118
6,911
Skyjack Telescopic Booms SJ61T+ SJ66T+ Parts Manual 229032AFA 2023
Brand: Skyjack
Type of Machine: Telescopic Booms
Model: Skyjack SJ61T+, SJ66T+ Telescopic Booms
Serial Number: A401000001 - A401999999
Part Number: 229032AFA
Publication Date: 2023
Number of Pages: 300 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Recommended Service Parts
Section 1 – Platform
1.1 Platform with Drop Bars
1.2 Platform with Swing Gate
1.3 Railings
1.4 Platform Base
1.5 Drop Bar Gate
1.6 Swing Gate
1.7 Platform Control Box
1.8 Boom / Turret Controller
1.9 Drive / Steer Controller
1.10 Platform Terminal Strip
1.11 Footswitch
1.12 Power to Platform - Outlet and Plugs - CE
1.13 Outlet 110V - ANSI/CSA
Section 2 – Boom
2.1 Boom Assembly
2.2 Boom Sections
2.3 Wire Rope
2.4 Cable Track
2.5 Jib Assembly - SJ66 T+
2.6 Jib Lift / Platform Rotate Valves
2.7 Limit Switches
2.8 Rotary Actuator Mount - SJ61 T+
2.9 Rotary Actuator
Section 3 – Cylinders
3.1 Extension Cylinder Hardware
3.2 Extension Cylinder
3.3 Lift and Master Cylinder Hardware
3.4 Lift Cylinder
3.5 Master Cylinder
3.6 Slave Cylinder
3.7 Jib Cylinder
3.8 Axle Lockout Cylinder
Section 4 – Turret
4.1 Cowling - Engine Side
4.2 Cowling - Control Side
4.3 Cowling - Center
4.4 High Pressure Filter
4.5 Turret
4.6 Manifold Hardware
4.7 Main Manifold
4.8 Brake Manifold
4.9 Rotary Manifold
4.10 Hydraulic Tank
4.11 No Generator & Oil Cooler Hose Fittings
4.12 Swing Drive
4.13 Fuel Tank - Gasoline
4.14 Fuel Tank - Diesel
4.15 Battery Cables
4.16 Battery
4.17 Auxiliary Pump
4.18 Base Control Box
4.19 Micro Relay Mount
4.20 Base Terminal Strip
Section 5 – Electrical Harnesses
5.1 Main Electrical Harness
5.2 Interface Harness - Deutz TD2.9L & D2011
5.3 Interface Harness - Deutz TCD2.2
5.4 Battery Cables
5.5 Jib & Platform Rotate Harnesses
5.6 Control and CANbus Cables
5.7 ECU Harnesses - Deutz D2011
5.8 Glow Plug Harness - Deutz TD2.9
5.9 Glow Plug Harness - Deutz TCD2.2
5.10 Glow Plug Harness - Deutz D2011
5.11 Engine Interface Harness - Deutz TD2.9L
5.12 Engine Interface Harness - Deutz TCD2.2
5.13 Engine Interface Harness - Kubota WG2503
5.14 Differential Lock Valve Harness
Section 6 – Base
6.1 Base
6.2 Counterweight
6.3 Front Axle
6.4 Central Housing - Front Axle
6.5 Differential - Front Axle
6.6 Hub Reduction - Front Axle
6.7 Steering - Front Axle
6.8 Trunnion - Front Axle
6.9 Drive Shaft
6.10 Brakes - Front and Rear Axles
6.11 Rear Axle
6.12 Central Housing - Rear Axle
6.13 Differential - Rear Axle
6.14 Hub Reduction - Rear Axle
6.15 Gear Box
6.16 Propane Assembly
6.17 Tires
Section 7 – Engines
7.1 Engine - Deutz TD2.9L
7.2 Radiator - Deutz TD2.9L
7.3 Air Intake - Deutz TD2.9L
7.4 Engine - Deutz TCD2.2
7.5 Radiator - Deutz TCD2.2 - S/N A401 000 672 & above
7.6 Radiator - Deutz TCD2.2 - S/N A401 000 671 & below
7.7 Air Intake - Deutz TCD2.2
7.8 Engine - Deutz D2011
7.9 Engine - Kubota WG2503
7.10 Engine Accessories - Kubota WG2503
7.11 Radiator & Air Intake - Kubota WG2503
7.12 Engine Tray
7.13 Drive & System Pump
7.14 Engine Coupling - Deutz
7.15 Engine Coupling - Kubota WG2503
Section 8 – Hose Connections
8.1 Standard Hose Numbering System
8.2 Hydraulic Hoses – Cylinders
8.3 Hydraulic Hoses – Control Compartment
8.4 Hydraulic Hoses – Pumps & Swing Drive
8.5 Hydraulic Hoses – Base and Axles
8.6 Fuel Line Hoses – Deutz TD2.9L & TCD2.2 Engines
8.7 Fuel Line Hoses – Deutz D2011 Engine
8.8 Fuel Line Hoses – Kubota WG2503 Engine
8.9 Turret Grease Hose
Section 9 – Optional Equipment
9.1 Oil Cooler with No Generator
9.2 Oil Cooler
9.3 Generator and Oil Cooler - 3.5kW
9.4 Generator - 3.5 kW
9.5 Hydraulic Hoses - Generator & Oil Cooler - 3.5 kW
9.6 Generator & Oil Cooler - 7.5 kW
9.7 Generator - 7.5 kW
9.8 Hydraulic Hoses - 7.5 kW Generator and Oil Cooler
9.9 Generator & Oil Cooler - 12 kW
9.10 Generator - 12 kW
9.11 Hydraulic Hoses - 12 kW Generator & Oil Cooler
9.12 Generator & Oil Cooler Wiring
9.13 Welder & Mount
9.14 Glazier Package
9.15 Cold Start Engine Option
9.16 Arctic Package Option
9.17 Arctic Package Load Circuit - Deutz TD2.9L
9.18 Block Heater
9.19 Oil Quick Drain
9.20 SGE - Secondary Guarding
9.21 External Platform Railing
9.22 Flashing Light
9.23 Air Hose To Platform
9.24 Diesel Scrubber
9.25 Control Box Cover
9.26 Positive Air Shut-Off Valve - Deutz TD2.9L
9.27 Positive Air Shut-Off Valve - Deutz D2011
9.28 Work Lights
9.29 Tool Caddy
9.30 Half-Height Platform Mesh
9.31 Elevate Telematics
9.32 Elevate Telematics Subscription
9.33 Pipe Rack
9.34 White Noise Alarm
9.35 Residual Current Device (RCD)
Section 10 – Labels
10.1 Label Kits
10.2 Labels - Front, Back and Bottom
10.3 Labels - Engine Side
10.4 Labels - Controls Side
10.5 Labels - Control Compartment
10.6 Labels - Engine Compartment
10.7 Labels - Platform
