Skyjack Telescopic Booms SJ40T to SJ66T Operating Manual 143852AB 2010
Brand: Skyjack
Type of Machine: Telescopic Booms
Type of Manual: Operating Manual
Model: Skyjack SJ40T, SJ45T, SJ61T, SJ66T Telescopic Booms
Serial Number:
SJ40T, SJ45T 98000522 & Above
SJ61T, SJ66T 97000001 & Above
Part Number: 143852AB
Publication Date: 2010
Number of Pages: 92 Pages
Section 1 - About Your Aerial Platform
Read and Heed
Aerial Platform Definition
Purpose of Equipment
Use of Equipment
Manual
Operator
Service Policy and Warranty
Optional Accessories
Scope of this Manual
Safety Rules
Operator Safety Reminders
Electrocution Hazard
Safety Precautions
Section 2 - Operation
2.1 General
2.1-1 Operator Qualifications
2.1-2 Operator’s Responsibility for Maintenance
2.1-3 Maintenance and Inspection Schedule
2.1-4 Owner’s Inspections
2.2 Major Components
2.3 Major Assemblies
2.3-1 Base
2.3-2 Turret
2.3-3 Boom Assembly
2.3-4 Platform
2.4 Serial Number Nameplate
2.5 Component Identification
2.5-1 Drive Bypass Valve
2.5-2 Main Power Disconnect Switch
2.5-3 Brake System
2.5-4 Tilt Switch
2.5-5 Turret Transportation Lock
2.5-6 All Motion Alarm
2.5-7 Footswitch
2.5-8 Manual Storage Box
2.5-9 Base Control Console
2.5-10 Platform Control Console
2.6 Special Options
2.6-1 Tire Sealant (If Equipped)
2.6-2 AC Outlet on Platform (If Equipped)
2.6-3 Cold Weather Start (If Equipped)
2.6-4 Flashing Amber Light (If Equipped)
2.6-5 Work Light (If Equipped)
2.6-6 Glazier Tray (If Equipped)
2.6-7 Welder (If Equipped)
2.6-8 Arctic Weather Package (If Equipped)
2.7 Operator’s Responsibility
2.8 Visual and Daily Maintenance Inspections
2.9 Function Tests
2.10 Start Operation
2.10-1 To Activate Base Control Console
2.10-2 To Rotate Platform Using Base Control Console
2.10-3 To Rotate Turret Using Base Control Console
2.10-4 To Move Jib Up and Down Using Base Control Console (If Equipped)
2.10-5 To Raise or Lower Main Boom Using Base Control Console
2.10-6 To Extend or Retract Fly Boom Using Base Control Console
2.10-7 To Level Platform Using Base Control Console
2.10-8 To Operate Using Emergency Power Switch at Base Control Console
2.10-9 To Activate Platform Control Console
2.10-10 To Drive Forward or Reverse Using Platform Control Console
2.10-11 To Steer Using Platform Control Console
2.10-12 To Move Jib Up and Down Using Platform Control Console (If Equipped)
2.10-13 To Extend or Retract Fly Boom Using Platform Control Console
2.10-14 To Level Platform Using Platform Control Console
2.10-15 To Rotate Platform Using Platform Control Console
2.10-16 To Raise or Lower Main Boom Using Platform Control Console
2.10-17 To Rotate Turret Using Platform Control Console
2.10-18 To Sound Horn
2.10-19 To Operate Using Emergency Power Switch at Platform Control Console
2.10-20 Shutdown Procedure
2.10-21 Hydraulic Generator (If Equipped)
2.10-22 To Switch Driving Light On (If Equipped)
2.10-23 Glazier Tray (If Equipped)
2.10-24 Arctic Weather Package (If Equipped)
2.11 Refueling Procedure
2.11-1 Regular Fuel (Gasoline or Diesel)
2.12 Loading/Unloading
2.12-1 Loading and Tie-down
2.12-2 Locking the Turret
2.12-3 Lifting
2.13 Winching and Towing Procedure
2.13-1 To Release Brakes Manually
2.14 Emergency Lowering Procedures
2.15 Chassis Tilt
2.15-1 Counterweight Uphill
2.15-2 Counterweight Downhill
2.16 Diagrams
2.17 Tables
2.18 Labels
List of Tables
2.1 Standard and Optional Features
2.2 Specifications and Features
2.3 Owner’s Annual Inspection Record
2.4 Tire/Wheel Specifications
2.5 Floor Loading Pressure
2.6 Maintenance and Inspection Schedule
2.7 Operator’s Checklist
Brand: Skyjack
Serial Number:
Read and Heed
Use of Equipment
Manual
Operator
Safety Rules
Safety Precautions
2.1 General
2.3-1 Base
2.3-2 Turret
2.3-3 Boom Assembly
2.3-4 Platform
2.5-3 Brake System
2.5-4 Tilt Switch
2.5-7 Footswitch
2.6 Special Options
2.9 Function Tests
2.12-3 Lifting
2.15 Chassis Tilt
2.16 Diagrams
2.17 Tables
2.18 Labels
List of Tables
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
