Skyjack Telescopic Booms SJ40T+ SJ45T+ Service Manual 229038AFA 2023
Brand: Skyjack
Type of Machine: Telescopic Booms
Type of Manual: Service Manual, Electrical Schematic, Hydraulic Schematic
Model: Skyjack SJ40T+, SJ45T+ Telescopic Booms
Serial Number: A400000001 - A400000262
Part Number: 229038AFA
Publication Date: 2023
Number of Pages: 220 Pages
Section 1 – Scheduled Maintenance
1.1 Read and Heed
1.2 Maintenance and Service
1.3 Scheduled Maintenance
1.4 Owner’s Annual Inspection Record
1.5 Pre-Delivery/Maintenance Inspection Checklist
1.6 Scheduled Maintenance Inspections
1.7 Function Tests
Section 2 – Maintenance Tables and Diagrams
2.1 Standard Hose Numbering System
2.2 MEWP Torque Specifications
2.3 Axle Torque Specifications
2.4 Torque Specifications for Fasteners (US)
2.5 Torque Specifications for Fasteners (Metric)
2.6 Torque Specifications for Hydraulic Couplings & Hoses
2.7 Axles Maintenance Intervals
2.8 Tire Specifications
2.9 Floor Loading Pressure
2.10 Hydraulic Specifications
2.11 Hydraulic & Gear Oils
2.12 Platform Capacities
2.13 Specifications and Features - Dimensional Data
2.14 Specifications and Features - Performance and Speeds
2.15 Engine Specifications
2.16 Reach Diagram - SJ40 T+
2.17 Dimensions - SJ40 T+
2.18 Reach Diagram - SJ45 T+
2.19 Dimensions - SJ45 T+
2.20 Axle Oscillation Diagrams
Section 3 – System Component Identification and Schematics
3.1 Electrical Symbol Chart
3.2 Hydraulic Symbol Chart
3.3 Wire Number and Colour Chart
3.4 Hydraulic Parts List
3.5 Electrical Component Parts List
3.6 Rotary Manifold Port Identification
3.7 Brake Manifold Port Identification
3.8 System Pump Port Identification
3.9 Drive Pump Port Identification
3.10 Drive Motor Port Identification
3.11 Jib & Platform Rotate Valve Port Identification - SJ45 T+
3.12 Platform Rotate Valve Port Identification - SJ40 T+
3.13 Main Manifold Port Identification
3.14 Main Manifold Electrical Component Identification
3.15 Main Manifold Hydraulic Component Identification
3.16 Major Components
3.17 Main Harness Wiring Diagram
3.18 Engine Interface Harness - Deutz D2.2
3.19 ECU Engine Wiring Diagram - Deutz D2011
3.20 Engine Interface Harness - Deutz D2.9L
3.21 Engine Interface Harness - Kubota WG2503
3.22 Glow Plug Harness - Deutz D2.9L
3.23 Glow Plug Harness - Deutz D2011
3.24 Jib and Platform Rotate Harnesses
3.25 Limit Switch Connections
3.26 Flashing Light Connection
3.27 Oil Cooler Harness Connections
3.28 Generator Wire Kit Connections
3.29 Differential Lock Harness
3.30 SGE Wiring Diagram
3.31 SGE Connections
3.32 Moba Load Cell Connections - ANSI/CSA
3.33 Footswitch Connections
3.34 CANbus Cable Connections
3.35 Power Cable Connections
3.36 Hydraulic Schematic
3.37 Platform Controls Wiring - SJ40 T+
3.38 Platform Controls Wiring - SJ45 T+
3.39 Base Controls Wiring - SJ40 T+
3.40 Base Controls Wiring - SJ40 T+ with Positive Air Shut-Off Option
3.41 Base Controls Wiring - SJ45 T+ ANSI/CSA & AS
3.42 Base Controls Wiring - SJ45 T+ ANSI/CSA & AS with Positive Air Shut-Off Option
3.43 Base Controls Wiring - SJ45 T+ CE
3.44 Electrical Schematic - ANSI/CSA & AS
3.45 Electrical Schematic - CE
3.46 Interface & Engine Electrical Schematic - Deutz TD2.9L & D2.2
3.47 Interface & Engine Electrical Schematic - Deutz D2011
3.48 Interface & Engine Electrical Schematic - Kubota WG2503
3.49 OEM Engine Harness - Deutz D2.2
Section 4 – Troubleshooting Information
4.1 Introduction
4.2 Electrical System
4.3 Hydraulic System
Section 5 – Procedures
5.1 General
5.2 Platform
5.3 Boom
5.4 Turret
5.5 Deutz Diesel Engines
5.6 Kubota WG2503 Dual Fuel Engine
5.7 Hydraulic Tank
5.8 Manifold and Hydraulic Pumps
5.9 Axles
5.10 Grease Points
5.11 Options
Brand: Skyjack
1.1 Read and Heed
1.7 Function Tests
4.1 Introduction
5.1 General
5.2 Platform
5.3 Boom
5.4 Turret
5.7 Hydraulic Tank
5.9 Axles
5.10 Grease Points
5.11 Options
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
