7,392
Skyjack Telescopic Booms SJ61T SJ66T Parts Manual 166872AK 2022
Brand: Skyjack
Type of Machine: Telescopic Booms
Model: Skyjack SJ61T, SJ66T Telescopic Booms
Serial Number: 97000918 - 97001135
Part Number: 166872AK
Publication Date: 2022
Number of Pages: 240 Pages
Section 1 – Platform Parts
1.1 Platform
1.2 Railing Assembly
1.3 Platform Base Assembly (Ansi/Csa)
1.4 Platform Base Assembly (Ce)
1.5 Swing Gate (A)
1.6 Swing Gate (B)
1.7 Drop Bar Gate (A)
1.8 Drop Bar Gate (B)
1.9 Railing Extension (No Gate)
1.10 Footswitch
1.11 Platform Control Console
1.12 Boom / Turret Controller Assembly (Dual Axis)
1.13 Drive / Steer Controller Assembly (Single Axis)
1.14 Platform Terminal Strip
Section 2 – Boom Parts
2.1 Boom Assembly Hardware
2.2 Main Boom Assembly
2.3 Fly Boom Assembly
2.4 Mid Boom Assembly
2.5 Power Track Carrier Assembly
2.6 Jib Assembly - 66t
2.7 Rotary Actuator Mounting
2.8 Jib Lift / Platform Rotate Valve Assemblies
2.9 Limit Switch Box Assembly
Section 3 – Cylinder Parts
3.1 Extension Cylinder Hardware
3.2 Extension Cylinder Assembly
3.3 Lift And Master Cylinder Hardware
3.4 Lift Cylinder Assembly
3.5 Master Cylinder Assembly
3.6 Slave Cylinder Assembly
3.7 Jib Cylinder Assembly
3.8 Axle Lockout Cylinder Assembly
Section 4 – Turret Parts
4.1 Cowling Assembly - Engine Side
4.2 Cowling Assembly - Control Side
4.3 Cowling Assembly - Center
4.4 High Pressure Filter Assembly
4.5 Turret Assembly
4.6 Main Manifold Assembly
4.7 Brake Manifold Assembly
4.8 Reducing Valve
4.9 Manifold Mounting Hardware
4.10 Rotary Manifold Assembly
4.11 Hydraulic Tank Assembly
4.12 No Generator And Oil Cooler Hose Fittings
4.13 Turret Swing Drive Assembly
4.14 Fuel Tank Assembly (Gm Dual Fuel Engine)
4.15 Fuel Tank Assembly (Deutz Td2.9l Engine)
4.16 Fuel Tank Assembly (Deutz D2011l04i Engine)
4.17 Battery And Lockout Switch Assembly
4.18 Emergency Power Unit
4.19 Base Control Console Assembly (Deutz Td2.9l Engine)
4.20 Base Control Console Assembly (Deutz D2011l04i Engine)
4.21 Base Control Console Assembly (Gm Engine)
4.22 Base Terminal Strip (Deutz Td2.9l Engine)
4.23 Base Terminal Strip (Deutz D2011 & Gm Engines)
4.24 Battery Cable Subgroup (Deutz Td2.9l Engine)
Section 5 – Electrical Harness Parts
5.1 Main Electrical Harness
5.2 Cable Harnesses
5.3 Control Cable Harnesses
5.4 Valve Harnesses And Limit Switches
5.5 110/220v Outlet Harness
5.6 Ecu Harnesses
5.7 Glow Plug Harness (Deutz Td2.9l Engine)
5.8 Glow Plug Harness (Deutz D2011l04i Engine)
5.9 Engine Interface Harness (Gm Engine)
5.10 Engine Interface Harness (Deutz Td2.9l Engine)
Section 6 – Base Parts
6.1 Base Assembly
6.2 Counterweight Assembly
6.3 Axle Assembly Hardware
6.4 Rear Axle Assembly With Gear Box
6.5 Differential Assembly - Rear Axle Assembly With Gear Box
6.6 Central Housing Assembly - Rear Axle Assembly With Gear Box
6.7 Gear Box (Rear Axle)
6.8 Hydraulic Drive Motor
6.9 Front Axle Assembly
6.10 Differential Assembly - Front Axle
6.11 Central Housing Assembly - Front Axle
6.12 Steering Assembly
6.13 Trunnion Assembly - Front Axle
6.14 Axle Drive Shaft
6.15 Brakes Assembly - Front & Rear Axle
6.16 Propane Tank Assembly
6.17 Tires
Section 7 – Engine Parts
7.1 Engine Assembly (Deutz Td2.9l Engine)
7.2 Radiator Assembly - Deutz Td2.9l
7.3 Engine Assembly (Deutz D2011l04i Engine)
7.4 Engine Assembly (Gm Dual Fuel Engine)
7.5 Engine Tray Assembly
7.6 Drive And System Pump Assembly
7.7 Engine Coupling Assembly
Section 8 – Hose Connection Parts
8.1 Standard Hose Numbering System
8.2 Hydraulic Hose Connection - Cylinders
8.3 Hydraulic Hose Connection - Control Compartment
8.4 Hydraulic Hose Connection - Engine Compartment
8.5 Fuel Line Hose Connection - Deutz Td2.9l Engine
8.6 Fuel Line Hose Connection - Deutz D2011l04i Engine
8.7 Hydraulic Hose Connection - Base And Axles
8.8 Turret Grease Hose Connections
Section 9 – Optional Equipment
9.1 3500w Generator And Oil Cooler Hardware
9.2 Hydraulic Hose Connection - 3500w Generator And Oil Cooler
9.3 3500w Generator Manifold Assembly
9.4 110v Generator Cable Assembly (Ansi/Csa)
9.5 Generator And Oil Cooler Harnesses
9.6 Generator Wire Assemblies
9.7 12 Kw Generator And Oil Cooler Hardware
9.8 Hydraulic Hose Connection - 12kw Generator And Oil Cooler
9.9 12 Kw Generator Manifold Assembly
9.10 Generator Wire Assemblies - 12kw Generator
9.11 Welder And Mounting Assembly
9.12 Glazier Package Option
9.13 Cold Start Engine Option
9.14 Arctic Package Option
9.15 Cold & Arctic Package Load Circuit - Deutz Td2.9l
9.16 Sgm Assembly
9.17 Sge Assembly
9.18 External Platform Railing Assembly
9.19 Flashing Light
9.20 Air Hose To Platform Option
Section 10 – Labels And Namplates
10.1 Label Kits
10.2 Labels - Platform Control Console
10.3 Labels - Front And Bottom
10.4 Labels - Engine Side
10.5 Labels - Controls Side
10.6 Labels - Controls Compartment
10.7 Labels - Engine Compartment
10.9 Labels - Operator Platform
10.10 Labels - Engine Fuel
11.1 Fluids Table
Section 11 – Tables
11.2 Boom Grease Locations - Axle Grease Table
11.3 Boom Grease Locations - Gear Grease Table
