118
6,911
Skyjack Telescopic Booms SJ40T SJ45T Parts Manual 160620AL 2023
Brand: Skyjack
Type of Machine: Telescopic Booms
Model: Skyjack SJ40T, SJ45T Telescopic Booms
Serial Number: 98000796 to 98001046
Part Number: 160620AL
Publication Date: 2023
Number of Pages: 230 Pages
Section 1 – Platform
1.1 Railing Assemblies - Side Gate
1.2 Railing Assemblies - Back Gate
1.3 Gate Assembly
1.4 Platform Assembly (Ansi/Csa)
1.5 Platform Assembly (Ce & As)
1.6 Platform Control Console Assembly
1.7 Boom / Turret Controller Assembly (Dual Axis)
1.8 Drive / Steer Controller Assembly (Single Axis)
1.9 Platform Terminal Strip
Section 2 – Boom
2.1 Boom Assembly
2.2 Power Track Carrier Assembly
2.3 Main Boom Turret End Hardware
2.4 Main Boom Platform End Hardware
2.5 Fly Boom Platform End Hardware
2.6 Extension Cylinder Support Assembly
2.7 Valve And Limit Switch Mounting Assembly
2.8 Work And Travel Limit Switch Mounting Assembly (Universal)
2.9 Jib Assembly - Sj 45t
2.10 Rotary Actuator Mounting - Sj 40t
2.11 Rotary Actuator Assembly
2.12 Jib Lift / Platform Rotate Valve Assemblies
Section 3 – Cylinders
3.1 Lift Cylinder Assembly
3.2 Extension Cylinder Assembly
3.3 Master Cylinder Assembly
3.4 Slave Cylinder Assembly
3.5 Jib Cylinder Assembly
3.6 Axle Lockout Cylinder Assembly
Section 4 – Turret
4.1 Cowlings, Mounting Hardware & Counterweight
4.2 Turret Assembly
4.3 Lift Cylinder Bracket Assembly
4.4 High Pressure Filter Assembly
4.5 Turret Swing Drive Assembly
4.6 Axle Lockout Valve Assembly
4.7 Main Boom Pin Assembly
4.8 Main Control Valve Assembly
4.9 Brake Control Valve Assembly
4.10 Rotary Manifold
4.11 Rotary Manifold (With Propane Fittings)
4.12 Hydraulic Tank Assembly
4.13 Fuel Tank Assembly (Gm Dual Fuel Engine)
4.14 Fuel Tank Assembly (Deutz Engine)
4.15 Emergency Power Unit
4.16 Battery Assembly
4.17 Base Control Console Assembly (Deutz Engine)
4.18 Base Control Console Assembly (Gm Dual Fuel Engine)
4.19 Base Terminal Strip
4.20 Charge Pressure Filter Assembly
4.21 No Generator And Oil Cooler Hose Fitting
Section 5 – Electrical Harnesses
5.1 Main Electrical Harness
5.2 Cable Harnesses
5.3 Control Cable Harnesses
5.4 Valve Harnesses And Limit Switch Assemblies
5.5 110/220v Outlet Harness
5.6 Ecu Harnesses
5.7 Glow Plug Harness
5.8 Engine Interface Harness (Gm Engine)
Section 6 – Base
6.1 Base, Axles And Wheels
6.2 Rear Axle With Gear Box
6.3 Differential - Rear Axle
6.4 Central Housing - Rear Axle
6.5 Gear Box - Rear Axle
6.6 Hydraulic Drive Motor
6.7 Brakes - Rear Axle
6.8 Front Axle - 2 Wheel Drive
6.9 Front Axle - 4 Wheel Drive
6.10 Differential - 4wd Front Axle
6.11 Central Housing - 4wd Front Axle
6.12 Steering Assembly
6.13 Trunnion
6.14 Axle Lockout Cylinder Fittings
6.15 Propane Tank Assembly
Section 7 – Engines
7.1 Engine Assembly (Deutz Diesel Engine)
7.2 System Pump Assembly
7.3 Drive Pump Assembly
7.4 Engine Coupling Assembly
7.5 Engine Assembly (Gm Dual Fuel Engine)
Section 8 – Hose Connections
8.1 Standard Hose Numbering System
8.2 Hydraulic Hose Connection - Cylinders
8.3 Hydraulic Hose Connection - Control Compartment
8.4 Hydraulic Hose Connection - Engine Compartment
8.5 Fuel Line Hose Connection - Deutz Diesel Engine
8.6 Fuel Line Hose Connection - Gm Dual Fuel Engine
8.7 Hydraulic Hose Connection - Base And Axles
8.8 Hydraulic Hose Connection - Turret Grease Fittings
Section 9 – Optional Equipment
9.1 Air Hose To Platform Option
9.2 Flashing Amber Light Option
9.3 Generator And Oil Cooler Assembly
9.4 Generator Control Valve Assembly
9.5 110v Generator Cable Assembly (Ansi/Csa)
9.6 Generator And Oil Cooler Harnesses
9.7 Generator Wire Assemblies
9.8 Hydraulic Hose Connection - Generator And Oil Cooler
9.9 12 Kw Generator Assembly
9.10 Circuit Breaker Assembly - 12kw Generator
9.11 Generator Wire Assemblies - 12kw Generator
9.12 Hydraulic Hose Connection - 12kw Generator
9.13 Cold Start Engine Assembly
9.14 Arctic Package Assembly
9.15 Arctic Rotary Actuator Assembly
9.16 Work Light Assembly
9.17 Welder And Mounting Assembly
9.18 External Platform Railing Assembly
9.19 Diesel Scrubber - Deutz Engine
9.20 Glazier Package Option
Section 10 – Labels
10.1 Label Kit
10.2 Labels - Platform Control Console
10.3 Labels - Front And Back
10.4 Labels - Engine Side
10.5 Labels - Controls Side
10.6 Labels - Controls Compartment
10.7 Labels - Engine Compartment
10.8 Labels - Engine Fuel
10.9 Labels - Operator Platform
Section 11 – Tables
11.1 Boom Fluids Table
11.2 Boom Grease Locations, Turret and Axle Grease Table
11.3 Boom Grease Locations and Gear Grease Table
