118
6,911
Skyjack Telescopic Booms SJ61T SJ66T Parts Manual 163737AF 2022
Brand: Skyjack
Type of Machine: Telescopic Booms
Model: Skyjack SJ61T, SJ66T Telescopic Booms
Serial Number: 97000806 to 97000917
Part Number: 163737AF
Publication Date: 2022
Number of Pages: 228 Pages
1.0 Platform Related Parts
1.1 Railing Assembly
1.2 Platform Base Assembly (Ansi/Csa)
1.3 Platform Base Assembly (Ce & As)
1.4 Footswitch Assembly
1.5 Gate Assembly - Swing
1.6 Gate Assembly - Drop Bar
1.7 Railing Extension (No Gate)
1.8 Platform Control Console Assembly
1.9 Boom / Turret Controller Assembly (Dual Axis)
1.10 Drive / Steer Controller Assembly (Single Axis)
1.11 Platform Terminal Strip
2.0 Boom Related Parts
2.1 Boom Assembly Hardware
2.2 Main Boom Assembly
2.3 Fly Boom Assembly
2.4 Mid Boom Assembly
2.5 Power Track Carrier Assembly
2.6 Limit Switch Box Assembly
2.7 Jib Assembly - 66t
2.8 Rotary Actuator Mounting
2.9 Jib Lift / Platform Rotate Valve Assemblies
3.0 Cylinder Related Parts
3.1 Extension Cylinder Hardware
3.2 Extension Cylinder Assembly
3.3 Lift And Master Cylinder Hardware
3.4 Lift Cylinder Assembly
3.5 Master Cylinder Assembly
3.6 Slave Cylinder Assembly
3.7 Jib Cylinder Assembly
3.8 Axle Lockout Cylinder Assembly
4.0 Turret Related Parts
4.1 Cowling Assembly - Engine Side
4.2 Cowling Assembly - Control Side
4.3 Cowling Assembly - Center
4.4 Turret Assembly
4.5 Charge Filter Assembly
4.6 High Pressure Filter Assembly
4.7 Main Manifold Assembly
4.8 Brake Manifold Assembly
4.9 Manifold Mounting Hardware
4.10 Rotary Manifold Assembly
4.11 Hydraulic Tank Assembly
4.12 No Generator And Oil Cooler Hose Fittings
4.13 Turret Swing Drive Assembly
4.14 Fuel Tank Assembly (Gm Dual Fuel Engine)
4.15 Fuel Tank Assembly (Deutz Engine)
4.16 Battery And Lockout Switch Assembly
4.17 Emergency Power Unit
4.18 Base Control Console Assembly (Deutz Engine)
4.19 Base Control Console Assembly (Gm Dual Fuel Engine)
4.20 Base Terminal Strip
5.0 Electrical Harness Related Parts
5.1 Main Electrical Harness
5.2 Cable Harnesses
5.3 Control Cable Harnesses
5.4 Valve Harnesses And Limit Switches
5.5 110/220v Outlet Harness
5.6 Ecu Harnesses
5.7 Glow Plug And Egr Harness (Deutz Diesel Engine)
5.8 Engine Interface Harness (Gm Engine)
6.0 Base Related Parts
6.1 Base Assembly
6.2 Counterweight Assembly
6.3 Axle Assembly Hardware
6.4 Rear Axle Assembly With Gear Box
6.5 Differential Assembly - Rear Axle Assembly With Gear Box
6.6 Central Housing Assembly - Rear Axle Assembly With Gear Box
6.7 Gear Box (Rear Axle)
6.8 Hydraulic Drive Motor
6.9 Front Axle Assembly
6.10 Differential Assembly - Front Axle
6.11 Central Housing Assembly - Front Axle
6.12 Steering Assembly
6.13 Trunnion Assembly - Front Axle
6.14 Axle Drive Shaft (4wd)
6.15 Brakes Assembly - Front & Rear Axle
6.16 Propane Tank Assembly
6.17 Tires
7.0 Engine Related Parts
7.1 Engine Assembly (Deutz Diesel Engine)
7.2 Engine Coupling Assembly
7.3 Engine Assembly (Gm Dual Fuel Engine)
7.4 Engine Tray Assembly
7.5 Drive Pump Assembly
7.6 System Pump Assembly
8.0 Hose Connection Related Parts
8.1 Standard Hose Numbering System
8.2 Hydraulic Hose Connection - Cylinders
8.3 Hydraulic Hose Connection - Control Compartment
8.4 Hydraulic Hose Connection - Engine Compartment
8.5 Fuel Line Hose Connection - Deutz Diesel Engine
8.6 Hydraulic Hose Connection - Base And Axles
8.7 Turret Grease Hose Connections
9.0 Optional Equipments
9.1 Air Hose To Platform Option
9.2 3500w Generator And Oil Cooler Hardware
9.3 Hydraulic Hose Connection - 3500w Generator And Oil Cooler
9.4 3500w Generator Manifold Assembly
9.5 110v Generator Cable Assembly (Ansi/Csa)
9.6 Generator And Oil Cooler Harnesses
9.7 Generator Wire Assemblies
9.8 12 Kw Generator And Oil Cooler Hardware
9.9 Hydraulic Hose Connection - 12kw Generator And Oil Cooler
9.10 12 Kw Generator Manifold Assembly
9.11 Circuit Breaker Assembly - 12kw Generator
9.12 Generator Wire Assemblies - 12kw Generator
9.13 Welder And Mounting Assembly
9.14 Glazier Package Option
9.15 Cold Start Engine Option
9.16 Arctic Package Option
9.17 Arctic Rotary Actuator Assembly
9.18 Diesel Scrubber Option
9.19 Work Light Assembly
9.20 External Platform Railing Assembly
10.0 Labels And Nameplates
10.1 Labels And Nameplates
10.2 Labels - Platform Control Console
10.3 Labels - Front And Bottom
10.4 Labels - Engine Side
10.5 Labels - Controls Side
10.6 Labels - Controls Compartment
10.7 Labels - Engine Compartment
10.8 Labels - Operator Platform
10.9 Labels - Engine Fuel
11.0 Tables
11.1 Boom Fluids Table
11.2 Boom Grease Locations - Axle Grease Table
11.3 Boom Grease Locations - Gear Grease Table
