118
6,911
Skyjack Telescopic Booms SJ40T SJ45T Parts Manual 143843AQ 2022
Brand: Skyjack
Type of Machine: Telescopic Booms
Model: Skyjack SJ40T, SJ45T Telescopic Booms
Serial Number: 98000001 to 98000795
Part Number: 143843AQ
Publication Date: 2022
Number of Pages: 260 Pages
Section 1 – Platform
1.1 Railings - Side Gate
1.2 Railings - Rear Gate
1.3 Gate
1.4 Platform Terminal Strip
1.5 Platform Assembly (Ansi/Csa)
1.6 Platform Assembly (Ce & As)
1.7 Platform Control Console - Sj40t S/N 98000521 & Below And All Sj45t
1.8 Platform Control Console - Sj40t S/N 98000522 & Above
1.9 Boom / Turret Controller Assembly (Dual Axis)
1.10 Drive / Steer Controller Assembly (Single Axis)
Section 2 – Boom
2.1 Boom Assembly
2.2 Power Track Carrier Assembly
2.3 Main Boom Turret End Hardware
2.4 Main Boom Platform End Hardware
2.5 Fly Boom Platform End Hardware
2.6 Extension Cylinder Support Assembly
2.7 Valve And Limit Switch Mounting Assembly
2.8 Work And Travel Limit Switch Mounting Assembly (Universal)
2.9 Jib Assembly - Sj45t With S/N 98000613 & Above
2.10 Jib Assembly - Sj45t With S/N 98000612 & Below
2.11 Rotary Actuator Mounting - Sj40t
2.12 Rotary Actuator Assembly
2.13 Jib Lift / Platform Rotate Valve Assemblies
Section 3 – Cylinders
3.1 Lift Cylinder
3.2 Extension Cylinder
3.3 Master Cylinder
3.4 Slave Cylinder
3.5 Jib Cylinder
3.6 Axle Lockout Cylinder
Section 4 – Turret
4.1 Cowlings, Mounting Hardware & Counterweight
4.2 Turret Assembly
4.3 Lift Cylinder Bracket - S/N 98 000 535 & Below
4.4 Lift Cylinder Bracket - S/N 98 000 536 & Above
4.5 High Pressure Filter
4.6 Turret Swing Drive
4.7 Axle Lockout Valve
4.8 Main Boom Pin Assembly
4.9 Main Mainfold
4.10 Brake Manifold
4.11 Rotary Manifold - S/N 98 000 621 & Below
4.12 Rotary Manifold - S/N 98 000 622 & Above
4.13 Propane Fittings
4.14 Emergency Power Unit
4.15 Hydraulic Tank
4.16 Fuel Tank - Gasoline
4.17 Fuel Tank - Diesel
4.18 Battery Assembly
4.19 Base Control Console - Deutz With External Tilt Switch
4.20 Base Control Console - Deutz With Internal Tilt Switch
4.21 Base Control Console - Gm With External Tilt Switch
4.22 Base Control Console - Gm With Internal Tilt Switch
4.23 Base Terminal Strip
4.24 Charge Pressure Filter
4.25 No Generator And Oil Cooler Hose Fitting
Section 5 – Electrical Harnesses
5.1 Main Electrical Harness
5.2 Cable Harnesses
5.3 Control Cable Harnesses
5.4 Valve Harnesses And Limit Switch Assemblies
5.5 110/220v Outlet Harness
5.6 Ecu Harnesses
5.7 Glow Plug Harness
5.8 Engine Interface Harness (Gm Engine)
Section 6 – Base
6.1 Base, Axles And Wheels
6.2 Rear Axle
6.3 Differential - Rear Axle
6.4 Central Housing - Rear Axle
6.5 Gear Box - Rear Axle
6.6 Brakes - Rear Axle
6.7 Front Axle (2 Wheel Drive)
6.8 Front Axle (4 Wheel Drive)
6.9 Differential - Front Axle
6.10 Central Housing - Front Axle
6.11 Steering Assembly
6.12 Trunnion Assembly
6.13 Axle Lockout Cylinder Fittings
6.14 Propane Tank Assembly
6.15 Hydraulic Drive Motor
Section 7 – Engines
7.1 Engine Assembly - Deutz Diesel
7.2 System Pump
7.3 Drive Pump
7.4 Engine Coupling - S/N 98 000 413 & Above
7.5 Engine Coupling - S/N 98 000 412 & Below
7.6 Engine Assembly - Gm Dual Fuel
Section 8 – Hydraulic Hoses & Fuel Lines
8.1 Standard Hose Numbering System
8.2 Hydraulic Hoses - Cylinders
8.3 Hydraulic Hoses - Control Compartment - S/N 98 000 585 & Above
8.4 Hydraulic Hoses - Control Compartment - S/N 98 000 584 & Below
8.5 Hydraulic Hoses - Engine Compartment
8.6 Hydraulic Hoses - Base And Axles
8.7 Fuel Lines - Deutz Diesel Engine
8.8 Fuel Lines - Gm Dual Fuel Engine
8.9 Turret Grease Lines
Section 9 – Optional Equipment
9.1 Flashing Amber Light
9.2 Generator And Oil Cooler Assembly
9.3 Generator Control Valve
9.4 110v Generator Cable (Ansi/Csa)
9.5 Generator And Oil Cooler Harnesses
9.6 Generator Wire Assemblies
9.7 Hydraulic Hoses - 3.5 Kw Generator And Oil Cooler
9.8 12 Kw Generator Assembly
9.9 Circuit Breaker Assembly - 12kw Generator
9.10 Generator Wire Assemblies - 12kw Generator
9.11 Hydraulic Hoses - 12kw Generator
9.12 Cold Start
9.13 Arctic Package
9.14 Arctic Rotary Actuator
9.15 Work Light
9.16 Welder And Mount
9.17 Air Hose To Platform
9.18 Diesel Scrubber - Deutz Engine
9.19 Glazier Package
Section 10 – Labels
10.1 Label Kit
10.2 Labels - Front And Back
10.3 Labels - Platform Control Console Sj40t S/N 98 000 521 & Below And All Sj45t
10.4 Labels - Platform Control Console Sj40t S/N 98 000 522 & Above
10.5 Labels - Engine Side
10.6 Labels - Control Side
10.7 Labels - Engine Compartment
10.8 Labels - Control Compartment
10.9 Labels - Platform
10.10 Labels - Engine Fuel
Section 11 – Fluids
11.1 Fluids Table
11.2 Turret And Axle Grease
11.3 Gear Grease
