Skyjack Telescopic Booms SJ40T SJ45T Service Manual 207563AL 2023
Brand: Skyjack
Type of Machine: Telescopic Booms
Type of Manual: Service Manual, Electrical Schematic, Hydraulic Schematic
Model: Skyjack SJ40T, SJ45T Telescopic Booms
Serial Number: 98001767 to 98999999
Part Number: 207563AL
Publication Date: 2023
Number of Pages: 261 Pages
Section 1 – Scheduled Maintenance
1.1 Read and Heed
1.2 Maintenance and Service
1.3 Scheduled Maintenance
1.4 Owner’s Annual Inspection Record
1.5 Pre-Delivery/Maintenance Inspection Checklist
1.6 Scheduled Maintenance Inspections
1.7 Function Tests
Section 2 – Maintenance Tables and Diagrams
2.1 Standard Hose Numbering System
2.2 Aerial Platform Torque Specifications
2.3 Axle Torque Specifications
2.4 Torque Specifications for Fasteners (US)
2.5 Torque Specifications for Fasteners (Metric)
2.6 Torque Specifications for Hydraulic Couplings & Hoses
2.7 Axles Maintenance Intervals
2.8 Tire Specifications
2.9 Floor Loading Pressure
2.10 Hydraulic Specifications & Gear Oil
2.11 Specifications and Features - Dimensional Data
2.12 Specifications and Features - Performance and Speeds
2.13 Engine Specifications
2.14 Dimension and Reach Diagram - SJ40T
2.15 Dimension and Reach Diagram - SJ45T
2.16 Axle Oscillation Diagrams
Section 3 – System Component Identification and Schematics
3.1 Electrical Symbol Chart
3.2 Hydraulic Symbol Chart
3.3 Wire Number and Color Code
3.4 Hydraulic Parts List
3.5 Electrical Component Parts List
3.6 Rotary Manifold Port Identification
3.7 Brake Manifold Port Identification
3.8 System Pump Port Identification
3.9 Drive Pump Port Identification
3.10 Drive Motor Port Identification
3.11 Jib Valve Port Identification - SJ45T
3.12 No Jib Valve Port Identifications - SJ40T
3.13 Main Manifold Port Identification
3.14 Main Manifold Electrical Component Identification
3.15 Main Manifold Hydraulic Component Identification
3.16 Main Harness Wiring Diagram
3.17 ECU Engine Wiring Diagram - Deutz D2011
3.18 Engine Interface Harness - Deutz D2.9L
3.19 Engine Interface Harness - Kubota WG2503
3.20 Glow Plug Harness - Deutz D2.9L
3.21 Glow Plug Harness - Deutz D2011
3.22 Platform Harnesses
3.23 Platform Control Cables
3.24 Limit Switch Connections
3.25 Load Sensing Cable Connection (CE & AS)
3.26 Flashing Light Connection
3.27 Oil Cooler Harness Connections
3.28 Generator Wire Kit Connections
3.29 Load Circuit Wiring
3.30 SGE Schematic
3.31 SGE Platform Control Box Wiring Diagram
3.32 Differential Lock Harness
3.33 Hydraulic Schematic - S/N 98 002 633 and above
3.34 Hydraulic Schematic - S/N 98 002 632 and below
3.35 Platform Controls Wiring - SJ40T ANSI/CSA Kubota
3.36 Platform Controls Wiring - SJ40T ANSI/CSA Deutz & Perkins
3.37 Platform Controls Wiring - SJ45T ANSI/CSA Kubota
3.38 Platform Controls Wiring - SJ45T ANSI/CSA Deutz & Perkins
3.39 Platform Controls Wiring - SJ45T CE Deutz
3.40 Platform Controls Wiring - SJ45T AS Deutz
3.41 Base Controls Wiring - SJ40T ANSI/CSA Kubota
3.42 Base Controls Wiring - SJ40T ANSI/CSA Deutz D2011
3.43 Base Controls Wiring - SJ40T ANSI/CSA Deutz D2011 with Positive Air Shut-Off Option
3.44 Base Controls Wiring - SJ40T ANSI/CSA Deutz D2.9L
3.45 Base Controls Wiring - SJ40T ANSI/CSA Deutz D2.9L with Positive Air Shut-Off Option
3.46 Base Controls Wiring - SJ40T ANSI/CSA Perkins
3.47 Base Controls Wiring - SJ45T ANSI/CSA Kubota
3.48 Base Controls Wiring - SJ45T ANSI/CSA Deutz D2011
3.49 Base Controls Wiring - SJ45T ANSI/CSA Deutz D2011 with Positive Air Shut-Off Option
3.50 Base Controls Wiring - SJ45T ANSI/CSA Deutz D2.9L
3.51 Base Controls Wiring - SJ45T ANSI/CSA Deutz D2.9L with Positive Air Shut-Off Option
3.52 Base Controls Wiring - SJ45T ANSI/CSA Perkins
3.53 Base Controls Wiring - SJ45T CE Deutz D2.2
3.54 Base Controls Wiring - SJ45T CE Deutz D2011
3.55 Base Controls Wiring - SJ45T AS Deutz D2011
3.56 Electrical Schematic - ANSI/CSA Kubota (S/N 98003579 and below)
3.57 Electrical Schematic - ANSI/CSA Kubota (S/N 98003580 and above)
3.58 Electrical Schematic - ANSI/CSA Deutz D2011 (S/N 98003579 and below)
3.59 Electrical Schematic - ANSI/CSA Deutz D2011 (S/N 98003580 and above)
3.60 Electrical Schematic - ANSI/CSA Deutz D2.9L (S/N 98003579 and below)
3.61 Electrical Schematic - ANSI/CSA Deutz D2.9L (S/N 98003580 and above)
3.62 Electrical Schematic - ANSI Perkins (S/N 98003579 and below)
3.63 Electrical Schematic - ANSI Perkins (S/N 98003580 and above)
3.64 Electrical Schematic - CE Deutz D2.2
3.65 Electrical Schematic - CE Deutz D2011 (S/N 98003579 and below)
3.66 Electrical Schematic - CE Deutz D2011 (S/N 98003580 and above)
3.67 Electrical Schematic - AS Deutz D2011 (S/N 98003579 and below)
3.68 Electrical Schematic - AS Deutz D2011 (S/N 98003580 and above)
3.69 Interface & Engine Electrical Schematic - Kubota WG2503
3.70 Interface & Engine Electrical Schematic - Deutz D2.9L
3.71 Interface & Engine Electrical Schematic - Deutz D2.2
3.72 OEM Engine Harness - Deutz D2.2
3.73 Engine Interface Harness Schematic - Perkins
3.74 Engine OEM Harness Schematic - Perkins
3.75 Engine Component Harness Schematic - Perkins
Section 4 – Troubleshooting Information
4.1 Introduction
4.2 Electrical System
4.3 Hydraulic System
4.4 Load Sensing System - CE
Section 5 – Procedures
5.1 General
5.2 Platform
5.3 Boom
5.4 Turret
5.5 Deutz Diesel Engines
5.6 Kubota WG2503 Dual Fuel Engine
5.7 Hydraulic Tank
5.8 Manifold and Hydraulic Pumps
5.9 Axles
5.10 Grease Points
5.11 Options
Brand: Skyjack
1.1 Read and Heed
1.7 Function Tests
3.30 SGE Schematic
4.1 Introduction
5.1 General
5.2 Platform
5.3 Boom
5.4 Turret
5.7 Hydraulic Tank
5.9 Axles
5.10 Grease Points
5.11 Options
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
