118
6,911
Skyjack Telescopic Booms SJ40T+ SJ45T+ Parts Manual 229031AFA 2023
Brand: Skyjack
Type of Machine: Telescopic Booms
Model: Skyjack SJ40T+, SJ45T+ Telescopic Booms
Serial Number: A400000001 - A400000262
Part Number: 229031AFA
Publication Date: 2023
Number of Pages: 274 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Recommended Service Parts
Section 1 – Platform
1.1 Platform with Drop Bars
1.2 Platform with Swing Gate
1.3 Railings
1.4 Platform Base
1.5 Drop Bar Gate
1.6 Swing Gate
1.7 Platform Control Box
1.8 Boom / Turret Controller
1.9 Drive / Steer Controller
1.10 Platform Terminal Strip
1.11 Footswitch
1.12 Power to Platform - Outlet and Plugs - CE
1.13 Outlet - 110/220V
Section 2 – Boom
2.1 Boom
2.2 Cable Track
2.3 Limit Switches
2.4 Jib Lift / Platform Rotate Valve
2.5 Jib - SJ45 T+
2.6 Rotary Actuator Mount - SJ40 T+
2.7 Rotary Actuator
2.8 Extension Cylinder Support
Section 3 – Cylinders
3.1 Lift Cylinder
3.2 Extension Cylinder
3.3 Master Cylinder
3.4 Slave Cylinder
3.5 Jib Cylinder
3.6 Axle Lock Cylinder
Section 4 – Turret
4.1 Turret
4.2 Cowling - Engine Side
4.3 Cowling - Controls Side
4.4 Cowling - Centre
4.5 Counterweight
4.6 Lift Cylinder Bracket
4.7 High Pressure Filter
4.8 Swing Drive
4.9 Auxiliary Pump
4.10 Manifold Hardware
4.11 Main Manifold
4.12 Brake Manifold
4.13 Rotary Manifold
4.14 Hydraulic Tank
4.15 Fuel Tank - Kubota
4.16 Fuel Tank - Deutz
4.17 Battery
4.18 Base Control Box
4.19 Mircro Relay Mount - Deutz
4.20 Base Terminal Strip
Section 5 – Electrical Harnesses
5.1 Main Electrical Harness
5.2 Interface Harness
5.3 Battery Cables
5.4 Control and CANbus Cables
5.5 Jib and Platform Rotate Harnesses
5.6 ECU Harnesses
5.7 Glow Plug Harness - Deutz D2.9L
5.8 Glow Plug Harness - Deutz D2.2
5.9 Glow Plug Harness - Deutz D2011
5.10 Engine Interface Harness - Deutz D2.9L
5.11 Engine Interface Harness - Deutz D2.2
5.12 Engine Interface Harness - Kubota WG2503
5.13 Differential Lock Valve Harness
Section 6 – Base
6.1 Base
6.2 Front Axle
6.3 Central Housing - Front Axle
6.4 Differential - Front Axle
6.5 Hub Reduction - Front Axle
6.6 Steering - Front Axle
6.7 Trunnion - Front Axle
6.8 Rear Axle
6.9 Central Housing - Rear Axle
6.10 Differential - Rear Axle
6.11 Hub Reduction - Rear Axle
6.12 Brakes - Rear Axle
6.13 Gear Box
6.14 Propane Tanks
6.15 Tires
Section 7 – Engines
7.1 Deutz D2.9L Engine
7.2 Radiator - Deutz D2.9L
7.3 Air Intake - Deutz D2.9L
7.4 Deutz D2.2 Engine
7.5 Radiator - Deutz D2.2
7.6 Air Intake - Deutz D2.2
7.7 Deutz D2011 Engine
7.8 Air Intake - Deutz D2011
7.9 Kubota WG2503 Engine
7.10 Kubota WG2503 Engine Accessories
7.11 Radiator & Air Intake - Kubota WG2503
7.12 Drive & System Pumps
7.13 Engine Coupling - Deutz
7.14 Engine Coupling - Kubota WG2503
Section 8 – Hose Connections
8.1 Standard Hose Numbering System
8.2 Hydraulic Hoses - Boom
8.3 Hydraulic Hoses - Control Compartment
8.4 Hydraulic Hoses - Engine Compartment
8.5 Hydraulic Hoses - Base & Axles
8.6 Fuel Lines - Deutz D2.9L & D2.2 Engines
8.7 Fuel Lines - Deutz D2011 Engine
8.8 Fuel Lines - Kubota WG2503
8.9 Propane Lines - Kubota WG2503
8.10 Grease Line
Section 9 – Optional Equipment
9.1 Air Hose To Platform
9.2 Flashing Amber Light
9.3 Generator and Oil Cooler - 3.5 kW
9.4 Oil Cooler
9.5 Generator - 3.5 kW
9.6 Generator and Oil Cooler Wiring
9.7 Generator and Oil Cooler Hoses - 3.5 kW
9.8 Generator and Oil Cooler - 7.5 kW
9.9 Generator and Oil Cooler - 12 kW
9.10 Generator - 12 kW
9.11 Generator and Oil Cooler Hoses - 12 kW
9.12 Welder and Mount
9.13 Cold Start
9.14 Arctic Package
9.15 Cold and Arctic Load Circuit - Deutz D2.9L
9.16 Block Heater
9.17 Oil Quick Drain
9.18 Diesel Scrubber - Deutz D2011
9.19 External Railing
9.20 Glazier Rack
9.21 SGE - Secondary Guarding
9.22 Control Box Cover
9.23 Positive Air Shut-off
9.24 Work Lights
9.25 Tool Caddy
9.26 Half-Height Platform Mesh
9.27 Elevate Telematics
9.28 Elevate Telematics Subscription
9.29 Pipe Rack
Section 10 – Labels
10.1 Label Kit
10.2 Labels - Front and Back
10.3 Labels - Engine Side
10.4 Labels - Controls Side
10.5 Labels - Controls Compartment
10.6 Labels - Engine Compartment
10.7 Labels - Fuel
10.8 Labels - Platform
