118
6,911
Skyjack Telehandler SJ519TH Parts Manual 216941AD 2023
Brand: Skyjack
Type of Machine: Telehandler
Model: Skyjack SJ519TH Telehandler
Serial Number: 87500000 to 87599999
Part Number: 216941AD
Publication Date: 2023
Number of Pages: 253 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Section 1 – Main Frame
1.1 Frame
1.2 Cowling
1.3 Fuel Tank
1.4 Hydraulic Tank
1.5 Rear Hitch
Section 2 – Axles
2.1 Front Axle
2.2 Front Axle - Differential
2.3 Front Axle - Hub Reduction
2.4 Front Axle - Central Housing
2.5 Front Axle - Hub Reduction
2.6 Front Axle - Brakes
2.7 Rear Axle
2.8 Rear Axle Housing
2.9 Rear Axle - Differential
2.10 Rear Axle - Hub Reduction
2.11 Rear Axle - Hub Reduction
2.12 Rear Axle - Steering
2.13 Rear Axle - Trunion
2.14 Drive Shaft
2.15 Tire and Wheel Assembly
Section 3 – Engine
3.1 Engine Tray
3.2 Engine Tray
3.3 Engine Assembly
3.4 Cooler
3.5 Cooler
3.6 Cooler - Internal Breakdown
3.7 Cooler Hoses
3.8 Air Intake
3.9 Air Intake
3.10 Air Intake Cover
3.11 Hydraulic Pump (Piston Drive)
3.12 Hydraulic Pump (Variable Displacement)
3.13 Fuel Lines
Section 4 – Operator's Cab
4.1 Cab Assembly
4.2 Open Cab
4.3 Open Cab Components
4.4 Steering Column
4.5 Orbital Steering Motor
4.6 Joystick
4.7 Proportional Flow Control Valve
4.8 Front Dash
4.9 Right Hand Dash Panel
4.10 Left Hand Dash Panel
4.11 Relay Bracket
4.12 Brake and Throttle Pedals
4.13 Enclosed Cab
4.14 Cab Door
4.15 Heater Unit Components
4.16 Heater Lines
Section 5 – Electrical
5.1 Glow Plug Harness
5.2 Console Harness
5.3 Engine Harness
5.4 Battery Cables
5.5 A/C Option Harness
Section 6 – Boom
6.1 Boom Components
6.2 Boom Components
6.3 Boom Sub-carriage
Section 7 – Cylinders
7.1 Fork Tilt Cylinder
7.2 Lift Cylinder
7.3 Extend Cylinder
7.4 Tilt Compensation Cylinder
7.5 Quick Attach Cylinder
Section 8 – Hydraulics
8.1 Standard Hose Numbering System
8.2 Main Manifold Assembly
8.3 Main Manifold
8.4 Main Manifold Components
8.5 Pilot Manifold
8.6 Pilot Manifold Components
8.7 Steer Valve Assembly
8.8 Steer Valve
8.9 Hydraulic Filters
8.10 Hydraulic Hoses - Cylinders
8.11 Drive and System Pump Hoses
8.12 Drive and System Pump Hoses
8.13 Drive and System Pump Hoses
8.14 Steer and Brake Hoses
8.15 Hydraulic Tank Oil Fill
8.16 Pilot Manifold Hoses
8.17 Cab Hydraulic Hoses
Section 9 – Standard and Optional Attachments
9.1 Mechanical Quick Coupler
9.2 Hydraulic Quick Coupler
9.3 Standard Carriage
9.4 Side Tilt Carriage
9.5 Side Shift Carriage
9.6 Forks
9.7 Skid Steer Adapter
9.8 72'' Trust Boom
9.9 1/2 Cubic Yard Bucket
Section 10 – Factory Options
10.1 Road Lights
10.2 Boom and Work Lights
10.3 Work Lights
10.4 Beacon Light
10.5 Four Wheel Fenders
10.6 Backup Camera and Sensor
10.7 Backup Sensor
10.8 Potentiometer
10.9 Positive Air Shutoff
10.10 Air Conditioner
10.11 Air Conditioner Harness
10.12 A/C Compressor
10.13 A/C Condensor
10.14 Fire Extinguisher Bracket
10.15 Service Convenience Kit
10.16 Cold Weather Package
Section 11 – Labels
11.1 Model Specific Labels
11.2 Pictorial Labels Layout
11.3 Cab Labels Layout
11.4 Load Charts Group
Section 12 – Tables
12.1 Recommended Fluids
