Skyjack Telescopic Booms SJ40T+ SJ45T+ Parts Manual 238270AEA 2023
Brand: Skyjack
Type of Machine: Telescopic Booms
Model: Skyjack SJ40T+, SJ45T+ Telescopic Booms
Serial Number: A400000263 - A400099999
Part Number: 238270AEA
Publication Date: 2023
Number of Pages: 206 Pages
Recommended Service Parts
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Section 1 – Platform
1.1 Platform with Drop Bars
1.2 Platform with Swing Gate
1.3 Railings
1.4 Platform Base
1.5 Drop Bar Gate
1.6 Swing Gate
1.7 Platform Control Box
1.8 Boom / Turret Controller
1.9 Drive / Steer Controller
1.10 Platform Terminal Strip
1.11 SGE
1.12 Footswitch
1.13 Power to Platform - ANSI/CSA
1.14 Power to Platform - CE & AS
Section 2 – Boom
2.1 Boom
2.2 Cable Track
2.3 Limit Switches
2.4 Jib Lift / Platform Rotate Valve
2.5 Jib - SJ45 T+
2.6 Rotary Actuator Mount - SJ40 T+
2.7 Rotary Actuator
2.8 Extension Cylinder Support
Section 3 – Cylinders
3.1 Lift Cylinder
3.2 Extension Cylinder
3.3 Master Cylinder
3.4 Slave Cylinder
3.5 Jib Cylinder
3.6 Axle Lock Cylinder
Section 4 – Turret
4.1 Turret
4.2 Cowling - Engine Side
4.3 Cowling - Controls Side
4.4 Cowling - Centre
4.5 Counterweights
4.6 Lift Cylinder Bracket
4.7 High Pressure Filter
4.8 Grease Line
4.9 Swing Drive
4.10 Auxiliary Pump
4.11 Manifold Hardware
4.12 Main Manifold
4.13 Brake Manifold
4.14 Rotary Manifold
4.15 Hydraulic Tank
4.16 Fuel Tank
4.17 Battery
4.18 Base Control Box
4.19 Base Terminal Strip
Section 5 – Base
5.1 Base
5.2 Front Axle
5.3 Central Housing - Front Axle
5.4 Differential - Front Axle
5.5 Hub Reduction - Front Axle
5.6 Steering - Front Axle
5.7 Trunnion - Front Axle
5.8 Rear Axle
5.9 Central Housing - Rear Axle
5.10 Differential - Rear Axle
5.11 Hub Reduction - Rear Axle
5.12 Brakes - Rear Axle
5.13 Gear Box
5.14 Tires
Section 6 – Engines
6.1 Kubota D1305 Engine
6.2 Air Intake & Exhaust
6.3 Fuel Lines
6.4 Drive & System Pumps
6.5 Flywheel Housing
Section 7 – Electrical Harnesses
7.1 Main Electrical Harness
7.2 Engine Harness
7.3 Engine Fuse Box
7.4 Battery Cables
7.5 Control & CANbus Cables
7.6 Jib and Platform Rotate Harnesses
7.7 Differential Lock Valve Harness
Section 8 – Hydraulic Hoses
8.1 Standard Hose Numbering System
8.2 Boom Hoses
8.3 Control Compartment Hoses
8.4 Engine Compartment Hoses
8.5 Base & Axle Hoses
Section 9 – Optional Equipment
9.1 Welder and Mount
9.2 Generator - 3.5 kW
9.3 Generator - 7.5 kW
9.4 Oil Quick Drain
9.5 Flashing Amber Light
9.6 External Railing
9.7 Pipe Rack
9.8 Glazier Rack
9.9 Control Box Cover
9.10 Tool Caddy
9.11 Half-Height Platform Mesh
9.12 Positive Air Shut-off
9.13 White Noise Alarm
9.14 Elevate Telematics
9.15 Elevate Telematics Subscription
Section 10 – Labels
10.1 Label Kit
10.2 Labels - Front and Back
10.3 Labels - Engine Side
10.4 Labels - Controls Side
10.5 Labels - Control Compartment
10.6 Labels - Engine Compartment
10.7 Labels - Platform
Brand: Skyjack
Foreword
General
Method of Listing
Quantities
1.3 Railings
1.4 Platform Base
1.5 Drop Bar Gate
1.6 Swing Gate
1.11 SGE
1.12 Footswitch
Section 2 – Boom
2.1 Boom
2.2 Cable Track
2.3 Limit Switches
2.5 Jib - SJ45 T+
2.7 Rotary Actuator
3.1 Lift Cylinder
3.3 Master Cylinder
3.4 Slave Cylinder
3.5 Jib Cylinder
Section 4 – Turret
4.1 Turret
4.5 Counterweights
4.8 Grease Line
4.9 Swing Drive
4.10 Auxiliary Pump
4.12 Main Manifold
4.13 Brake Manifold
4.15 Hydraulic Tank
4.16 Fuel Tank
4.17 Battery
Section 5 – Base
5.1 Base
5.2 Front Axle
5.8 Rear Axle
5.13 Gear Box
5.14 Tires
Section 6 – Engines
6.3 Fuel Lines
7.2 Engine Harness
7.3 Engine Fuse Box
7.4 Battery Cables
8.2 Boom Hoses
9.4 Oil Quick Drain
9.7 Pipe Rack
9.8 Glazier Rack
9.10 Tool Caddy
Section 10 – Labels
10.1 Label Kit
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
