Skyjack Telehandler ZB2044 Parts Manual 161849AB 2014
Brand: Skyjack
Type of Machine: Telehandler
Model: Skyjack ZB2044 Telehandler
Serial Number: 85800073 and Above
Part Number: 161849AB
Publication Date: 2014
Number of Pages: 252 Pages
1.0 Engine Tier Specific Parts
1.1 Engine And Transmission Assembly - Tier 4i
1.2 Engine Assembly - Tier 4i
1.3 Engine And Transmission Assembly - Tier 3
1.4 Engine Exhaust Assembly - Tier 4i
1.5 Engine Exhaust Assembly - Tier 3
1.6 Air Intake Assembly - Tier 4i
1.7 Air Intake Assembly - Tier 3
1.8 Cooling System Assembly - Tier 4i
1.9 Cooler Assembly - Tier 4i
1.10 Cooling System Assembly - Tier 3
1.11 Sheet Metal Assembly - Tier 4i
1.12 Sheet Metal Assembly - Tier 3
1.13 Crankcase Ventilation Assembly - Tier 4
1.14 Cab Heater Assembly - Tier 4i
1.15 Cab Heater Assembly - Tier 3
1.16 Air Conditioner And Electric Condenser Assembly - Tier 4i
1.17 Air Conditioner And Electric Condenser Assembly - Tier 3
1.18 Fuel Tank Assembly - Tier 4i
1.19 Fuel Tank Assembly - Tier 3
1.20 Dual Batteries Assembly - Tier 4i
1.21 Dual Batteries Assembly - Tier 3
1.22 Cab Harness - Tier 4i
1.21 Cab Harness - Tier 3
1.22 Junction Box - Tier 4i
1.23 Junction Box - Tier 3
1.24 Main Wiring Harness - Tier 4i
1.25 Main Wiring Harness - Tier 3
1.26 Engine Harness - Tier 4i
1.27 Engine Harness - Tier 3
1.28 Grid Heater Harness - Tier 4i
1.29 Grid Heater Harness - Tier 3
1.30 Block Stud To Starter Harness - Tier 4i
2.0 Engine And Transmission Related Parts
2.1 Front Axle And Frame Level Cylinders
2.2 Rear Axle And Axle Lock Cylinders
2.3 Front And Rear Drive Shafts Assembly
3.0 Frame And Cab Related Parts
3.1 Frame Assembly
3.2 Outriggers Assembly
3.3 Hydraulic Oil Tank Assembly
3.4 Mirror Mount Assembly
3.5 Wheel Assembly
3.6 Cab Installation
3.7 Standard Cab Group
3.8 Instrument Panel Assembly
3.9 Steering Wheel Assembly
3.10 Seat Box Assembly
3.11 Seat Assembly
4.0 Valves And Manifolds Related Parts
4.1 Main Valve Assembly
4.2 Priority Valve Assembly
4.3 Brake Valve Assembly
4.4 Return Manifold Assembly
4.5 Brake Charge Valve Assembly
4.6 Steering Function Valve Assembly
4.7 Steering Motor Assembly
4.8 Charge Accumulators Assembly
4.9 Dual Charge Brake Pedal Assembly
4.10 Axle Lock Valve Assembly
4.11 Frame Level Control Valve Assembly
4.12 Diverter Valve Assembly
4.13 Front Joystick Controller Assembly
4.14 Rear Joystick Controller Assembly
4.15 Throttle Pedal Assembly
5.0 Booms Assembly Related Parts
5.1 Main Boom Assembly
5.2 Primary Boom Assembly
5.3 Secondary Boom Assembly
5.4 Booms Assembly
5.5 Boom Cylinders Assembly
6.0 Attachments Related Parts
6.1 Standard Carriage Assembly
6.2 Fork Positioner Carriage Assembly
6.3 Fork Positioner/Side Shift Q.D. Carriage Assembly
6.4 72” Service Fork Positioner/Side Shift Carriage Assembly
6.5 Integral Fork Positioner/Side Shift Carriage Assembly
6.6 Bridge Stripper Assembly
6.7 Pipe And Pole Grappler Assembly
6.8 Winch Attachment Assembly
6.9 Jib Boom Attachment
6.10 Bucket Attachment
6.11 51” Coil Ram Attachment
7.0 Hydraulic Hose Connection Related Parts
7.1 Main Hydraulics System
7.2 Steering System
7.3 Service Brakes Hydraulic System
7.4 Main Valve - Pilot Control
7.5 Boom Lift System
7.6 Frame Level System
7.7 Rear Axle Lock System
7.8 Carriage Tilt And Slave Cylinders System
7.9 Boom Extension System
7.10 Outriggers System
7.11 Standard Auxiliary Hydraulics System
7.12 Optional Auxiliary Hydraulics System
8.0 Electrical Harness Related Parts
8.1 Transmission Disconnect And Shifter Harnesses
8.2 3-Speed Shifter Harness
8.3 Frame Level And Axle Lock Harnesses
8.4 Steering And Brakes Harnesses
8.5 Outrigger Raise/Lower Harness
8.6 Diverter Valve Harness
8.7 Open Cab Power Module (Aux. Hyd.)
8.8 Open Cab Power Module (Aux. Hyd. - Head/Tail/Stop Lights)
8.9 Open Cab Power Module (Aux. Hyd. - Head/Tail/Stop/Boom/Aux. Lights)
8.10 Enclosed Cab Power Module (Aux. Hyd.)
8.11 Enclosed Cab Power Module (Aux. Hyd. - A/C - Head/Tail/Stop Lights)
8.12 Enclosed Cab Power Module (Aux. Hyd. - Head/Tail/Stop Lights)
8.13 Enclosed Cab Power Module (Aux. Hyd. - Head/Tail/Stop/Boom/Aux. Lights)
8.14 Front Joystick Harness
8.15 Rear Joystick Harness
8.16 Horn / Fuel / Brake Pressure Switch Harness
9.0 Optional Equipment Related Parts
9.1 Light Installation Group
9.2 Lighting Harness
9.3 Enclosed Cab Group
9.4 Pop-Out Window Assembly
9.5 Enclosed Cab Interior
9.6 Wiper Group
9.7 Fan And Light Attachment
9.8 Boom Lights Assembly
9.9 Pintle Hook Assembly
9.10 Fenders Assembly
9.11 Mud Flaps Assembly
9.12 Battery Disconnect Switch Assembly
9.13 Mine Spec. - Instrument Panel Assembly
9.14 Mine Spec. - Brakes Harness
9.15 Mine Spec. - Pressure Switches Harness
9.16 Positive Air Shutoff
9.17 Mine Spec. - Steering Accumulator Harness
10.0 Labels And Nameplates
10.1 Operator Cab And Dash Panel Labels
10.2 Cab And Front Side Labels
10.3 Tank And Back Side Labels
11.0 Recommended Fluids Table
11.1 Recommended Fluids Table
Brand: Skyjack
3.1 Frame Assembly
3.5 Wheel Assembly
3.11 Seat Assembly
5.4 Booms Assembly
7.2 Steering System
9.6 Wiper Group
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
