator Wire Kit Connections
3.30 Generator Connection - 12 kW
3.31 Differential Lock Harness
3.32 SGE Wiring Diagram
3.33 SGE Connections
3.34 Moba Load Cell Connections
3.35 Footswitch Connections
3.36 CANbus Cable Connections
3.37 Power Cable Connections
3.38 Hydraulic Schematic
3.39 Platform Controls Wiring - SJ61 T+
3.40 Platform Controls Wiring - SJ66 T+ ANSI/CSA & CE - all engines except Deutz TCD2.2
3.41 Platform Controls Wiring - SJ66 T+ CE - Deutz TCD2.2
3.42 Base Controls Wiring - SJ61 T+ ANSI/CSA
3.43 Base Controls Wiring - SJ61 T+ with Positive Air Shut-Off Option
3.44 Base Controls Wiring - SJ66 T+ ANSI/CSA & AS
3.45 Base Controls Wiring - SJ66 T+ ANSI/CSA & AS with Positive Air Shut-Off Option
3.46 Base Controls Wiring - SJ66 T+ CE with Deutz D2011
3.47 Base Controls Wiring - SJ66 T+ CE with Deutz TCD2.2
3.48 Electrical Schematic - ANSI/CSA & AS
3.49 Electrical Schematic - CE with Deutz D2011 engine
3.50 Electrical Schematic - CE with Deutz TCD2.2 Engine
3.51 Interface & Engine Electrical Schematic - Deutz TD2.9L
3.52 Interface & Engine Electrical Schematic - Deutz TCD2.2
3.53 Engine OEM Harness Schematic - Deutz TCD2.2
3.54 Interface & Engine Electrical Schematic - Deutz D2011
3.55 Interface & Engine Electrical Schematic - Kubota
Section 4 – Troubleshooting Information
4.1 Introduction
4.2 Electrical System
4.3 Hydraulic System
Section 5 – Procedures
5.1 Safety and Workmanship
5.2 System Control Module (SCM)
5.3 Platform
5.4 Boom
5.5 Turret
5.6 Deutz Diesel Engines
5.7 Kubota WG2503 Dual Fuel Engine
5.8 Hydraulic Tank
5.9 Manifold and Hydraulic Pumps
5.10 Axles
5.11 Grease Points
5.12 Options
Brand: Skyjack
1.1 Read And Heed
4.1 Introduction
5.3 Platform
5.4 Boom
5.5 Turret
5.8 Hydraulic Tank
5.10 Axles
5.11 Grease Points
5.12 Options
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
