118
6,911
Skyjack Telescopic Booms SJ40T SJ45T Parts Manual 163736AF 2022
Brand: Skyjack
Type of Machine: Telescopic Booms
Model: Skyjack SJ40T, SJ45T Telescopic Booms
Serial Number: 98001047 to 98001141
Part Number: 163736AF
Publication Date: 2022
Number of Pages: 230 Pages
1.0 Platform Related Parts
1.1 Railing Assembly
1.2 Platform Base Assembly (Ansi/Csa)
1.3 Platform Base Assembly (Ce & As)
1.4 Footswitch Assembly
1.5 Gate Assembly - Swing
1.6 Gate Assembly - Drop Bar
1.7 Railing Extension (No Gate)
1.8 Platform Control Console Assembly Sj 40t
1.9 Platform Control Console Assembly Sj 45t
1.10 Boom / Turret Controller Assembly (Dual Axis)
1.11 Drive / Steer Controller Assembly (Single Axis)
1.12 Platform Terminal Strip
2.0 Boom Related Parts
2.1 Boom Assembly
2.2a Power Track Carrier Assembly
2.2b Power Track Carrier Assembly
2.2c Power Track Carrier Assembly
2.3 Main Boom Turret End Hardware
2.4 Main Boom Platform End Hardware
2.5 Fly Boom Platform End Hardware
2.6 Extension Cylinder Support Assembly
2.7a Valve Mounting Assembly
2.7b Valve Mounting Assembly
2.8 Work And Travel Limit Switch Mounting Assembly (Universal)
2.9 Jib Assembly - Sj 45t
2.10 Rotary Actuator Mounting - Sj 40t
2.11 Rotary Actuator Assembly
2.12 Jib Lift / Platform Rotate Valve Assemblies
3.0 Cylinder Related Parts
3.1 Lift Cylinder Assembly
3.2 Extension Cylinder Assembly
3.3 Master Cylinder Assembly
3.4 Slave Cylinder Assembly
3.5 Jib Cylinder Assembly
3.6 Axle Lockout Cylinder Assembly
4.0 Turret Related Parts
4.1 Cowling Assembly - Engine Side
4.2 Cowling Assembly - Controls Side
4.3 Cowling Assembly - Centre
4.4 Counterweight Assembly
4.5 Turret Assembly
4.6 Lift Cylinder Bracket Assembly
4.7a High Pressure Filter Assembly
4.7b High Pressure Filter Assembly
4.8 Turret Swing Drive Assembly
4.9 Axle Lockout Valve Assembly
4.10 Main Boom Pin Assembly
4.11 Main Control Valve Assembly
4.12 Brake Control Valve Assembly
4.13a Rotary Manifold
4.13b Rotary Manifold (With Propane Fittings)
4.14 Hydraulic Tank Assembly
4.15 Fuel Tank Assembly (Gm Dual Fuel Engine)
4.16 Fuel Tank Assembly (Deutz Engine)
4.17 Emergency Power Unit
4.18 Battery Assembly
4.19 Base Control Console Assembly (Deutz Engine)
4.20 Base Control Console Assembly (Gm Dual Fuel Engine)
4.21 Base Terminal Strip
4.22 Charge Pressure Filter Assembly
4.23 No Generator And Oil Cooler Hose Fitting
5.0 Electrical Harness Related Parts
5.1 Main Electrical Harness
5.2 Cable Harnesses
5.3 Control Cable Harnesses
5.4 Valve Harnesses And Limit Switch Assemblies
5.5 110/220v Outlet Harness
5.6 Ecu Harnesses
5.7 Glow Plug Harness
5.8 Engine Interface Harness (Gm Engine)
6.0 Base Related Parts
6.1 Base Assembly
6.2 Axle Assembly Hardware
6.3 Rear Axle Assembly With Gear Box
6.4 Differential Assembly (Rear Axle Assembly With Gear Box)
6.5 Central Housing Assembly (Rear Axle Assembly With Gear Box)
6.6 Gear Box - Rear Axle
6.7 Brakes - Rear Axle
6.8 Front Axle Assembly (2 Wheel Drive)
6.9 Front Axle Assembly (4 Wheel Drive)
6.10 Differential Assembly (4 Wheel Drive)
6.11 Central Housing Assembly (4 Wheel Drive)
6.12 Steering Assembly
6.13 Trunnion Assembly
6.14 Axle Drive Shaft (4wd)
6.15 Propane Tank Assembly
6.16 Tires
7.0 Engine Related Parts
7.1 Engine Assembly (Deutz Diesel Engine)
7.2 System Pump Assembly
7.3 Drive Pump Assembly
7.4 Engine Assembly (Gm Dual Fuel Engine)
7.5 Engine Coupling Assembly
8.0 Hose Connection Related Parts
8.1 Standard Hose Numbering System
8.2 Hydraulic Hose Connection - Cylinders
8.3 Hydraulic Hose Connection - Control Compartment
8.4 Hydraulic Hose Connection - Engine Compartment
8.5 Fuel Line Hose Connection - Deutz Diesel Engine
8.6 Fuel Line Hose Connection - Gm Dual Fuel Engine
8.7 Hydraulic Hose Connection - Base And Axles
8.8 Hydraulic Hose Connection - Turret Grease Fittings
9.0 Optional Equipment
9.1 Air Hose To Platform Option
9.2 Flashing Amber Light Option
9.3 Generator And Oil Cooler Assembly
9.4 Generator Control Valve Assembly
9.5 110v Generator Cable Assembly (Ansi/Csa)
9.6 Generator And Oil Cooler Harnesses
9.7 Generator Wire Assemblies
9.8 Hydraulic Hose Connection - Generator And Oil Cooler
9.9 12 Kw Generator Assembly
9.10 Circuit Breaker Assembly - 12kw Generator
9.11 Generator Wire Assemblies - 12kw Generator
9.12 Hydraulic Hose Connection - 12kw Generator
9.13 Cold Start Engine Assembly
9.14 Arctic Package Assembly
9.15 Welder And Mounting Assembly
9.16 Work Light Assembly
9.17 External Platform Railing Assembly
9.18 Glazier Package Option
9.19 Diesel Scrubber - Deutz Engine
10.0 Labels
10.1 Label Kit
10.2 Labels - Platform Control Console
10.3 Labels - Front And Back
10.4 Labels - Engine Side
10.5 Labels - Controls Side
10.6 Labels - Controls Compartment
10.7 Labels - Engine Compartment
10.8 Labels - Engine Fuel
10.9 Labels - Operator Platform
11.0 Tables
11.1 Boom Fluids Table
11.2 Boom Grease Locations, Turret And Axle Grease Table
11.3 Boom Grease Locations And Gear Grease Table
