118
6,911
Skyjack Telehandler ZB2044 Parts Manual 207052AA 2023
Brand: Skyjack
Type of Machine: Telehandler
Model: Skyjack ZB2044 Telehandler
Serial Number: 85800118 and Above
Part Number: 207052AA
Publication Date: 2023
Number of Pages: 272 Pages
1.0 Engine Tier Specific Parts
1.1 Engine (Tier 4f) And Transmission Assembly (T3200)
1.2 Engine (Tier 4f) And Transmission Assembly (T14)
1.3 Engine (Tier 3) And Transmission Assembly (T14)
1.4 Engine Assembly
1.5 Fuel Lines Assembly
1.6 Engine Exhaust Assembly
1.7 Aftertreatment Assembly
1.8 Def Tank Assembly
1.9 Air Intake Assembly
1.10 Cooling System Assembly - Tier 4f
1.11 Cooling System Assembly - Tier 3
1.12 Cooler Assembly
1.13 Coolant Lines Assembly
1.14 Sheet Metal Assembly
1.15 Crankcase Ventilation Assembly
1.16 Cab Heater Assembly
1.17 Air Conditioner And Electric Condenser Assembly
1.18 Air Conditioner And Electric Condenser Assembly (Continued)
1.19 Fuel Tank Assembly
1.20 Battery Disconnect Switch Assembly
1.21 Cab Harness
1.22 Junction Box
1.23 Main Wiring Harness
1.24 Engine Harness
1.25 Grid Heater Harness
1.26 Ground Harnesses
2.0 Axles
2.1 Front Axle And Frame Level Cylinders
2.2 Rear Axle And Axle Lock Cylinders
2.3 Front And Rear Drive Shafts Assembly
2.4 Front And Rear Drive Shafts Assembly (T14 Transmission)
3.0 Frame And Cab Related Parts
3.1 Frame Assembly
3.2 Outriggers Assembly
3.3 Hydraulic Oil Tank Assembly
3.4 Mirror Mount Assembly
3.5 Wheel Assembly
3.6 Cab Installation
3.7 Standard Cab Group
3.8 Instrument Panel Assembly
3.9 Steering Wheel Assembly
3.10 Seat Box Assembly
3.11 Seat Assembly
4.0 Valves And Manifolds Related Parts
4.1 Main Valve Assembly
4.2 Priority Valve Assembly
4.3 Brake Valve Assembly
4.4 Return Manifold Assembly
4.5 Brake Charge Valve Assembly
4.6 Steering Function Valve Assembly
4.7 Steering Motor Assembly
4.8 Charge Accumulators Assembly
4.9 Dual Charge Brake Pedal Assembly
4.10 Axle Lock Valve Assembly
4.11 Frame Level Control Valve Assembly
4.12 Diverter Valve Assembly
4.13 Front Joystick Controller Assembly
4.14 Rear Joystick Controller Assembly
4.15 Throttle Pedal Assembly
4.16 Main Valve Block Assembly
4.17 Service Brake Tee Assembly
4.18 Service Brake Tee Assembly
5.0 Booms Assembly Related Parts
5.1 Booms Assembly
5.2 Main Boom Assembly
5.3 Primary Boom Assembly
5.4 Secondary Boom Assembly
5.5 Boom Cylinders Assembly
6.0 Attachments Related Parts
6.1 Standard Carriage Assembly
6.2 Fork Positioner Carriage Assembly
6.3 Fork Positioner/Side Shift Q.D. Carriage Assembly
6.4 72” Service Fork Positioner/Side Shift Carriage Assembly
6.5 Integral Fork Positioner/Side Shift Carriage Assembly
6.6 Bridge Stripper Assembly
6.7 Pipe And Pole Grappler Assembly
6.8 Winch Attachment Assembly
6.9 Jib Boom Attachment
6.10 Bucket Attachment
6.11 51” Coil Ram Attachment
7.0 Hydraulic Hose Connection Related Parts
7.1 Main Hydraulics System
7.2 Steering System
7.3 Service Brakes Hydraulic System
7.4 Main Valve - Pilot Control
7.5 Boom Lift System
7.6 Frame Level System
7.7 Rear Axle Lock System
7.8 Carriage Tilt And Slave Cylinders System
7.9 Boom Extension System
7.10 Outriggers System
7.11 Standard Auxiliary Hydraulics System
7.12 Optional Auxiliary Hydraulics System
8.0 Electrical Harness Related Parts
8.1 Instrumental Panel Wiring
8.2 Fuse Block Assembly
8.3 Transmission Disconnect And Shifter Harnesses
8.4 3-Speed Shifter Harness
8.5 Frame Level And Axle Lock Harnesses
8.6 Steering And Brakes Harnesses
8.7 Outrigger Raise/Lower Harness
8.8 Diverter Valve Harness
8.9 Open Cab Power Module (Aux. Hyd.)
8.10 Open Cab Power Module (Aux. Hyd. - Head/Tail/Stop Lights)
8.11 Open Cab Power Module (Aux. Hyd. - Head/Tail/Stop/Boom/Aux. Lights)
8.12 Enclosed Cab Power Module (Aux. Hyd.)
8.13 Enclosed Cab Power Module (Aux. Hyd. - A/C - Head/Tail/Stop Lights)
8.14 Enclosed Cab Power Module (Aux. Hyd. - Head/Tail/Stop Lights)
8.15 Enclosed Cab Power Module (Aux. Hyd. - Head/Tail/Stop/Boom/Aux. Lights)
8.16 Front Joystick Harness
8.17 Rear Joystick Harness
8.18 Horn / Fuel / Brake Pressure Switch Harness
8.19 T14 Transmission Harness
9.0 Optional Equipment Related Parts
9.1 Light Installation Group
9.2 Lighting Harness
9.3 Enclosed Cab Group
9.4 Pop-Out Window Assembly
9.5 Enclosed Cab Interior
9.6 Wiper Group
9.7 Fan And Light Attachment
9.8 Boom Lights Assembly
9.9 Pintle Hook Assembly
9.10 Fenders Assembly
9.11 Mud Flaps Assembly
9.12 Air Intake Shutoff
9.13 Harness Air Intake Shutoff
9.14 Mine Spec - Fuel Tank Assembly
9.15 Mine Spec. - Instrument Panel Assembly
9.16 Block Heater
9.17 Mine Spec. - Brakes Harness
9.18 Mine Spec. - Pressure Switches Harness
9.19 Mine Spec. - Steering Accumulator Harness
9.20 Backup Camera And Sensor
9.21 Reverse Warning System Harness
9.22 Elevate Telematics
9.23 Elevate Telematics Harness
9.24 Back-Up Alarm
9.25 White Noise Alarm
10.0 Labels And Nameplates
10.1 Model Specific Labels
10.2 Pictorial Labels
10.3 Cab And Control Labels
10.4 Load Charts Group
11.0 Recommended Fluids Table
11.1 Recommended Fluids Table
