Skyjack Telescopic Booms SJ61T SJ66T Parts Manual 207562AI 2023
Brand: Skyjack
Type of Machine: Telescopic Booms
Model: Skyjack SJ61T, SJ66T Telescopic Booms
Serial Number: 97001833 to 97099999
Part Number: 207562AI
Publication Date: 2023
Number of Pages: 332 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Recommended Service Parts
Section 1 – Platform
1.1 Platform with Drop Bars
1.2 Platform with Swing Gate
1.3 Railings
1.4 Platform Base - CE & AS
1.5 Swing Gate
1.6 Drop Bar Gate
1.7 Footswitch
1.8 Platform Control Box
1.9 Boom / Turret Controller
1.10 Drive / Steer Controller
1.11 Platform Terminal Strip
Section 2 – Boom
2.1 Boom Assembly
2.2 Main Boom
2.3 Fly Boom
2.4 Mid Boom
2.5 Cable Track
2.6 Jib Assembly - SJ66T
2.7 Rotary Actuator Mount - SJ61T
2.8 Rotary Actuator
2.9 Jib Lift / Platform Rotate Valves
Section 3 – Cylinders
3.1 Extension Cylinder Hardware
3.2 Extension Cylinder
3.3 Lift and Master Cylinder Hardware
3.4 Lift Cylinder
3.5 Master Cylinder
3.6 Slave Cylinder
3.7 Jib Cylinder
3.8 Axle Lockout Cylinder
Section 4 – Turret
4.1 Cowling - Engine Side
4.2 Cowling - Control Side
4.3 Cowling - Center
4.4 High Pressure Filter
4.5 Turret
4.6 Manifold Hardware
4.7 Main Manifold
4.8 Brake Manifold
4.9 Rotary Manifold
4.10 Hydraulic Tank
4.11 No Generator & Oil Cooler Hose Fittings
4.12 Swing Drive
4.13 Fuel Tank - Gasoline
4.14 Fuel Tank - Diesel
4.15 Battery Cables
4.16 Battery
4.17 Auxiliary Pump
4.18 Base Control Box - Deutz TD2.9L & Perkins 2.2TA
4.19 Base Control Box - Deutz TCD2.2
4.20 Base Control Box - Deutz D2011 & Kubota
4.21 Base Terminal Strip - Deutz TD2.9L & Perkins
4.22 Base Terminal Strip - Deutz TCD2.2
4.23 Base Terminal Strip - Deutz D2011 & Kubota
Section 5 – Electrical Harnesses
5.1 Main Electrical Harness
5.2 Battery Cables
5.3 Control Cable Harnesses
5.4 Jib & Platform Rotate Harnesses
5.5 Outlet - 110/220V
5.6 ECU Harnesses - Deutz D2011
5.7 Glow Plug Harness - Deutz TD2.9
5.8 Glow Plug Harness - Deutz TCD2.2
5.9 Glow Plug Harness - Deutz D2011
5.10 Engine Interface Harness - Deutz TD2.9L
5.11 Engine Interface Harness - Deutz TCD2.2
5.12 Engine Interface Harness - Kubota WG2503
5.13 Engine Interface Harness - Perkins 2.2TA
5.14 Fuse Box - Perkins 2.2TA
5.15 Differential Lock Valve Harness
Section 6 – Base
6.1 Base
6.2 Counterweight
6.3 Front Axle
6.4 Central Housing - Front Axle
6.5 Differential - Front Axle
6.6 Hub Reduction - Front Axle
6.7 Steering - Front Axle
6.8 Trunnion - Front Axle
6.9 Drive Shaft
6.10 Brakes - Front and Rear Axles
6.11 Rear Axle
6.12 Central Housing - Rear Axle
6.13 Differential - Rear Axle
6.14 Hub Reduction - Rear Axle
6.15 Gear Box
6.16 Propane Assembly
6.17 Tires
Section 7 – Engines
7.1 Engine - Deutz TD2.9L
7.2 Radiator - Deutz TD2.9L
7.3 Air Intake - Deutz TD2.9L
7.4 Engine - Deutz TCD2.2
7.5 Radiator - Deutz TCD2.2
7.6 Air Intake - Deutz TCD2.2
7.7 Engine - Deutz D2011
7.8 Engine - Perkins 2.2TA
7.9 Radiator - Perkins 2.2TA
7.10 Air Intake - Perkins 2.2TA
7.11 Engine - Kubota WG2503
7.12 Engine Accessories - Kubota WG2503
7.13 Radiator & Air Intake - Kubota WG2503
7.14 Engine Tray
7.15 Drive & System Pump
7.16 Engine Coupling - Deutz
7.17 Engine Coupling - Kubota WG2503
7.18 Engine Coupling - Perkins
Section 8 – Hose Connections
8.1 Standard Hose Numbering System
8.2 Hydraulic Hoses – Cylinders
8.3 Hydraulic Hoses – Control Compartment
8.4 Hydraulic Hoses – Pumps & Swing Drive
8.5 Hydraulic Hoses – Base and Axles
8.6 Fuel Line Hoses – Deutz TD2.9L & TCD2.2 Engines
8.7 Fuel Line Hoses – Deutz D2011 Engine
8.8 Fuel Line Hoses – Perkins 2.2TA
8.9 Fuel Line Hoses – Kubota WG2503 Engine
8.10 Turret Grease Hose
Section 9 – Optional Equipment
9.1 Oil Cooler with No Generator
9.2 Oil Cooler
9.3 Generator and Oil Cooler - 3.5kW
9.4 Generator - 3.5 kW
9.5 Hydraulic Hoses - Generator & Oil Cooler - 3.5 kW
9.6 Generator & Oil Cooler - 7.5 kW
9.7 Generator - 7.5 kW
9.8 Hydraulic Hoses - 7.5 kW Generator and Oil Cooler
9.9 Generator & Oil Cooler - 12 kW
9.10 Generator - 12 kW
9.11 Hydraulic Hoses - 12 kW Generator & Oil Cooler
9.12 Generator & Oil Cooler Wiring
9.13 Welder & Mount
9.14 Glazier Package
9.15 Cold Start Engine Option
9.16 Arctic Package Option
9.17 Arctic Package Load Circuit - Deutz TD2.9L
9.18 Block Heater
9.19 Oil Quick Drain
9.20 SGM - Secondary Guarding
9.21 SGE - Secondary Guarding
9.22 External Platform Railing
9.23 Flashing Light
9.24 Air Hose To Platform
9.25 Diesel Scrubber
9.26 Control Box Cover
9.27 Positive Air Shut-Off Valve - Deutz TD2.9L
9.28 Positive Air Shut-Off Valve - Deutz D2011
9.29 Work Lights
9.30 Tool Caddy
9.31 Half-Height Platform Mesh
9.32 Elevate Telematics
9.33 Elevate Telematics Subscription
9.34 Pipe Rack
Section 10 – Labels
10.1 Label Kits
10.2 Labels - Platform Control Box
10.3 Labels - Front and Bottom
10.4 Labels - Engine Side
10.5 Labels - Controls Side
10.6 Labels - Control Compartment
10.7 Labels - Fuel
10.8 Labels - Engine Compartment
10.9 Labels - Platform
Brand: Skyjack
Foreword
General
Method of Listing
Quantities
1.3 Railings
1.5 Swing Gate
1.6 Drop Bar Gate
1.7 Footswitch
Section 2 – Boom
2.1 Boom Assembly
2.2 Main Boom
2.3 Fly Boom
2.4 Mid Boom
2.5 Cable Track
2.8 Rotary Actuator
3.4 Lift Cylinder
3.5 Master Cylinder
3.6 Slave Cylinder
3.7 Jib Cylinder
Section 4 – Turret
4.5 Turret
4.7 Main Manifold
4.8 Brake Manifold
4.9 Rotary Manifold
4.10 Hydraulic Tank
4.12 Swing Drive
4.15 Battery Cables
4.16 Battery
4.17 Auxiliary Pump
5.2 Battery Cables
Section 6 – Base
6.1 Base
6.2 Counterweight
6.3 Front Axle
6.9 Drive Shaft
6.11 Rear Axle
6.15 Gear Box
6.17 Tires
Section 7 – Engines
7.14 Engine Tray
9.2 Oil Cooler
9.13 Welder & Mount
9.18 Block Heater
9.23 Flashing Light
9.29 Work Lights
9.30 Tool Caddy
9.34 Pipe Rack
Section 10 – Labels
10.1 Label Kits
10.7 Labels - Fuel
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
