118
6,911
Skyjack Telescopic Booms SJ61T SJ66T Parts Manual 170946AI 2022
Brand: Skyjack
Type of Machine: Telescopic Booms
Model: Skyjack SJ61T, SJ66T Telescopic Booms
Serial Number: 97001396 - 97001832
Part Number: 170946AI
Publication Date: 2022
Number of Pages: 268 Pages
1.0 Platform
1.1 Platform
1.2 Railing Assembly
1.3 Platform Base Assembly (Ansi/Csa)
1.4 Platform Base Assembly (Ce)
1.5 Swing Gate Assembly
1.6 Drop Bar Gate
1.7 Railing Extension (No Gate)
1.8 Footswitch
1.9 Platform Control Console
1.10 Boom / Turret Controller Assembly (Dual Axis)
1.11 Drive / Steer Controller Assembly (Single Axis)
1.12 Platform Terminal Strip
2.0 Boom
2.1 Boom Assembly
2.2 Main Boom Assembly
2.3 Fly Boom Assembly
2.4 Mid Boom Assembly
2.5 Power Track Carrier Assembly
2.6 Jib Assembly - 66t
2.7 Rotary Actuator Mounting - 61t
2.8 Rotary Actuator Assembly
2.9 Jib Lift / Platform Rotate Valve Assemblies
3.0 Cylinders
3.1 Extension Cylinder Hardware
3.2 Extension Cylinder Assembly
3.3 Lift And Master Cylinder Hardware
3.4 Lift Cylinder Assembly
3.5 Master Cylinder Assembly
3.6 Slave Cylinder Assembly
3.7 Jib Cylinder Assembly
3.8 Axle Lockout Cylinder Assembly
4.0 Turret
4.1 Cowling Assembly - Engine Side
4.2 Cowling Assembly - Control Side
4.3 Cowling Assembly - Center
4.4 High Pressure Filter Assembly
4.5 Turret Assembly
4.6 Manifold Hardware
4.7 Main Manifold Assembly
4.8 Brake Manifold Assembly
4.9 Pressure Reducing Manifold
4.10 Rotary Manifold Assembly
4.11 Hydraulic Tank Assembly
4.12 No Generator And Oil Cooler Hose Fittings
4.13 Turret Swing Drive Assembly
4.14 Fuel Tank Assembly (Gm Dual Fuel Engine)
4.15 Fuel Tank Assembly - Kubota Engine
4.16 Fuel Tank Assembly - Deutz Diesel Engine
4.17 Battery Cable Assembly
4.18 Battery And Lockout Switch Assembly
4.19 Auxiliary Pump
4.20 Base Control Box - Deutz Td2.9l Engine
4.21 Base Control Box - Deutz D2011 & Gm Engines
4.22 Base Terminal Strip - Deutz Td2.9l Engine
4.23 Base Terminal Strip - Deutz D2011 & Gm Engines
5.0 Electrical Harnesses
5.1 Main Electrical Harness
5.2 Battery Cables
5.3 Control Cable Harnesses
5.4 Jib & Platform Rotate Harnesses
5.5 110/220v Outlet Harness
5.6 Ecu Harnesses - Deutz D2011
5.7 Glow Plug Harness (Deutz Td2.9l Engine)
5.8 Glow Plug Harness (Deutz D2011 Engine)
5.9 Engine Interface Harness - Deutz Td2.9l Engine
5.10 Engine Interface Harness - Kubota Wg2503
5.11 Engine Interface Harness - Gm Engine
6.0 Base
6.1 Base Assembly
6.2 Counterweight Assembly
6.3 Axle Hardware
6.4 Rear Axle Assembly
6.5 Differential Assembly - Rear Axle
6.6 Central Housing Assembly - Rear Axle
6.7 Gear Box - Rear Axle
6.8 Hydraulic Drive Motor
6.9 Front Axle Assembly
6.10 Differential Assembly - Front Axle
6.11 Central Housing Assembly - Front Axle
6.12 Steering Assembly
6.13 Trunnion Assembly - Front Axle
6.14 Axle Drive Shaft
6.15 Brake Assembly - Front & Rear Axle
6.16 Propane Tank Assembly
6.17 Tires
7.0 Engines
7.1 Engine Assembly - Deutz Td2.9l
7.2 Radiator Assembly - Deutz Td2.9l
7.3 Engine Assembly - Deutz D2011
7.4 Engine Assembly - Gm Dual Fuel
7.5 Engine Assembly - Kubota Wg2503
7.6 Radiator & Air Intake Assemblies - Kubota Wg2503
7.7 Engine Tray Assembly
7.8 Drive And System Pump Assembly
7.9 Engine Coupling - Deutz
7.10 Engine Coupling - Kubota Wg2503
8.0 Hose Connections
8.1 Standard Hose Numbering System
8.2 Hydraulic Hose Connection - Cylinders
8.3 Hydraulic Hose Connection - Control Compartment
8.4 Hydraulic Hose Connection - Pumps & Swing Drive
8.5 Hydraulic Hose Connection - Base And Axles
8.6 Fuel Line Hose Connection - Deutz Td2.9l Engine
8.7 Fuel Line Hose Connection - Deutz D2011 Engine
8.8 Fuel Line Hose Connection - Gm Engine
8.9 Fuel Line Hose Connection - Kubota Wg2503 Engine
8.10 Turret Grease Hose Connections
9.0 Optional Equipment
9.1 Generator And Oil Cooler - 3.5kw
9.2 Generator Assembly - 3.5kw
9.3 Oil Cooler With No Generator
9.4 Oil Cooler Assembly
9.5 Hydraulic Hose Connection - Generator And Oil Cooler - 3.5kw
9.6 Generator And Oil Cooler Wiring
9.7 Generator And Oil Cooler -12 Kw
9.8 Generator Assembly - 12kw
9.9 Hydraulic Hose Connection - 12kw Generator And Oil Cooler
9.10 Welder And Mounting Assembly
9.11 Glazier Package Option
9.12 Cold Start Engine Option
9.13 Arctic Package Option
9.14 Cold & Arctic Package Load Circuit - Deutz Td2.9l
9.15 Block Heater - Deutz Td2.9l
9.16 Oil Quick Drain
9.17 Sgm Assembly
9.18 Sge Assembly
9.19 External Platform Railing Assembly
9.20 Flashing Light
9.21 Air Hose To Platform Option
9.22 Diesel Scrubber
9.23 Control Box Cover
9.24 Positive Air Shut-Off Valve - Deutz Td2.9l
9.25 Positive Air Shut-Off Valve - Deutz D2011
9.26 Telematics - Morey
9.27 Telematics - Ztr
10.0 Labels
10.1 Label Kits
10.2 Labels - Platform Control Console
10.3 Labels - Front And Bottom
10.4 Labels - Engine Side
10.5 Labels - Controls Side
10.6 Labels - Controls Compartment
10.7 Labels - Engine Compartment
10.8 Labels - Platform
10.9 Labels - Engine Fuel
11.0 Tables
11.1 Fluids
11.2 Grease Locations - Axle
11.3 Grease Locations - Gears
11.4 Filters
