Skyjack Telescopic Booms SJ61T SJ66T Parts Manual 143870AK 2022
Brand: Skyjack
Type of Machine: Telescopic Booms
Model: Skyjack SJ61T, SJ66T Telescopic Booms
Serial Number: 97000001 to 97000418
Part Number: 143870AK
Publication Date: 2022
Number of Pages: 226 Pages
Section 1 – Platform
1.1 Railing Assemblies - Side Gate
1.2 Railing Assemblies - Back Gate (Ce)
1.3 Gate Assembly
1.4 Footswitch Assembly
1.5 Platform Base Assembly (Ansi/Csa)
1.6 Platform Base Assembly (Ce)
1.7 Platform Control Console Assembly
1.8 Boom / Turret Controller Assembly (Dual Axis)
1.9 Drive / Steer Controller Assembly (Single Axis)
1.10 Platform Terminal Strip
Section 2 – Boom
2.1 Boom Assembly Hardware
2.2 Main Boom Assembly
2.3 Fly Boom Assembly
2.4 Mid Boom Assembly
2.5 Power Track Carrier Assembly
2.6 Power Track - Support Mounts
2.7 Limit Switch Box Assembly
2.8 Jib Assembly - Sj66t
2.9 Rotary Actuator Mounting - Sj61t
2.10 Jib Lift / Platform Rotate Valve Assemblies
Section 3 – Cylinders
3.1 Extension Cylinder Hardware
3.2 Extension Cylinder Assembly
3.3 Lift And Master Cylinder Hardware
3.4 Lift Cylinder Assembly
3.5 Master Cylinder Assembly
3.6 Slave Cylinder Assembly
3.7 Jib Cylinder Assembly
3.8 Axle Lockout Cylinder Assembly
Section 4 – Turret
4.1 Cowling Assembly - Engine Side
4.2 Cowling Assembly - Control Side
4.3 Cowling Assembly - Center
4.4 Turret Assembly
4.5 High Pressure Filter Assembly
4.6 Charge Filter Assembly
4.7 Main Manifold Assembly
4.8 Brake Manifold Assembly
4.9 Manifold Mounting Hardware
4.10 Rotary Manifold (Dual Mount Brackets)
4.11 Rotary Manifold (Single Mount Bracket)
4.12 Hydraulic Tank Assembly
4.13 No Generator And Oil Cooler Hose Fittings
4.14 Turret Swing Drive Assembly
4.15 Fuel Tank Assembly (Gm Dual Fuel Engine)
4.16 Fuel Tank Assembly (Deutz Engine)
4.17 Battery And Lockout Switch Assembly
4.18 Emergency Power Unit
4.19 Base Control Console Assembly (Deutz Engine)
4.20 Base Control Console Assembly (Gm Engine)
4.21 Base Terminal Strip
Section 5 – Electrical Harnesses
5.1 Main Electrical Harness
5.2 Cable Harnesses
5.3 Control Cable Harnesses
5.4 Valve Harnesses And Limit Switches
5.5 110/220v Outlet Harness
5.6 Ecu Harnesses
5.7 Glow Plug And Egr Harness (Deutz Diesel Engine)
5.8 Engine Interface Harness (Gm Engine)
Section 6 – Base
6.1 Base Assembly
6.2 Counterweight
6.3 Axle Hardware
6.4 Rear Axle With Gear Box
6.5 Differential - Rear Axle
6.6 Central Housing - Rear Axle
6.7 Gear Box (Rear Axle)
6.8 Hydraulic Drive Motor
6.9 Front Axle
6.10 Differential - Front Axle
6.11 Central Housing - Front Axle
6.12 Steering Assembly
6.13 Trunnion - Front Axle
6.14 Axle Drive Shaft (4wd)
6.15 Brakes - Front & Rear Axle
6.16 Propane Tank Assembly
6.17 Tires
Section 7 – Engines
7.1 Engine Assembly (Deutz Diesel Engine)
7.2 Engine Coupling Assembly, S/N 97 000 413 & Above
7.3 Engine Coupling Assembly, S/N 97 000 412 & Below
7.4 Engine Assembly (Gm Dual Fuel Engine)
7.5 Engine Tray Assembly
7.6 Drive Pump Assembly
7.7 System Pump Assembly
Section 8 – Hose Connections
8.1 Standard Hose Numbering System
8.2 Hydraulic Hose Connection - Cylinders
8.3 Hydraulic Hose Connection - Control Compartment
8.4 Hydraulic Hose Connection - Engine Compartment
8.5 Fuel Line Hose Connection - Deutz Diesel Engine
8.6 Hydraulic Hose Connection - Base And Axles
8.7 Turret Grease Hose Connections
Section 9 – Optional Equipment
9.1 Air Hose To Platform Option
9.2 3500w Generator And Oil Cooler Hardware
9.3 Hydraulic Hose Connection - 3500w Generator And Oil Cooler
9.4 3500w Generator Manifold Assembly
9.5 110v Generator Cable Assembly (Ansi/Csa)
9.6 Generator And Oil Cooler Harnesses
9.7 Generator Wire Assemblies
9.8 12 Kw Generator And Oil Cooler Hardware
9.9 Hydraulic Hose Connection - 12kw Generator And Oil Cooler
9.10 12 Kw Generator Manifold Assembly
9.11 Circuit Breaker Assembly - 12kw Generator
9.12 Generator Wire Assemblies - 12kw Generator
9.13 Welder And Mounting Assembly
9.14 Glazier Package Option
9.15 Cold Start Engine Option
9.16 Arctic Package Option
9.17 Arctic Rotary Actuator Assembly
9.18 Diesel Scrubber Option
Section 10 – Labels
10.1 Label Kits
10.2 Labels - Boom (Platform Control Console)
10.3 Labels - Boom (Front)
10.4 Labels - Boom (Engine Side)
10.5 Labels - Boom (Control Side)
10.6 Labels - Compartments (Engine)
10.7 Labels - Compartments (Control)
10.8 Labels - Boom (Railing)
10.9 Labels - Fuel
Section 11 – Tables
11.1 Boom Fluids Table
11.2 Boom Grease Locations - Axle Grease Table
11.3 Boom Grease Locations - Gear Grease Table
Brand: Skyjack
1.3 Gate Assembly
Section 2 – Boom
Section 4 – Turret
4.4 Turret Assembly
5.2 Cable Harnesses
5.6 Ecu Harnesses
Section 6 – Base
6.1 Base Assembly
6.2 Counterweight
6.3 Axle Hardware
6.9 Front Axle
6.17 Tires
Section 7 – Engines
Section 10 – Labels
10.1 Label Kits
10.9 Labels - Fuel
Section 11 – Tables
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
