Skyjack Telescopic Booms SJ40T SJ45T Parts Manual 168891AH 2022
Brand: Skyjack
Type of Machine: Telescopic Booms
Model: Skyjack SJ40T, SJ45T Telescopic Booms
Serial Number: 98001331 - 98001500
Part Number: 168891AH
Publication Date: 2022
Number of Pages: 230 Pages
1.0 Platform
1.1 Platform
1.2 Railings
1.3 Platform Base (Ansi/Csa)
1.4 Platform Base (Ce & As)
1.5 Swing Gate
1.6 Drop Bar Gate
1.7 Railing Extension (No Gate)
1.8 Footswitch
1.9 Platform Control Box
1.10 Boom / Turret Controller (Dual Axis)
1.11 Drive / Steer Controller (Single Axis)
1.12 Platform Terminal Strip
2.0 Boom
2.1 Boom Assembly
2.2 Main & Fly Boom Assemblies
2.3 E-Chain Assembly
2.4 Jib Lift / Platform Rotate Valve Assembly
2.5 Jib Assembly - 45t
2.6 Rotary Actuator Mounting - 40t
2.7 Rotary Actuator Assembly
2.8 Extension Cylinder Support Assembly
3.0 Cylinders
3.1 Lift Cylinder Assembly
3.2 Extension Cylinder Assembly
3.3 Master Cylinder Assembly
3.4 Slave Cylinder Assembly
3.5 Jib Cylinder Assembly
3.6 Axle Lockout Cylinder Assembly
4.0 Turret
4.1 Turret Assembly
4.2 Cowling Assembly - Engine Side
4.3 Cowling Assembly - Controls Side
4.4 Cowling Assembly - Centre
4.5 Counterweight Assembly
4.6 Lift Cylinder Bracket Assembly
4.7 High Pressure Filter Assembly
4.8 Turret Swing Drive Assembly
4.9 Boom Lift Limit Switch
4.10 Manifold Hardware
4.11 Main Manifold Assembly
4.12 Brake Manifold
4.13 Rotary Manifold
4.14 Pressure Reducing Manifold
4.15 Hydraulic Tank Assembly
4.16 Fuel Tank (Gm Dual Fuel Engine)
4.17 Fuel Tank (Deutz Diesel Engine)
4.18 Auxiliary Pump Assembly
4.19 Battery Assembly
4.20 Base Control Console Assembly (Deutz D2.9l Engine)
4.21 Base Control Console Assembly (Deutz D2011 Engine)
4.22 Base Control Console Assembly (Gm Dual Fuel Engine)
4.23 Base Terminal Strip (Deutz D2.9l Engine)
4.24 Base Terminal Strip (Deutz D2011 & Gm Engines)
5.0 Electrical Harnesses
5.1 Main Electrical Harness
5.2 Battery Cables
5.3 Control Cables
5.4 Jib And Platform Rotate Harnesses
5.5 110/220v Outlet Cable
5.6 Ecu Harnesses
5.7 Glow Plug Harness (Deutz D2.9l)
5.8 Glow Plug Harness (Deutz D2011)
5.9 Engine Interface Harness (Deutz D2.9l)
5.10 Engine Interface Harness (Gm Engine)
6.0 Base
6.1 Base Assembly
6.2 Axle Assembly Hardware
6.3 Rear Axle Assembly With Gear Box
6.4 Differential Assembly
6.5 Central Housing Assembly
6.6 Gear Box - Rear Axle
6.7 Brakes - Rear Axle
6.8 Front Axle Assembly
6.9 Differential Assembly
6.10 Central Housing Assembly
6.11 Steering Assembly
6.12 Trunnion Assembly
6.13 Axle Drive Shaft
6.14 Propane Tank Assembly
6.15 Tires
7.0 Engines
7.1 Deutz D2.9l Engine
7.2 Deutz D2011 Engine
7.3 Gm Dual Fuel Engine
7.4 Drive & System Pumps
7.5 Engine Coupling - Deutz
8.0 Hose Connections
8.1 Standard Hose Numbering System
8.2 Hydraulic Hose Connection - Cylinders
8.3 Hydraulic Hose Connection - Control Compartment
8.4 Hydraulic Hose Connection - Engine Compartment
8.5 Hydraulic Hose Connection - Base And Axles
8.6 Fuel Line Hose Connection - Deutz D2.9l Engine
8.7 Fuel Line Hose Connection - Deutz D2011 Engine
8.8 Fuel Line Hose Connection - Gm Dual Fuel Engine
8.9 Hydraulic Hose Connection - Turret Grease Fittings
9.0 Optional Equipment
9.1 Air Hose To Platform Option
9.2 Flashing Amber Light Option
9.3 Generator And Oil Cooler - 3.5 Kw
9.4 Oil Cooler Assembly
9.5 110v Generator Cable Assembly (Ansi/Csa)
9.6 Generator And Oil Cooler Wiring
9.7 Hydraulic Hose Connection - Generator And Oil Cooler - 3.5 Kw
9.8 Generator And Oil Cooler Assembly - 12 Kw
9.9 Hydraulic Hose Connection - Generator And Oil Cooler - 12 Kw
9.10 Welder And Mounting Assembly
9.11 Cold Start Assembly
9.12 Arctic Package Assembly
9.13 Cold & Arctic Packages Load Circuit - Deutz D2.9l
9.14 Block Heater - Deutz D2.9l
9.15 Oil Quick Drain
9.16 Diesel Scrubber - Deutz D2011 Engine
9.17 External Railing Assembly
9.18 Glazier Rack Assembly
9.19 Sgm Assembly
9.20 Sge Assembly
9.21 Control Box Cover
10.0 Labels
10.1 Label Kit
10.2 Labels - Platform Control Box
10.3 Labels - Front And Back
10.4 Labels - Engine Side
10.5 Labels - Controls Side
10.6 Labels - Controls Compartment
10.7 Labels - Engine Compartment
10.8 Labels - Engine Fuel
10.9 Labels - Platform
11.0 Tables
11.1 Fluids Table
11.2 Turret And Axle Grease
11.3 Gear Grease
Brand: Skyjack
1.0 Platform
1.1 Platform
1.2 Railings
1.5 Swing Gate
1.6 Drop Bar Gate
1.8 Footswitch
2.0 Boom
2.1 Boom Assembly
3.0 Cylinders
4.0 Turret
4.1 Turret Assembly
4.12 Brake Manifold
5.2 Battery Cables
5.3 Control Cables
5.6 Ecu Harnesses
6.0 Base
6.1 Base Assembly
6.15 Tires
7.0 Engines
9.19 Sgm Assembly
9.20 Sge Assembly
10.0 Labels
10.1 Label Kit
11.0 Tables
11.1 Fluids Table
11.3 Gear Grease
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
